  3. My Slim 2AA Battery Node
498 Posts 71 Posters 598.5k Views 69 Watching
  • carlekiC
    carlekiC
    carleki
    @m26872 is it possible to send the sketch in the atmega on board ? using an FTDI serial/usb ?
    • carlekiC carleki
      @jeti said:
      ups... C5 is also not there on my board,it shoud be parallel to C4!
      J
      J
      jeti
      @carmelo42 yes
      carlekiC 1 Reply Last reply
      • J jeti
        @carmelo42 yes
        carlekiC
        carlekiC
        carleki
        @jeti said:
        @carmelo42 yes
        I have this serial/usb adapter :
        https://img1.picload.org/image/ldrrddg/deekrobot-isp.png
        Can you tell me how I connect it to my node ? (noob question I guess ... but I don't want to burn my node :( )
        • carlekiC carleki
          @jeti said:
          @carmelo42 yes
          carlekiC
          carlekiC
          carleki
          @carmelo42 said:
          @jeti said:
          @carmelo42 yes
          I have found the answer myself with the schematic ;)
          Have you ever tried to power the node with 1 x CR2032 battery ?
          I have tried, but the node doesn't send anything further than 5 meters ...
          • siodS
            siodS
            siod
            I would like to know if your nodes are working all fine. I have the problem that my nodes freeze after a day or sometimes after a week.
            still learning...
            • siodS siod
              carlekiC
              carlekiC
              carleki
              @siod my temperature nodes work good, but my relay one doesn't work :'(
              Do you have any logs when it freezes ?
              • siodS
                siodS
                siod
                @carmelo42 no, unfortunately I don´t have any logs, any idea how to create logs?
                still learning...
                • siodS siod
                  carlekiC
                  carlekiC
                  carleki
                  maybe if you keep your node connected to your computer with USB to serial adapter ?
                  • siodS
                    siodS
                    siod
                    mmh, no, that would mean I would have to run my computer for maybe 2 weeks 24/7...
                    I guess it has somehting to do with the sleep function, the device seems to nat wake up after a while for some reason
                    still learning...
                    • dpressleD
                      dpressleD
                      dpressle
                      wrote on last edited by dpressle
                      #359
                      So i got the boards and build them and they work perfect.
                      One thing i couldn't figure out is why do i get relatively high current consumption, when the node is sleeping i get 1.5mA and not 5.8uA as in mentioned in this post.
                      I use 8MHz internal clock and the sleep function and nothing is connected to the node.
                      Can someone help?
                      AWIA 1 Reply Last reply
                      • dpressleD dpressle
                        Can someone help?
                        AWIA
                        AWIA
                        AWI
                        @dpressle Can you post the sketch?
                        • dpressleD
                          dpressleD
                          dpressle
                          Thanks, i see its 6.8 uA now, i had something wrong with my measurements :disappointed:
                          • JonnyDev13J
                            JonnyDev13J
                            JonnyDev13
                            It took me a while, but I just figured out how to get a bootloader burned onto the chip and I'm ready to make my slim nodes! Which board type in Arduino IDE do I use to program the chip once I'm using the 6 pin header after it's installed in the PCB?
                            m26872M 1 Reply Last reply
                            • JonnyDev13J JonnyDev13
                              m26872M
                              m26872M
                              m26872
                              @JonnyDev13 Make a new board type by editing "boards.txt". There's an example in the first post.
                              • ร
                                ร
                                รอเรือ
                                wrote on last edited by รอเรือ
                                #364
                                Hi there! I need to buy some PCBs on Dirty PCBs but the URL http://dirtypcbs.com/view.php?share=13847&accesskey= seems broken. Any ideas? Thanks!
                                • ร รอเรือ
                                  m26872M
                                  m26872M
                                  m26872
                                  wrote on last edited by m26872
                                  #365
                                  @รอเรือ Apparently they've moved to a new site. Perhaps you can try this link: http://dev.dirtypcbs.com/store/designer/details/m26872/663/myslim2aabatterynodepcbv2-0panelized
                                  I think you must have a user account and login first. Please report back if it's working or not.
                                  Edit: Wrong link the first time.
                                  ร 1 Reply Last reply
                                  • m26872M m26872
                                    ร
                                    ร
                                    รอเรือ
                                    Thanks @m26872
                                    That link didn't work either. However, by browsing all the shared PCBs I found this URL That link is accessible without logging in first.
                                    • ร รอเรือ
                                      Thanks @m26872
                                      m26872M
                                      m26872M
                                      m26872
                                      @รอเรือ Thanks a lot! All links are now changed.
                                      • E
                                        E
                                        Eawo
                                        wrote on last edited by Eawo
                                        #368
                                        Hey im building my first slim node and i wonder if someone has a sketch for 2 reed switches? i have found the sketch for only 1 reed switch in this thread. Im going to use it for my mailbox. How long do u think it can run on 2x aa batteries?
                                        Do i have to add 2x 10M resistors? or doesnt it work with external resistors then using more then 1 reed switch?
                                        m26872M 2 Replies Last reply
                                        • E Eawo
                                          m26872M
                                          m26872M
                                          m26872
                                          @Eawo The example sketch should fit your needs. link Change the pull-ups activation to Low if you use external ones.
                                          I'd expect battery life 5-10 years depending on things such mailbox opening frequency, use of heartbeat signal, battery self discharge and climate.
