  3. MYSBootloader 1.3pre2 testing
otamyscontrollermysbootloader
73 Posts 25 Posters 41.0k Views 31 Watching
    mannkind
    wrote on last edited by mannkind
    jmkhaelJ 1 Reply Last reply
    • tekkaT tekka
      @NiklasO you can use the internal RC oscillator (that is 8Mhz), no need to use external XTAL. For AVR fuse calculator, refer to http://www.engbedded.com/fusecalc/ or http://eleccelerator.com/fusecalc/fusecalc.php?chip=atmega328p and the documentation therein.
      NiklasON
      NiklasON
      NiklasO
      wrote on last edited by NiklasO
      I don't understand the fusecalc yet. I don't know all the terms used on that calc page or how it really works but I'm learning I guess. ;) The Pro Mini clones i got from eBay has this extremely small external 8 MHz (for 3.3V) and 16MHz (for 5V) crystal/oscillator/resonator or what they are called. Why is it there if not needed? Genuine interested here.
        So, I gather there is no RFM69 version?
        • M mannkind
          [[topic:post-is-deleted]]
          jmkhaelJ
          jmkhaelJ
          jmkhael
          @mannkind what other software do you use for ota firmware update?
          thanks
            Not getting an answer here. Should I be asking the question somewhere else?
            • jmkhaelJ jmkhael
              thanks
              mannkind
              • M mannkind
                jmkhaelJ
                jmkhaelJ
                jmkhael
                @mannkind thank you for your reply. I don't want to get you in trouble regarding the rules. i don't feel it is against the rules to promote open source or contribution around mysensors if it makes the journey more enjoyable. maybe a mod or admin can pitch in and clarify in any case.
                I understand that the gateway role is to open up integration with other controllers (and we have quite many thanks to that)
                The problem i am trying to wrap my head around is to have mysensors network attached to my current controller, and ideally be able to update over the air the sketches. how can i begin doing that? i am ready to use 2 or more controller (mycontroller or myscontroller or...), 2 ore more gateways and even maybe have the nodes on two different rf channels.
                Basically, what is the recommended way to achieve that, while having for the time being at least, another controller attached.?
                • Velo17V
                  Velo17V
                  Velo17
                  Hello! Will there be a chance to change the radio channel used for the bootloader OTA process?
                  • jmkhaelJ
                    jmkhaelJ
                    jmkhael
                    wrote on last edited by jmkhael
                    @mannkind : thank you for your message. I'll give that a go later on.
                    @tekka , @anyone :)
                    I am trying to make this work using MYSController (from MYSBootloader_V13pre2/). I've followed the instructions above from @tekka, but it feels like the OTA process kicks around quite quick, then it seems to block in a loop
                     [2016-10-17 23:09:29.821 Info] RX	1;255;4;0;0;0A0001005000D4460102
                     [2016-10-17 23:09:29.821 Info] INFO	BL version=258
                     [2016-10-17 23:09:29.821 Info] INFO	Send FW info to node 1: type=A, version=1, blocks=0x0050, CRC=0x46D4
                     [2016-10-17 23:09:29.822 Info] TX	1;0;4;0;1;0A0001005000D446
                    I'll try to keep it going all night, but here are my full log till now.
                    Any idea what is going wrong?
                    0_1476738954886_MySensors_20161017-230018.log
                    M tekkaT 2 Replies Last reply
                    • jmkhaelJ jmkhael
                      @tekka , @anyone :)
                      mannkind
                      • jmkhaelJ jmkhael
                        @tekka , @anyone :)
                        tekkaT
                        tekkaT
                        tekka
                        @jmkhael Looks like a bad radio connection (GW too close / far, interference, power) What happens if you upload the FW via serial link?
                        • tekkaT tekka
                          jmkhaelJ
                          jmkhaelJ
                          jmkhael
                          @mannkind : thanks for the clarifications. My problem is that the node seems to hang at the booting phase in MYSController sa per the screenshot.
                          @tekka that should be it (gw in the 50 cm range). I'll try more tests and get back here in any case.
                          @mannkind, @tekka: How do we interpret the OTA logs?
                          • jmkhaelJ jmkhael
                            jmkhaelJ
                            jmkhaelJ
                            jmkhael
                            @tekka: it was probably a mix of power/distance. when change these two parameters, OTA went fine. thank you
                            What is the best way to handle OTA for sleeping nodes? is there something else todo besides setting the property under settings in MYSController? Do I need to powercycle the node or will MYSController kicks in when the node sleeps/smartSleeps?
                            thank you for your time
                            tekkaT 1 Reply Last reply
                            • jmkhaelJ jmkhael
                              tekkaT
                              tekkaT
                              tekka
                              @jmkhael MYSController will reboot the node as soon as it wakes up, sends and processes incoming messages.
                              • tekkaT tekka
                                jmkhaelJ
                                jmkhaelJ
                                jmkhael
                                @tekka my node wakes up every two minutes (or on pir movement) sends some messages (temperature, light level...) and sleeps right away. will MYSController be able to do that in this small time window? is there something i can code to help it? (heartBeat, wait, smartSomething?)
                                (as i saw during my few tests, i had to powercycle my node, maybe i wasn't patient enough :))
                                • jmkhaelJ jmkhael
                                  tekkaT
                                  tekkaT
                                  tekka
                                  @jmkhael place smartSleep() instead of sleep(), before sending any values to the controller - MYSController will pick this up and send a reboot command. Also, you need to mark the node as battery-powered/sleeping node...
                                  • JCLBJ
                                    JCLBJ
                                    JCLB
                                    wrote on last edited by JCLB
                                    #23
                                    Just tried with this release, works great (had no problem with previous release)
                                    The only drawback is the packet bitrate, around 40 per minute with 45 bytes each.
                                    It takes 1h to flash a node. few minutes, just make sure of your wiring as this is a very intensive process compared to node's standard radio use.
                                    Here is a flash running on a test network:
                                    snip
                                    Can we update many nodes at the same time ? haven't tried
                                    • JCLBJ JCLB
                                      snip
                                      tekkaT
                                      tekkaT
                                      tekka
                                      @JCLB This is unusual. A regular sketch ~20kB takes ~2mins. Maybe you are having issues with power supply, bad clones, or other sources of interference.
                                      • JCLBJ
                                        JCLBJ
                                        JCLB
                                        #25
                                        I can now gets dozen of packets at once, then hold, continues...depending of how I press the wires on radio side :sweat:
                                        It's a wiring problem, will try this weekend with a soldered node.
                                        Thank you
                                        • JCLBJ JCLB
                                          Thank you
                                          tekkaT
                                          tekkaT
                                          tekka
                                          @JCLB Thanks for reporting, I'm using short dupont cables or have the radio fixed on a PCB.
