  3. WS5100 GW is not working after 2.0.1b update [SOLVED]
14 Posts 3 Posters 3.2k Views 3 Watching
  • alexsh1A
    alexsh1A
    alexsh1
    @hek
    GW log:
    0;255;3;0;9;MCO:BGN:INIT GW,CP=RNNGAS-,VER=2.0.1-beta
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;TSM:INIT:TSP OK
    0;255;3;0;9;TSM:INIT:GW MODE
    0;255;3;0;9;TSM:READY
    IP: 10.1.1.120
    0;255;3;0;9;MCO:BGN:STP
    0;255;3;0;9;MCO:BGN:INIT OK,ID=0,PAR=0,DIS=0,REG=1
    0;255;3;0;9;TSF:MSG:READ,10-10-0,s=1,c=1,t=17,pt=5,l=4,sg=0:220
    0;255;3;0;9;TSF:MSG:READ,10-10-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    0;255;3;0;9;TSF:MSG:BC
    0;255;3;0;9;TSF:MSG:FPAR REQ,ID=10
    0;255;3;0;9;TSF:PNG:SEND,TO=0
    0;255;3;0;9;TSF:CKU:OK
    0;255;3;0;9;TSF:MSG:GWL OK
    0;255;3;0;9;!TSF:MSG:SEND,0-0-10-10,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
    0;255;3;0;9;Eth: connect
    0;255;3;0;9;Eth: 0;0;3;0;2;
    0;255;3;0;9;Eth: 0;0;3;0;2;Get Version
    0;255;3;0;9;Eth: 0;0;3;0;18;PING
    node log:
    0 MCO:BGN:INIT NODE,CP=RNONA--,VER=2.0.1-beta
    4 TSM:INIT
    10 TSM:INIT:TSP OK
    12 TSM:INIT:STATID=13
    14 TSF:SID:OK,ID=13
    16 TSM:FPAR
    53 TSF:MSG:SEND,13-13-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    2062 !TSM:FPAR:NO REPLY
    2064 TSM:FPAR
    2101 TSF:MSG:SEND,13-13-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    4110 !TSM:FPAR:NO REPLY
    4112 TSM:FPAR
    4149 TSF:MSG:SEND,13-13-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    6158 !TSM:FPAR:NO REPLY
    6160 TSM:FPAR
    6197 TSF:MSG:SEND,13-13-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    8206 !TSM:FPAR:FAIL
    8208 TSM:FAIL:CNT=1
    8210 TSM:FAIL:PDT
    From what I understand there is a problem with GW.
    Will probably have to change radio. It is PA version fed from AMS117 from 5V Mega 2560 pin - should be enough juice.
    Tried to change the power source without any luck.
    • alexsh1A
      alexsh1A
      alexsh1
      Changing nrf24l01+ PA for another one resolved the issue. I hate this Chinese transceiver - so much time is waited to troubleshoot hardware issues.
        Sorry to hear that you got a crappy radio @alexsh1, and good that you found the issue.
        alexsh1A 1 Reply Last reply
          alexsh1A
          alexsh1A
          alexsh1
          @hek The issue is that nrf24l01+ was (and still is) working fine with pre 2.0 version. In fact it was one of the best transceivers I have in terms of range.
          For whatever reason it does not work with 2.0
          • alexsh1A alexsh1
            @alexsh1 You could consider donating this radio to the project, so we can run some tests on it.
            If an incompatibility snook in with 2.0.0. we might be able to fix it, so we can all benefit from it.
            • YveauxY Yveaux
              alexsh1A
              alexsh1A
              alexsh1
              @Yveaux @hek More than happy to donate. However, as I discovered today the issue was not the transceiver. The issue was this little board (AMS1117 3.3). The problem is that it has been working intermittently. 0_1477332967655_image.jpeg
              My multimeter was showing a stable 3.4V, but under load it was behaving strangely. A normal nrf24l01+ (non PA) was performing much better for a while and then after a while it would start playing again.
              I have spent a few months trying to troubleshoot the problem not spending too much time, but today I decided to nail it down finally.
              :rage: :rage: :rage: :rage: :rage: :rage: :rage:
              • alexsh1A alexsh1
                @alexsh1 Any idea what is wrong with it? The AMS1117 is a rather common chip and not much else is on it, so I wonder what caused the issue...
                • YveauxY Yveaux
                  alexsh1A
                  alexsh1A
                  alexsh1
                  @Yveaux No idea - I just replaced it for a similar board. I am going to change AMS1117 or can donate it if you can to get down to the bottom of it
                  • alexsh1A
                    alexsh1A
                    alexsh1
                    All I can see is that after changing the AMS1117 the GW works like a charm. Surely, I need to do more testing to make sure it is rock solid.
                    • alexsh1A alexsh1
                      @alexsh1 Well, I suspect the AMS is of bad quality, hardly able to supply 100mA.
                      Another thing is that when they fail for some reason, they tend to short-circuit internally and pass on their input voltage to their outputs directly, frying the circuit you're trying to power :rage4:
                      At least, that's what I found out about them so far...
                      • YveauxY Yveaux
                        alexsh1A
                        alexsh1A
                        alexsh1
                        Luckily, this is not what happened to me.
                        AMS1117 has not failed completely. Only with PA version (higher current) I experienced issues.
                        12.5k
