  3. MYSBootloader 1.3pre2 testing
otamyscontrollermysbootloader
73 Posts 25 Posters 41.1k Views 31 Watching
  • jmkhaelJ jmkhael
    @mannkind : thank you for your message. I'll give that a go later on.
    @tekka , @anyone :)
    I am trying to make this work using MYSController (from MYSBootloader_V13pre2/). I've followed the instructions above from @tekka, but it feels like the OTA process kicks around quite quick, then it seems to block in a loop
     [2016-10-17 23:09:29.821 Info] RX	1;255;4;0;0;0A0001005000D4460102
     [2016-10-17 23:09:29.821 Info] INFO	BL version=258
     [2016-10-17 23:09:29.821 Info] INFO	Send FW info to node 1: type=A, version=1, blocks=0x0050, CRC=0x46D4
     [2016-10-17 23:09:29.822 Info] TX	1;0;4;0;1;0A0001005000D446
    I'll try to keep it going all night, but here are my full log till now.
    Any idea what is going wrong?
    0_1476738954886_MySensors_20161017-230018.log
    tekkaT
    tekkaT
    tekka
    @jmkhael Looks like a bad radio connection (GW too close / far, interference, power) What happens if you upload the FW via serial link?
    jmkhaelJ 1 Reply Last reply
    • tekkaT tekka
      jmkhaelJ
      jmkhaelJ
      jmkhael
      @mannkind : thanks for the clarifications. My problem is that the node seems to hang at the booting phase in MYSController sa per the screenshot.
      @tekka that should be it (gw in the 50 cm range). I'll try more tests and get back here in any case.
      @mannkind, @tekka: How do we interpret the OTA logs?
      • jmkhaelJ jmkhael
        jmkhaelJ
        jmkhaelJ
        jmkhael
        @tekka: it was probably a mix of power/distance. when change these two parameters, OTA went fine. thank you
        What is the best way to handle OTA for sleeping nodes? is there something else todo besides setting the property under settings in MYSController? Do I need to powercycle the node or will MYSController kicks in when the node sleeps/smartSleeps?
        thank you for your time
        tekkaT 1 Reply Last reply
        • jmkhaelJ jmkhael
          tekkaT
          tekkaT
          tekka
          @jmkhael MYSController will reboot the node as soon as it wakes up, sends and processes incoming messages.
          • tekkaT tekka
            jmkhaelJ
            jmkhaelJ
            jmkhael
            @tekka my node wakes up every two minutes (or on pir movement) sends some messages (temperature, light level...) and sleeps right away. will MYSController be able to do that in this small time window? is there something i can code to help it? (heartBeat, wait, smartSomething?)
            (as i saw during my few tests, i had to powercycle my node, maybe i wasn't patient enough :))
            • jmkhaelJ jmkhael
              tekkaT
              tekkaT
              tekka
              @jmkhael place smartSleep() instead of sleep(), before sending any values to the controller - MYSController will pick this up and send a reboot command. Also, you need to mark the node as battery-powered/sleeping node...
              • JCLBJ
                JCLBJ
                JCLB
                wrote on last edited by JCLB
                #23
                Just tried with this release, works great (had no problem with previous release)
                The only drawback is the packet bitrate, around 40 per minute with 45 bytes each.
                It takes 1h to flash a node. few minutes, just make sure of your wiring as this is a very intensive process compared to node's standard radio use.
                Here is a flash running on a test network:
                snip
                Can we update many nodes at the same time ? haven't tried
                • JCLBJ JCLB
                  snip
                  tekkaT
                  tekkaT
                  tekka
                  @JCLB This is unusual. A regular sketch ~20kB takes ~2mins. Maybe you are having issues with power supply, bad clones, or other sources of interference.
                  • JCLBJ
                    JCLBJ
                    JCLB
                    #25
                    I can now gets dozen of packets at once, then hold, continues...depending of how I press the wires on radio side :sweat:
                    It's a wiring problem, will try this weekend with a soldered node.
                    Thank you
                    • JCLBJ JCLB
                      Thank you
                      tekkaT
                      tekkaT
                      tekka
                      @JCLB Thanks for reporting, I'm using short dupont cables or have the radio fixed on a PCB.
                      • kk02067K
                        kk02067K
                        kk02067
                        I have also problem with speed of the upload. I get about 1 packet per 3 seconds. Is there a something in the code for the bootloader that has a waitingtime of 3 seconds? And if so, because of what? From that info we might be able to tell if it's a reception problem of the node or the gateway.
                        • pkuP
                          pkuP
                          pku
                          @tekka Thank you for great job on MYSBootloader. It works fine for me. Currently I'm testing it and have few questions.
