  2. Announcements
  • dopeeyeD dopeeye
    @Christian-Simonsen
    I have exactly the same error
    mysGateway: !TSF:MSG:LEN,0!=7
    Have you been able to resolve that problem yet? I have tried multiple radios with different capacitors and powersources grounded to the Raspberry Pi.
    thanks
    Christian SimonsenC
    Christian SimonsenC
    Christian Simonsen
    @dopeeye
    Sadly not. I ended up creating an serial gateway (arduino with NRF24L01 and a USB connector) and connected this to the Raspberry Pi, rather than connecting the NRF24L01 directly to the GPIO pins. This worked perfectly straight away.
    dopeeyeD 1 Reply Last reply
    • Christian SimonsenC Christian Simonsen
      @dopeeye
      dopeeyeD
      dopeeyeD
      dopeeye
      @Christian-Simonsen
      Too stubborn to give up, yet.
      If i find a resolution I will let you know
      carlylerC 1 Reply Last reply
      • GrahamG
        GrahamG
        Graham
        I would like to try this, but my pins19-23 are already used by other hardware. Has anyone tried using the SPI1 Pins?
        • dopeeyeD dopeeye
          @Christian-Simonsen
          carlylerC
          carlylerC
          carlyler
          @dopeeye I had this issue and unfortunately changed several things at once and got rid of it. However, one thing I noticed was I had different versions of mySensors in my library directory since I downloaded the examples package. Therefore the sensor was likely compiling on a different version than the Gateway. You might want to check that.
          If you could post more of your logs (sensor and gateway) it might help.
          • E
            E
            ericvdb
            @marceloaqno
            When running as a service, is there a way to watch the debug log?
            • Patrik SöderströmP
              Patrik SöderströmP
              Patrik Söderström
              Any ETA on support for RFM69 ? Need to extend my coverage :)
              • alescA
                alescA
                alesc
                Done:
                1. git clone https://github.com/mysensors/MySensors.git
                2. ./configure --my-gateway=mqtt --my-controller-ip-address=127.0.0.1 --my-mqtt-publish-topic-prefix=mysensors-out --my-mqtt-subscribe-topic-prefix=mysensors-in --my-mqtt-client-id=mygateway1
                3. make.
                  Got error:
                  In file included from ./MySensors.h:287:0,
                  from examples_linux/mysGateway.cpp:70:
                  ./drivers/RF24/RF24.cpp: In function âuint8_t RF24_spiMultiByteTransfer(uint8_t, uint8_t*, uint8_t, bool)â:
                  ./drivers/RF24/RF24.cpp:65:22: error: âNOPâ was not declared in this scope
                  *ptx++ = NOP ;
                  Makefile:46: recipe for target 'examples_linux/mysGateway.o' failed
                  make: *** [examples_linux/mysGateway.o] Error 1
                  Any idea?
                mfalkviddM tekkaT 2 Replies Last reply
                • alescA alesc
                  Done:
                  3. make.
                    Got error:
                    *ptx++ = NOP ;
                    Any idea?
                  #103
                  @alesc looks like this commit in the development branch broke the code.
                  Do
                  git checkout master
                  before running configure should get the code to the latest stable release.
                  EDIT: Sorry, that won't work because the Raspberry Pi stuff didn't exist when MySensors 2.0 was released. You'll have to do git pull instead, to get tekka's fix.
                  • alescA alesc
                    Done:
                    3. make.
                      Got error:
                      *ptx++ = NOP ;
                      Any idea?
                    tekkaT
                    tekkaT
                    tekka
                    wrote on last edited by tekka
                    #104
                    @alesc @mfalkvidd Thanks for reporting, fixed: https://github.com/mysensors/MySensors/pull/635
                    • ben999B
                      ben999B
                      ben999
                      wrote on last edited by ben999
                      #105
                      Hi Everyone !
                      Big thumb up for the amount of work supplied !!!
                      After being more or less successful with openHAB1 I had a go with openHAB2 today, via a online install....
                      But no success with the "mysGateway" install : should i go back to serial gateway with an arduino ?
                      Thanks a lot for your help
                      • carlylerC
                        carlylerC
                        carlyler
                        @ben999 try again, because it works great. I assume by online install you mean apt-get; I too had trouble when trying this. However, I tried again following @TimO instructions here:
                        wiki, then everything came up nicely. I feel it is some permission issue that I have not tried to figure out yet.
                        ben999B 1 Reply Last reply
                          marceloaqno
                          Code Contributor
                          wrote on last edited by marceloaqno
                          #107
                          @ericvdb when running as a service, debug messages are masked and aren't shown in the system logs, but it would be a good idea to have a way to connect to gateway perhaps using telnet and watch the logs. I'll work on something.
                          • carlylerC carlyler
                            ben999B
                            ben999B
                            ben999
                            @carlyler
                            Thanks a lot for your message, hope is back on my side :)
                            Actually I had a go with openHABian (i didn't make it clear in my previous message, sorry)
                            The install itself couldn't be easier : OS+openHAB installed in one go, just by formatting SD Card with a tiny img file. One hour later and voilà !
                            So that could be the source of my trouble?
                            I will go with the link you supplied tonight and let you know (lookslike it is a manual install... scary!!)
