  3. DHT22 and DS18b20 on same node: DS shows up with Humidity now.
15 Posts 8 Posters 10.7k Views 5 Watching
  • A
    andriej
    Until Domoticz team doesn't fix it, there's no solution.
    Even registering second ID for arduino didn't solve problem.
    • T
      torfinn
      Seems to be related to the domoticz gateway. Also tried to downgrade to the first version that supported Arduino as serial controller but same problem. Strange thing is that if you restart controller and only present temp in the sketch its working until you present the humidity??
      • T
        torfinn
        Hi ! You can get a partly workaround using V_DUST_LEVEL or something instead of V_HUM.
        • Z
          Z
          zampedro
          This is a really annoying thing.
          I finally decided to modify the Domoticz sources, and now
          temperature shows up with humidity only if they have
          consecutive ID, otherwise they are shown separated.
          miljumeM 1 Reply Last reply
          • Z zampedro
            miljumeM
            miljumeM
            miljume
            @zampedro I have exactly the same problem
            Could you please tell me more of how you modified Domoticz source?
            This bug is really annoying!
            Regards,
            Mikael
            AWIA 1 Reply Last reply
            • miljumeM miljume
              Regards,
              Mikael
              AWIA
              AWIA
              AWI
              @miljume Domoticz developers consider this a feature... not a bug ;-)
              • mfalkviddM
                I get a similar problem on my plant monitoring. The graph always says "Temperature" even though the sensors only report humidity. I need to explain it every time I show the graphs to anyone.
                • Z
                  Z
                  zampedro
                  I modified MySensorBase.cpp
                  void MySensorsBase::SendSensor2Domoticz
                  case V_TEMP:
                  at lines 595 and 603 (numbers from last git code) for Temperature
                  // SendTempHumBaroSensorFloat(cNode, pChild->batValue, Temp, Humidity, Baro, nforecast, (!pChild->childName.empty()) ? pChild->childName : "TempHumBaro");
                  if ( (pChildHum->childID+1)== pChild->childID)
                  SendTempSensor(cNode, pChild->batValue, Temp, (!pChild->childName.empty()) ? pChild->childName : "Temp");
                  // SendTempHumSensor(cNode, pChild->batValue, Temp, Humidity, (!pChild->childName.empty()) ? pChild->childName : "TempHum");
                  case V_HUM:
                  at lines 678 and 686 for Humidity
                  // SendTempHumBaroSensorFloat(cNode, pChildTemp->batValue, Temp, Humidity, Baro, nforecast, (!pChild->childName.empty()) ? pChild->childName : "TempHumBaro");
                  if ( (pChild->childID+1)== pChildTemp->childID)
                  SendHumiditySensor(cNode, pChild->batValue, Humidity, (!pChild->childName.empty()) ? pChild->childName : "Hum");
                  // SendTempHumSensor(cNode, pChildTemp->batValue, Temp, Humidity, (!pChild->childName.empty()) ? pChild->childName : "TempHum");
                  In this way hum+temp of DHT11 are shown together ( CHILD_ID_HUM +1 == CHILD_ID_TEMP ) and
                  temperatures from ds18b20 are alone in separate widgets.
                  #define CHILD_ID_HUM 9 // DHT11
                  #define CHILD_ID_TEMP 10 // DHT11
                  #define DS18B20_STARTID 15 // DS18B20
                  Regards
                  palande.vaibhavP 1 Reply Last reply
                  • miljumeM
                    miljumeM
                    miljume
                    wrote on last edited by miljume
                    @zampedro Sounds perfect, is there any chance this change can be merged into the source of Domoticz?
                    • Z zampedro
                      case V_TEMP:
                      case V_HUM:
                      Regards
                      palande.vaibhavP
                      palande.vaibhavP
                      palande.vaibhav
                      case V_TEMP:
                      case V_HUM:
                      Regards
                      Where can I find the MySensorsBase.cpp? I am running domoticz on windows and in the installation folder I can't find the file. I can see the file on GitHub but how do I install domoticz from GitHub?
                      Z 1 Reply Last reply
                      • palande.vaibhavP palande.vaibhav
                        case V_TEMP:
                        case V_HUM:
                        Regards
                        Z
                        Z
                        zampedro
                        @palande.vaibhav You have to compile domoticz from source, highly recommended if
                        you run it on raspberry, orangepi etc...
                        • Z zampedro
                          AWIA
                          AWIA
                          AWI
                          @zampedro Please have a look at this thread. The "combination issue" is discussed and solved. There is no reason to compile Domoticz yourself when running on Raspberry. I discourage compiling yourself (unless you like the excercise). The precompiled image works out of the box.
                          • AWIA AWI
                            Z
                            Z
                            zampedro
                            @AWI Thanks for the hint.
                            I thought this wasn't a "issue" but just a "really annoying thing".
                            However i run domoticz on a Orange PI PC with WiringOP support and i can't find precompiled images.
                            12.5k
