  2. Announcements
  3. 💬 Water Meter Pulse Sensor
109 Posts 37 Posters 67.0k Views 35 Watching
  • Patrik SöderströmP
    Patrik SöderströmP
    Patrik Söderström
    I get error on compiling.
    "exit status 1
    call of overloaded 'set(volatile long unsigned int&)' is ambiguous"
    The following line gets red marked in Arduino IDE
    send(lastCounterMsg.set(pulseCount)); // Send pulsecount value to gw in VAR1
      Compiles fine here in 1.6.12..
        Patrik SöderströmP
        Patrik Söderström
        Running 1.6.11, will try and update.
          Patrik SöderströmP
          Patrik Söderström
          Should have said that I was trying to run it on a Node MCU 0.9. I can compile fine for Arduino Nano but not for Node MCU. Also I got another error now when I upgraded to 1.6.12.
          In file included from C:\Users\xxxxx\Documents\Arduino\libraries\MySensors-development/MySensors.h:337:0,
                           from C:\Users\xxxxxxx\AppData\Local\Temp\untitled921979828.tmp\sketch_oct14a\sketch_oct14a.ino:44:
          C:\Users\xxxxxxx\Documents\Arduino\libraries\MySensors-development/core/MyMainESP8266.cpp:4:22: fatal error: Schedule.h: No such file or directory
           #include "Schedule.h"
          compilation terminated.
          exit status 1
          Error compiling for board NodeMCU 0.9 (ESP-12 Module).```
            Please update NodeMCU in board manager to rc3.
            Hmm .. I can see the "overloaded 'set(volatile long unsigned int&)' is ambiguous" error here as well... I wonder why it behaves differently from Arduino...
              Works if you replace
              with
              volatile uint16_t pulseCount = 0;
                Patrik SöderströmP
                Patrik Söderström
                Great! Thanks for the help :)
                Now I just need to figure out a good placement for it and get values to Domoticz.
                But this helped me a lot to get started.
                • V
                  V
                  vikram0228
                  It is not clear to me from the picture if the water meter pulse output leads go to gnd and VCC or VCC and DO? The water-meter pulse output is only two leads.
                  I am going to MySensors with great hope on this water meter sensor. I have the Vera gateway working fine. Now the test with my first and most important sensor!
                  Thanks in advance
                  • V vikram0228
                    Thanks in advance
                    @vikram0228 I haven't built this node, but the pictures and the connections table on the page describes three leads. Do you have a different sensor?
                    • V
                      V
                      vikram0228
                      Water Meters with pulse output have two leads. They generate a simple pulse.
                      The MySensors circuit also should also work with two leads - just need to know which two. The three leads are for water meters with no pulse output and where you need an optical sensor to sense the moving wheel.
                      • DirtbagD
                        DirtbagD
                        Dirtbag
                        Hi.
                        Cant get my watersensor to send any values.
                        I have debug enabled and it seems like it communicates fine with the gw but no flow data are beeing reported to the gw or the serial monitor.
                        TSP:MSG:SEND 4-4-0-0 s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=ok:
                        Anyone else experienced this problem?
