  3. Mi-Light controller for Mysensors
69 Posts 15 Posters 52.6k Views 27 Watching
  • CrankyCoderC
    CrankyCoderC
    CrankyCoder
    I have done a little bit of tinkering with it today. i have not cleaned up the code yet, but I have been able to get my arduino repeater to pair with one of the lights, and turn it on and off. My progress so far.
    • Convert to using the mysensor 2.0 framework
    • setup a bulb and paired
    • can turn bulb on and off
    My next step is to see if i can change colors on the bulb. The only thing I noticed is there is a small delay when switching the radio between the mysensors rf and the milight rf protocol. I may later see if it's possible to do 2 radios. But for now progress is being made with a repeater node.
    Once it's working, Ill see if i can post some samples of how I controlled it via mqtt. (I use openhab)
    If the original author of this sketch is interested I will provide him current code progress. Or I can throw it on github if anyone is interested in tinkering with it. I definitely want to get some documentation together for how to get multiple bulbs working on it.
    Home Automation Tinkerer
    www.CrankyCoder.net
    Gateway: MQTTClientGateway
    MySensors: 2.3
    • CrankyCoderC
      CrankyCoderC
      CrankyCoder
      I have put my mods on github.
      https://github.com/brunkj/MySensorsMiLight/
      I have not been able to mess with it since the weekend. Still trying to get some info on the RGB part. If anyone wants to take a shot at it let me know if you make any progress :)
      www.CrankyCoder.net
      MySensors: 2.3
      • CrankyCoderC
        CrankyCoderC
        CrankyCoder
        spent some more time working on this. Still not having luck figuring out a what to send to the V_VAR1 to get the bulb to do anything
        I can send simple on off for S_LIGHT V_STATUS
        if (message.type == V_STATUS)
            //Serial.println("triggered V_STATUS");
            mlr.begin();
            // Change light status
            if ( message.getBool())
              Serial.println("here");
              // Serial.println("triggered ON");
              sendCommand (outgoingPacket_on, sizeof(outgoingPacket_on));
            else {
              //  Serial.println("triggered off");
              sendCommand(outgoingPacket_off, sizeof(outgoingPacket_off));
            _begin();
        Easy. But the V_VAR1 on S_CUSTOM I can't figure out what to put in the payload
        if (message.type == V_VAR1)
            // Serial.println("triggered V_VAR1");
            incomingCommand = (char *)message.getCustom();
            Serial.println((char *)message.getCustom());
             mlr.begin();
             Serial.println("#############");
            for (int i=0; i<sizeof(outgoingPacket); i++)
            { outgoingPacket[i] = 16*char_to_uint8_t(incomingCommand[i*2]) + char_to_uint8_t(incomingCommand[i*2+1]);
              Serial.println(outgoingPacket[i]);
            Serial.write(outgoingPacket, 7);
            sendCommand(outgoingPacket, sizeof(outgoingPacket));
            _begin();
        I have referenced the hacking milight protocol pages and many other, I just can't seem to get it right to get my bulb to do anything.
        Anyone want to take a shot at it? or have payload data I could try?
        full sketch
        #define MY_REPEATER_FEATURE
        #include <MyConfig.h>
        #define CE_PIN 9     //CE and CSN pin for nrf24 radio
        #define CSN_PIN 10
        #include <nRF_24L01.h>
        #include <avr/power.h>
        #include <printf.h>
        #include "PL1167_nRF24.h"
        #include "MiLightRadio.h"
        #define NODE_ID 100
        #define mi_command_repeat 30   //# of times to resend the command to bulb
        RF_24 mi_radio(CE_PIN, CSN_PIN);
        PL1167_nRF24 prf(mi_radio);
        MiLightRadio mlr(prf);
                                               // B0-176   F2-242    EA-234    6D    B0    02    f0
        static uint8_t outgoingPacket_on[7] = { 0xB0, 0xF2, 0xEA, 0x6D, 0x91, 0x03, 0x00};  //the first three #s are remote ID, replace with yours
        static uint8_t outgoingPacket_off[7] = { 0xB0, 0xF2, 0xEA, 0x04, 0x91, 0x04, 0x00};
        uint8_t outgoingPacket[7];
        #define sizeofincomingCommand 15 //command comes in text form of 7 uint8_t, with an additional NULL at end
        char *incomingCommand;    //array for incoming command
        boolean mi_radio_state = false;
          //Send the sensor node sketch version information to the gateway
          sendSketchInfo("Milight controller", "1.0");
           //clock_prescale_set(clock_div_2);     //for a barebone atmega328p, this  will make the CPU running at 4MHz.
          //Serial.begin(115200);
          // The third argument enables repeater mode.
          present(0, S_LIGHT);
          present(1, S_CUSTOM);
          // The command will be transmitted in V_VAR1 type, in the following 7 byte format: ID1 ID2 ID3 COLOR BRIGHTNESS COMMAND.
