  3. RFM69HW make a chance in Myconfig.h
11 Posts 5 Posters 3.4k Views 3 Watching
  • TON RIJNAARDT Offline
    TON RIJNAARD
    I am trying to make a gateway and sensor with RFM 69HW.
    Stil now it is not working and i don't no what it is.
    I see in the MyConfig bij the RFM69HW a remark // standing and i use 433 Mhz and in the Myconfig.h is 862 Mhz.
    Can some one tell mee that i have to make chance in his Myconfig.h file.
    2e questing can i test the gateway?
    I see the gateway in domoticz is it than working.
    Ton Rijnaard
    • T Offline
      T Offline
      tbowmo
      @TON-RIJNAARD
      It should not be necessary to change the MyConfig.h file. All you need is to include the following in your sketch (before you include MySensors.h)
      #define MY_RFM69_FREQUENCY  RF69_433MHZ
        TON RIJNAARD
        Thanks for the fast re[ly but with the RF69_433MHZ it is not work.
        I get from the GW the next information.
        0;255;3;0;9;Starting gateway (RRNGA-, 2.0.0)
        0;255;3;0;9;TSM:INIT
        0;255;3;0;9;TSM:RADIO:OK
        0;255;3;0;9;TSM:GW MODE
        0;255;3;0;9;TSM:READY
        0;255;0;0;18;2.0.0
        0;255;3;0;9;TSP:SANCHK:OK
        Tis information from the node:
        Starting sensor (RRNNA-, 2.0.0)
        TSM:INIT
        TSM:RADIO:OK
        TSP:ASSIGNID:OK (ID=1)
        TSM:FPAR
        TSP:MSG:SEND 1-1-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
        TSM:FPAR
        TSM:FPAR
        TSM:FPAR
        !TSM:FPAR:FAIL
        !TSM:FAILURE
        TSM:PDT
        The GW is Arduino uno with RFM69HW + 47 uf capacitor
        The Node is Mini pro with RFM69HW + 47 uf cacitor and 3.3 volt regulator.
        Can some one tell me of the information from the GW is correct.
        And what there is fals with the node that the !TSM:FPAR:FAIL means.
        Ton Rijnaard
        • alexsh1A Offline
          alexsh1A Offline
          alexsh1
          @TON-RIJNAARD Do not forget - you have H version, so put the following in your sketch or change it in Myconfig.h
          #define MY_IS_RFM69HW
          EDIT: !TSM:FPAR:FAIL means the parent (GW) not found. Your node is not communicating
          to the GW. Try to put (1) the same frequencies and (2) as above in the GW and node sketches
            TON RIJNAARD
            I have chance the sketch like under:
            // #define MY_RADIO_NRF24
            #define MY_RADIO_RFM69HW_FREQUENCY RF69_433MHZ
            #define DIGITAL_INPUT_SENSOR 3 // The digital input you attached your motion sensor. (Only 2 and 3 generates interrupt!)
            #define CHILD_ID 1 // Id of the sensor child
            Now i can not compile the sketch i get this error:
            In file included from C:\Users\tonri\AppData\Local\Temp\arduino_modified_sketch_877909\MotionSensor.ino:38:0:
            C:\Users\tonri\Documents\Arduino\libraries\arduino_572221/MySensors.h:287:4: error: #error No forward link or gateway feature activated. This means nowhere to send messages! Pretty pointless.
            exit status 1
            Fout bij het compileren van board Arduino Pro or Pro Mini
            When i get the // away #define MY_RADIO_NRF24 then ik can compile wth out error
            Now give the monitor that no radio:
            TSM:INIT
            !TSM:RADIO:FAIL
            !TSM:FAILURE
            TSM:PDT
            TSM:INIT
            !TSM:RADIO:FAIL
            !TSM:FAILURE
            TSM:PDT
            I have also change the Myconfig.h but no chance
            Ton
            • TON RIJNAARDT TON RIJNAARD
              exit status 1
              TSM:INIT
              !TSM:RADIO:FAIL
              !TSM:FAILURE
              TSM:PDT
              TSM:INIT
              !TSM:RADIO:FAIL
              !TSM:FAILURE
              TSM:PDT
              Ton
              mfalkviddM Online
              mfalkviddM Online
              @TON-RIJNAARD The rfmhw radio needs to be enabled. Add this before including MySensors.h
              with no transport enabled, there would be nowhere to send messages.
                TON RIJNAARD
                @mfalkvidd
                Thanks for your help.
                Look ad my piece of sketch that is be enabled or do i see somting about the head.
                Ton
                • K Offline
                  K Offline
                  korttoma
                  Hi @TON-RIJNAARD did you manage to get this to work?
                  Here is how I have configured my RFM69 nodes and gateway when using RFM69 with 433MHz:
                  Code in the beginning of Gateway sketch:
                  //#define MY_RADIO_NRF24
                  Code in the beginning of each sensor node:
                  I have not done any chages to the Myconfig.h
                  Hope this helps...
                  • Tomas
                  alexsh1A 1 Reply Last reply
                  • K korttoma
                    Hope this helps...
                    alexsh1A Offline
                    alexsh1A Offline
                    alexsh1
                    @korttoma Why disabling MY_DEBUG? This is a useful function?
                    You can either introduce your code in each sketch (like you did) or change MyConfig.h to make it default
                    K 1 Reply Last reply
                    • alexsh1A alexsh1
                      K Offline
                      K Offline
                      korttoma
                      @alexsh1 I usually disable debug once I have confirmed that my node is working as expected. While testing I do have it enabled.
                      • Tomas
                        TON RIJNAARD
                        Hello
                        Thanks for all the help i have it working now!!
                        The problem was that in the GW this line was not there.
                        #define MY_RFM69_PA_LEVEL RF69_PA_LOW
                        here was standing, i have not chance that line
                        ton
