  3. MYSBootloader 1.3pre2 testing
otamyscontrollermysbootloader
73 Posts 25 Posters 41.0k Views 31 Watching
  • M mannkind
    [[topic:post-is-deleted]]
    jmkhaelJ
    jmkhaelJ
    jmkhael
    @mannkind thank you for your reply. I don't want to get you in trouble regarding the rules. i don't feel it is against the rules to promote open source or contribution around mysensors if it makes the journey more enjoyable. maybe a mod or admin can pitch in and clarify in any case.
    I understand that the gateway role is to open up integration with other controllers (and we have quite many thanks to that)
    The problem i am trying to wrap my head around is to have mysensors network attached to my current controller, and ideally be able to update over the air the sketches. how can i begin doing that? i am ready to use 2 or more controller (mycontroller or myscontroller or...), 2 ore more gateways and even maybe have the nodes on two different rf channels.
    Basically, what is the recommended way to achieve that, while having for the time being at least, another controller attached.?
    • Velo17V
      Velo17V
      Velo17
      Hello! Will there be a chance to change the radio channel used for the bootloader OTA process?
      • jmkhaelJ
        jmkhaelJ
        jmkhael
        wrote on last edited by jmkhael
        @mannkind : thank you for your message. I'll give that a go later on.
        @tekka , @anyone :)
        I am trying to make this work using MYSController (from MYSBootloader_V13pre2/). I've followed the instructions above from @tekka, but it feels like the OTA process kicks around quite quick, then it seems to block in a loop
         [2016-10-17 23:09:29.821 Info] RX	1;255;4;0;0;0A0001005000D4460102
         [2016-10-17 23:09:29.821 Info] INFO	BL version=258
         [2016-10-17 23:09:29.821 Info] INFO	Send FW info to node 1: type=A, version=1, blocks=0x0050, CRC=0x46D4
         [2016-10-17 23:09:29.822 Info] TX	1;0;4;0;1;0A0001005000D446
        I'll try to keep it going all night, but here are my full log till now.
        Any idea what is going wrong?
        0_1476738954886_MySensors_20161017-230018.log
        M tekkaT 2 Replies Last reply
        • jmkhaelJ jmkhael
          @tekka , @anyone :)
          mannkind
          • jmkhaelJ jmkhael
            @tekka , @anyone :)
            tekkaT
            tekkaT
            tekka
            @jmkhael Looks like a bad radio connection (GW too close / far, interference, power) What happens if you upload the FW via serial link?
            jmkhaelJ 1 Reply Last reply
            • tekkaT tekka
              jmkhaelJ
              jmkhaelJ
              jmkhael
              @mannkind : thanks for the clarifications. My problem is that the node seems to hang at the booting phase in MYSController sa per the screenshot.
              @tekka that should be it (gw in the 50 cm range). I'll try more tests and get back here in any case.
              @mannkind, @tekka: How do we interpret the OTA logs?
              • jmkhaelJ jmkhael
                jmkhaelJ
                jmkhaelJ
                jmkhael
                @tekka: it was probably a mix of power/distance. when change these two parameters, OTA went fine. thank you
                What is the best way to handle OTA for sleeping nodes? is there something else todo besides setting the property under settings in MYSController? Do I need to powercycle the node or will MYSController kicks in when the node sleeps/smartSleeps?
                thank you for your time
                tekkaT 1 Reply Last reply
                • jmkhaelJ jmkhael
                  tekkaT
                  tekkaT
                  tekka
                  @jmkhael MYSController will reboot the node as soon as it wakes up, sends and processes incoming messages.
                  • tekkaT tekka
                    jmkhaelJ
                    jmkhaelJ
                    jmkhael
                    @tekka my node wakes up every two minutes (or on pir movement) sends some messages (temperature, light level...) and sleeps right away. will MYSController be able to do that in this small time window? is there something i can code to help it? (heartBeat, wait, smartSomething?)
                    (as i saw during my few tests, i had to powercycle my node, maybe i wasn't patient enough :))
                    • jmkhaelJ jmkhael
                      tekkaT
                      tekkaT
                      tekka
                      @jmkhael place smartSleep() instead of sleep(), before sending any values to the controller - MYSController will pick this up and send a reboot command. Also, you need to mark the node as battery-powered/sleeping node...
                      • JCLBJ
                        JCLBJ
                        JCLB
                        wrote on last edited by JCLB
                        #23
                        Just tried with this release, works great (had no problem with previous release)
                        The only drawback is the packet bitrate, around 40 per minute with 45 bytes each.
                        It takes 1h to flash a node. few minutes, just make sure of your wiring as this is a very intensive process compared to node's standard radio use.
                        Here is a flash running on a test network:
                        snip
                        Can we update many nodes at the same time ? haven't tried
                        • JCLBJ JCLB
                          snip
                          tekkaT
                          tekkaT
                          tekka
                          @JCLB This is unusual. A regular sketch ~20kB takes ~2mins. Maybe you are having issues with power supply, bad clones, or other sources of interference.
                          • JCLBJ
                            JCLBJ
                            JCLB
                            #25
                            I can now gets dozen of packets at once, then hold, continues...depending of how I press the wires on radio side :sweat:
                            It's a wiring problem, will try this weekend with a soldered node.
