  3. Air Quality Sensor
Air Quality Sensor
calibrationaqigas sensorhchoair quality
270 Posts 46 Posters 452.6k Views 35 Watching
  • epierreE epierre
    @korttoma You've been lucky finding such a schema, but it is strange there is a resistance on the other side of the sensor, and the variable one is not where expected... maybe the 1K is wrong on the schema, can you mesure it on the board?
    5.1 Ohm is low...
    The RL here is for the voltage comparator that gives the digital output with led.
    MQ-2 datasheet asks for Rs in 3KΩ-30KΩ
    If this is right, then the value that the autocalibration "in clean air" should give you something around 1K.
    The MQ-9 datasheet is a bit more versatile:
    Power of Sensitivity body(Ps): Ps=Vc^2×Rs/(Rs+RL)^2
    Resistance of sensor(Rs): Rs=(Vc/VRL-1)×RL
    MQ-9: Rs(in air)/Rs(100ppm CO)≥5
    I fear they are using a standard board for all sensors and that the resistance value may be wrong from this, just because they want to deliver a digital signal...
    korttomaK
    korttomaK
    korttoma
    @epierre
    I did not find the schema, I measured the board and figured it out myself so it might be wrong.
    Could you draw a schema that would show me exactly how it would preferably look so I can change it? Because I'm clearly not smart enough to understand it from your descriptions. Please explain it to me like I was 4 years old ;)
    • Tomas
    • korttomaK
      korttomaK
      korttoma
      Now changed my sensor according to this (disconnected the OP related to DOUT) :
      upload-94e081f9-006e-4d91-b736-3f82ef8e119b
      Please confirm that this is how it is preferred to be connected.
      • Tomas
      epierreE 2 Replies Last reply
      • korttomaK korttoma
        epierreE
        epierreE
        epierre
        I guess here you have the same that the datasheet, so I assume it is ok ;-)
        I've been working to port sketches to a Spark Core with good results, the 12 bits ADC gives more precise values, at least the MQ135 is now very sensitive.
        I am also correcting errors in the sketches I have produced.
        z-wave - Vera -> Domoticz
        • epierreE
          epierreE
          epierre
          #71
          A good article on the comparison of 3 same MQ-7 sensors
          A lot of good questions, not easy to answer! It is good you tryed it with three sensors instead of just one, and you can see there is a lot of variation from one sensor to the next of the same batch.
          As to the value of Ro, that is the million dollar question. You have to have a known calibration source of CO in order to determine that! Each MQ-7 sensor will be different. The normal levels in a lab or home will be (should be!) well below the level that this sensor can detect and discriminate. It's lower limit implied in the data sheet is around 50ppm, which is where it begins to be dangerous for continuous exposure. Do read wiki and other sources about carbon monoxide and levels that can occur under different conditions.
          • korttomaK
            korttomaK
            korttoma
            During the weekend I did the hardware changes and tried my MQ-2 sensor again and now if I hit it with smoke (I have smoke on a can) I do get values in Vera under the Variable1 property. No values on the dashboard device itself. I guess some changes are needed for the device file to display the V_VAR1 or we should use something else than V_VAR1.
            If you have already updated the sketch for the MQ-2 please let me know where I can get the latest version so I can try it out.
            btw, is the MQ-2 supposed to give the value 0 after it is calibrated in clean air? My sensor sends the value 0 all the time unless I hit it with my smoke can.
            • Tomas
            • epierreE
              epierreE
              epierre
              #73
              Yes I am deeply modifying it, and will have a question for @hek : to have something consistant in time, it owuld be better to have the initial calibration stored, either in EEPROM or as a VAR on the server. Could it be possible that I introduce a loop that wait till the var is answered and if not go into calibration ?
              @korttoma the best sketch so far is the following, to be scaled down to one sensor, remove specific Mega initialization. I will make a simpler one based on this soon, as I have already done it for the Spark core.
              https://github.com/empierre/arduino/blob/master/MQv01dgi_1_4.ino
              hekH 1 Reply Last reply
              • epierreE epierre
                @epierre
                The best solution (and most simple) is to keep calibration data in EEPROM.
                • epierreE
                  epierreE
                  epierre
                  #75
                  Now some questions I have currently:
                  I've used your clean air calibration in open air given values of air concentration where appropriate. Around sept 20th I applied this method t omy sketches and I have since sensors that are very much more reactive ! Only 2SH12 has no curve, it is voltage for this (damn) sensor doesn't have a datasheet...
                  I don't know if this was this predictible...
