  3. DS18B20 Sketch from Examples doesn't brings Node to sleep.
sleepsleepingds18b20
7 Posts 4 Posters 3.4k Views 3 Watching
  • F
    F
    Floca
    Hi, the 1.1 Sketch doesn't brings the Node to sleep with 2.0.1-beta.
    Anyone else is having this problem?
    I have two nodes and both having this issue :(
      What type of hardware?
      • F
        F
        Floca
        Arduino Pro Mini with NRF24L01+...
        It Works great with the "old" 2.0.0 beta.
        • F
          F
          Floca
          Any Ideas, why it is not working with new 2.0.1-beta?
            Could you post more infos plz ?
            • your sketch even if it's the original
            • which lib you're using for onewire
            • enable MY_DEBUG in sketch and post the logs
            • F
              F
              Floca
              wrote on last edited by Floca
              DEBUG:
              0 MCO:BGN:INIT REPEATER,CP=RNNRA--,VER=2.0.1-beta
              4 MCO:BGN:BFR
              65 TSM:INIT
              73 TSM:INIT:TSP OK
              75 TSM:INIT:STATID=2
              77 TSF:SID:OK,ID=2
              79 TSM:FPAR
              114 TSF:MSG:SEND,2-2-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
              227 TSF:MSG:READ,0-0-2,s=255,c=3,t=8,pt=1,l=1,sg=0:0
              233 TSF:MSG:FPAR OK,ID=0,D=1
              2123 TSM:FPAR:OK
              2123 TSM:ID
              2125 TSM:ID:OK
              2127 TSM:UPL
              2134 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
              2156 TSF:MSG:READ,0-0-2,s=255,c=3,t=25,pt=1,l=1,sg=0:1
              2162 TSF:MSG:PONG RECV,HP=1
              2164 TSM:UPL:OK
              2166 TSM:READY
              2170 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
              2181 TSF:MSG:SEND,2-2-0-0,s=255,c=0,t=18,pt=0,l=10,sg=0,ft=0,st=OK:2.0.1-beta
              2191 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
              2197 TSF:MSG:READ,0-0-2,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
              4208 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=11,pt=0,l=18,sg=0,ft=0,st=OK:Temperature Sensor
              4225 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.1
              4235 TSF:MSG:SEND,2-2-0-0,s=0,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=OK:
              4241 MCO:REG:REQ
              4245 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
              4263 TSF:MSG:READ,0-0-2,s=255,c=3,t=27,pt=1,l=1,sg=0:1
              4270 MCO:PIM:NODE REG=1
              4274 MCO:BGN:STP
              4276 MCO:BGN:INIT OK,ID=2,PAR=0,DIS=1,REG=1
              4282 MCO:SLP:MS=750,SMS=0,I1=255,M1=255,I2=255,M2=255
              4288 !MCO:SLP:REP
              5070 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:19.0
              5079 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
              5085 !MCO:SLP:REP
              65089 MCO:SLP:MS=750,SMS=0,I1=255,M1=255,I2=255,M2=255
              65095 !MCO:SLP:REP
              65875 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:18.7
              65884 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
              65890 !MCO:SLP:REP```
              SKETCH:
               * Example sketch showing how to send in DS1820B OneWire temperature readings back to the controller
               * http://www.mysensors.org/build/temp
              #define MY_NODE_ID 2
              #define MY_REPEATER_FEATURE Disabled
              #include <OneWire.h>
              #define MAX_ATTACHED_DS18B20 2
              unsigned long SLEEP_TIME = 60000; // Sleep time between reads (in milliseconds)
              int numSensors=0;
              bool receivedConfig = false;
              bool metric = true;
              MyMessage msg(0,V_TEMP);
              void before()
                sensors.begin();
                   present(i, S_TEMP);
                sleep(conversionTime);
                  float temperature = static_cast<float>(static_cast<int>((getConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
                  #if COMPARE_TEMP == 1
                sleep(SLEEP_TIME);
              ...and the Onewire Library from: Mysensors Libraries @GitHub
              tekkaT 1 Reply Last reply
              • F Floca
                DEBUG:
                4 MCO:BGN:BFR
                65 TSM:INIT
                73 TSM:INIT:TSP OK
                77 TSF:SID:OK,ID=2
                79 TSM:FPAR
                2123 TSM:FPAR:OK
                2123 TSM:ID
                2125 TSM:ID:OK
                2127 TSM:UPL
                2164 TSM:UPL:OK
                2166 TSM:READY
                4241 MCO:REG:REQ
                4274 MCO:BGN:STP
                4288 !MCO:SLP:REP
                5085 !MCO:SLP:REP
                65095 !MCO:SLP:REP
                SKETCH:
                int numSensors=0;
                bool metric = true;
                void before()
                  sensors.begin();
                     present(i, S_TEMP);
                  sleep(SLEEP_TIME);
                tekkaT
                tekkaT
                tekka
                @Floca Your node is defined as repeater, and repeaters do not sleep by definition:
                See log:
                65890 !MCO:SLP:REP
                To disable repeater mode, comment this line (writing "Disabled" won't work):
