  3. My Slim 2AA Battery Node
498 Posts 71 Posters 598.5k Views 69 Watching
  • carlekiC carleki
    I have received yesterday my little packet from DirtyPCB :)
    11 PCBs, so 33 sensors :)
    I'm just wondering where the C5 capactior will go on the board .. Can't figure out :(
    J
    J
    jeti
    wrote on last edited by jeti
    #347
    @carmelo42: maybe this helps, all Cs and the R assembled!
    J 1 Reply Last reply
    • J jeti
      J
      J
      jeti
      ups... C5 is also not there on my board,it shoud be parallel to C4!
      carlekiC 1 Reply Last reply
      • J jeti
        carlekiC
        carlekiC
        carleki
        • carlekiC
          carlekiC
          carleki
          @m26872 is it possible to send the sketch in the atmega on board ? using an FTDI serial/usb ?
          • carlekiC carleki
            J
            J
            jeti
            @carmelo42 yes
            • J jeti
              @carmelo42 yes
              carlekiC
              carlekiC
              carleki
              @jeti said:
              @carmelo42 yes
              I have this serial/usb adapter :
              https://img1.picload.org/image/ldrrddg/deekrobot-isp.png
              Can you tell me how I connect it to my node ? (noob question I guess ... but I don't want to burn my node :( )
              • carlekiC carleki
                @jeti said:
                @carmelo42 yes
                carlekiC
                carlekiC
                carleki
                @carmelo42 said:
                @jeti said:
                @carmelo42 yes
                I have found the answer myself with the schematic ;)
                Have you ever tried to power the node with 1 x CR2032 battery ?
                I have tried, but the node doesn't send anything further than 5 meters ...
                • siodS
                  siodS
                  siod
                  I would like to know if your nodes are working all fine. I have the problem that my nodes freeze after a day or sometimes after a week.
                  still learning...
                  • siodS siod
                    carlekiC
                    carlekiC
                    carleki
                    @siod my temperature nodes work good, but my relay one doesn't work :'(
                    Do you have any logs when it freezes ?
                    • siodS
                      siodS
                      siod
                      @carmelo42 no, unfortunately I don´t have any logs, any idea how to create logs?
                      still learning...
                      • siodS siod
                        carlekiC
                        carlekiC
                        carleki
                        maybe if you keep your node connected to your computer with USB to serial adapter ?
                        • siodS
                          siodS
                          siod
                          mmh, no, that would mean I would have to run my computer for maybe 2 weeks 24/7...
                          I guess it has somehting to do with the sleep function, the device seems to nat wake up after a while for some reason
                          still learning...
                          • dpressleD
                            dpressleD
                            dpressle
                            wrote on last edited by dpressle
                            #359
                            So i got the boards and build them and they work perfect.
                            One thing i couldn't figure out is why do i get relatively high current consumption, when the node is sleeping i get 1.5mA and not 5.8uA as in mentioned in this post.
                            I use 8MHz internal clock and the sleep function and nothing is connected to the node.
                            Can someone help?
                            AWIA 1 Reply Last reply
                            • dpressleD dpressle
                              Can someone help?
                              AWIA
                              AWIA
                              AWI
                              @dpressle Can you post the sketch?
                              • dpressleD
                                dpressleD
                                dpressle
                                Thanks, i see its 6.8 uA now, i had something wrong with my measurements :disappointed:
                                • JonnyDev13J
                                  JonnyDev13J
                                  JonnyDev13
                                  It took me a while, but I just figured out how to get a bootloader burned onto the chip and I'm ready to make my slim nodes! Which board type in Arduino IDE do I use to program the chip once I'm using the 6 pin header after it's installed in the PCB?
                                  m26872M 1 Reply Last reply
                                  • JonnyDev13J JonnyDev13
                                    m26872M
                                    m26872M
                                    m26872
                                    @JonnyDev13 Make a new board type by editing "boards.txt". There's an example in the first post.
                                    • ร
                                      ร
                                      รอเรือ
                                      wrote on last edited by รอเรือ
                                      #364
                                      Hi there! I need to buy some PCBs on Dirty PCBs but the URL http://dirtypcbs.com/view.php?share=13847&accesskey= seems broken. Any ideas? Thanks!
                                      • ร รอเรือ
                                        m26872M
                                        m26872M
                                        m26872
                                        wrote on last edited by m26872
                                        #365
                                        @รอเรือ Apparently they've moved to a new site. Perhaps you can try this link: http://dev.dirtypcbs.com/store/designer/details/m26872/663/myslim2aabatterynodepcbv2-0panelized
                                        I think you must have a user account and login first. Please report back if it's working or not.
                                        Edit: Wrong link the first time.
                                        ร 1 Reply Last reply
                                        • m26872M m26872
                                          ร
                                          ร
                                          รอเรือ
                                          Thanks @m26872
                                          That link didn't work either. However, by browsing all the shared PCBs I found this URL That link is accessible without logging in first.