                  They are all placed inside a room that I sometime open to clean air. Also there are restarts that calculates again those values where you see it drop maybe, but anyway it will still go to the previous values.
                  MQ135 in CO2:
                  MQ2 in Smoke:
                  2SH12 in SO2 in voltage:
                  MQ6 in O3:
                    epierreE
                    epierreE
                    epierre
                    #76
                    @korttoma I have found a sketch that may interrest you about the gas sensors boards:
                    http://www.parallax.com/sites/default/files/downloads/27983-Gas-Sensor-Board-A-Schematic.pdf
                    Their document speaks also about calibrating some gases:
                    http://www.parallax.com/sites/default/files/downloads/27983-Gas-Sensor-Board-Guide-v1.0.pdf
                    • epierreE epierre
                      @Yveaux you mean something like this ?
                      return ( (((float)RL_VALUE*(1023.0 - (float) raw_adc)) / (float) raw_adc));
                      I somehow forked the discussion on arduino.cc and sent an email in parallel do Davide Gironi for I would like to understand his formula as opposed to the curve approach.
                      epierreE
                      epierreE
                      epierre
                      @Yveaux I have doubts about calculing the resistance, for it is depending on the steps, either 1024 or 4096, and/or the voltage either 5V or 3.3V.
                      I started with this formulae:
                      return ( ((float)RL_VALUE*(1023-raw_adc)/raw_adc));
                      But saw Davide Gironi using this one:
                      return  (long)((long)(1024*(long)RL_VALUE)/raw_adc-(long)RL_VALUE);
                      RL_VALUE=22000
                      • epierreE
                        epierreE
                        epierre
                        @Yveaux @korttoma
                        Bummer... this is the same formula when doing the reduction.... one is 1023 the other 1024 the only change.
                        The RL_VALUE for Davide was 22k, when I mesure the resistance with Analog out with ground, I get 0,996 or 0,999 ohms depending on the sensor. I guess this is the RL_VALUE of the board which is way below the sensor maker recommendation (between 10K and 47K for a MQ135).
                        Also, I saw that the pot on the board does not change the analog to ground resistance, meaning it is used only for comparison of the digital output....
                        Am I correct in mesuring this ?
                        • epierreE epierre
                          @Yveaux @korttoma
                          That seems to match the schematic above where the pot connects to + of the lm393
                          • epierreE
                            epierreE
                            epierre
                            #80
                            @Yveaux Doing so, I have used a RL_VALUE for each board I mesured, one went to 5MOhms...
                            MQ2:-8.85
                            MQ6:0.00
                            MQ131:0.00
                            TGS2600:0.00
                            MQ135:0.00
                            2SH12:-155004.00
                            TGZS2602:0.00
                            Something to be noted: same boards have the same resistance, whatever the sensor maker recommendation, this is a pity...
                            The output I have:
                            MQ2    :LPG   :7ppm    CO    :0ppm    SMOKE :10ppm
                            MQ6    :LPG   :0ppm    CH4   :0ppm
                            MQ131  :CL2   :0ppm    O3    :0ppm
                            TGS2600:H2    :0ppm    C2H5OH:0ppm C4H10 :0ppm
                            MQ135  :CO2   :0ppm    CO    :0ppm     CH3   :0ppm    NH4    :0ppm
                            2SH12  :SO2   :-154588.20 raw
                            TGS2602:C7H8  :0ppm
                            Dust   :raw   : 0    Voltage: 0.00 - Dust Density: -0.10
                            something to remember: MQ135 was calibrated for 1ppm of CO, not 399ppm of CO2, so the calculated value is very low, a per gas Ro must be calculated (clean air calibration) if several gas on one sensor is required to be displayed.
                            • epierreE
                              epierreE
                              epierre
                              Some interresting points from another discussion on the MQ138 that is given for HCHO.
                              Historically a datasheet said so, but it is impossible to read the datasheet curves:
                              http://china-total.com/Product/meter/gas-sensor/MQ138.pdf
                              The latest ones do not speak of HCHO any more.
                              An available alternative: grove is a wsp2110 and datasheet can be found.
                              http://www.seeedstudio.com/wiki/Grove_-_HCHO_Sensor
                              • A
                                alex
                                Hello all,
                                I'm new here, thanks to this topic very interesting for my personal project: a mobile air quality sensor.
                                (sorry for my english, i'm french)
                                Fistly, congrat's @epierre and the other, for having shared all this informations!
