  3. 💬 Insulated Whole House Fan
mysensorswhole house fan
72 Posts 11 Posters 23.4k Views 11 Watching
    @petewill Wow, amazing work :thumbsup:
      https://www.mysensors.org/view/127/Insulated-Whole-House-Fan
      rechin304R
      rechin304R
      rechin304
      @petewill Great work. Did you by any chance make it work with Mysensors V2 ?
      petewillP 1 Reply Last reply
      • rechin304R rechin304
        petewillP
        petewillP
        petewill
        @rechin304 No not yet. It's on the list but it will be winter here for a while so it's not at the top. When were you planning to build yours?
        rechin304R 1 Reply Last reply
        • petewillP petewill
          rechin304R
          rechin304R
          rechin304
          @petewill I already build the wooden box, and i have all electronic parts. I do wait for threaded rod, threaded Insert, Ball Bearing to arrive from china. I just finish today the shield that will hold arduino, testing lcd screen (i have a different version then you have, less pin's and no need for resistors). I will try to convert your schetch latter to V2 (still need to make an gateway for V2). If successful i will post the code.
            petewillP
            petewillP
            petewill
            @rechin304 Ok, sounds good. Let me know if you get stuck and I'll do my best to help.
            • rechin304R
              rechin304R
              rechin304
              wrote on last edited by rechin304
              This is hat i made until now. I have two issues:
              1. DHT11 is not working (no temp or hum is shown)
              2. I use Domoticz as controller and i do not see the node connecting to it, even the clock is sync with gateway. Gateway is version 2. So please if you have some time to look at the code your help be highly appreciated. Thanks.
                 Power monitoring code adapted from: http://henrysbench.capnfatz.com/henrys-bench/arduino-current-measurements/acs712-arduino-ac-current-tutorial/
                 REVISION HISTORY
                 Version 1.0 - Initial code
                 Version 2.0 - Changed for Mysensors v2
                 DESCRIPTION
                 The code below will run a MySensors whole house fan with wall mounted lcd control panel.  The fan is installed in the attic and an insulated cover will
                 open/close to conserve energy.  The project cost a little over $300 US.  A comparable commercial product costs around $1200.
                 FEATURES
                 - Physical button switch to control on/off in case there are ever issues with radio communications.
                 - DHT22 sensor for temp/humidity monitoring in the attic
                 - LCD screen displays status, temp/humidity, errors & date/time
                 - If an error occurs a message is sent to the gateway
                 - When the unit looses power it will make sure the cover is closed and the fan is off after power is restored.
                 - Safety Features
              	- The cover will wait to close until power has been shut off to the fan
              	- Customizable over current protection on the cover motor (automatically shut off if the cover gets stuck)
              	- Customizable cover close time limit (if it slips out off the coupling the motor won't run indefinitely)
                 NOTE
                 This program is too large to run with all debugging and the display enabled.
                 To upload either comment out "#define DEBUG_ON" in the code below or comment out
                 "#define DEBUG" in MyConfig.h in the MySensors library.
                 For troubleshooting "#ifdef TFT_DISPLAY_ON" can be commented out so all debugging
                 messages can be output to the serial monitor
              #include <Adafruit_GFX.h>    // Core graphics library
              #include <Adafruit_ST7735.h> // Hardware-specific library
              #include <Time.h>
              #include <TimeLib.h>
              //#define NODE_ID AUTO //or set to AUTO to have the gateway assign an ID
              //#define NODE_REPEAT false //change to true to set to a repeating/relaying node
              #define MY_NODE_ID AUTO  //set to AUTO to have the gateway assign an ID
              #define SKETCH_NAME "House Fan Mysensors v2"
              #define SKETCH_VERSION "2.1"
              #define FAN_ID 0   	// ID of the fan sensor child
              #define ERROR_ID 1 	// ID of the alert child
              #define	HUM_ID 2 	//ID of the humidity child
              #define TEMP_ID 3 	//ID of the temp child
              #define BUTTON_PIN 2  				//Pin for the on/off button
              #define DHT_DATA_PIN A0
              #define SENSOR_TEMP_OFFSET 0
              static const uint64_t UPDATE_INTERVAL = 60000;
              #define FAN_RELAY_PIN  A1  			//Pin number for relay that will control the fan
              #define COVER_CLOSE_LIMIT_PIN A2 	//Pin number for the "cover closed" limit switch
              #define COVER_OPEN_LIMIT_PIN A3 	//Pin number for the "cover open" limit switch
              #define COVER_CLOSE_PIN A4 			//Pin number for the "cover close" L298N motor control board
              #define COVER_OPEN_PIN A5			//Pin number for the "cover open" L298N motor control board
              #define FAN_POWER_PIN A6			//Pin number for the ACS712 monitoring the fan
              #define COVER_POWER_PIN A7			//Pin number for the ACS712 monitoring the cover motor
              #define TFT_DISPLAY_ON //Use to turn on/off display functionality (need to turn off for debugging because code is too large).