                            Thank you
                            • JCLBJ JCLB
                              Thank you
                              tekkaT
                              tekkaT
                              tekka
                              @JCLB Thanks for reporting, I'm using short dupont cables or have the radio fixed on a PCB.
                              • kk02067K
                                kk02067K
                                kk02067
                                I have also problem with speed of the upload. I get about 1 packet per 3 seconds. Is there a something in the code for the bootloader that has a waitingtime of 3 seconds? And if so, because of what? From that info we might be able to tell if it's a reception problem of the node or the gateway.
                                • pkuP
                                  pkuP
                                  pku
                                  @tekka Thank you for great job on MYSBootloader. It works fine for me. Currently I'm testing it and have few questions.
                                  • Please can you provide source code? Maybe then I can answer my questions myself :)
                                  • Software signing doesn't work after firmware is uploaded. EEPROM is cleared. Is it possible to restore shared key HMAC after firmware is stored?
                                  • Is possible to send firmware with signing to prevent loading from fake gateway? I thing signing of available firmware version and firmware CRC is enough ..?
                                  Thank you for answers.
                                  JCLBJ 1 Reply Last reply
                                  • NiklasON
                                    NiklasON
                                    NiklasO
                                    wrote on last edited by NiklasO
                                    #29
                                    I have changed the fuse settings for my setup. I don't know if it makes any difference but there is a fuse for "Preserve EEPROM memory through the Chip Erase cycle". Was noticing that my sensors was getting a new id every time I did some changes in my sketches and flashed using "Upload with programmer". I have not succeeded with OTA flashing yet.
                                    I also use the external crystal present on the Pro Mini. Using 0xFF, 0xD2 and 0xFE.
                                    Probably only used when programming using ICSP.
                                    MYSBL13.menu.cpu.8MHzatmega328=ATmega328 8MHz (XTAL, BOD1V8)
                                    MYSBL13.menu.cpu.8MHzatmega328.upload.maximum_size=30720
                                    MYSBL13.menu.cpu.8MHzatmega328.upload.maximum_data_size=2048
                                    MYSBL13.menu.cpu.8MHzatmega328.upload.speed=38400
                                    MYSBL13.menu.cpu.8MHzatmega328.bootloader.low_fuses=0xFF
                                    MYSBL13.menu.cpu.8MHzatmega328.bootloader.high_fuses=0xD2
                                    MYSBL13.menu.cpu.8MHzatmega328.bootloader.extended_fuses=0xFE
                                    MYSBL13.menu.cpu.8MHzatmega328.bootloader.file=MYSBootloader/MYSBL13pre_atmega328_8Mhz.hex
                                    MYSBL13.menu.cpu.8MHzatmega328.build.mcu=atmega328p
                                    MYSBL13.menu.cpu.8MHzatmega328.build.f_cpu=8000000L
                                    pkuP 1 Reply Last reply
                                    • NiklasON NiklasO
                                      pkuP
                                      pkuP
                                      pku
                                      @NiklasO I'm using Arduino Mini 5V, 16Mhz with fuses as you have. Except BODLEVEL 2.7V and EEPROM Cleared. OTA works fine, 21kB hex file is sent in cca 2-5 minutes (very depends on count of wrong packets, without 47uF capacitor on NRF24 or with low power supply it takes about 2 hours :) ). I started with MYSController and small and easy Blink.ino.hex from MYSController distribution. Now I use MyController and own firmwares...
                                      • pkuP pku
                                        JCLBJ
                                        JCLBJ
                                        JCLB
                                        @pku if your keys are in the sketch everything will work for signing.
                                        #define MY_SOFT_HMAC_KEY XXX... //signing key
                                        #define MY_AES_KEY XXX... // if you use encryption
                                        Of course if you want to use whitelisting then you need to compile each node sketch separately with it's serial.
                                        @NiklasO
                                        Personally I set the node ID manually to avoid this
                                        #define MY_NODE_ID 30 // Sets a static id for a node
                                        And I group tens so all my 3X nodes are in kitchen, 4X in office, 11X in bedroom 1 and so on.
                                        I would love to see a proxy mode in MYSController, in order to interface between a controller that doesn't support OTA and an Ethernet gateway :heart_eyes:
                                        Let say your LAN is the following:
                                        • MySensors gateway 192.168.0.1
                                        • controller (raspberry + Domoticz or else) 192.168.0.2
                                        • PC with MYSController 192.168.0.3
                                        Whenever you need to update a node, you launch MYSController but don't connect to the gateway, then you tells Domoticz .2 to connect to MYSController .3 instead of the gateway .1, at this point MYSController starts relaying everything between Domoticz and the gateway + provides you the ability to update a node.
                                        When you want to get back to normal operations, you set back 192.168.0.1 on Domoticz, MYSController receives a TCP reset and ends it's session with Domoticz and stop the session with the gateway.
                                        We would get a minimum downtime and can could use MYSController to update nodes and debug traffic while letting the normal controller...controlling
                                        NiklasON AndurilA 2 Replies Last reply
                                        • JCLBJ JCLB
                                          @NiklasO
                                          NiklasON
                                          NiklasON
                                          NiklasO
                                          @NiklasO
                                          Ah, yes. Setting static id sound like a solution to my problem. Thanks.
