  2. Announcements
  3. đź’¬ Building a Raspberry Pi Gateway
    @Patrik-Söderström said:
    Can I attach one or more DallasTemp sensors on the Raspberry Pi gateway?
    I haven't seen anyone doing anything similar so it might require some work. But almost anything is possible given enough work :)
    Patrik SöderströmP
    Patrik SöderströmP
    Patrik Söderström
    @mfalkvidd Alright :) The thing is that I have my Raspberry Pi as a Gateway today near my server rack and would like to measure the temperatur. Maybe I just get a Nano to do the work for me. Just would have been great to use the Raspberry.
    • Patrik SöderströmP Patrik Söderström
      @Patrik-Söderström You can probably connect a temperature sensor to the gpio pins and have your controller read the sensor (without using MySensors)
      • carlylerC carlyler
        Appears things are changing, please update wiki:
        Warning: --my-radio is deprecated, please use --my-transport
        marceloaqno
        Code Contributor
        @carlyler Thanks for pointing that out.
        • jerseyguy1996J jerseyguy1996
          Has anyone else had an issue with getting a sensor node to reconnect after a lost connection? I can see it attempting to reconnect but even though it is back within range of the gateway it won't reestablish the connection. If I reset the node it re-establishes the connection without any problem. This is the cycle that it gets stuck in:
          TSM:FPAR
          TSP:MSG:SEND 3-3-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
          TSP:MSG:READ 0-0-3 s=255,c=3,t=8,pt=1,l=1,sg=0:0
          TSP:MSG:PAR OK (ID=0, dist=1)
          TSM:FPAR:OK
          TSM:ID
          TSM:CHKID:OK (ID=3)
          TSM:UPL
          TSP:PING:SEND (dest=0)
          !TSP:MSG:SEND 3-3-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=fail:1
          TSP:CHKUPL:FAIL (hops=255)
          !TSM:UPL:FAIL
          TSM:FPAR
          !TSP:SEND:TNR
          !TSP:SEND:TNR
          !TSP:SEND:TNR
          !TSP:SEND:TNR
          !TSP:SEND:TNR
          !TSP:SEND:TNR
          TSM:FPAR
          TSM:FPAR:OK
          TSM:ID
          TSM:CHKID:OK (ID=3)
          TSM:UPL
          !TSM:UPL:FAIL
          TSM:FPAR
          !TSP:SEND:TNR
          !TSP:SEND:TNR
          !TSP:SEND:TNR
          !TSP:SEND:TNR
          !TSP:SEND:TNR
          !TSP:SEND:TNR```
          marceloaqno
          Code Contributor
          @jerseyguy1996 Are you using a decoupling capacitor?
          jerseyguy1996J R 2 Replies Last reply
          • M marceloaqno
            jerseyguy1996J
            jerseyguy1996J
            jerseyguy1996
            wrote on last edited by jerseyguy1996
            #92
            @marceloaqno Yes its 220 uF. It was all I had handy. I read somewhere that this may be a problem specific to the arduino nano. I may give it a try with the pro mini. Although I'm not sure what that may have to do with it.
            Edit: I tried the same sketch on an arduino pro mini and it worked fine. When I simulated a loss of connection by walking out of range of the gateway it immediately reestablished the connection when I got back within range. The only difference is that the pro mini is running at 8 mhz whereas the nano runs at 16 mhz. Not sure how that affects things.
            • Velo17V
              Velo17V
              Velo17
              Hello everyone. Is there a way to reduce the number of Heartbeat messages the gateway produces by itself? Using MYSController to analyze the data traffic, I see every 10 seconds a Heartbeat - would like to reduce this once everything is working as expected to maybe every 5 or 10 minutes...
                @Velo17
                Just sleep longer. It sends one heartbeat every time the node wakes up.
                • Christian SimonsenC Christian Simonsen
                  @marceloaqno said:
                  @Christian-Simonsen
                  mysGateway: TSF:MSG:READ,0-0-0,s=0,c=0,t=0,pt=0,l=0,sg=0:
                  mysGateway: !TSF:MSG:LEN,0!=7
                  looks like a power issue with the nrf24 module.
                  Ok,
                  I've tested with the Voltmeter and the NRF24L01 module do get a steady 3.26 V. Both the gateway module and the Arduino sensor node...