              // TFT display and SD card pins.  They will share the software SPI interface.
              #define SPI_SCK 8  //Also can be labeled CLK on display
              #define SPI_DI  4 //Labeled MISO on display
              #define SPI_DO  7  //Labeled MOSI on display
              //#define SD_CS   5  // Chip select line for SD card (not currently used)
              #define TFT_CS  3
              #define TFT_DC  6 //Labeled RS
              #define TFT_RST 0  // you can also connect this to the Arduino reset
              Adafruit_ST7735 tft = Adafruit_ST7735(TFT_CS, TFT_DC, SPI_DO, SPI_SCK, TFT_RST);
              #ifdef DEBUG_ON
              #define RELAY_ON 1 //Switch to 0 if fan relay is off when it should be on
              #define RELAY_OFF 0 //Switch to 1 if fan relay is on when it should be off
              #define DWELL_TIME 50 //Time to wait between radio messages sent (helps prevent missed messages)
              #define closingStall 465 //The value of the ACS712 when the cover motor is stopped while closing. This value should be less than the normal operating power draw.
              #define openingStall 580 //The value of the ACS712 when the cover motor is stopped while opening.  This value should be greater than the normal operating power draw.
              #define coverLimitTime 37000 //Slightly over the time it takes for the cover to fully open/close in milliseconds.  This will prevent the cover motor from running indefinitely.
              //Fan power reading variables. You may need to adjust these depending on your ACS712 model and house voltage
              uint8_t mVperAmp = 69; //had to adjust for my sensor you may need to adjust yours a well // use 185 for 5A Module, 100 for 20A Module and 66 for 30A Module
              uint8_t houseVoltage = 220; //Voltage of your house wiring (110 or 220)
              Bounce debouncerOnOff = Bounce();
              Bounce debouncerClosedState = Bounce();
              Bounce debouncerOpenState = Bounce();
              uint8_t fanButtonPrev = 0;
              uint8_t fanState = 0;
              uint8_t fanStatePrevious = 1;
              uint8_t fanRelayState;
              uint8_t coverMoving = 0;
              uint8_t	coverClosedState = LOW;
              uint8_t	coverOpenState = LOW;
              uint8_t errorState = 0; //Used to keep track of errors.  Can be reset by manually pushing button
              uint8_t fanPowerReading = 0;
              int coverPowerReading = 0;
              unsigned long currentMillis; //used for timers
              unsigned long powerReadMillis; //Used read power every second
              unsigned long powerUpdateMillis; //Used to update power usage on LCD and gateway
              unsigned long coverMillis;
              unsigned long dhtMillisPrev;
              unsigned long dhtDelay = 305000;	//5 minutes 5 seconds.  Offset is in case of power failure I don't want all my nodes reporting at the same time.
              unsigned long lastGetTime; //Used for getting time from gateway
              uint8_t lastSecond;
              uint8_t lastMinute;
              uint8_t lastHour;
              DHT dht;
              float lastTemp = 0;
              float lastHum = 0;
              uint8_t nNoUpdatesTemp;
              uint8_t nNoUpdatesHum;
              boolean metric = true; //Set to true if you use the metric system
              double Voltage = 0; //Voltage read from analog pin (used to calc power)
              double VRMS = 0;
              double AmpsRMS = 0;
              uint16_t wattTotal = 0; //Used to calculate the watts used for the last minute
              int wattAvg = 0;
              int wattAvgPrev = 0;
              uint8_t wattCount = 0; //Will be used to divide watts
              uint16_t pMaxValue = 0; // store max value here
              uint16_t pMinValue = 1024; // store min value here
              //MySensor gw;
              MyMessage msgFan(FAN_ID, V_STATUS);
              MyMessage msgFanPwr(FAN_ID, V_WATT);
              MyMessage msgError(ERROR_ID, V_TRIPPED);
              MyMessage msgHum(HUM_ID, V_HUM);
              MyMessage msgTemp(TEMP_ID, V_TEMP);
                present(FAN_ID, S_BINARY);
                wait(DWELL_TIME);
                present(ERROR_ID, S_MOTION);
                wait(DWELL_TIME);
                present(HUM_ID, S_HUM);
                wait(DWELL_TIME);
                present(TEMP_ID, S_TEMP);
                wait(DWELL_TIME);