                          • Please can you provide source code? Maybe then I can answer my questions myself :)
                          • Software signing doesn't work after firmware is uploaded. EEPROM is cleared. Is it possible to restore shared key HMAC after firmware is stored?
                          • Is possible to send firmware with signing to prevent loading from fake gateway? I thing signing of available firmware version and firmware CRC is enough ..?
                          Thank you for answers.
                          JCLBJ 1 Reply Last reply
                          • NiklasON
                            NiklasON
                            NiklasO
                            wrote on last edited by NiklasO
                            #29
                            I have changed the fuse settings for my setup. I don't know if it makes any difference but there is a fuse for "Preserve EEPROM memory through the Chip Erase cycle". Was noticing that my sensors was getting a new id every time I did some changes in my sketches and flashed using "Upload with programmer". I have not succeeded with OTA flashing yet.
                            I also use the external crystal present on the Pro Mini. Using 0xFF, 0xD2 and 0xFE.
                            Probably only used when programming using ICSP.
                            MYSBL13.menu.cpu.8MHzatmega328=ATmega328 8MHz (XTAL, BOD1V8)
                            MYSBL13.menu.cpu.8MHzatmega328.upload.maximum_size=30720
                            MYSBL13.menu.cpu.8MHzatmega328.upload.maximum_data_size=2048
                            MYSBL13.menu.cpu.8MHzatmega328.upload.speed=38400
                            MYSBL13.menu.cpu.8MHzatmega328.bootloader.low_fuses=0xFF
                            MYSBL13.menu.cpu.8MHzatmega328.bootloader.high_fuses=0xD2
                            MYSBL13.menu.cpu.8MHzatmega328.bootloader.extended_fuses=0xFE
                            MYSBL13.menu.cpu.8MHzatmega328.bootloader.file=MYSBootloader/MYSBL13pre_atmega328_8Mhz.hex
                            MYSBL13.menu.cpu.8MHzatmega328.build.mcu=atmega328p
                            MYSBL13.menu.cpu.8MHzatmega328.build.f_cpu=8000000L
                            pkuP 1 Reply Last reply
                            • NiklasON NiklasO
                              pkuP
                              pkuP
                              pku
                              @NiklasO I'm using Arduino Mini 5V, 16Mhz with fuses as you have. Except BODLEVEL 2.7V and EEPROM Cleared. OTA works fine, 21kB hex file is sent in cca 2-5 minutes (very depends on count of wrong packets, without 47uF capacitor on NRF24 or with low power supply it takes about 2 hours :) ). I started with MYSController and small and easy Blink.ino.hex from MYSController distribution. Now I use MyController and own firmwares...
                              • pkuP pku
                                JCLBJ
                                JCLBJ
                                JCLB
                                @pku if your keys are in the sketch everything will work for signing.
                                #define MY_SOFT_HMAC_KEY XXX... //signing key
                                #define MY_AES_KEY XXX... // if you use encryption
                                Of course if you want to use whitelisting then you need to compile each node sketch separately with it's serial.
                                @NiklasO
                                Personally I set the node ID manually to avoid this
                                #define MY_NODE_ID 30 // Sets a static id for a node
                                And I group tens so all my 3X nodes are in kitchen, 4X in office, 11X in bedroom 1 and so on.
                                I would love to see a proxy mode in MYSController, in order to interface between a controller that doesn't support OTA and an Ethernet gateway :heart_eyes:
                                Let say your LAN is the following:
                                • MySensors gateway 192.168.0.1
                                • controller (raspberry + Domoticz or else) 192.168.0.2
                                • PC with MYSController 192.168.0.3
                                Whenever you need to update a node, you launch MYSController but don't connect to the gateway, then you tells Domoticz .2 to connect to MYSController .3 instead of the gateway .1, at this point MYSController starts relaying everything between Domoticz and the gateway + provides you the ability to update a node.
                                When you want to get back to normal operations, you set back 192.168.0.1 on Domoticz, MYSController receives a TCP reset and ends it's session with Domoticz and stop the session with the gateway.
                                We would get a minimum downtime and can could use MYSController to update nodes and debug traffic while letting the normal controller...controlling
                                NiklasON AndurilA 2 Replies Last reply
                                • JCLBJ JCLB
                                  @NiklasO
                                  NiklasON
                                  NiklasON
                                  NiklasO
                                  @NiklasO
                                  Ah, yes. Setting static id sound like a solution to my problem. Thanks.
                                  • JCLBJ JCLB
                                    @NiklasO
                                    AndurilA
                                    AndurilA
                                    Anduril
                                    but that would give a listener your full MY_SOFT_HMAC_KEY and signing would be useless in future. Therefor it is better to write the key in eeprom with cable and later only update firmware without key via OTA.