                        • bart59B
                          bart59B
                          bart59
                          wrote on last edited by bart59
                          I wanted to operate my water pulse meter on batteries and also get the water flow. The original design had the following issues with that:
                          • Incorrect flow calc: micros() was used to calculate the flow, however micros() wraps every 70 minutes which looks like a huge flow (which is then discarded in code)
                          • Volume calc: millis() wraps every 50 days which is not handled correctly either
                          • Too much current for battery use: The IR LED of the TCRT5000 is always on and the LM393 comparator is also taking a few mA's
                          • Could not report flow in sleep mode because millis() does not increment on sleep - need to do this based on calculation of total sleep time. We now simply calculate the number of pulses per minute and deduct the flow
                          • I also had issued with the data transport reliability, so I added error counters (which show up on the Gateway as distance sensors)
                          • I also wanted to provide a measurement counter to the gateway (that counts up each time a message is sent)
                          • The sensor will reboot itself when too many errors occur
                          So I modified the circuit of the IR sensor:
                          • Assumption that the wheel of the water meter turns slowly (takes at least a few seconds to turn around)
                          • We will wake up every 500 millisecond to turn on the IR LED connected to PIN 8. Pin 8 also powers the photo transistor that measures the reflection
                          • I removed the power from the opamp circuit that is linked to the photo transistor
                          • The voltage from the photo transistor is then read using an analog read on A1. Based on a threshold value we will deduct if the mirror on the water meter is in view
                          • Pin 7 is connected to a learning switch which will turn the device in a specific mode and the min/max values on A1 are used to calculate the value of the threshold (which is then stored in the EEPROM)
                          • After 30 seconds in learning mode, the new threshold is established and the LED on Pin 6 will show the actual on/off mirror signals, so you can see the pulses are correctly counted
                          • switch back the DIP switch on Pin 7 to bring back normal mode
                          • The circuit also contains the battery voltage sensor circuit (I am using a 1.5V battery and step up circuit). So the resistors used are 470k from + pole of battery to the A0 input and 1 M ohm from A0 to ground
                           * Version 1.0 - Henrik Ekblad
                           * Version 1.1 - GizMoCuz
                           * Version 1.2 - changed BM: using low power separate circuit for infra red on pin 8 + analog A1
                           * ISSUES WITH ORIGINAL CODE
                           * Incorrect flow calc: micros() was used to calculate the flow, however micros() is wraps every 70 minutes which looks like a huge flow (which is discarded)
                           * Volume calc: millis() wraps every 50 days which is not handled correctly
                           * Too much current for battery use: The IR LED of the TCRT5000 is always on and the LM393 comparator is also taking a few mA's
                           * Could not report flow in sleep mode because millis() does not increment on sleep - need to do this based on calculation of total sleep time
                           * MODIFIED CIRCUIT IR SENSOR
                           * Assumption that the wheel of the water meter turns slowly (takes at least a few seconds to turn around)
                           * We will wake up every second to turn on the IR LED (connected to PIN 8). Pin 8 also powers the photo transistor that measures the reflection
                           * The voltage from the photo transistor is then read using an analog read on A1. Based on a treshold value we will deduct if the mirror is in view
                           * Pin 7 is connected to a learning switch which will turn the device in continous mode and the min/max values on A1 are used to recalc the treshold
                           * during a 30 second period. After this period the new treshold is established and the LED on Pin 6 will show the actual on/off mirror signals
                           * http://www.mysensors.org/build/pulse_water
                          // BOARD: PRO MINI 3.3V/ 8Mhz ATMEGA328 8Mhz
                          #define MY_NODE_ID 10                 // hard code the node number
                          #define SENSOR_POWER 8                // pin that will provide power to IR LED + sense circuit
                          #define IR_SENSE_PIN  A1              // input for IR voltage
                          #define BATTERY_SENSE_PIN  A0         // select the input pin for the battery sense point
                          #define LEARN_SWITCH_PIN 7            // switch (SW1 on battery module) to turn on learning mode (low==on)
                          #define LEARN_LED_PIN 6               // LED feedback during learning mode (LED on battery module)
                          #define LEARN_TIME 30                 // number of seconds we will keep learn loop
                          #define PULSE_FACTOR 1000             // Nummber of blinks per m3 of your meter (One rotation/1 liter)
                          #define MAX_FLOW 80                   // Max flow (l/min) value to report. This filters outliers.