                delay(2000); //Allow time for sensors to power up
              requestTime();
                dht.setup(DHT_DATA_PIN);
                digitalWrite(FAN_RELAY_PIN, RELAY_OFF);
                digitalWrite(COVER_OPEN_PIN, LOW);
                digitalWrite(COVER_CLOSE_PIN, LOW);
                // Set the pin mode
                pinMode(FAN_RELAY_PIN, OUTPUT);
                pinMode(COVER_OPEN_PIN, OUTPUT);
                pinMode(COVER_CLOSE_PIN, OUTPUT);
                pinMode(COVER_OPEN_LIMIT_PIN, INPUT_PULLUP);
                pinMode(COVER_CLOSE_LIMIT_PIN, INPUT_PULLUP);
                pinMode(BUTTON_PIN, INPUT_PULLUP); // Setup the on/off button and activate internal pull-up
                // After setting up the pin modes, setup debouncers
                debouncerOnOff.attach(BUTTON_PIN);
                debouncerOnOff.interval(50);
                debouncerOpenState.attach(COVER_OPEN_LIMIT_PIN);
                debouncerOpenState.interval(50);
                debouncerClosedState.attach(COVER_CLOSE_LIMIT_PIN);
                debouncerClosedState.interval(50);
                send(msgError.set(0)); // Reset Alert state
                //Check the cover slide limit switch values
                debouncerOpenState.update();
                coverOpenState = debouncerOpenState.read();
                debouncerClosedState.update();
                coverClosedState = debouncerClosedState.read();
              unsigned long functionTimeout = millis();
                while (timeStatus() == timeNotSet && millis() - functionTimeout < 30000UL)
                  requestTime();
                  DEBUG_PRINTLN(F("Getting Time"));
                  wait(1000); // call once per second
                  DEBUG_PRINTLN(F("."));
                //**Note: I had a red tab LCD but the black tab setting worked the best for me
                // If your TFT's plastic wrap has a Black Tab, use the following:
                tft.initR(INITR_BLACKTAB);   // initialize a ST7735S chip, black tab
                // If your TFT's plastic wrap has a Red Tab, use the following:
                //tft.initR(INITR_REDTAB);   // initialize a ST7735R chip, red tab
                // If your TFT's plastic wrap has a Green Tab, use the following:
                //tft.initR(INITR_GREENTAB); // initialize a ST7735R chip, green tab
                //Initial Setup - Set state to Idle
                tft.drawLine(0, 7, 160, 7, tft.Color565(123, 123, 123)); //Setup
                tft.fillRect(0, 8, 160, 21, tft.Color565(80, 80, 80)); //Setup
                tft.drawLine(0, 29, 160, 29, tft.Color565(34, 34, 34)); //Setup
                tft.drawLine(0, 110, 160, 110, ST7735_WHITE); //Setup
                tft.fillRect(0, 111, 160, 43, tft.Color565(230, 230, 230)); //Setup
                tft.drawLine(0, 153, 160, 153, tft.Color565(170, 170, 170)); //Setup
                updateTime();
                updateTemp();
                updateHum();
                currentMillis = millis();
                coverMillis = currentMillis;
                //Make sure the fan is off and the cover is closed when first powered on
                fanOff();
                dht.readSensor(true);
                currentMillis = millis(); //Set the current millis (used for timers)
                //  DEBUG_PRINT(F("coverClosedState = "));
                //  DEBUG_PRINTLN(coverClosedState);
                //There is a spike in current when the motor is first turned on.  We need to stop reading for a short period so the motor doesn't immedately turn off
                if (currentMillis - coverMillis > 1500)
                  coverPowerReading = analogRead(COVER_POWER_PIN); //change back when sensor is attached
                  //DEBUG_PRINT(F("coverPowerReading = "));
                  //DEBUG_PRINTLN(coverPowerReading);
                  if (coverPowerReading > closingStall && coverPowerReading < openingStall)
                    //Cover motor power draw is within limits
                    //Cover motor power draw is over the limit.  Motor has stalled.
                    coverPowerReading = 1;
                debouncerOnOff.update();
                uint8_t fanButton = debouncerOnOff.read(); // Get the update value
                //DEBUG_PRINTLN(fanButton);
                if (fanButton != fanButtonPrev && fanButton == 0) {
                  if (coverMoving == 1)
                    //If the cover is already moving, change directions.
