  2. Bug Reports
  3. [solved] RFM69 based nodes unable to report Lib Version
51 Posts 8 Posters 24.8k Views 5 Watching
  • J jpaulin
    @Anticimex
    I don't know how to file a pull request, so I put the test results here.
    Modified as follows to remove the preprocessor condition at: https://github.com/mysensors/MySensors/blob/development/core/MySigning.cpp#L154-L160
    // #if defined(MY_SIGNING_FEATURE)
        // If we do support signing, wait for the gateway to tell us how it prefer us to transmit our messages
        if (destination == GATEWAY_ADDRESS) {
    	    SIGN_DEBUG(PSTR("Waiting for GW to send signing preferences...\n"));
    	    wait(2000, C_INTERNAL, I_SIGNING_PRESENTATION);
    // #endif
    solves the issue.
    At the same time the internal message received from the gateway seems to be erroneously transferred to the receive() function in a sketch. Adding to the sketch
        Serial.println("something came in");
    gets the message dump:
    2310 TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
    2332 TSF:MSG:READ,0-0-3,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
    something came in
    2409 TSF:MSG:SEND,3-3-0-0,s=255,c=0,t=17,pt=0,l=10,sg=0,ft=0,st=OK:2.0.1-beta
    2496 TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
    To solve this I made the following change to _processInternalMessages(void) in MySensorsCore.cpp.
    Line https://github.com/mysensors/MySensors/blob/development/core/MySensorsCore.cpp#L407 is replaced with:
    	else if (type == I_SIGNING_PRESENTATION) {
    	else return false;
    The message dump now looks like this:
    2250 TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
    2269 TSF:MSG:READ,0-0-3,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
    2331 TSF:MSG:SEND,3-3-0-0,s=255,c=0,t=17,pt=0,l=10,sg=0,ft=0,st=OK:2.0.1-beta
    2441 TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
    At the API description page https://www.mysensors.org/download/serial_api_20 seems to be another error.
    For the internal message t=15 the name description
    I_REQUEST_SIGNING 	15 	Used between sensors when initialting signing.
    should be changed to
    I_SIGNING_PRESENTATION 	15 	Provides signing related preferences.
    This I think is relevant both for the master and the development branch.
    AnticimexA
    AnticimexA
    Anticimex
    @jpaulin I have made a pull request. My solution differs slightly from your as the I_SIGNING_PRESENTATION should never reach the _processInternalMessages function. I do however not have the ability to test so I would appreciate if you could test the PR for me?
    Thanks for finding and pointing out the flaws! :D
    J 1 Reply Last reply
    • AnticimexA Anticimex
      J
      J
      jpaulin
      @Anticimex
      I updated my node and GW with your pull request and made some basic tests and it seems to work ok with my sketch. I added MY_DEBUG_VERBOSE_SIGNING and got the following messages.
      From the node:
      2205 TSM:READY
      2220 TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
      2226 Waiting for GW to send signing preferences...
      2280 TSF:MSG:READ,0-0-3,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
      2285 Received signing presentation, but signing is not supported (message ignored)
      2349 TSF:MSG:SEND,3-3-0-0,s=255,c=0,t=17,pt=0,l=10,sg=0,ft=0,st=OK:2.0.1-beta
      2450 TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
      From the GW:
      0;255;3;0;9;TSF:MSG:PINGED,ID=3,HP=1
      0;255;3;0;9;TSF:MSG:SEND,0-0-3-3,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
      0;255;3;0;9;TSF:MSG:READ,3-3-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
      0;255;3;0;9;Informing node 3 that we do not require signatures because we do not support it
      0;255;3;0;9;TSF:MSG:SEND,0-0-3-3,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
      0;255;3;0;9;TSF:MSG:READ,3-3-0,s=255,c=0,t=17,pt=0,l=10,sg=0:2.0.1-beta
      0;255;3;0;9;Sending message on topic: my_RFM69_gw1-out/3/255/0/0/17
      0;255;3;0;9;TSF:MSG:READ,3-3-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
      Do you need some more testing?
      AnticimexA 1 Reply Last reply
      • J jpaulin
        @Anticimex
        From the node:
        2205 TSM:READY
        From the GW:
        AnticimexA
        AnticimexA
        Anticimex
        @jpaulin thanks for testing. The change should have little effect for people using signing. The issue is for people who does not use it as the node did not wait for a gw response in that case.
