  3. Windows GUI/Controller for MySensors
myscontrollermysbootloader
486 Posts 101 Posters 494.1k Views 73 Watching
  • H Offline
    H Offline
    Harrdy
    My current running setup is a Arduino via USB-Serial attached to a Arduino with my Controller Software. But i want to use this Windows Controller at the same time. Anyone a idea how i can do this (local serial and serial2net at the same time on the same serial device)? if i start the serial2net my raspberry controller is broken and can't connect to the arduino usb serial but the serial2net work.
    • H Harrdy
      T Offline
      T Offline
      tekka
      @Harrdy you can use the "GW mode" in the latest release and have your controller pointing to your PC's IP.
      • H Offline
        H Offline
        Harrdy
        wrote on last edited by Harrdy
        #412
        Thanks @ @tekka I saw the button "gw mode" but pimatic unfortunately only supports serial gateways. so if i use the "gw mode" i need a package like net2ser (instead of ser2net). But i think something like that does not exist
        edit:
        okay, it works with socat
        sudo socat -d -d pty,link=/dev/ttyPimaticGW,raw,echo=0,waitslave tcp:192.168.170.32:5003;
        • H Harrdy
          edit:
          T Offline
          T Offline
          tekka
          @Harrdy cool, thanks for reporting 👍
          • AndurilA Offline
            AndurilA Offline
            Anduril
            wrote on last edited by Anduril
            #414
            @Harrdy I made the experience that a socat tcp tunnel is not stable all the time. I was trying to establish a connection between my ESP8266 gateway and a serial port (to be used with pimatic), but that tended to disconnect after few hours/days. This was also reported by other users in the pimatic forum. But maybe this is only a problem in relation with a ESP gateway.
            I would just recommend to check your connection regularly.
            If it is also unstable for you, I am testing node-red for that purpose at the moment and it looks promising. I will report when testing is finished.
            • techRHT Offline
              techRHT Offline
              techRH
              Maybe this helps any one else:
              I run openHAB on a RPI3 and i have made a Mysensors serial GW on a arduino nano.
              I want to use openHAB for the interface and MySController for the managment. So i need to forward my serial communication to a TCP socket.
              ser2net is a nice tool works fast but it block the Serial connection for openHAB.
              socat works better for me by executing the following command:
              $ sudo socat tcp-l:5003,reuseaddr,fork file:/dev/mySensorsCOM,nonblock,waitlock=/var/run/mySensorsCOM.lock
              next step will be to put it in a script and sends the process to the background and restarts it if there went something go's wrong.
              R 1 Reply Last reply
              • AndurilA Offline
                AndurilA Offline
                Anduril
                @Harrdy there is a ethernet branch of the mysensors plugin for pimatic now under development. You can have a look at the mysensors thread in the pimatic forum to find the instructions.
                • techRHT techRH
                  R Offline
                  R Offline
                  robosensor
                  Does anyone know how to allow multiple TCP connections forwarded to one MYS tty port? This socat command blocks second TCP connection until first one disconnected.
                  I just want to connect MYSController using TCP without disconnecting my custom MQTT<=>serial controller script. I'm using RPi with USB-serial gateway.
                  P.S. @tekka is there any chances that MQTT access will be implemented in MYSController?
                  P 1 Reply Last reply
                  • T tekka
                    Hi all,
                    I've been working on this project since some time, basically it's a GUI for controlling/updating/debugging a network of MySensors nodes. OTA functionality is supported via MYSBootloader - read posts for further instructions/troubleshooting or PM.
                    link updated: MYSController Version 1.0.0.3316 released
                    New features:
                    • support OTA FW update Sensebender board
                    • metric/imperial system I_CONFIG
                    • save nodes
                    Update via update button in MYSController or download here.
                    jmkhaelJ Offline
                    jmkhaelJ Offline
                    jmkhael
                    @tekka great work! thank you for sharing this.
                    Your controller and great contribution had me quickly started with mysensors. I am interested in a way to do OTA updates using MYSController via api or a script call or even rewriting the logic in an outside code. I'll try to explain the need based on my setup below.