                    fanStatePrevious = fanState;
                    coverMoving = 0;
                  fanState = fanState ? 0 : 1;
                  DEBUG_PRINT(F("fanState value changed to: "));
                  DEBUG_PRINTLN(fanState);
                  send(msgFan.set(fanState), true); // Send new state and request ack back
                  errorState = 0;
                  wait(DWELL_TIME);
                  coverMillis = currentMillis; //Set the millis (used to keep track of cover close/open times)
                fanButtonPrev = fanButton;
                if (fanState != fanStatePrevious && fanState == 0 && errorState == 0)
                  fanOff();
                if (fanState != fanStatePrevious && fanState == 1 && errorState == 0)
                  fanOn();
                if (currentMillis - dhtMillisPrev > dhtDelay)
                  if (isnan(temperature))
                    DEBUG_PRINTLN(F("Failed reading temperature from DHT"));
                    if (!metric)
                    if (temperature != lastTemp || nNoUpdatesTemp == FORCE_UPDATE_N_READS)
                      lastTemp = temperature;
                      wait(DWELL_TIME);
                      updateTemp();
                      DEBUG_PRINT(F("Temperature is: "));
                      DEBUG_PRINTLN(temperature);
                  float humidity = dht.getHumidity();;
                  if (isnan(humidity))
                    DEBUG_PRINTLN(F("Failed reading humidity from DHT"));
                  } else if (humidity != lastHum || nNoUpdatesHum == FORCE_UPDATE_N_READS)
                    lastHum = humidity;
                    nNoUpdatesHum = 0;
                    wait(DWELL_TIME);
                    updateHum();
                    DEBUG_PRINT(F("Humidity is: "));
                    DEBUG_PRINTLN(humidity);
                  nNoUpdatesHum++;
                  dhtMillisPrev = currentMillis;
                  Check power usage here
                  I want to check it every second then send it every minute (when changed) to the gateway and LCD
                  In the "every second" check it should get a running average so it would divide by the number of seconds
                if (currentMillis - powerReadMillis < 1000)
                  //Read power every second
                  uint16_t readValue = analogRead(FAN_POWER_PIN);
                  //DEBUG_PRINT(F("readValue: "));
                  //DEBUG_PRINTLN(readValue);
                  // see if you have a new pMaxValue
                  if (readValue > pMaxValue)
                    /*record the maximum sensor value*/
                    pMaxValue = readValue;
                  if (readValue < pMinValue)
                    pMinValue = readValue;
                  //Calulate power usage and update gateway if necessary
                  // Subtract min from max
                  Voltage = ((pMaxValue - pMinValue) * 5.0) / 1024.0;
                  VRMS = (Voltage / 2.0) * 0.707;
                  AmpsRMS = (VRMS * 1000) / mVperAmp;
                  if (AmpsRMS < .15) //filter out low readings when fan is off
                    AmpsRMS = 0;
                  DEBUG_PRINT(F("Amps RMS: "));
                  DEBUG_PRINT(AmpsRMS);
                  wattTotal += houseVoltage * AmpsRMS;
                  DEBUG_PRINT(F(".  Watt Total: "));
                  DEBUG_PRINT(wattTotal);
                  wattCount ++;
                  DEBUG_PRINT(F(".  Watt Count: "));
                  DEBUG_PRINTLN(wattCount);
                  powerReadMillis = currentMillis;
                  //Reset max and min values
                  pMaxValue = 0;
                  pMinValue = 1024;
                  //Update fanPowerReading to make sure the fan is off before closing the cover
                  fanPowerReading = AmpsRMS > 1 ? 1 : 0;
                  DEBUG_PRINT(F("fanPowerReading: "));
                  DEBUG_PRINTLN(fanPowerReading);
                  //Update Gateway and LCD every minute if necessary
                  if (currentMillis - powerUpdateMillis > 60000)
                    //We don't want to flood the gateway with updates so if the last reading was close to the current one we don't need to send the new reading
                    wattAvg = wattTotal / wattCount;
                    DEBUG_PRINT(F("Watt Average: "));
                    DEBUG_PRINTLN(wattAvg);
                    //Only update if last usage was different by 2 watts
                    if (wattAvgPrev - wattAvg > 2 || wattAvg - wattAvgPrev > 2)
                      //Send to gateway
                      send(msgFanPwr.set(wattAvg));
                      if (fanPowerReading == 1)
                        //Update LCD if running
                        tft.setTextColor(ST7735_WHITE, tft.Color565(53, 47, 125));
                        tft.setFont();
                        tft.setTextSize(1);
                        tft.setCursor(5, 95);
                        tft.print("Watts: "); //First line of text 20 characters max
                        tft.print(wattAvg);
                        tft.print("  ");
                        DEBUG_PRINT(F("Watts update display: "));
                    wattAvgPrev = wattAvg;
                    //Reset watt trackers
                    wattTotal = 0;
                    wattCount = 0;
                    powerUpdateMillis = currentMillis;
                    //Using this if statement to update the time every minute
                    //Update Time on Display every minute
                    updateTime();
                if (currentMillis - lastGetTime >= 3600000UL) // updates clock time and gets zone times from gateway once every hour
                  lastGetTime = millis();
              void fanOff() {
                   1. Turn off the fan
                   2. Make sure it's off before we start closing the cover
                   3. Close cover
                      a. Start a timer for how long the closing should take
                      b. Stop the motor when the limit switch is hit
                   4. Ensure the limit switch has been pressed and the timer didn't run out.  If it did send an error message (via motion sensor).
                   5. Send "off" message to gateway/controller
                //DEBUG_PRINTLN(F("In the fanOff function"));
                if (fanRelayState == RELAY_ON)
                  DEBUG_PRINTLN(F("Turning off fan"));
                  //Turn off fan and set fan relay state to 0
                  fanRelayState = RELAY_OFF;
                if (currentMillis - coverMillis < coverLimitTime)
                  if (coverPowerReading == 0)
                    //Make sure the fan is off before closing the cover to prevent damage to the cover and fan
                    if (fanPowerReading == 0)
                      //Start closing the cover
                      //Set the close pin on the L298N board to high
                      if (coverMoving == 0)
                        DEBUG_PRINTLN(F("Closing Cover"));
                        digitalWrite(COVER_CLOSE_PIN, HIGH);
                        //Set COVER_OPEN_PIN to low just to be safe
                        //Update the LCD with "Closing" status message
                        tft.setFont();
                        tft.setTextSize(1);
                        tft.print("CLOSING COVER     "); //First line of text 20 characters max
                        coverMoving = 1;
                      if (coverClosedState == LOW)
                        //The cover is closed.  Stop motor and send status to gateway.