                            Thank you again for your support
                            • carlylerC
                              carlylerC
                              carlyler
                              @ben999 if you have not already, read through the MySensors OH2 thread. I noticed a recent post by @TimO that talks about setting some permissions and that might be the issue. Otherwise, the manual install is not bad as he gives you step-by-step; I am a new to all this and managed to get it to work...
                                ben999B
                                ben999B
                                ben999
                                @carlyler
                                Smashing
                                Thanks a lot for that hint... I remember reading that...
                                Linux is so damn rigid :laughing:
                                Thank you again for your help
                                • JahFyahhJ
                                  JahFyahhJ
                                  JahFyahh
                                  Either its not stated or I cannot see it, but i was wondering... Is this version 2 voor de rPi?
                                  At the moment I am using MySensors version 1.5 with Pimatic as controller. And I would like to use v2.
                                  • E
                                    E
                                    ericvdb
                                    @ben999 Yes, version 2
                                    • ben999B
                                      ben999B
                                      ben999
                                      #113
                                      I feel a bit sorry to come back here for my own little troubles...
                                      1- So i installed openhab2 on RPi3 with a fresh SDCard
                                      2- I followed tobof 's excellent step-by-step howto
                                      3- I installed mysGateway
                                      4- With pi@raspberrypi:~/MySensors $ sudo ./examples_linux/mysGateway -d i can see that my motion sensor and my RPi gateway get on well... they do speak to each other, right ?
                                      mysGateway: Starting gateway...
                                      mysGateway: Protocol version - 2.0.1-beta
                                      mysGateway: MCO:BGN:INIT GW,CP=RNNG---,VER=2.0.1-beta
                                      mysGateway: TSF:LRT:OK
                                      mysGateway: TSM:INIT
                                      mysGateway: TSM:INIT:TSP OK
                                      mysGateway: TSM:INIT:GW MODE
                                      mysGateway: TSM:READY
                                      mysGateway: MCO:REG:NOT NEEDED
                                      mysGateway: MCO:BGN:STP
                                      mysGateway: MCO:BGN:INIT OK,ID=0,PAR=0,DIS=0,REG=1
                                      mysGateway: TSF:MSG:READ,1-1-0,s=1,c=1,t=16,pt=0,l=1,sg=0:1
                                      mysGateway: TSF:MSG:READ,1-1-0,s=1,c=1,t=16,pt=0,l=1,sg=0:0
                                      5-in things/demo.things" I put this.
                                      Bridge mysensors:bridge-ser:gateway [ serialPort="/dev/pts/2", sendDelay=200 ] {  }
                                      Right away, it worked (king of the world!) and i could see that bridge in paperUI !!!
                                      But i got that after a reboot of RPi
                                      openhab> Failed to connect on port: /dev/pts/2 exception:
                                      gnu.io.NoSuchPortException
                                              at gnu.io.CommPortIdentifier.getPortIdentifier(CommPortIdentifier.java:273)
                                              at gnu.io.NRSerialPort.connect(NRSerialPort.java:48)
                                              at org.openhab.binding.mysensors.protocol.serial.MySensorsSerialConnection.<init>(MySensorsSerialConnection.java:52)
                                              at org.openhab.binding.mysensors.handler.MySensorsBridgeHandler.initialize(MySensorsBridgeHandler.java:63)
                                              at org.eclipse.smarthome.core.thing.internal.ThingManager$9$1.call(ThingManager.java:764)
                                              at org.eclipse.smarthome.core.thing.internal.ThingManager$9$1.call(ThingManager.java:1)
                                              at org.eclipse.smarthome.core.common.SafeMethodCaller$CallableWrapper.call(SafeMethodCaller.java:177)
                                              at java.util.concurrent.FutureTask.run(FutureTask.java:266)
                                              at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
                                              at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
                                              at java.lang.Thread.run(Thread.java:745)
                                      Wrong serial port ?
                                      Juste to make it clear : mysGateway bit of software is the magic that makes RPi believe that there's an arduino acting as a gateway on USB and collects the NRF24 info through GPio ?
                                      • ben999B ben999
                                        Wrong serial port ?
                                        @ben999 said:
                                        Wrong serial port ?
                                        Likely ;-)
                                        /dev/pts/x are pseudo-terminals , not serial ports.
                                        On my (old) Pi running Raspbian the serial port is /dev/ttyAMA0
                                        You could run something like
                                        dmesg |grep -i tty
                                        to get an idea of serial ports on your Pi.
                                        • YveauxY Yveaux
                                          @ben999 said:
                                          Wrong serial port ?
                                          Likely ;-)
                                          dmesg |grep -i tty
                                          ben999B
                                          ben999B
                                          ben999
                                          @Yveaux thanks a lot for your answer. Understanding linux is a slow and painful process :laughing:
                                          Here is the output from your command : dmesg |grep -i tty
                                          pi@raspberrypi:~ $ dmesg |grep -i tty
                                          [    0.000000] Kernel command line: 8250.nr_uarts=0 dma.dmachans=0x7f35 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2709.boardrev=0xa02082 bcm2709.serial=0xcc3e67e3 smsc95xx.macaddr=B8:27:EB:3E:67:E3 bcm2708_fb.fbswap=1 bcm2709.uart_clock=48000000 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
                                          [    0.001337] console [tty1] enabled
                                          [    1.772114] 3f201000.uart: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
                                          What a mess...
                                          ttyAMA0 is the one !!!
                                          Thanks @Yveaux you got me on the right path !!! Goto next step! :smile:
