  2. Announcements
    @Velo17
    Just sleep longer. It sends one heartbeat every time the node wakes up.
    • Christian SimonsenC Christian Simonsen
      @marceloaqno said:
      @Christian-Simonsen
      mysGateway: TSF:MSG:READ,0-0-0,s=0,c=0,t=0,pt=0,l=0,sg=0:
      mysGateway: !TSF:MSG:LEN,0!=7
      looks like a power issue with the nrf24 module.
      Ok,
      I've tested with the Voltmeter and the NRF24L01 module do get a steady 3.26 V. Both the gateway module and the Arduino sensor node...
      Im now building a few extra sensor nodes, so I can test without the Raspberry pi. Hopefully I can atleast get them talking based on Arduinos first. Before testing the Raspberry Pi.
      dopeeyeD
      dopeeyeD
      dopeeye
      @Christian-Simonsen
      I have exactly the same error
      Have you been able to resolve that problem yet? I have tried multiple radios with different capacitors and powersources grounded to the Raspberry Pi.
      thanks
      Christian SimonsenC 1 Reply Last reply
      • dopeeyeD dopeeye
        @Christian-Simonsen
        thanks
        Christian SimonsenC
        Christian SimonsenC
        Christian Simonsen
        @dopeeye
        Sadly not. I ended up creating an serial gateway (arduino with NRF24L01 and a USB connector) and connected this to the Raspberry Pi, rather than connecting the NRF24L01 directly to the GPIO pins. This worked perfectly straight away.
        dopeeyeD 1 Reply Last reply
          @dopeeye
          dopeeyeD
          dopeeyeD
          dopeeye
          @Christian-Simonsen
          Too stubborn to give up, yet.
          If i find a resolution I will let you know
          carlylerC 1 Reply Last reply
          • GrahamG
            GrahamG
            Graham
            I would like to try this, but my pins19-23 are already used by other hardware. Has anyone tried using the SPI1 Pins?
            • dopeeyeD dopeeye
              @Christian-Simonsen
              carlylerC
              carlylerC
              carlyler
              @dopeeye I had this issue and unfortunately changed several things at once and got rid of it. However, one thing I noticed was I had different versions of mySensors in my library directory since I downloaded the examples package. Therefore the sensor was likely compiling on a different version than the Gateway. You might want to check that.
              If you could post more of your logs (sensor and gateway) it might help.
              • E
                E
                ericvdb
                @marceloaqno
                When running as a service, is there a way to watch the debug log?
                • Patrik SöderströmP
                  Patrik SöderströmP
                  Patrik Söderström
                  Any ETA on support for RFM69 ? Need to extend my coverage :)
                  • alescA
                    alescA
                    alesc
                    Done:
                    1. git clone https://github.com/mysensors/MySensors.git
                    2. ./configure --my-gateway=mqtt --my-controller-ip-address=127.0.0.1 --my-mqtt-publish-topic-prefix=mysensors-out --my-mqtt-subscribe-topic-prefix=mysensors-in --my-mqtt-client-id=mygateway1
                    3. make.
                      Got error:
                      In file included from ./MySensors.h:287:0,
                      from examples_linux/mysGateway.cpp:70:
                      ./drivers/RF24/RF24.cpp: In function âuint8_t RF24_spiMultiByteTransfer(uint8_t, uint8_t*, uint8_t, bool)â:
                      ./drivers/RF24/RF24.cpp:65:22: error: âNOPâ was not declared in this scope
                      *ptx++ = NOP ;
                      Makefile:46: recipe for target 'examples_linux/mysGateway.o' failed
                      make: *** [examples_linux/mysGateway.o] Error 1
                      Any idea?
                    mfalkviddM tekkaT 2 Replies Last reply
                    • alescA alesc
                      Done:
                      3. make.
                        Got error:
                        *ptx++ = NOP ;
                        Any idea?
                      #103
                      @alesc looks like this commit in the development branch broke the code.
                      Do
                      git checkout master
                      before running configure should get the code to the latest stable release.
                      EDIT: Sorry, that won't work because the Raspberry Pi stuff didn't exist when MySensors 2.0 was released. You'll have to do git pull instead, to get tekka's fix.
                      • alescA alesc
                        Done:
                        3. make.
                          Got error:
                          *ptx++ = NOP ;
                          Any idea?
                        tekkaT
                        tekkaT
                        tekka
                        wrote on last edited by tekka
                        #104
                        @alesc @mfalkvidd Thanks for reporting, fixed: https://github.com/mysensors/MySensors/pull/635
                        • ben999B
                          ben999B
                          ben999
                          wrote on last edited by ben999
                          #105
                          Hi Everyone !
                          Big thumb up for the amount of work supplied !!!
                          After being more or less successful with openHAB1 I had a go with openHAB2 today, via a online install....
                          But no success with the "mysGateway" install : should i go back to serial gateway with an arduino ?
                          Thanks a lot for your help
                          • carlylerC
                            carlylerC
                            carlyler
                            @ben999 try again, because it works great. I assume by online install you mean apt-get; I too had trouble when trying this. However, I tried again following @TimO instructions here:
                            wiki, then everything came up nicely. I feel it is some permission issue that I have not tried to figure out yet.
