  2. Announcements
  3. 💬 Relay
💬 Relay
139 Posts 47 Posters 78.6k Views 45 Watching
    wrote on last edited by hek
    This thread contains comments for the article "Relay" posted on MySensors.org.
    • R
      R
      Reza
      how convert a relay 2 channel to roller shutter ?!
      in site , there is not a sketch.
      please put a sketch for roller shutter
      • tianaT
        tianaT
        tiana
        Both sketch not working giving me "error: 'saveState' was not declared in this scope
          saveState(CHILD_ID, state);"
        • drradkinD
          drradkinD
          drradkin
          How can I edit the sketch to make this work with a double (multiple) relay board instead of a single?
          hekH 1 Reply Last reply
          • drradkinD drradkin
            @drradkin
            Have you tried reading the code?
            drradkinD 1 Reply Last reply
              @drradkin
              drradkinD
              drradkinD
              drradkin
              @hek yes. I changed the line for the number of relays but it didn't work. I don't know anything about the code.
                Stating "It didn't work" doesn't give enough information for anyone to help you.
                What have you tried? What steps did you go through to determine that it doesn't work?
                • stockenS
                  stockenS
                  stocken
                  greetings, i have an idea to use a 12volt fan to move some air from one room to the room next to it (the first room has a stove for heating).
                  and i was thinking a relay would do the trick so i dont manually have to start it (and a nice script in domoticz that uses the data from the temp sensor + the ability to manually turn it on/off in domoticz).
                  now to my question: which relay should i get?
                  I looked at the ones in the store but it seems they are either for 230VAC or 5VDC
                    The control signal is 5VCD... The "other side" can be anything (up to 230VCD).
                    • pepsonP
                      pepsonP
                      pepson
                      Can you show converted sketch with 2 buttons and 2 relays ? I dont know how convert this sketch bersion with buttons...
                      Boots33B 1 Reply Last reply
                      • pepsonP pepson
                        Boots33B
                        Boots33B
                        Boots33
                        @pepson Have a look at this thread for some ideas to get you started.
                        • fdojuradoF
                          fdojuradoF
                          fdojurado
                          I would like to ask about ack. Does the library have a specific timeout? Does the library resends the message when ack is not received? Thank you.
                          • Puneit ThukralP
                            Puneit ThukralP
                            Puneit Thukral
                            Cam I use an arduino pro mini 3.3V 8 Mhz to trigger the relay - or do I need a 5v arduino?
                            • Puneit ThukralP Puneit Thukral
                              sundberg84S
                              sundberg84S
                              @Puneit-Thukral - it depends on the relay.
                              If you read the datasheet for intended relay you will see what is needed. Most relays i have seen requiers 5v and a good current (which Arduino sometimes fail to deliver).
                              Puneit ThukralP 1 Reply Last reply
                              • sundberg84S sundberg84
                                Puneit ThukralP
                                Puneit ThukralP
                                Puneit Thukral
                                @sundberg84 I used a 3904 transistor between the relay and arduino and it works just fine with 3.3 V Arduino pro mini 8 HMz.
                                (2N2222 also works, but I have many pieces of 3904 and just a few 2N2222, hence using 3904)
                                • Javier RubioJ
                                  Javier RubioJ
                                  Javier Rubio
                                  I have my gateway and my relay, I believe is working fine, I just want to know what set of caracters do I need to send in the serial monitor to turn on the relay? I will like to use the info in order to use a controller like Vantage or C4, is that possible? Regards
                                  • Javier RubioJ Javier Rubio
                                    Puneit ThukralP
                                    Puneit ThukralP
                                    Puneit Thukral
                                    @Javier-Rubio I m not an expert- a complete novice.
                                    I would suggest one of the following - trigger the relay through a controller or use one the the arduino relay example sketch in which relay is programmed to turn on and off every 1 second. This would help you validate if your wiring is correct or not.
                                    • GizmohG
                                      GizmohG
                                      Gizmoh
                                      I tried the relay sketch on my arduino mini pro (5v), step down converter for the NRF module and a two channel relay. It's conecte to a Raspi GW wirh the 2.0.0 beta and FHEM as controller. The switching works as expexted. but the relay switches continuisly on and off on its own after a certain time. I tried removing the loop-block but with no effort. Is there anything i can do to get a stable state? Thanks
                                      korttomaK 1 Reply Last reply
                                      • GizmohG Gizmoh
                                        korttomaK
                                        korttomaK
                                        korttoma
                                        @Gizmoh sounds like the relays are not receiving enough power to remain on. How are you powering all this?
                                        • Tomas
                                        GizmohG 1 Reply Last reply
                                        • korttomaK korttoma
                                          GizmohG
                                          GizmohG
                                          Gizmoh
                                          @korttoma
                                          I'm powering this with 6 x AA Batteries into the RAW Input from the Arduino and the 5v output from Arduino to the Relay.