                                    • AndurilA Anduril
                                      pkuP
                                      pkuP
                                      pku
                                      @Anduril
                                      1. I agree, keys located in sketch can be used as workaround only, because the security is broken.
                                      2. But I'm interesting in key located in EEPROM. How it is work during flashing? If Clear EEPROM fuse is not set then everybody can take my outside node, put his own firmware and it will work with keys from EEPROM. It is again a security issue (of course he must have physical access to my node).
                                        I thing it should work with this scenario:
                                      • reguest for new firmware
                                      • copy key, serial and rsa into RAM
                                      • flash new firmware (with fuse clear EEPROM)
                                      • copy key, serial and rsa back into EEPROM
                                      What do you thing?
                                      • AndurilA
                                        AndurilA
                                        Anduril
                                        For a node that is physically accessable it is realy hard. First: does this node needs signing? For sensor data you don't need in most cases. Maybe you should use the hardware chip, there you can't read out the key and if it was locked you also can't change it.
                                        If you still need to use softsigning you could use whitelisting and revoke the whitelist-entry in case of corruption.
                                        • jmkhaelJ
                                          jmkhaelJ
                                          jmkhael
                                          wrote on last edited by jmkhael
                                          #36
                                          I am trying to use MYSController with MYSBootloader 1.3pre2 to reassign a node's ID, and I cannot make it work.
                                          I've tried to check/uncheck the Auto ID toggle/tried to use the MYSBootloader CMDs/Assign ID and setting a new one to no avail.
                                          After that, when it reboots, the node reask for it's firmware, and MYSController re-uploads it, but the node keeps the old ID from the EEProm. (note that the sketch don't hardcode the node's ID).
                                          I'd like to keep the ID management free (i.e. do not hardcode all my node's IDs of course)
                                          How can I do that?
                                           [2016-10-21 13:41:33.318 Info] CLICK	Reassign ID from 1 to 20
                                           [2016-10-21 13:41:33.319 Info] TX	1;0;3;0;13;0
                                           [2016-10-21 13:41:33.364 Info] RX	0;255;3;0;9;!TSP:MSG:SEND 0-0-1-1 s=0,c=3,t=13,pt=0,l=1,sg=0,ft=0,st=fail:0
                                           [2016-10-21 13:41:37.886 Info] RX	0;255;3;0;9;TSP:MSG:READ 4-4-0 s=255,c=3,t=22,pt=5,l=4,sg=0:155561124
                                           [2016-10-21 13:41:37.886 Info] RX	4;255;3;0;22;155561124
                                           [2016-10-21 13:41:42.855 Info] RX	0;255;3;0;9;TSP:MSG:READ 2-2-0 s=1,c=1,t=16,pt=0,l=1,sg=0:0
                                           [2016-10-21 13:41:42.857 Info] RX	2;1;1;0;16;0
                                           [2016-10-21 13:41:46.623 Info] RX	0;255;3;0;9;TSP:MSG:READ 8-5-0 s=2,c=1,t=16,pt=0,l=1,sg=0:0
                                           [2016-10-21 13:41:46.625 Info] RX	8;2;1;0;16;0
                                           [2016-10-21 13:41:47.899 Info] RX	0;255;3;0;9;TSP:MSG:READ 8-5-0 s=3,c=1,t=23,pt=2,l=2,sg=0:80
                                           [2016-10-21 13:41:47.901 Info] RX	8;3;1;0;23;80
                                           [2016-10-21 13:41:50.491 Info] RX	0;255;3;0;9;TSP:MSG:READ 4-4-0 s=1,c=1,t=0,pt=7,l=5,sg=0:22.0
                                           [2016-10-21 13:41:50.494 Info] RX	0;255;3;0;9;TSP:MSG:ACK msg
                                           [2016-10-21 13:41:50.540 Info] RX	0;255;3;0;9;!TSP:MSG:SEND 0-0-4-4 s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=fail:22.0
                                           [2016-10-21 13:41:50.540 Info] RX	4;1;1;0;0;22.0
                                           [2016-10-21 13:41:50.570 Info] RX	0;255;3;0;9;TSP:MSG:READ 4-4-0 s=255,c=3,t=22,pt=5,l=4,sg=0:155562401
                                           [2016-10-21 13:41:50.570 Info] RX	4;255;3;0;22;155562401
                                           [2016-10-21 13:41:57.014 Info] RX	0;255;3;0;9;TSP:SANCHK:OK
                                           [2016-10-21 13:42:02.832 Info] RX	0;255;3;0;9;TSP:MSG:READ 4-4-0 s=255,c=3,t=22,pt=5,l=4,sg=0:155563404