                        send(msgFan.set(fanState), true); // Send new state with Ack
                        coverMoving = 0;
                        //Update LCD
                        wait(200); //Wait for radio SPI to stop (otherwise display is garbled)
                        updateTFTStatus(0); //Set status to idle state
                    //Cover motor is using too much power.  Stop everything to avoid damage.
                    DEBUG_PRINTLN(F("The slide motor is using too much power!"));
                    errorState = 1; //Set the error state so it doesn't keep trying to close
                    send(msgError.set(1)); // Send alert state to gateway
                    //Update LCD
                    updateTFTStatus(2); //Set status to error state
                    errorOvercurrent(); //More detailed error message
                  /*Things have taken too long there must be an error.  Print it out to the LCD and send trigger to gateway
                    Possible errors could be:
                    Fan did not shut off.
                    Cover did not fully close in time (slide jam, motor slip etc.)
                    Over current in cover motor (jammed?)
                  //Send commands to stop everything to avoid damage.
                  DEBUG_PRINTLN(F("Cover time exceeded"));
                  //Update LCD
                  errorTime(); //Write more detailed error to LCD
              void fanOn() {
                  1. Open the cover
                    a. Start a timer to keep track of how long the cover has been opening
                  2. Ensure the limit switch has been pressed and the timer didn't run out.  If it did send an error message.
                  3. Start the fan
                  4. Send "on" message to gateway/controller
                    //Start opening the cover
                      DEBUG_PRINTLN(F("Opening Cover"));
                      //Set COVER_CLOSE_PIN to low just to be safe
                      digitalWrite(COVER_OPEN_PIN, HIGH);
                      coverMoving = 1;
                      wait(200); //Wait for radio communication to stop (otherwise display is garbled because of SPI conflicts)
                      //Update LCD
                      updateTFTStatus(1); //Set status to idle state
                    if (coverOpenState == LOW)
                      //The cover is open.  Stop motor and send status to gateway.
                      //Turn on Fan
                      digitalWrite(FAN_RELAY_PIN, RELAY_ON);
                      fanRelayState = RELAY_ON;
                      coverMoving = 0;
                    DEBUG_PRINTLN(F("The cover motor is using too much power!"));
                    //Update LCD
                    Cover did not fully open in time (slide jam, motor slip etc.)
                    Overcurrent in cover motor (jammed?)
                  //Update LCD
                  tft.setCursor(5, 90);
                  errorTime();
              void receive(const MyMessage & message) {
                if (message.isAck()) {
                if (message.type == V_LIGHT && !message.isAck()) {
                  // Change relay state
                  fanState = message.getBool();
                    //If the cover is already moving, check to see if we need to change directions
                    DEBUG_PRINT(F("Cover is moving"));
                    if (fanState == fanStatePrevious)
                      //We need to change directions
                      fanStatePrevious = fanState ? 0 : 1;
                      coverMoving = 0;
                  coverMillis = millis(); //Set the millis (used to keep track of cover close/open times)
                  DEBUG_PRINT(F("Incoming change for sensor:"));
                  DEBUG_PRINT(message.sensor);
                  DEBUG_PRINT(F(", New status: "));
              void receiveTime(unsigned long time) {
                // Ok, set incoming time
                setTime(time);
              void updateTFTStatus(uint8_t bgStat)
                //bgStat: 0 = "Idle", 1 = "Running", 2 = "Error"
                //Idle Color = 37, 125, 20
                //Running Color = 53, 47, 125
                //Error Color = 155, 26, 26
                uint8_t r, g, b;
                const char *displayStatus[] = {
                  "Idle", "Running", "Error"
                if (bgStat == 0)
                  //Idle
                  r = 37;
                  g = 125;
                  b = 20;
                else if (bgStat == 1)
                  //Running
                  r = 53;
                  g = 47;
                  b = 125;
                  //Error
                  r = 155;
                  g = 26;
                  b = 26;
                tft.fillRect(0, 0, 160, 7, tft.Color565(r, g, b));
                tft.fillRect(0, 30, 160, 80, tft.Color565(r, g, b));
                tft.fillRect(0, 154, 160, 6, tft.Color565(r, g, b));
                tft.setCursor(5, 40);
                tft.setTextColor(ST7735_WHITE);
                tft.setTextSize(1);
                tft.println("Status");
                tft.setCursor(5, 65);
                tft.setFont();
                //tft.setTextSize(3);
                tft.setTextSize(bgStat == 1 ? 2 : 3); //The word "Running" doesn't fit with text size 3.