                                (it's a litte funny because we had the same idea in the almost same time)
                                So after having read the entire subject, here my questions (the number in front is the number post):
                                _
                                17 - @epierre, I haven't well understand How you can distinguish individual gas from a sensor who react with several gas.
                                45 - The "Wunder Weather" list that you talked about, it's a website?
                                55 - What David did you answer to you about "if he speaks of the organic sensor or the ceramic ones"?
                                Moreover, what are the organic sensors? Have you example?
                                72- On winsensor.com, an chinese gas sensor producer, the MQ-7 is more powerfull... I don't know who trust, maybe it's not the same?? See the PDF datasheet here.
                                81 - Where did you read that the lastest one don't speak of HCHO anymore?
                                After some research, I founded two, one who speak about HCHO here in english , and the other who don't....but I'm not sure (beacause in chinese) here.
                                Otherwise, for the WSP2110 datasheet, it is here! But chinese too =/
                                Regards,
                                Alex.
                                • epierreE
                                  epierreE
                                  epierre
                                  This is a short post, half has been lost in a forum crash, I hope the best remains ;-)
                                  You cannot as I showed below with the broken perfume bottle, you can guess there is one, but not which one.
                                  This is wunderground.com
                                  The organic are the one that have a lifetime of 2 years, calibrated but wery expensive (aroung $150+ apiece), the winseng one for example, big and round.
                                  this is hard to say... the MQ-7 is quite special with a sequence to power it up, and readings every period.
                                  After some research, I found two, one who speak about HCHO here in english , and the other who don't....but I'm not sure (beacause in chinese) here.
                                  I don't see mention of HCHO (formaldehyde) in the english one (n-Hexane, Benzene, NH3, alcohol, ,smoke, CO. I found one in chinese with the link above but the curve couldn't be exploited. Please remark that Alcohool has not a single formula, but here they show only one curve, not very precise.
                                  Yes for this one something can be done, but there is no for WSP1110 there is no...
                                  • A
                                    alex
                                    wrote on last edited by alex
                                    #84
                                    Ok! Thanks.
                                    And what about the ceramic sensors (like MQ serie). How long can we trust them?
                                    • epierreE
                                      epierreE
                                      epierre
                                      @alex said:
                                      Ok! Thanks.
                                      a bit longer but they vary in time as Davide made the remark, so calibration is not one time in its life...
                                      • A
                                        alex
                                        #86
                                        Hello
                                        @epierre : after received the PPD42NS, compared to the DSM501A, which one is the best do you think?
                                        Other things, I planned to purchase soon the sensors that I need for my air station.
                                        You made a list on the #1 post, and it's very useful thanks, but now I have to choose between them for each gas targeted (maybe some sensors are still missing on the list below)
                                        Which one appears for you, the better for each gas, with a reasonable price?
                                        O3		    MQ131   MICS-2610    Mics-2614
                                        NO2 	      MiCS-2710    MiCS-2714
                                        NO            ?
                                        PM10 PM2.5    PPD42NS    SamYoung DSM501
                                        Benzene	   MQ135
                                        CO  	      MQ307A   MQ309A   AQ-7   MiCS-5525   TGS2442
                                        So2 	      MQ136
                                        COV       	MQ135  TGS2602
                                        CO2 	      MQ135
                                        epierreE 1 Reply Last reply
                                        • A alex
                                          Hello
                                          NO            ?
                                          Benzene	   MQ135
                                          So2 	      MQ136
                                          COV       	MQ135  TGS2602
                                          CO2 	      MQ135
                                          epierreE
                                          epierreE
                                          epierre
                                          I currently have only the DSL501A working, many issues with the dead Shinyei (still in dispute escalade) and getting one from another seller takes so much time...
                                          NO ?
                                          Benzene MQ135
                                          So2 MQ136
                                          COV MQ135 TGS2602
                                          CO2 MQ135
                                          The price is low, but so is the result. Only the CO-MH-Z14 is calibrated. For all the others, there is the calibration issue.
                                          See the sketch for a lit of known/tested sensors (some I don't have but a frien asked me for the curves so I added it to the Mega sketch)
                                          https://github.com/empierre/arduino/blob/master/AirQuality-Multiple_Gas_Sensor1_4.ino
                                          • The MiCS are problematic to find in Europe (!) so I have only one that I have not yet tested.
                                          • The Figaro have been tested, but it is hard to know how to really test them on some gases...
                                          • The MQxx:
                                            • MQ2: good result on smoke
                                            • MQ135 good result on CO2
                                              The others I'm not yet able to give any opinion.