        • korttomaK
          korttomaK
          korttoma
          tried the latest development branch on my test system and the results are good so far. Now I just need to update my "real" system also. Thanks to everyone that participated in solving this!!
          • Tomas
          • korttomaK
            korttomaK
            korttoma
            Updated now also 2 nodes in my "real" system and both now successfully reported Lib version. I did not update the GW. Maybe it is safe to say that the Lib reporting problem is solved now.
            Now I will try to look in to the sofSerial RFM69 solution that @scalz is working on, do you have any eta on when you will try to include our solution in the official MySensors development branch?
            Any recommendations for the wiring of an W5100/RFM69 Gateway?
            • Tomas
              #21
              i have removed my stuff for the moment..
              for integration in mysensors, it's coreteam work in progress, thx to @Tekka ;)
              Once, someone smart told me that 1+1=3, quite true :) and with Tekka i think we can say = 4 ahah
              So for an eta.., i prefer not saying anything lol, just i'm back on this for the week, i was playing with other stuff..
              • korttomaK korttoma
                J
                J
                jpaulin
                @korttoma I have an up and running RFM69 GW with W5100 (actually a W5500, but it's the same). I'm not using softSerial in my setup. With this it is possible to integrate with eg. Moteino or Anarduino, which comes with the radio chip preinstalled on the Arduino compatible boards. But a standard arduino with a separate chip would work as well (lower price). The GW-RFM69 has been stable and flawless, as far as I can see, for quite some time. The SPI for the RFM69 and W5500 uses the following pins in my setup.
                RFM69W:
                • SCK = 13
                • MISO = 12
                • MOSI = 11
                • CS = 10
                • IRQ = 2
                W5500:
                • SCK = 13
                • MISO = 12
                • MOSI = 11
                • CS = 7
                I'll try to share wire diagrams and software setup later. I had to do some tweakings in the ethernet.h file to make it work.
                korttomaK 1 Reply Last reply
                • J jpaulin
                  RFM69W:
                  • SCK = 13
                  • MISO = 12
                  • MOSI = 11
                  • CS = 10
                  • IRQ = 2
                  W5500:
                  • SCK = 13
                  • MISO = 12
                  • MOSI = 11
                  • CS = 7
                  korttomaK
                  korttomaK
                  korttoma
                  @jpaulin I am very interested in your solution. Could it work with a normal Arduino Pro mini 3,3V version? Just so that I know if I need to order some parts or can work with what I have.
                  • Tomas
                  J 2 Replies Last reply
                    J
                    J
                    jpaulin
                    @korttoma
                    Yes, it should work with an Arduino Pro Mini 3.3V. Personally I'm using for the moment an Anarduino. But it's almost the same.
                      J
                      J
                      jpaulin
                      wrote on last edited by jpaulin
                      #25
                      @korttoma
                      My RFM69 - Ethernet - GW has the following setup.
                      On the RFM69 radio I'm using D10 as CS pin (Chip Select). This is because in my case the RFM69 radio is hard-wired to pin D10, as with eg. a Moteino or Anarduino. But this is not mandatory. If you use an Arduino Pro Mini you could select another pin for the RFM69 CS-pin on the Arduino, if you want.
                      The Ethernet W5100 uses the Arduino IDE pre-installed library Ethernet.h. In the library the CS-pin is as well fixed to D10. CS of course has to be unique for each SPI slave device. I changed directly in the Ethenet.h library the CS pin to be D7. But D9, D8 or some other pin is ok to use as well.
                      Take care, if none of your SPI Slave devices (radio and W5100) uses D10 as CS-pin. In this case make sure to set the D10 pin to OUTPUT in your sketch to keep the Arduino as SPI Master. On the ATmega328 the D10 pin is hard-wired to be the SS pin (Slave Select). The Arduino has to always be the SPI Master and the devices SPI Slaves on the SPI bus to get everything to work.
                      Another consideration is:
                      The RFM69 radio uses the SPI functions during the interrupt sequence (Pin D2). The Ethernet.h library won't work correctly if another device uses SPI signalling during an interrupt sequence. The fix I'm using is to block interrupts from the radio-unit during SPI usage of the W5100 unit. I haven't seen any flaws with this fix so far. I've found other people on the internet using the same fix too without issues.