                tft.println(displayStatus[bgStat]);
              void errorOvercurrent()
                tft.setFont();
                tft.setTextSize(1);
                tft.println("Motor overcurrent"); //First line of text 20 characters max
                tft.setCursor(5, 101);
                tft.println("Check cover slide"); //Second line of text 20 characters max
              void errorTime()
                tft.setFont();
                tft.setTextSize(1);
                tft.println("Time exceeded"); //First line of text 20 characters max
                tft.setCursor(5, 100);
              void updateTime()
                //Update Time
                tft.setCursor(5, 17);
                tft.setTextColor(ST7735_WHITE, tft.Color565(80, 80, 80));
                tft.setTextSize(1);
                tft.print(hourFormat12());
                tft.print(minute() < 10 ? F(":0") : F(":"));
                tft.print(minute());
                tft.print(isAM() ? F("am") : F("pm"));
                tft.print(month() < 10 ? F(" 0") : F(" "));
                tft.print(month());
                tft.print(day() < 10 ? F("/0") : F("/"));
                tft.print(day());
                tft.print(F("/"));
                tft.print(year() % 100);
                tft.print(F(" "));
              void updateTemp()
                //Update Temperature
                tft.setCursor(5, 120);
                tft.setTextColor(tft.Color565(80, 80, 80), tft.Color565(230, 230, 230));
                tft.setTextSize(1);
                tft.print("Temp: ");
                tft.print(lastTemp, 1);
                tft.print((char)247);
                tft.print(" ");
              void updateHum()
                //Update Humidity
                tft.setCursor(5, 140);
                tft.setTextSize(1);
                tft.print("Humidity: ");
                tft.print(lastHum, 1);
                tft.print("% ");
              • rechin304R
                rechin304R
                rechin304
                Small progress. It can be seen now in Domoticz, however DHT11 not working.
                • NuubiN
                  NuubiN
                  Nuubi
                  Excellent project. However, have you considered any possibility of condensation of humid air in the attic? At least where I live, that would become a problem.
                  • rechin304R
                    rechin304R
                    rechin304
                    In my case the air will go outside attic (i have a shaft for ventilation).
                    • NuubiN Nuubi
                      petewillP
                      petewillP
                      petewill
                      @Nuubi You need to have proper venting in your attic to use a fan like this. If you have the venting the humidity should not be a problem because it will pull fresh air from the outside through your house and out the attic vents. I don't live in a high humidity area so maybe the venting in attics is different there though.
                        petewillP
                        petewillP
                        petewill
                        Are you sure you have the wiring correct? Does it show in the serial monitor but not Domoticz or neither place?
                        • rechin304R
                          rechin304R
                          rechin304
                          Hi @petewill , i do not see anything on serial monitor related to temp or hum, and yes is connected correctly on A0, everything now works ok, except temp and hum. I do not have yet an DHT22 to test.
                            petewillP
                            petewillP
                            petewill
                            @rechin304 Strange. Did you enable debugging in the code (uncomment this line "//#define DEBUG_ON")? Without that line enabled you won't see anything in the serial monitor.
                                 REVISION HISTORY
                                 DESCRIPTION
                                 FEATURES
                                 - Safety Features
                                 NOTE
                              #include <Time.h>
                              #define TFT_CS  3
                              #ifdef DEBUG_ON
                              uint8_t lastSecond;
                              uint8_t lastMinute;
                              uint8_t lastHour;
                              DHT dht;
                              float lastTemp = 0;
                              float lastHum = 0;
                              double VRMS = 0;
                              double AmpsRMS = 0;
                              int wattAvg = 0;
                              //MySensor gw;
                                wait(DWELL_TIME);
                                wait(DWELL_TIME);
                                wait(DWELL_TIME);
                                wait(DWELL_TIME);
                              requestTime();
                                // Set the pin mode
                                  requestTime();
                                updateTime();
                                updateTemp();
                                updateHum();
                                fanOff();
                                    coverMoving = 0;
                                  errorState = 0;
                                  wait(DWELL_TIME);
                                  fanOff();
                                  fanOn();
                                    if (!metric)
                                      wait(DWELL_TIME);
                                      updateTemp();
                                    lastHum = humidity;
                                    nNoUpdatesHum = 0;
                                    wait(DWELL_TIME);
                                    updateHum();
                                  nNoUpdatesHum++;
                                    AmpsRMS = 0;
                                  wattCount ++;
                                  pMaxValue = 0;
                                  pMinValue = 1024;
                                      //Send to gateway
                                        tft.setFont();
                                        tft.setTextSize(1);
                                        tft.print(wattAvg);
                                        tft.print("  ");
                                    wattTotal = 0;
                                    wattCount = 0;
                                    updateTime();
                              void fanOff() {
                                   1. Turn off the fan
                                   3. Close cover
                                        tft.setFont();
                                        tft.setTextSize(1);
                                        coverMoving = 1;
                                        coverMoving = 0;
                                        //Update LCD
                                    //Update LCD
                                  //Update LCD
                              void fanOn() {
                                  1. Open the cover
                                  3. Start the fan
                                      coverMoving = 1;
                                      //Update LCD
                                      //Turn on Fan
                                      coverMoving = 0;
                                    //Update LCD
                                  //Update LCD
                                  errorTime();
                                      coverMoving = 0;
                                setTime(time);
                                uint8_t r, g, b;
                                if (bgStat == 0)