                          #define CHILD_ID 1                    // Id of the sensor child (contains 3 subs: V_FLOW, V_VOLUME, VAR1)
                          #define CHILD_PINGID 2                // ID of ping counter
                          #define CHILD_ERRID 3                 // ID of error counter
                          #define CHECK_FREQUENCY 500           // time in milliseconds between loop (where we check the sensor) - 500ms
                          #define MIN_SEND_FREQ 60              // Minimum time between send (in multiplies of CHECK_FREQUENCY). We don't want to spam the gateway (30 seconds)
                          #define MAX_SEND_FREQ 1200            // Maximum time between send (in multiplies of CHECK_FREQUENCY). We need to show we are alive (600 sec/10 min)
                          #define IR_ON_SETTLE 2                // number of milliseconds after we turned on the IR LED and we assume the receive signal is stable (in ms)
                          #define EE_TRESHOLD 10                // config addresses 0 + 1 used for treshold from learning (loadState() returns only uint8 value)
                          #define TRESHOLD_MARGIN 3             // additional margin before we actually see a one or zero
                          #define RESETMIN 5                    // number of cycle times (either 30 sec of 10 min) we consistently need to have transmission errors before we perform hard reset
                          MyMessage volumeMsg(CHILD_ID,V_VOLUME); // display volume and flow on the same CHILD_ID
                          MyMessage flowMsg(CHILD_ID,V_FLOW); // flow
                          MyMessage lastCounterMsg(CHILD_ID,V_VAR1);
                          MyMessage pingMsg(CHILD_PINGID,V_DISTANCE); // use distance to keep track of changing value
                          MyMessage errMsg(CHILD_ERRID,V_DISTANCE); // use distance to keep track of changing value
                          double ppl = ((double)PULSE_FACTOR / 1000.0);    // Pulses per liter
                          unsigned int oldBatteryPcnt = 0;          // check if changed
                          unsigned int minsendcnt = MIN_SEND_FREQ;  // counter for keeping minimum intervals between sending
                          unsigned int maxsendcnt = MAX_SEND_FREQ;  // counter for keeping maximum intervals between sending
                          unsigned int treshold = 512;              // threshold value when to swap on/off for pulse
                          unsigned long pulseCount = 0;             // total volume of this pulse meter (value stored/received on gateway on pcReceived)
                          unsigned long oldPulseCount = 0;          // to see if we have received something
                          boolean pcReceived = false;               // received volume from prior reboot
                          boolean onoff = false;                    // sensor value above/below treshold
                          unsigned int intervalcnt = 0;             // number of cycles between last period (for flow calculation)
                          double flow = 0;                          // maintain flow
                          double oldflow = 0;                       // keep prior flow (only send on change)
                          unsigned int learntime=LEARN_TIME*2;      // timer for learning period
                          unsigned int learnlow = 1023;             // lowest value found during learning
                          unsigned int learnhigh = 0;               // highest value found during learning
                          boolean learnsaved = false;               // have saved learned value
                          unsigned long pingcnt = 0;
                          unsigned long errcnt = 0;                 // error count
                          unsigned int errcnt2 = 0;                 // error counter set to 0 when sending is ok
                          void(* resetFunc) (void) = 0;//declare reset function at address 0 (for rebooting the Arduino)
                            // make sure a few vars have the right init value after software reboot
                            pingcnt = 0;
                            pcReceived = false;
                            pulseCount = oldPulseCount = 0;
                            // setup hardware
                            pinMode(SENSOR_POWER, OUTPUT);
                            digitalWrite(SENSOR_POWER, LOW);
                            pinMode(LEARN_SWITCH_PIN, INPUT_PULLUP);
                            pinMode(LEARN_LED_PIN, INPUT);      // default is input because this pin also has SW2 of battery block
                            // Fetch last known pulse count value from gateway
                            request(CHILD_ID, V_VAR1);
                            // Fetch threshold value from EE prom
                            treshold = readEeprom(EE_TRESHOLD);
                            if (treshold<30 || treshold>1000) treshold = 512;   // wrong value in EEprom, take default
                            Serial.print("Treshold: ");
                            Serial.println(treshold);
                            // use the 1.1 V internal reference for the battery and IR sensor
                             analogReference(INTERNAL1V1);
                             analogReference(INTERNAL);
                            analogRead(IR_SENSE_PIN); // settle analogreference value
                            wait(CHECK_FREQUENCY); // wait a bit
                          void presentation()  {
                            sendSketchInfo("Water Meter", "1.2");
                            // Register this device as Waterflow sensor
                            present(CHILD_ID, S_WATER);
                            present(CHILD_PINGID, S_DISTANCE);
                            present(CHILD_ERRID, S_DISTANCE);
                            if (digitalRead(LEARN_SWITCH_PIN)==LOW) {
                              pinMode(LEARN_LED_PIN, OUTPUT);
                              digitalWrite(SENSOR_POWER, HIGH);
                              intervalcnt = 0;
                              learn_loop();
                              learnlow = 1023;
                              learnhigh = 0;
                              normal_loop();
                          void learn_loop() {
                            // will run into this loop as long as we are learning
                            wait(500);
                            unsigned int sensorValue = analogRead(IR_SENSE_PIN);
                            Serial.print("IR: ");
                            Serial.print(sensorValue);
                            if (learntime>0) {
                              // still learning
                              learntime--;
                              learnsaved = false;
                              digitalWrite(LEARN_LED_PIN, !digitalRead(LEARN_LED_PIN));  // blink led
                              if (sensorValue < learnlow) {
                                learnlow = sensorValue;
                                Serial.println(" Lowest");
                              } else if (sensorValue > learnhigh) {
                                learnhigh = sensorValue;
                                Serial.println(" Highest");
                              } else Serial.println();
                              if (!learnsaved) {
                                treshold = (learnhigh + learnlow)/2;
                                storeEeprom(EE_TRESHOLD, treshold);
                              learnsaved = true;
                              // just display using LED
                              digitalWrite(LEARN_LED_PIN, sensorValue>treshold);
                              Serial.println((sensorValue>treshold ? " on" : " off"));
                          void normal_loop() {
                            unsigned long start_loop = millis();    // to allow adjusting wait time
                            intervalcnt++;
                            // we start doing a measurement
                            wait(IR_ON_SETTLE);
                            #ifdef MY_DEBUG_DETAIL
                            Serial.println(sensorValue);
                            boolean nowvalue = onoff;
                            if (onoff && (sensorValue<treshold-TRESHOLD_MARGIN)) nowvalue = false;
                            if (!onoff && (sensorValue>treshold+TRESHOLD_MARGIN)) nowvalue = true;
                            if (nowvalue != onoff) {
                              // we have a pulse, only count on upwards pulse
                              onoff = nowvalue;
                              if (onoff) {
                                pulseCount++;
                                #ifdef MY_DEBUG
                                Serial.print("p: ");
                                Serial.println(pulseCount);
                            if (minsendcnt>0) minsendcnt--;
                            if (maxsendcnt>0) maxsendcnt--;
                            // send minimum interval when we have pulse changes or if we had some flow the prior time or send on timeout
                            if ((minsendcnt==0 && (pulseCount != oldPulseCount)) || (minsendcnt==0 && oldflow != 0) || maxsendcnt==0) {
                              if (!pcReceived) {   //Last Pulsecount not yet received from controller, request it again
                                Serial.print("Re-request var1 ..");
                          // Prevent flooding the gateway with re-requests,,, wait at least 1000 ms for gateway (cannot be sleep or smartSleep
                                wait(2*CHECK_FREQUENCY);
                                return;
                              pingcnt++;
                              sensorValue = analogRead(BATTERY_SENSE_PIN);
                              // ((1e6+470e3)/1e6)*1.1 = Vmax = 1.67 Volts
                              // 1.67/1023 = Volts per bit = 0.00158065
                              Serial.print("Battery %: ");
                              Serial.println(batteryPcnt);
                                oldBatteryPcnt = batteryPcnt;
                              double volume = ((double)pulseCount/((double)PULSE_FACTOR));
                              flow = ((double) (pulseCount-oldPulseCount)) * (60000.0 / ((double) intervalcnt*(double) CHECK_FREQUENCY)) / ppl;  // flow in liter/min
                              #ifdef MY_DEBUG
                              Serial.print("pulsecount:");
                              Serial.print("volume:");
                              Serial.println(volume, 3);
                              Serial.print("l/min:");
                              Serial.println(flow);
                              bool b = send(lastCounterMsg.set(pulseCount));  // Send  pulsecount value to gw in VAR1
                              if (b) errcnt2=0; else { errcnt++; errcnt2++; }
                              b = send(volumeMsg.set(volume, 3));               // Send volume (set function 2nd argument is resolution)
                              b = send(flowMsg.set(flow, 2));                   // Send flow value to gw
                              b = send(pingMsg.set(pingcnt));                   // ensure at least this var has a different value
                              b = send(errMsg.set(errcnt2+((float) errcnt2/100),2));    // ensure we always send error count
                              oldPulseCount = pulseCount;
                              intervalcnt = 0;
                              oldflow = flow;
                              if (errcnt2>= (5*RESETMIN)) {
                                Serial.println("Reset");
                                wait(300);
                                resetFunc(); //call reset to reboot the Arduino
                          // calculate how long it took to process all of this. then go to sleep for the remaining period
                            unsigned long end_loop = millis();
                            if (end_loop - start_loop < CHECK_FREQUENCY)
                              sleep(CHECK_FREQUENCY - (end_loop > start_loop ? end_loop - start_loop : 0));
                            if (message.type==V_VAR1) {
                              unsigned long gwPulseCount=message.getULong();
                              pulseCount += gwPulseCount;
                              oldPulseCount += gwPulseCount;
                              flow=oldflow=0;
                              Serial.print("Received last pulse count from gw:");
                              pcReceived = true;
                          void storeEeprom(int pos, int value) {
                              // function for saving the values to the internal EEPROM
                              // value = the value to be stored (as int)
                              // pos = the first byte position to store the value in
                              // only two bytes can be stored with this function (max 32.767)
                              saveState(pos, ((unsigned int)value >> 8 ));
                              pos++;
                              saveState(pos, (value & 0xff));
                          int readEeprom(int pos) {
                              // function for reading the values from the internal EEPROM
                              // pos = the first byte position to read the value from
                              int hiByte;
                              int loByte;
                              hiByte = loadState(pos) << 8;
                              pos++;
                              loByte = loadState(pos);
                              return (hiByte | loByte);
                          mfalkviddM Emmanuel AbrahamE 2 Replies Last reply
                          • bart59B bart59
                              pingcnt = 0;
                              pcReceived = false;
                              // setup hardware
                                intervalcnt = 0;
                                learn_loop();
                                learnlow = 1023;
                                learnhigh = 0;
                                normal_loop();
                            void learn_loop() {
                              wait(500);
                              if (learntime>0) {
                                // still learning
                                learntime--;
                                learnsaved = false;
                                if (!learnsaved) {
                                learnsaved = true;
                              intervalcnt++;
                              wait(IR_ON_SETTLE);
                                onoff = nowvalue;
                                if (onoff) {
                                  pulseCount++;
                                  #ifdef MY_DEBUG
                                  return;
                                pingcnt++;
                                #ifdef MY_DEBUG
                                intervalcnt = 0;
                                oldflow = flow;
                                  wait(300);
                                flow=oldflow=0;
                                pcReceived = true;
                                pos++;
                                int hiByte;
                                int loByte;
                                pos++;
                            Great work @bart59 !
                            Do you have any indication on how long battery life you will get with this setup?
                            bart59B S 2 Replies Last reply
                              bart59B
                              bart59B
                              bart59
                              @mfalkvidd - I did measure the average current consumption at the time, but I not remember the exact value. I believe it was well below the 0.5 mA. The sensor has been up and running on the same single 1.5V AA battery for 30 days now and the batt percentage still shows 93%.
                              • dpcrD
                                dpcrD
                                dpcr
                                I hope this is not off topic but I'm trying to read our gas meter - but....I cannot use a photo sensor or a hall sensor or a reed switch (the meter is outside and there is no magnet in it). I was able to get some good data using a magnetometer (https://www.sparkfun.com/tutorials/301) using an arduino. But I tink from what I am told is the arduino isn't big enough to handle the code I need to use to change the data (x axis, y axis, z axis) into a pulse but will work on a pi.
                                My question is am I missing something (hardware guy, not software)? Can I use a Pi for a sensor (it has the inputs and room), all the code on this site is for arduinos. Could I have the Pi output a pulse to an arduino? Am I over thinking this?
                                bart59B 1 Reply Last reply
                                • dpcrD dpcr
                                  bart59B
                                  bart59B
                                  bart59
                                  @dpcreel. I would be surprised the Arduino could not handle the HMC5883L magnetometer from Sparkfun. The I2C protocol is natively supported and you only need to analyse numbers coming from the 3-Axis to decide when the wheels inside the gas meter turn. I think the position of the sensor will be very critical, but the code should not be too complex. Arduino's are typically limited in handling much data (there is only 2000 bytes of RAM in the ATmega328), but your code should not need much RAM space. The program size can be 32 KB which should be enough.