                    Given that I am using jeedom right now as a controller, but sadly it doesn't seem to support yet OTA updates. I'd like to be able to reuse or even contribute to this feature and I'd appreciate pointers to start doing that.
                    My setup has it that jeedom runs off a raspi and has a mysensors serial gateway attached. (1 to 2 Watts draw for this setup). MYSController can work as an ethernet relay gateway, but if I understand correctly I have to run it on windows (more moving parts), or a much hungrier box than my raspi.
                    Is there a way I can make that work somehow? I am ready and appreciate any type of suggestions with the current setup I have or an evolution which goes into that direction.
                    • AndurilA Offline
                      AndurilA Offline
                      Anduril
                      @robosensor you could try nodered. It can connect multiple inputs (mqtt, tcp,...) and merge it to a single serial output and vice versa. You might have to add some logic, but that shouldn't be a problem.
                      • R robosensor
                        P Offline
                        P Offline
                        pdey
                        @robosensor I wrote a bridge to use on the Linino side of the Arduino Yun for this:
                        https://github.com/peterdey/Yun-Linino-NewBridge
                        But there's no reason you couldn't use this on an rPi - you'll probably just need to turn the baud rate down to 115200.
                        • jmkhaelJ jmkhael
                          T Offline
                          T Offline
                          tekka
                          @jmkhael You can use "GW mode" (=proxy mode) in the tab bar
                          • techRHT Offline
                            techRHT Offline
                            techRH
                            I thought the socat command is to slow in switching so i have created a python script which will readout the mysensors serial GW and sends the data to a virtual serial port to connect to openhab and a TCP socket for the MySensors controller.
                            https://github.com/Rutger798/serial_to_serial_and_tcp/blob/master/serial_to_serial_and_tcp.py
                            • dopeeyeD Offline
                              dopeeyeD Offline
                              dopeeye
                              How do i use MYSController with a Raspberry Pi ?
                              I have a RPi2 with a NRF24 radio as a gateway and want to troubleshoot some communication issues i have been having. I usually log into the RPi2 via ssh to make adjustments.
                              Can I just download the files and rund the .exe via command-line?
                              • AndurilA Offline
                                AndurilA Offline
                                Anduril
                                I think it's windows software only. If you want to use it this way you should make you gateway device accessible via ethernet, maybe socat or nodered is an option for you.
                                dopeeyeD 1 Reply Last reply
                                • AndurilA Anduril
                                  dopeeyeD Offline
                                  dopeeyeD Offline
                                  dopeeye
                                  ok thanks for clarifying.
                                  gonna give the node-red a try
                                  • P pdey
                                    @Mark-Swift : If you're happy to modify the MySensors library in an unsupported way, I've added a logMessage function to transmit text/debug messages from remote nodes:
                                    https://github.com/peterdey/MySensors-Arduino/commit/f5f339b71620ec3cd896304a2ca6aba40ad40218
                                    Found it useful, particularly in conjunction with MYSController OTA firmware updates.
                                    jumpingJ Offline
                                    jumpingJ Offline
                                    jumping
                                    is it possible to use with mysensor 2.0 API ?
                                    Raspberrry PI3 - Domoticz
                                    ESP8266 GW - MySensors 2.1.1
                                    • interxisI Offline
                                      interxisI Offline
                                      interxis
                                      Very cool. It also works on Ubuntu with Wine.
                                      You have to create a COM port like this:
                                      ln -s /dev/ttyUSB0 ~/.wine/dosdevices/com1
                                      • karlheinz2000K Offline
                                        karlheinz2000
                                        How do I get MYSController to save info about each node?
                                        I always have to set "battery-powered" after each upload and it does not save sketch name etc.
                                        • meanmrgreenM Offline
                                          meanmrgreen
                                          Ok this might be a realy stupid question but im what you call a "nuub" ;)
                                          If i want to monitor my current setup (serial gateway on a pi3) on windows/mint. Do i build another gateway and plug it in the pc?
                                          Sorry if i missed the instructions on this