                  Im now building a few extra sensor nodes, so I can test without the Raspberry pi. Hopefully I can atleast get them talking based on Arduinos first. Before testing the Raspberry Pi.
                  dopeeyeD
                  dopeeyeD
                  dopeeye
                  @Christian-Simonsen
                  I have exactly the same error
                  Have you been able to resolve that problem yet? I have tried multiple radios with different capacitors and powersources grounded to the Raspberry Pi.
                  thanks
                  Christian SimonsenC 1 Reply Last reply
                  • dopeeyeD dopeeye
                    @Christian-Simonsen
                    thanks
                    Christian SimonsenC
                    Christian SimonsenC
                    Christian Simonsen
                    @dopeeye
                    Sadly not. I ended up creating an serial gateway (arduino with NRF24L01 and a USB connector) and connected this to the Raspberry Pi, rather than connecting the NRF24L01 directly to the GPIO pins. This worked perfectly straight away.
                    dopeeyeD 1 Reply Last reply
                      @dopeeye
                      dopeeyeD
                      dopeeyeD
                      dopeeye
                      @Christian-Simonsen
                      Too stubborn to give up, yet.
                      If i find a resolution I will let you know
                      carlylerC 1 Reply Last reply
                      • GrahamG
                        GrahamG
                        Graham
                        I would like to try this, but my pins19-23 are already used by other hardware. Has anyone tried using the SPI1 Pins?
                        • dopeeyeD dopeeye
                          @Christian-Simonsen
                          carlylerC
                          carlylerC
                          carlyler
                          @dopeeye I had this issue and unfortunately changed several things at once and got rid of it. However, one thing I noticed was I had different versions of mySensors in my library directory since I downloaded the examples package. Therefore the sensor was likely compiling on a different version than the Gateway. You might want to check that.
                          If you could post more of your logs (sensor and gateway) it might help.
                          • E
                            E
                            ericvdb
                            @marceloaqno
                            When running as a service, is there a way to watch the debug log?
                              Patrik SöderströmP
                              Patrik Söderström
                              Any ETA on support for RFM69 ? Need to extend my coverage :)
                              • alescA
                                alescA
                                alesc
                                Done:
                                1. git clone https://github.com/mysensors/MySensors.git
                                2. ./configure --my-gateway=mqtt --my-controller-ip-address=127.0.0.1 --my-mqtt-publish-topic-prefix=mysensors-out --my-mqtt-subscribe-topic-prefix=mysensors-in --my-mqtt-client-id=mygateway1
                                3. make.
                                  Got error:
                                  In file included from ./MySensors.h:287:0,
                                  from examples_linux/mysGateway.cpp:70:
                                  ./drivers/RF24/RF24.cpp: In function âuint8_t RF24_spiMultiByteTransfer(uint8_t, uint8_t*, uint8_t, bool)â:
                                  ./drivers/RF24/RF24.cpp:65:22: error: âNOPâ was not declared in this scope
                                  *ptx++ = NOP ;
                                  Makefile:46: recipe for target 'examples_linux/mysGateway.o' failed
                                  make: *** [examples_linux/mysGateway.o] Error 1
                                  Any idea?
                                mfalkviddM tekkaT 2 Replies Last reply
                                • alescA alesc
                                  Done:
                                  3. make.
                                    Got error:
                                    *ptx++ = NOP ;
                                    Any idea?
                                  #103
                                  @alesc looks like this commit in the development branch broke the code.
                                  Do
                                  git checkout master
                                  before running configure should get the code to the latest stable release.
                                  EDIT: Sorry, that won't work because the Raspberry Pi stuff didn't exist when MySensors 2.0 was released. You'll have to do git pull instead, to get tekka's fix.
                                  • alescA alesc
                                    Done:
                                    3. make.
                                      Got error:
                                      *ptx++ = NOP ;
                                      Any idea?
                                    tekkaT
                                    tekkaT
                                    tekka
                                    wrote on last edited by tekka
                                    #104
                                    @alesc @mfalkvidd Thanks for reporting, fixed: https://github.com/mysensors/MySensors/pull/635
                                    • ben999B
                                      ben999B
                                      ben999
                                      wrote on last edited by ben999
                                      #105
                                      Hi Everyone !
                                      Big thumb up for the amount of work supplied !!!
                                      After being more or less successful with openHAB1 I had a go with openHAB2 today, via a online install....
                                      But no success with the "mysGateway" install : should i go back to serial gateway with an arduino ?
                                      Thanks a lot for your help
                                      • carlylerC
                                        carlylerC
                                        carlyler
                                        @ben999 try again, because it works great. I assume by online install you mean apt-get; I too had trouble when trying this. However, I tried again following @TimO instructions here:
                                        wiki, then everything came up nicely. I feel it is some permission issue that I have not tried to figure out yet.
                                        ben999B 1 Reply Last reply
                                          marceloaqno
                                          Code Contributor
                                          wrote on last edited by marceloaqno
                                          #107
                                          @ericvdb when running as a service, debug messages are masked and aren't shown in the system logs, but it would be a good idea to have a way to connect to gateway perhaps using telnet and watch the logs. I'll work on something.
                                          With your input, this post could be even better đź’—