                                  If you want to go for the PI, there are I2C libraries out there you could use and I would then bypass the Mysensors gateway alltogether and connect an ethernet cable to the PI and use the MQTT protocol to talk to your home controller.
                                  regards
                                  Bart
                                  dpcrD 1 Reply Last reply
                                  • bart59B bart59
                                    regards
                                    Bart
                                    dpcrD
                                    dpcrD
                                    dpcr
                                    @bart59 The Arduino works fine with the HMC5883L, I got some good data from it and was able to "see" the gas meter movements very well. I am not able to write code (hardware guy) to change this data to a pulse for MySensors or whatever it needs. I just want to be able to read my gas meter with the HMC5883L. I did find some code in python that works on the pi, that's why I mentioned it. I'm a hack at software.
                                    • A
                                      aram
                                      Hi
                                      I am trying to use the subject code with pulse water meters and hope someone can help to figure out what needs to be adjusted to get more accurate data.
                                      My setup:
                                      Gateway ESP8266 (NodeMCU) + NRF24 -> Connected to Domoticz
                                      Sensor node: Arduino Uno + NRF24
                                      Default codes from Build. Test sensors so far work great.
                                      Task:
                                      Need to connect Siemens WFK2 water meters (four of them actually) with pulse outputs (2 line). According to data sheet (link text) there are two types: reed output or NAMUR.
                                      To start with, I connected the reed output of the water meter via 10k resistor to +5V, GND and D3. Again, according to data sheet, for every 10l the water meter should give an impulse (e.g. connect the switch). Taking this into account I have adjusted pulse factor to 100 and based on Nominal Flow Rate (Max Flow Rate impossible in my case) limited Max Flow to 25 l/min. This setup works, but I definitely get wrong flow values (e.g. with constant flow of 6l/min serial monitor and domoticz report anything between 12-15l/min) and also wrong water usage m3 and litre usage in Domoticz.
                                      When trying to debug, found out following behaviour (must be connected to Pulse length an Qn from data sheet IMHO):
                                      with each turn it indeed switches on, e.g. shortens the contacts which generates pulse for the sensor, however it takes up to 2-4 litres until switch is in the off state.
                                      As a result you might have a situation when meter switches on, one closes the tap, and the signal is on for minutes/hours until tap is again opened and 2-4 litres have been used, after which signal will switch off.
                                      Do I understand correctly that the debouncer which should take care of similar situations is not ready for this?
                                      thanks in advance for support
                                      • bart59B
                                        bart59B
                                        bart59
                                        Hi Aram
                                        The original code from the mysensors site does not handle your situation very well (indeed because the switch staying on or off for a long time). You can use my code (see my post further up this discussion). In my case I have a pulse every 1 liter.
                                        In your case you only have 1 pulse every 10 liters, which means you have to take a much longer period to calculate the flow correctly. Basically you have to set MIN_SEND_FREQ to a higher value. The flow is calculated based on the number of pulses in a given time period. Example: with 6 l/min you have to calculate this value only once every 5 minutes (=30 liter = 3 pulses from your Siemens meter) instead of every 30 seconds as I do. So if MIN_SEND_FREQ = 600 (every 5 minutes) your flow is calculated as:
                                        In the example above (pulseCount-oldPulseCount) = 3 pulses
                                        ppl = 0.1
                                        intervalcnt = MIN_SEND_FREQ = 600
                                        CHECK_FREQUENCY = 500
                                        ==> flow is 6 l/min
                                        regards
                                        Bart
                                        • A
                                          aram
                                          bart59,
                                          thanks for quick reply. I will try to adjust MIN_SEND_FREQ and use your code.
                                          however, if I understand correctly, with the current logic used its impossible to avoid misinterpretations of pulses in case of very very long on or off state. It will approximate the flow rate to more correct value during usage of water (this is good enough) and should report total usage somehow correctly (this one I would better get as precise as possible). I wonder if the code will capture the correct number of pulses in the case of very long on state.
                                          BTW, I was not able to find a readily available sketch to connect NAMUR output, which is basically 5kOhm off state and 1.5795 kOhm on state. I believe, I will have to calculate required pull up resistance to get a proper voltage divider for 5\3.3v, right?