                            ben999B 1 Reply Last reply
                              marceloaqno
                              Code Contributor
                              wrote on last edited by marceloaqno
                              #107
                              @ericvdb when running as a service, debug messages are masked and aren't shown in the system logs, but it would be a good idea to have a way to connect to gateway perhaps using telnet and watch the logs. I'll work on something.
                              • carlylerC carlyler
                                ben999B
                                ben999B
                                ben999
                                @carlyler
                                Thanks a lot for your message, hope is back on my side :)
                                Actually I had a go with openHABian (i didn't make it clear in my previous message, sorry)
                                The install itself couldn't be easier : OS+openHAB installed in one go, just by formatting SD Card with a tiny img file. One hour later and voilà !
                                So that could be the source of my trouble?
                                I will go with the link you supplied tonight and let you know (lookslike it is a manual install... scary!!)
                                Thank you again for your support
                                • carlylerC
                                  carlylerC
                                  carlyler
                                  @ben999 if you have not already, read through the MySensors OH2 thread. I noticed a recent post by @TimO that talks about setting some permissions and that might be the issue. Otherwise, the manual install is not bad as he gives you step-by-step; I am a new to all this and managed to get it to work...
                                    ben999B
                                    ben999B
                                    ben999
                                    @carlyler
                                    Smashing
                                    Thanks a lot for that hint... I remember reading that...
                                    Linux is so damn rigid :laughing:
                                    Thank you again for your help
                                    • JahFyahhJ
                                      JahFyahhJ
                                      JahFyahh
                                      Either its not stated or I cannot see it, but i was wondering... Is this version 2 voor de rPi?
                                      At the moment I am using MySensors version 1.5 with Pimatic as controller. And I would like to use v2.
                                      • E
                                        E
                                        ericvdb
                                        @ben999 Yes, version 2
                                        • ben999B
                                          ben999B
                                          ben999
                                          #113
                                          I feel a bit sorry to come back here for my own little troubles...
                                          1- So i installed openhab2 on RPi3 with a fresh SDCard
                                          2- I followed tobof 's excellent step-by-step howto
                                          3- I installed mysGateway
                                          4- With pi@raspberrypi:~/MySensors $ sudo ./examples_linux/mysGateway -d i can see that my motion sensor and my RPi gateway get on well... they do speak to each other, right ?
                                          mysGateway: Starting gateway...
                                          mysGateway: Protocol version - 2.0.1-beta
                                          mysGateway: MCO:BGN:INIT GW,CP=RNNG---,VER=2.0.1-beta
                                          mysGateway: TSF:LRT:OK
                                          mysGateway: TSM:INIT
                                          mysGateway: TSM:INIT:TSP OK
                                          mysGateway: TSM:INIT:GW MODE
                                          mysGateway: TSM:READY
                                          mysGateway: MCO:REG:NOT NEEDED
                                          mysGateway: MCO:BGN:STP
                                          mysGateway: MCO:BGN:INIT OK,ID=0,PAR=0,DIS=0,REG=1
                                          mysGateway: TSF:MSG:READ,1-1-0,s=1,c=1,t=16,pt=0,l=1,sg=0:1
                                          mysGateway: TSF:MSG:READ,1-1-0,s=1,c=1,t=16,pt=0,l=1,sg=0:0
                                          5-in things/demo.things" I put this.
                                          Bridge mysensors:bridge-ser:gateway [ serialPort="/dev/pts/2", sendDelay=200 ] {  }
                                          Right away, it worked (king of the world!) and i could see that bridge in paperUI !!!
                                          But i got that after a reboot of RPi
                                          openhab> Failed to connect on port: /dev/pts/2 exception:
                                          gnu.io.NoSuchPortException
                                                  at gnu.io.CommPortIdentifier.getPortIdentifier(CommPortIdentifier.java:273)
                                                  at gnu.io.NRSerialPort.connect(NRSerialPort.java:48)
                                                  at org.openhab.binding.mysensors.protocol.serial.MySensorsSerialConnection.<init>(MySensorsSerialConnection.java:52)
                                                  at org.openhab.binding.mysensors.handler.MySensorsBridgeHandler.initialize(MySensorsBridgeHandler.java:63)
                                                  at org.eclipse.smarthome.core.thing.internal.ThingManager$9$1.call(ThingManager.java:764)
                                                  at org.eclipse.smarthome.core.thing.internal.ThingManager$9$1.call(ThingManager.java:1)
                                                  at org.eclipse.smarthome.core.common.SafeMethodCaller$CallableWrapper.call(SafeMethodCaller.java:177)
                                                  at java.util.concurrent.FutureTask.run(FutureTask.java:266)
                                                  at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
                                                  at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
                                                  at java.lang.Thread.run(Thread.java:745)
                                          Wrong serial port ?
                                          Juste to make it clear : mysGateway bit of software is the magic that makes RPi believe that there's an arduino acting as a gateway on USB and collects the NRF24 info through GPio ?
