  3. My Slim 2AA Battery Node
498 Posts 71 Posters 598.5k Views 69 Watching
  • carlekiC
    carlekiC
    carleki
    I have received yesterday my little packet from DirtyPCB :)
    11 PCBs, so 33 sensors :)
    I'm just wondering where the C5 capactior will go on the board .. Can't figure out :(
    J 1 Reply Last reply
    • carlekiC carleki
      J
      J
      jeti
      wrote on last edited by jeti
      #347
      @carmelo42: maybe this helps, all Cs and the R assembled!
      • J jeti
        J
        J
        jeti
        ups... C5 is also not there on my board,it shoud be parallel to C4!
        carlekiC 1 Reply Last reply
        • J jeti
          carlekiC
          carlekiC
          carleki
          • carlekiC
            carlekiC
            carleki
            @m26872 is it possible to send the sketch in the atmega on board ? using an FTDI serial/usb ?
            • carlekiC carleki
              J
              J
              jeti
              @carmelo42 yes
              • J jeti
                @carmelo42 yes
                carlekiC
                carlekiC
                carleki
                @jeti said:
                @carmelo42 yes
                I have this serial/usb adapter :
                https://img1.picload.org/image/ldrrddg/deekrobot-isp.png
                Can you tell me how I connect it to my node ? (noob question I guess ... but I don't want to burn my node :( )
                • carlekiC carleki
                  @jeti said:
                  @carmelo42 yes
                  carlekiC
                  carlekiC
                  carleki
                  @carmelo42 said:
                  @jeti said:
                  @carmelo42 yes
                  I have found the answer myself with the schematic ;)
                  Have you ever tried to power the node with 1 x CR2032 battery ?
                  I have tried, but the node doesn't send anything further than 5 meters ...
                  • siodS
                    siodS
                    siod
                    I would like to know if your nodes are working all fine. I have the problem that my nodes freeze after a day or sometimes after a week.
                    still learning...
                    • siodS siod
                      carlekiC
                      carlekiC
                      carleki
                      @siod my temperature nodes work good, but my relay one doesn't work :'(
                      Do you have any logs when it freezes ?
                      • siodS
                        siodS
                        siod
                        @carmelo42 no, unfortunately I don´t have any logs, any idea how to create logs?
                        still learning...
                        • siodS siod
                          carlekiC
                          carlekiC
                          carleki
                          maybe if you keep your node connected to your computer with USB to serial adapter ?
                          • siodS
                            siodS
                            siod
                            mmh, no, that would mean I would have to run my computer for maybe 2 weeks 24/7...
                            I guess it has somehting to do with the sleep function, the device seems to nat wake up after a while for some reason
                            still learning...
                            • dpressleD
                              dpressleD
                              dpressle
                              wrote on last edited by dpressle
                              #359
                              So i got the boards and build them and they work perfect.
                              One thing i couldn't figure out is why do i get relatively high current consumption, when the node is sleeping i get 1.5mA and not 5.8uA as in mentioned in this post.
                              I use 8MHz internal clock and the sleep function and nothing is connected to the node.
                              Can someone help?
                              AWIA 1 Reply Last reply
                              • dpressleD dpressle
                                Can someone help?
                                AWIA
                                AWIA
                                AWI
                                @dpressle Can you post the sketch?
                                • dpressleD
                                  dpressleD
                                  dpressle
                                  Thanks, i see its 6.8 uA now, i had something wrong with my measurements :disappointed:
                                  • JonnyDev13J
                                    JonnyDev13J
                                    JonnyDev13
                                    It took me a while, but I just figured out how to get a bootloader burned onto the chip and I'm ready to make my slim nodes! Which board type in Arduino IDE do I use to program the chip once I'm using the 6 pin header after it's installed in the PCB?
                                    m26872M 1 Reply Last reply
                                    • JonnyDev13J JonnyDev13
                                      m26872M
                                      m26872M
                                      m26872
                                      @JonnyDev13 Make a new board type by editing "boards.txt". There's an example in the first post.
                                      • ร
                                        ร
                                        รอเรือ
                                        wrote on last edited by รอเรือ
                                        #364
                                        Hi there! I need to buy some PCBs on Dirty PCBs but the URL http://dirtypcbs.com/view.php?share=13847&accesskey= seems broken. Any ideas? Thanks!
                                        • ร รอเรือ
                                          m26872M
                                          m26872M
                                          m26872
                                          wrote on last edited by m26872
                                          #365
                                          @รอเรือ Apparently they've moved to a new site. Perhaps you can try this link: http://dev.dirtypcbs.com/store/designer/details/m26872/663/myslim2aabatterynodepcbv2-0panelized
                                          I think you must have a user account and login first. Please report back if it's working or not.
                                          Edit: Wrong link the first time.
                                          ร 1 Reply Last reply