                      To use RFM69 CS=D10 pin and W5100 CS=D9 pin do the following change in the W5100.h that is part of the Ethernet library.
                      If you use a Windows computer you'll find the file here:
                      C:\Program Files (x86)\Arduino\libraries\Ethernet\src\utility\w5100.h
                      Look for the following lines at the end of the file.
                        inline static void initSS()    { DDRB  |=  _BV(2); };
                        inline static void setSS()     { PORTB &= ~_BV(2); };
                        inline static void resetSS()   { PORTB |=  _BV(2); };
                      If you use D9 as CS pin for the W5100 module change as follows:
                        inline static void initSS()    { DDRB  |=  _BV(1); };
                        inline static void setSS()     { cli(); PORTB &= ~_BV(1); };
                        inline static void resetSS()   { PORTB |=  _BV(1); sei(); };
                      If you uses, as I do, D7 as CS pin then change as follows:
                        inline static void initSS()    { DDRD  |=  _BV(7); };
                        inline static void setSS()     { cli(); PORTD &= ~_BV(7); };
                        inline static void resetSS()   { PORTD |=  _BV(7); sei(); };
                      If you want to keep D10 for the W5100 just add the cli(); and sei(); macros. (cli = clear interrupt. sei = set interrupt).
                      If you want to use another SPI CS pin than D10 on the RFM69 radio (eg. D9) it should be safe to modify it directly in the sketch with the preprocessor constant:
                      #define MY_RF69_SPI_CS 9
                      For the MOSI, MISO and SCK pins use as mentioned above, they are as well hard-wired in the ATmega328 chip to D11,D12 and D13.
                      If you have any doubts please let me know.
                      • J jpaulin
                        @korttoma
                        korttomaK
                        korttomaK
                        korttoma
                        Hi @jpaulin thanks for this, I will test it immediately.
                        Would you mind sharing your complete sketch? The MySensors W5100 GW example has all this Soft SPI stuff, I might make a mistake clearing out all the unnecessary parts.
                        Btw, do you see any problem with me adding some local "sensors" to this type of GW? I would like to add 4 relays and 4 buttons to it also.
                        • Tomas
                        • korttomaK
                          korttomaK
                          korttoma
                          It is alive :D
                          I managed to get a W5100 RFM69 Gateway working.
                          I wanted minimal change to the w5100.h so I just added the cli(); and sei(); macros.
                          (I would still like to see your sketch @jpaulin to compare)
                          There are some random failures in the RF communication but these might be because of the breadboard setup. I just have one temp sensor sending in some value now to test with.
                          • Tomas
                            It is alive :D
                            J
                            J
                            jpaulin
                            @korttoma
                            Here's my sketch. It's an MQTT GW with LEDs.
                             * Version 1.0 - Henrik Ekblad
                             * The W5100 MQTT gateway sends radio network (or locally attached sensors) data to your MQTT broker.
                             * The node also listens to MY_MQTT_TOPIC_PREFIX and sends out those messages to the radio network
                             * LED purposes:
                             * - RX (yellow) - blink fast on radio message recieved. In inclusion mode will blink fast only on presentation received
                             * - TX (green) - blink fast on radio message transmitted. In inclusion mode will blink slowly
                             * - ERR (red) - fast blink on error during transmission error or receive crc error
                            //#define MY_RADIO_NRF24
                            #define MY_RADIO_RFM69
                            #define MY_RFM69_FREQUENCY   RF69_433MHZ
                            #define MY_MQTT_PUBLISH_TOPIC_PREFIX "my_RFM69_gw1-out"
                            #define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX "my_RFM69_gw1-in"
                            // Set MQTT client id
                            #define MY_MQTT_CLIENT_ID "mysensors_RFM69-1"
                            //#define MY_W5100_SPI_EN 4
                            // Enable these if your MQTT broker requires username/password
                            #define MY_IP_ADDRESS 192,168,1,93
                            #define MY_CONTROLLER_IP_ADDRESS 192, 168, 1, 90
                            #define MY_PORT 1883
                            // Set blinking period
                            #define MY_DEFAULT_LED_BLINK_PERIOD 50
                            // Flash leds on rx/tx/err
                            #define MY_DEFAULT_ERR_LED_PIN A3  // Error led pin
                            #define MY_DEFAULT_RX_LED_PIN  A2  // Receive led pin
                            #define MY_DEFAULT_TX_LED_PIN  A0  // Transmit led pin
                            #include <Ethernet.h>    // modified for W5500 module and with CS pin = D7 (Default CS pin D10 is already used by RFM69W module)
                              #29
                              little side note about the rfm69 driver : it will use spitransaction which should solve this, with some noint/int should be ok. (https://www.arduino.cc/en/Tutorial/SPITransaction)
                              • J jpaulin
                                @korttoma
                                 * LED purposes:
                                korttomaK
                                korttomaK
                                korttoma
                                @jpaulin Thanks, not much different from my sketch I see:
                                #define MY_GATEWAY_W5100
                                #define MY_IP_ADDRESS 192,168,1,25   // If this is disabled, DHCP is used to retrieve address
                                #define MY_PORT 5003
                                //#define MY_LEDS_BLINKING_FEATURE
                                // Enable inclusion mode
                                //#define MY_DEFAULT_TX_LED_PIN  9  // the PCB, on board LED
                                #if defined(MY_USE_UDP)
                                  #include <EthernetUdp.h>
                                void setup(){
                                It has been running for a few hours now without issues. Gona try adding the buttons and relays tomorrow.
                                • Tomas
                                • korttomaK
                                  korttomaK
                                  korttoma
                                  #31
                                  Adding the relays and buttons seems to work fine also. I will go with this setup now until there is a "Official" solution for the GatewayW5100RFM69.
                                   * Version 1.0 - Henrik EKblad
                                   * LED purposes:
                                  #define SN "EthGW/RFM69 Rele Button"
                                  #define SV "1.0"
                                  //#define MY_W5100_SPI_EN 10
                                  // radio on the same spi bus.
                                  // Enable to UDP
                                  //#define MY_USE_UDP
                                  #define RELAY_ON 0                      // switch around for ACTIVE LOW / ACTIVE HIGH relay
                                  #define RELAY_OFF 1
                                  #define noRelays 4                     //2-4
                                  const int relayPin[] = {14, 15, 16, 17};       //  switch around pins to your desire
                                  const int buttonPin[] = {6, 7, 4, 5};   //  switch around pins to your desire
                                  class Relay             // relay class, store all relevant data (equivalent to struct)
                                    public:
                                      int buttonPin;                   // physical pin number of button
                                      int relayPin;             // physical pin number of relay
                                      boolean relayState;               // relay status (also stored in EEPROM)
                                  Relay Relays[noRelays];
                                  Bounce debouncer[noRelays];
                                  MyMessage msg[noRelays];
                                    wait(100);
                                    for (int i = 0; i < noRelays; i++) {
                                      Relays[i].buttonPin = buttonPin[i];              // assign physical pins
                                      msg[i].type = V_LIGHT;
                                      wait(100);
                                      Relays[i].relayState = loadState(i);                               // retrieve last values from EEPROM
                                      digitalWrite(Relays[i].relayPin, Relays[i].relayState ? RELAY_ON : RELAY_OFF); // and set relays accordingly
                                      send(msg[i].set(Relays[i].relayState ? true : false));                 // make controller aware of last status
                                      wait(50);
                                      debouncer[i].interval(30);
                                      wait(50);
                                    sendSketchInfo(SN, SV);
                                    wait(100);
                                      present(i, S_LIGHT);                               // present sensor to gateway
                                    wait(100);
                                    for (byte i = 0; i < noRelays; i++) {
                                      if (debouncer[i].update()) {
                                        if ( value == LOW) {
                                          // save sensor state in EEPROM (location == sensor number)
                                          saveState( i, Relays[i].relayState );
                                    //wait(20);
                                      if (message.sensor < noRelays) {          // check if message is valid for relays..... previous line  [[[ if (message.sensor <=noRelays){ ]]]
                                        digitalWrite(Relays[message.sensor].relayPin, Relays[message.sensor].relayState ? RELAY_ON : RELAY_OFF); // and set relays accordingly
                                        saveState( message.sensor, Relays[message.sensor].relayState ); // save sensor state in EEPROM (location == sensor number)
                                    wait(20);
                                  • Tomas
                                     * LED purposes:
                                    #define SV "1.0"
                                    // Enable to UDP
                                    #define RELAY_OFF 1
                                      public:
                                      wait(100);
                                        wait(100);
                                        wait(50);
                                        wait(50);
                                      wait(100);
                                      wait(100);
                                      //wait(20);
                                      wait(20);
                                    J
                                    J
                                    jpaulin
                                    @korttoma Excellent news. So now we are at least two with a stable RFM69-Ethernet-GW. :smiley:
                                       * LED purposes:
                                      #define SV "1.0"
                                      // Enable to UDP
                                      #define RELAY_OFF 1
                                        public:
                                        wait(100);
                                          wait(100);
                                          wait(50);
                                          wait(50);
                                        wait(100);
                                        wait(100);
                                        //wait(20);
                                        wait(20);
                                      J
                                      J
                                      jpaulin
                                      #33
                                      @korttoma Sharing a pair of photos of my gw. Became pretty neat, I think. It's parked permanently beside the WiFi Router.
                                      • korttomaK
                                        korttomaK
                                        korttoma
                                        I've seen pictures of your GW in another thread, it is very nice and professional @jpaulin
                                        I stil have some parts missing from my GW build so I only have the breadboard setup right now.
                                        • Tomas
                                          #35
                                          @TimO
                                          Hi.
                                          Sorry for delay, so much projects.
                                          As you tried to make a push, when you'll have some time, could you tell me if SOFTSPI is working please ? i'm a bit lazy to make a w5100 setup, as i'm not using it.
                                          https://github.com/scalz/Mysensors/tree/rfm69_update
                                          Set of defines is
                                          #define MY_RFM69_FREQUENCY   RFM69_868MHZ // RFM69_433MHZ for 433MHz, RFM69_868MHZ for default 868MHz or RF69_915MHZ for 915MHz
                                          //#define MY_IS_RFM69HW // uncomment this if you're running the RFM69HW model
                                          //#define MY_RFM69_TX_POWER_DBM (5) // default
                                          //#define MY_RFM69_ATC_TARGET_RSSI_DBM	(-80) // default
                                          //#define MY_RFM69_ATC_MODE_DISABLED
                                          //#define MY_RFM69_NETWORKID     100  // default
                                          //#define MY_RFM69_RST_PIN 9
                                          //#define MY_RFM69_IRQ_PIN 5
                                          //#define MY_RFM69_SPI_CS 23
                                          // For Advanced users
                                          //#define MY_RFM69_SPI_MAX_SPEED (4000000ul)
                                          //#define MY_RFM69_BITRATE_MSB RFM69_BITRATEMSB_55555  // Bitrate is for users who knows what they're doing as it can impact your network reliabilty, and read the datasheet/registers.h file to get the right bitrate.
                                          //#define MY_RFM69_BITRATE_LSB RFM69_BITRATELSB_55555  // So bitrates are hardwritten values
                                          // Before radio sending, random delay, to be sure that two nodes which were waiting for free channel, doesn't send at same time and collide
                                          // delay = MY_RFM69_CSMA_ADD_DELAY_BASE * random(1,MY_RFM69_CSMA_ADD_DELAY_COUNT)
                                          //#define MY_RFM69_CSMA_ADD_DELAY_BASE 50  // default 50ms
                                          //#define MY_RFM69_CSMA_ADD_DELAY_COUNT 10 // default max 10 counts
                                          Note these are my defines for my ATSAM gw.
                                          You can also send RSSI and powerlevel as internal msg by doing, like sendBattery function works.
                                          Example:
                                          Function: sendRadioStats
                                          Purpose : Sends radio rssi and powerlevel values
                                          Input   : - force : Forces transmission of a value (even if it's the same as previous measurement)
                                                         - ack : boolean. true if ack needed
                                          Output  : - true if transmission occured
                                          Comments:
                                          bool sendRadioStats(bool force, bool ack)
                                             static int16_t lastRssi=0;
                                             int16_t rssiVal = transportGetRSSI();
                                             uint8_t txPower = transportGetTxPower();
                                             if (abs(lastRssi - rssiVal) >= 10 || force == true) {
                                                force = sendSignalStrength(rssiVal, ack);
                                                force |= sendTXPowerLevel(txPower, ack);
                                                lastRssi = rssiVal;
                                             return force;