                                  //Idle
                                  r = 37;
                                  g = 125;
                                  b = 20;
                                  //Running
                                  r = 53;
                                  g = 47;
                                  b = 125;
                                  //Error
                                  r = 155;
                                  g = 26;
                                  b = 26;
                                tft.setTextSize(1);
                                tft.setFont();
                                tft.setFont();
                                tft.setTextSize(1);
                              void errorTime()
                                tft.setFont();
                                tft.setTextSize(1);
                              void updateTime()
                                //Update Time
                                tft.setTextSize(1);
                                tft.print(month());
                                tft.print(day());
                                tft.print(F("/"));
                                tft.print(F(" "));
                              void updateTemp()
                                tft.setTextSize(1);
                                tft.print(" ");
                              void updateHum()
                                //Update Humidity
                                tft.setTextSize(1);
                                tft.print("% ");
                              rechin304R
                              rechin304R
                              rechin304
                              Yes, debug is enabled, see the code adapted for v2, below. I have build separate node for testing only temp and hum and no data is coming too (several DHT11 used).. i used example that come from library. (example used is this https://github.com/mysensors/MySensorsArduinoExamples/blob/master/examples/DhtTemperatureAndHumiditySensor/DhtTemperatureAndHumiditySensor.ino )
                                 REVISION HISTORY
                                 DESCRIPTION
                                 FEATURES
                                 - Safety Features
                                 NOTE
                              #include <Time.h>
                              #define TFT_CS  3
                              #ifdef DEBUG_ON
                              uint8_t lastSecond;
                              uint8_t lastMinute;
                              uint8_t lastHour;
                              DHT dht;
                              float lastTemp = 0;
                              float lastHum = 0;
                              double VRMS = 0;
                              double AmpsRMS = 0;
                              int wattAvg = 0;
                              //MySensor gw;
                                wait(DWELL_TIME);
                                wait(DWELL_TIME);
                                wait(DWELL_TIME);
                                wait(DWELL_TIME);
                              requestTime();
                                // Set the pin mode
                                  requestTime();
                                updateTime();
                                updateTemp();
                                updateHum();
                                fanOff();
                                    coverMoving = 0;
                                  errorState = 0;
                                  wait(DWELL_TIME);
                                  fanOff();
                                  fanOn();
                                    if (!metric)
                                      wait(DWELL_TIME);
                                      updateTemp();
                                    lastHum = humidity;
                                    nNoUpdatesHum = 0;
                                    wait(DWELL_TIME);
                                    updateHum();
                                  nNoUpdatesHum++;
                                    AmpsRMS = 0;
                                  wattCount ++;
                                  pMaxValue = 0;
                                  pMinValue = 1024;
                                      //Send to gateway
                                        tft.setFont();
                                        tft.setTextSize(1);
                                        tft.print(wattAvg);
                                        tft.print("  ");
                                    wattTotal = 0;
                                    wattCount = 0;
                                    updateTime();
                              void fanOff() {
                                   1. Turn off the fan
                                   3. Close cover
                                        tft.setFont();
                                        tft.setTextSize(1);
                                        coverMoving = 1;
                                        coverMoving = 0;
                                        //Update LCD
                                    //Update LCD
                                  //Update LCD
                              void fanOn() {
                                  1. Open the cover
                                  3. Start the fan
                                      coverMoving = 1;
                                      //Update LCD
                                      //Turn on Fan
                                      coverMoving = 0;
                                    //Update LCD
                                  //Update LCD
                                  errorTime();
                                      coverMoving = 0;
                                setTime(time);
                                uint8_t r, g, b;
                                if (bgStat == 0)
                                  //Idle
                                  r = 37;
                                  g = 125;
                                  b = 20;
                                  //Running
                                  r = 53;
                                  g = 47;
                                  b = 125;
                                  //Error
                                  r = 155;
                                  g = 26;
                                  b = 26;
                                tft.setTextSize(1);
                                tft.setFont();
                                tft.setFont();
                                tft.setTextSize(1);
                              void errorTime()
                                tft.setFont();
                                tft.setTextSize(1);
                              void updateTime()
                                //Update Time
                                tft.setTextSize(1);
                                tft.print(month());
                                tft.print(day());
                                tft.print(F("/"));
                                tft.print(F(" "));
                              void updateTemp()
                                tft.setTextSize(1);
                                tft.print(" ");
                              void updateHum()
                                //Update Humidity
                                tft.setTextSize(1);
                                tft.print("% ");
                              • rechin304R
                                rechin304R
                                rechin304
                                This is the output that i get. Maybe you can understand why. And this is a clean example. Anyone have make temp DHT11 to work in version2 ?
