  3. 💬 OH MySensors RGBW Controller
mysensorspcbrgbwcontroller
106 Posts 18 Posters 59.4k Views 19 Watching
  • openhardware.ioO
    openhardware.ioO
    openhardware.io
    https://www.openhardware.io/view/74/OH-MySensors-RGBW-Controller
    • Cliff KarlssonC
      Cliff KarlssonC
      Cliff Karlsson
      Is it possible to buy the corrected pcb anywhere?
      • L
        L
        LastSamurai
        Not yet. You could take the kicad files from my github and change that by yourself. I did start to update my design some weeks ago but as I still have enough of the old boards (and they work with that one tweak) I didn't finish that. Might do that soon so. Once I updated it I will add the new file to my github repo and the openhardware page.
        • L
          L
          LastSamurai
          @Cliff-Karlsson I did update my kicad and gerber files in the github repo (are these files automatically updated in the openhardware.io project too?). I haven't tested these yet but they should work without an error now. You could just take these gerber files and order them somewhere.
            Nope, you have to press the refresh button in the github-tab.
            • Cliff KarlssonC
              Cliff KarlssonC
              Cliff Karlsson
              Great, just one stupid question. Do I just upload the gbl file to dirtypcbs/oshpark or how does it work?
              L 1 Reply Last reply
                L
                L
                LastSamurai
                wrote on last edited by LastSamurai
                You take a zip file with all the gerber files inside (I think I already put one into the git), test it online (if you want to; sometimes it doesnt look perfect here) and then you upload it to dirtypcbs. I don't know how oshpark works, but I guess similar.
                Online gerber viewers I use are:
                http://circuitpeople.com/
                http://mayhewlabs.com/3dpcb
                Edit: I did just fix the files, you should be able to just use the RGBWController-Gerber.zip from the github (I will try to update the openhardware.io page now)
                • Cliff KarlssonC
                  Cliff KarlssonC
                  Cliff Karlsson
                  What is the correct pitch for the screw terminals? 2.54mm? 5mm ? or other?
                    L
                    L
                    LastSamurai
                    @Cliff-Karlsson It should be 5 mm
                    • AchimA
                      AchimA
                      Achim
                      dirtypcb says that the outline files are missing
                      No board outline (.GML/.GKO/.GBR) file found.
                      Can you please add this outline files to the GIT.
                      • Cliff KarlssonC
                        Cliff KarlssonC
                        Cliff Karlsson
                        I had the same problem with dirtypcbs so I ordered from seedstudio instead. Almost the same price.
                        • L
                          L
                          LastSamurai
                          Oh thats just a naming issue. Rename the "RGBWController-Edge.cuts.gm1" to .gml in the zip file and it should work just fine.
                          • peerkersezuukerP
                            peerkersezuukerP
                            peerkersezuuker
                            Just got the v1.3 pcb's from OSH Park, just waiting for some components, and the we go. It will be an exciting christmas ;-)
                            Domoticz / My Sensors / Z-Wave
                            https://www.kermisbuks.nl
                            • J
                              J
                              Jan Gatzke
                              I got my v1.3 pcbs from Smart Prototyping. Quality is good. The controller works fine BUT the sketch version in your github repo is broken. Seems like the non linear fading part never got finished. I am now using linear fading and the sketch is working. :)
                              peerkersezuukerP 1 Reply Last reply
                              • J Jan Gatzke
                                peerkersezuukerP
                                peerkersezuukerP
                                peerkersezuuker
                                @Jan-Gatzke
                                Hi can you please post your adjusted sketch for further reference?
                                J 1 Reply Last reply
                                • peerkersezuukerP peerkersezuuker
                                  @Jan-Gatzke
                                  J
                                  J
                                  Jan Gatzke
                                  @peerkersezuuker
                                  You have to fix the following part:
                                  for (int i = 0; i < NUM_CHANNELS; i++) {
                                      if (isOn) {
                                        // normal fading
                                        //analogWrite(channels[i], dimming / 100.0 * values[i]);
                                        // non linear fading, idea from https://diarmuid.ie/blog/pwm-exponential-led-fading-on-arduino-or-other-platforms/
                                        analogWrite(channels[i], pow (2, (dimming / R)) - 1);
                                        analogWrite(channels[i], 0);
                                  Corrected Version
                                      if (isOn) {
                                        // normal fading
                                        //analogWrite(channels[i], pow (2, (dimming / R)) - 1);
                                  Or else all channels are set to the Value of dimming. The sketch on openhardware.io is broken, too.
                                  • J Jan Gatzke
                                    @peerkersezuuker
                                        if (isOn) {
                                          // normal fading
                                    Corrected Version
                                        if (isOn) {
                                          // normal fading
                                    peerkersezuukerP
                                    peerkersezuukerP
                                    peerkersezuuker
                                    @Jan-Gatzke
                                    Thank you for your post.
                                    I hope the Mosfet's are comming in today, then i can build it up and play with it.
                                    • L
                                      L
                                      LastSamurai
                                      @Jan-Gatzke Thank you for correcting it ;) I never got around to making the fading part work a 100% so I reverted back to my normal linear fading for my controllers. Seems like I forgot to correct that in my git repo :frowning: Sorry for that, I will fix it after christmas.
                                      Great to hear that others are using the controllers too! Have fun with them and update me if you change something or build some (other) cool thing with them!
                                      • peerkersezuukerP
                                        peerkersezuukerP
                                        peerkersezuuker
                                        A little question, the v1.3 is this the one with the corrected mosfet placement ?
                                        I build and programmed one now, but i only get a bright white light, and no response when i switch the node. So now i am in doubt...
                                        With regards
                                        Peer
                                          With regards
                                          Peer
                                          J
                                          J
                                          Jan Gatzke
                                          @peerkersezuuker
                                          The node always starts with white on. This is normal behaviour.
                                          12.5k
