  3. How to pass the #define for MySensors
4 Posts 2 Posters 1.4k Views 3 Watching
  • Ricardo JL RufinoR Offline
    Ricardo JL Rufino
    I need to use the same technique in my library but is not working.
    I am using in my config.h
    #ifdef ODEV_API_KEY
    #define ODEV_API_KEY_REAL ODEV_API_KEY
    #ifndef ODEV_API_KEY
    #define ODEV_API_KEY_REAL "*"
    const char MQTT_TOPIC[] = ODEV_API_KEY_REAL "/in/ModuleName";
    If I put a #error at first condiftion, it really indicates is falling in this first condition, but MQTT_TOPIC is as if he had fallen in second
    • hekH Offline
      hekH Offline
      The "trick" we use in the mysensors library is to include code files (cpp) in the MySensors.h header file. A bit ugly but as the Arduino IDE has a very limited build system, it's the only way you can make defines in sketch visible in the code.
        Ricardo JL Rufino
        wrote on last edited by Ricardo JL Rufino
        If I knew it could include cpf in a .h file I had done before ... =]
        Thanks for the tip.
          Ricardo JL Rufino
          I have found some alternatives that can be used:
          https://electrohobby.ca/forum/showthread.php?tid=214&pid=1281