          // see https://hackaday.io/project/5888-reverse-engineering-the-milight-on-air-protocol
          Serial.println(message.type);
            mlr.begin();
            else {
            _begin();
             mlr.begin();
            _begin();
        //gw.begin(incomingMessage, NODE_ID, true);
        void sendCommand(uint8_t mi_Command[7], int sizeofcommand)
        { for (int i = 0; i < mi_command_repeat; i++)
          { mlr.write(mi_Command, sizeofcommand);
        uint8_t char_to_uint8_t(char c)
        	uint8_t i;
        	if (c <= '9')
        		i = c - '0';
        	else if (c >= 'a')
        		i = c - 'a' + 10;
        		i = c - 'A' + 10;
        	return i;
        www.CrankyCoder.net
        MySensors: 2.3
        • n1ck1355N
          n1ck1355N
          n1ck1355
          wrote on last edited by n1ck1355
          #48
          @Jason-Brunk
          unfortunately i havnt got my own milight bulbs but for what i've seen on the
          reverse engineered protocol page the payload must be something like
          "07B0F2EA359001B9ACF9" for all on or
          "07B0F2EA7D910FD4EC72" for green
          or the part "07B0F2EA" must be the ID so the payload
          is somethink like "359001B9ACF9" for all on and
          "7D910FD4EC72" for green
          • n1ck1355N
            n1ck1355N
            n1ck1355
            @ted are you there and can get a hint please? :)
            • n1ck1355N n1ck1355
              ted
              @n1ck1355 @Jason-Brunk
              sorry i'm been really busy with job recently. I used openhab to send the payload to V_VAR1 and S_CUSTOM. When I get home tonight, I'll post the openhab rule file so people can get some sense how to control color.
              • n1ck1355N
                n1ck1355N
                n1ck1355
                that's really great :) Thanks!
                  ted
                  @n1ck1355
                  sorry for the delay. Here is what I learned from https://hackaday.io/project/5888-reverse-engineering-the-milight-on-air-protocol
                  Basically, the mi controller will receive text string and convert them into HEX format and send it to the bulb. The text string should be formatted as the following (+ added for easy of reading, no '+' in the actual command):
                  ID + color + brightness + button code + seq
                  The ID is the ID of the bulb to be controlled, it is six byte in ASCII but will be converted into 3 byte HEX before sending to the bulb.
                  color, brightness and button code are each 2 byte in ASCII and will be converted into 1 byte HEX and send to bulb.
                  Seq is 2 byte in ASCII but it appears that you can just use "00".
                  To change color, you need to send a color code (e.g.: "00"=purple, "1B"=red, "40"=yellow,e tc) and using button code "OF".
                  To change back to white, you use "04" as color code and "13" as button code.
                  The detailed button code definition can be found here:
                  https://cdn.hackaday.io/images/1224221432724803073.jpg
                  Hope this helps.
                  • n1ck1355N
                    n1ck1355N
                    n1ck1355
                    Thank you @ted :)
                    i already played with it and can turn the bulbs on/off. i will play around with your
                    information to make the other funktions work.
                    But what i see is that you cannot e.g. dim the bulbs softly from say 100% to 20% cause
                    that would be more commands behind each other. But the node must reset itself after
                    each command by calling _Begin() and that takes some time..
                    any suggestions to resolve that?
                      Thank you @ted :)
                      ted
                      @n1ck1355
                      my only solution is to use two radios, one receives command from the gateway and the other sending command to the bulbs. it might be doable with just 1 arduino by using softSPI.
                      Nca78N 1 Reply Last reply
                      • T ted
                        @n1ck1355
                        @ted said:
                        @n1ck1355
                        I don't see why you would need SoftSPI for that ? It should just need some change for CE and CSN pins for the NRF that is used to send data to the milights. I will try to find time to check that this week.
                        • n1ck1355N
                          n1ck1355N
                          n1ck1355
                          @Nca78 :
                          did you have success with thw NRF boards connecting?
                            @Nca78 :
                            @n1ck1355 said:
                            @Nca78 :
                            Hello, unfortunately I had no time to test it, I was busy with my Livolo switch :P
                            • Cliff KarlssonC
                              Cliff KarlssonC
                              Cliff Karlsson
                              I just tried out openhab2, would it be easier controling the bulbs from openhab2 or do I still to do alot of "coding" on my own?
                              • Nca78N
                                wrote on last edited by Nca78
                                #59
                                Hello, few months have passed and I finally had a look at the code from @Jason-Brunk
                                I made a MiLightBulb class with methods to set on/off, set brightness level, set color and set animation. It still needs improvements as brightness is not working, some colors are a bit off and I didn't test animation yet but it's starting to take shape and I can use it from RGB light control in domoticz.
                                I have connected 2 nrf24 also, using pins 7&8 for the one sending MiLight messages instead of 9&10 and it running fine as expected, no use to call begin() all the time: much more reactive.
                                I'll publish the code as soon as I have time to finish and clean up.
                                • Cliff KarlssonC
                                  Cliff KarlssonC
                                  Cliff Karlsson
                                  Great news @Nca78
                                  • CrankyCoderC
                                    CrankyCoderC
                                    CrankyCoder
                                    any updates? I have a couple milight bulbs ready to test :)
                                    www.CrankyCoder.net
                                    MySensors: 2.3
                                    • CrankyCoderC CrankyCoder
                                      @Jason-Brunk sorry I received my PCBs for Livolo switches so these will have my priority at the moment. And we're still in the lunar new year holidays here, not much time available.
                                      • CrankyCoderC
                                        CrankyCoderC
                                        CrankyCoder
                                        Totally understand. That's another project I am interested in :)
                                        www.CrankyCoder.net
                                        MySensors: 2.3
                                        • lozzer65L
                                          lozzer65L
                                          lozzer65
                                          Hi
                                          I have read through this thread fully and the concept look great. I am confused as to the hardware that is required thought. I have a mysensors gateway connetcted to wifi and some sensors setup and working on Home Assistant. What do I need to build to implement this solution, and what would I have to install in HA.
                                          Thanks for any help
                                          Laurie
