  3. WS5100 GW is not working after 2.0.1b update [SOLVED]
14 Posts 3 Posters 3.0k Views 3 Watching
  • alexsh1A Offline
    alexsh1A Offline
    alexsh1
    I updated my GW (Mega + shield 5100) with 2.0.1b and have now the following in the log:
    1	18/10/2016 17:34:35	RX	0 - Gateway	INTERNAL	C_INTERNAL	NO	I_HEARTBEAT_RESPONSE	399502
    2	18/10/2016 17:34:45	RX	0 - Gateway	INTERNAL	C_INTERNAL	NO	I_HEARTBEAT_RESPONSE	409499
    It does not accept any connections. The heartbeat goes on and it does not start. Never had a problem with 2.0b or before...
    Any idea what may have caused it please?
    • H Offline
      H Offline
      This doesn't look like a log from the gateway.
      • alexsh1A Offline
        alexsh1A Offline
        alexsh1
        @hek this is a log from MYSController
        • alexsh1A Offline
          alexsh1A Offline
          alexsh1
          @hek
          GW log:
          0;255;3;0;9;MCO:BGN:INIT GW,CP=RNNGAS-,VER=2.0.1-beta
          0;255;3;0;9;TSM:INIT
          0;255;3;0;9;TSM:INIT:TSP OK
          0;255;3;0;9;TSM:INIT:GW MODE
          0;255;3;0;9;TSM:READY
          IP: 10.1.1.120
          0;255;3;0;9;MCO:BGN:STP
          0;255;3;0;9;MCO:BGN:INIT OK,ID=0,PAR=0,DIS=0,REG=1
          0;255;3;0;9;TSF:MSG:READ,10-10-0,s=1,c=1,t=17,pt=5,l=4,sg=0:220
          0;255;3;0;9;TSF:MSG:READ,10-10-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
          0;255;3;0;9;TSF:MSG:BC
          0;255;3;0;9;TSF:MSG:FPAR REQ,ID=10
          0;255;3;0;9;TSF:PNG:SEND,TO=0
          0;255;3;0;9;TSF:CKU:OK
          0;255;3;0;9;TSF:MSG:GWL OK
          0;255;3;0;9;!TSF:MSG:SEND,0-0-10-10,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
          0;255;3;0;9;Eth: connect
          0;255;3;0;9;Eth: 0;0;3;0;2;
          0;255;3;0;9;Eth: 0;0;3;0;2;Get Version
          0;255;3;0;9;Eth: 0;0;3;0;18;PING
          node log:
          0 MCO:BGN:INIT NODE,CP=RNONA--,VER=2.0.1-beta
          4 TSM:INIT
          10 TSM:INIT:TSP OK
          12 TSM:INIT:STATID=13
          14 TSF:SID:OK,ID=13
          16 TSM:FPAR
          53 TSF:MSG:SEND,13-13-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          2062 !TSM:FPAR:NO REPLY
          2064 TSM:FPAR
          2101 TSF:MSG:SEND,13-13-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          4110 !TSM:FPAR:NO REPLY
          4112 TSM:FPAR
          4149 TSF:MSG:SEND,13-13-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          6158 !TSM:FPAR:NO REPLY
          6160 TSM:FPAR
          6197 TSF:MSG:SEND,13-13-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          8206 !TSM:FPAR:FAIL
          8208 TSM:FAIL:CNT=1
          8210 TSM:FAIL:PDT
          From what I understand there is a problem with GW.
          Will probably have to change radio. It is PA version fed from AMS117 from 5V Mega 2560 pin - should be enough juice.
          Tried to change the power source without any luck.
          • alexsh1A Offline
            alexsh1A Offline
            alexsh1
            Changing nrf24l01+ PA for another one resolved the issue. I hate this Chinese transceiver - so much time is waited to troubleshoot hardware issues.
            • H Offline
              H Offline
              Sorry to hear that you got a crappy radio @alexsh1, and good that you found the issue.
              alexsh1A 1 Reply Last reply
              • H hek
                alexsh1A Offline
                alexsh1A Offline
                alexsh1
                @hek The issue is that nrf24l01+ was (and still is) working fine with pre 2.0 version. In fact it was one of the best transceivers I have in terms of range.
                For whatever reason it does not work with 2.0
                Y 1 Reply Last reply
                • alexsh1A alexsh1
                  Y Offline
                  Y Offline
                  @alexsh1 You could consider donating this radio to the project, so we can run some tests on it.
                  If an incompatibility snook in with 2.0.0. we might be able to fix it, so we can all benefit from it.
                  • Y Yveaux
                    alexsh1A Offline
                    alexsh1A Offline
                    alexsh1
                    @Yveaux @hek More than happy to donate. However, as I discovered today the issue was not the transceiver. The issue was this little board (AMS1117 3.3). The problem is that it has been working intermittently. 0_1477332967655_image.jpeg
                    My multimeter was showing a stable 3.4V, but under load it was behaving strangely. A normal nrf24l01+ (non PA) was performing much better for a while and then after a while it would start playing again.
                    I have spent a few months trying to troubleshoot the problem not spending too much time, but today I decided to nail it down finally.
                    :rage: :rage: :rage: :rage: :rage: :rage: :rage:
                    • alexsh1A alexsh1
                      Y Offline
                      Y Offline
                      @alexsh1 Any idea what is wrong with it? The AMS1117 is a rather common chip and not much else is on it, so I wonder what caused the issue...
                      • Y Yveaux
                        alexsh1A Offline
                        alexsh1A Offline
                        alexsh1
                        @Yveaux No idea - I just replaced it for a similar board. I am going to change AMS1117 or can donate it if you can to get down to the bottom of it
                        • alexsh1A Offline
                          alexsh1A Offline
                          alexsh1
                          All I can see is that after changing the AMS1117 the GW works like a charm. Surely, I need to do more testing to make sure it is rock solid.
                          • alexsh1A alexsh1
                            Y Offline
                            Y Offline
                            @alexsh1 Well, I suspect the AMS is of bad quality, hardly able to supply 100mA.
                            Another thing is that when they fail for some reason, they tend to short-circuit internally and pass on their input voltage to their outputs directly, frying the circuit you're trying to power :rage4:
                            At least, that's what I found out about them so far...
                            • Y Yveaux
                              alexsh1A Offline
                              alexsh1A Offline
                              alexsh1
                              Luckily, this is not what happened to me.
                              AMS1117 has not failed completely. Only with PA version (higher current) I experienced issues.
                              12.1k