                                           [2016-10-21 13:42:02.832 Info] RX	4;255;3;0;22;155563404
                                           [2016-10-21 13:42:20.453 Info] RX	0;255;3;0;9;TSP:MSG:READ 1-1-0 s=255,c=3,t=22,pt=5,l=4,sg=0:4712
                                           [2016-10-21 13:42:20.453 Info] RX	1;255;3;0;22;4712
                                           [2016-10-21 13:42:20.453 Info] CHILD	New child discovered, node id=1, child id=internal
                                           [2016-10-21 13:42:20.951 Info] RX	0;255;3;0;9;TSP:MSG:READ 1-1-0 s=2,c=1,t=16,pt=0,l=1,sg=0:0
                                           [2016-10-21 13:42:20.953 Info] RX	1;2;1;0;16;0
                                           [2016-10-21 13:42:20.953 Info] CHILD	New child discovered, node id=1, child id=2
                                           [2016-10-21 13:42:21.954 Info] RX	0;255;3;0;9;TSP:MSG:READ 1-1-0 s=3,c=1,t=23,pt=2,l=2,sg=0:42
                                           [2016-10-21 13:42:21.956 Info] RX	1;3;1;0;23;42
                                           [2016-10-21 13:42:21.956 Info] CHILD	New child discovered, node id=1, child id=3
                                           [2016-10-21 13:42:27.773 Info] RX	0;255;3;0;9;TSP:MSG:READ 4-4-0 s=255,c=3,t=22,pt=5,l=4,sg=0:155565680
                                           [2016-10-21 13:42:27.774 Info] RX	4;255;3;0;22;155565680
                                           [2016-10-21 13:42:40.382 Info] RX	0;255;3;0;9;TSP:MSG:READ 4-4-0 s=255,c=3,t=22,pt=5,l=4,sg=0:155566954
                                           [2016-10-21 13:42:40.382 Info] RX	4;255;3;0;22;155566954
                                          TSM:INIT
                                          TSM:RADIO:OK
                                          TSP:ASSIGNID:OK (ID=1)
                                          TSM:FPAR
                                          TSP:MSG:SEND 1-1-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                                          TSP:MSG:READ 5-5-1 s=255,c=3,t=8,pt=1,l=1,sg=0:1
                                          TSP:MSG:FPAR RES (ID=5, dist=1)
                                          TSP:MSG:PAR OK (ID=5, dist=2)
                                          TSP:MSG:READ 0-0-1 s=255,c=3,t=8,pt=1,l=1,sg=0:0
                                          TSP:MSG:PAR OK (ID=0, dist=1)
                                          TSM:FPAR:OK
                                          TSM:ID
                                          TSM:CHKID:OK (ID=1)
                                          TSM:UPL
                                          TSP:PING:SEND (dest=0)
                                          TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
                                          TSP:MSG:READ 0-0-1 s=255,c=3,t=25,pt=1,l=1,sg=0:1
                                          TSP:MSG:PONG RECV (hops=1)
                                          TSP:CHKUPL:OK
                                          TSM:UPL:OK
                                          TSM:READY
                                          TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
                                          TSP:MSG:SEND 1-1-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=ok:2.0.0
                                          TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=ok:0
                                          TSP:MSG:READ 0-0-1 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                          TSP:MSG:READ 0-0-1 s=255,c=3,t=6,pt=0,l=1,sg=0:M
                                          TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=11,pt=0,l=12,sg=0,ft=0,st=ok:Multi Sensor
                                          TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=ok:1.0
                                          TSP:MSG:SEND 1-1-0-0 s=2,c=0,t=1,pt=0,l=0,sg=0,ft=0,st=ok:
                                          TSP:MSG:SEND 1-1-0-0 s=0,c=0,t=7,pt=0,l=0,sg=0,ft=0,st=ok:
                                          TSP:MSG:SEND 1-1-0-0 s=1,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=ok:
                                          TSP:MSG:SEND 1-1-0-0 s=3,c=0,t=16,pt=0,l=0,sg=0,ft=0,st=ok:
                                          Request registration...
                                          TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
                                          TSP:MSG:READ 0-0-1 s=255,c=3,t=27,pt=1,l=1,sg=0:1
                                          Node registration=1
                                          Init complete, id=1, parent=0, distance=1, registration=1
                                          TSP:MSG:SEND 1-1-0-0 s=2,c=1,t=16,pt=0,l=1,sg=0,ft=0,st=ok:0
                                          TSP:MSG:SEND 1-1-0-0 s=3,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=ok:54