                                TSM:INIT
                                TSM:RADIO:OK
                                TSP:ASSIGNID:OK (ID=27)
                                TSM:FPAR
                                TSP:MSG:SEND 27-27-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                                TSM:FPAR
                                TSP:MSG:READ 25-25-27 s=255,c=3,t=8,pt=1,l=1,sg=0:1
                                TSP:MSG:FPAR RES (ID=25, dist=1)
                                TSP:MSG:PAR OK (ID=25, dist=2)
                                TSP:MSG:READ 0-0-27 s=255,c=3,t=8,pt=1,l=1,sg=0:0
                                TSP:MSG:PAR OK (ID=0, dist=1)
                                TSM:FPAR:OK
                                TSM:ID
                                TSM:CHKID:OK (ID=27)
                                TSM:UPL
                                TSP:PING:SEND (dest=0)
                                TSP:MSG:SEND 27-27-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
                                TSP:MSG:READ 0-0-27 s=255,c=3,t=25,pt=1,l=1,sg=0:1
                                TSP:MSG:PONG RECV (hops=1)
                                TSP:CHKUPL:OK
                                TSM:UPL:OK
                                TSM:READY
                                TSP:MSG:SEND 27-27-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
                                TSP:MSG:SEND 27-27-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=ok:2.0.0
                                TSP:MSG:SEND 27-27-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=ok:0
                                TSP:MSG:READ 0-0-27 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                TSP:MSG:READ 0-0-27 s=255,c=3,t=6,pt=0,l=1,sg=0:M
                                TSP:MSG:SEND 27-27-0-0 s=255,c=3,t=11,pt=0,l=22,sg=0,ft=0,st=ok:TemperatureAndHumidity
                                TSP:MSG:SEND 27-27-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=ok:1.1
                                TSP:MSG:SEND 27-27-0-0 s=0,c=0,t=7,pt=0,l=0,sg=0,ft=0,st=ok:
                                TSP:MSG:SEND 27-27-0-0 s=1,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=ok:
                                Request registration...
                                TSP:MSG:SEND 27-27-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
                                TSP:MSG:READ 0-0-27 s=255,c=3,t=27,pt=1,l=1,sg=0:1
                                Node registration=1
                                Init complete, id=27, parent=0, distance=1, registration=1```
                                If i get the sensor out i get this
                                Failed reading temperature from DHT!
                                petewillP flyswiftlyF 2 Replies Last reply
                                  TSM:INIT
                                  TSM:RADIO:OK
                                  TSM:FPAR
                                  TSM:FPAR
                                  TSM:FPAR:OK
                                  TSM:ID
                                  TSM:UPL
                                  TSP:CHKUPL:OK
                                  TSM:UPL:OK
                                  TSM:READY
                                  Node registration=1
                                  petewillP
                                  petewillP
                                  petewill
                                  @rechin304 Something is most likely wrong with your wiring or the sensor. I am using a DHT22 without any issues in my rain gauge which is on 2.0 (I'm using the most recent beta release). Try connecting a 4.7k resistor between the data pin and power on the DHT like this.
                                  0_1478303148400_upload-1d245d6b-aad9-4841-8307-485c9caf5056
                                  • enloE
                                    enloE
                                    enlo
                                    @petewill wow, your screen case looks amazing! Is that acryl glass? Did you build that yourself too?
                                    • enloE enlo
                                      petewillP
                                      petewillP
                                      petewill
                                      @enlo Thanks. Yeah, it's acrylic glass (Plexiglas). It was a pain to use though as I couldn't clean off the paint very well. My next project I'm working on I'm going to try to use regular glass.
                                        TSM:INIT
                                        TSM:RADIO:OK
                                        TSM:FPAR
                                        TSM:FPAR
                                        TSM:FPAR:OK
                                        TSM:ID
                                        TSM:UPL
                                        TSP:CHKUPL:OK
                                        TSM:UPL:OK
                                        TSM:READY
                                        Node registration=1
                                        flyswiftlyF
                                        flyswiftlyF
                                        flyswiftly
                                        For what it's worth, I just went through a very long debug session trying to get a simple dht11 based sensor built and working. For reasons I don't even pretend to understand, the one thing I changed that allows it to work is changing the 'sleep' command in this section of the setup function to a 'wait' command.
                                        • flyswiftlyF flyswiftly
                                          rechin304R
                                          rechin304R
                                          rechin304
                                          @flyswiftly thanks for trying,
                                          in my case still i do not see any data. What library do you use ? The one from MySensorsArduinoExamples-master.zip ?
                                          flyswiftlyF 1 Reply Last reply
