  3. Wemos D1 Mini ESP8266 GW Homeassistant connection problem with sensor node
10 Posts 2 Posters 4.7k Views 3 Watching
  • SushukkaS Offline
    SushukkaS Offline
    Sushukka
    I'm trying to setup my first ESP8266 sensor. I have uploaded the ESP8266 Gateway sketch from Mysensors_master library:
     * Version 1.0 - Henrik EKblad
     * Contribution by Ivo Pullens (ESP8266 support)
     * The EthernetGateway sends data received from sensors to the WiFi link.
     * VERA CONFIGURATION:
     * LED purposes:
     * See http://www.mysensors.org/build/esp8266_gateway for wiring instructions.
     * nRF24L01+  ESP8266
     * VCC        VCC
     * CE         GPIO4
     * CSN/CS     GPIO15
     * SCK        GPIO14
     * MISO       GPIO12
     * MOSI       GPIO13
     * GND        GND
      * Inclusion mode button:
    #include <EEPROM.h>
    #define MY_BAUD_RATE 9600
    //#define MY_RADIO_NRF24
    #define MY_RADIO_RFM69
    #define MY_GATEWAY_ESP8266
    #define MY_ESP8266_SSID "Mywlan"
    #define MY_ESP8266_PASSWORD "xxxxxx"
    // Enable UDP communication
    //#define MY_USE_UDP
    #define MY_ESP8266_HOSTNAME "ESP8266-sensor-gateway"
    //#define MY_IP_ADDRESS 192,168,0,70
    //#define MY_IP_GATEWAY_ADDRESS 192,168,0,1
    #define MY_PORT 5003
    // Enable inclusion mode
    // #define MY_INCLUSION_BUTTON_FEATURE
    // Flash leds on rx/tx/err
    // #define MY_LEDS_BLINKING_FEATURE
    // Set blinking period
    // #define MY_DEFAULT_LED_BLINK_PERIOD 300
    #if defined(MY_USE_UDP)
      #include <WiFiUDP.h>
      #include <ESP8266WiFi.h>
    and it seems to start ok:
    ÈHlìÉ`,lEØ4HÈrðú0;255;3;0;9;Starting gateway (RRNGE-, 2.0.0)
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;TSM:RADIO:OK
    0;255;3;0;9;TSM:GW MODE
    0;255;3;0;9;TSM:READY
    scandone
    f 0, ....scandone
    state: 0 -> 2 (b0)
    state: 2 -> 3 (0)
    state: 3 -> 5 (10)
    add 0
    aid 5
    cnt
    connected with Mywlan, channel 9
    dhcp client start...
    ......ip:192.168.0.70,mask:255.255.255.0,gw:192.168.0.1
    .IP: 192.168.0.70
    pm open,type:2 0
    My sensor sketch looks like this:
     * Version 1.0: Henrik EKblad
     * sensor using a DHT11/DHT-22.
    // Enable debug prints
    #define MY_NODE_ID 1
    //#define MY_RS485
    #define DHTPIN 4
    #define DHTTYPE DHT22   // DHT 22  (AM2302)
    #define SENSOR_TEMP_OFFSET 0
    static const uint64_t UPDATE_INTERVAL = 10000;
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    float lastTemp;
    float lastHum;
    uint8_t nNoUpdatesTemp;
    uint8_t nNoUpdatesHum;
    bool metric = true;
    DHT dht(DHTPIN, DHTTYPE);
      sendSketchInfo("TemperatureAndHumidity", "1.1");
      present(CHILD_ID_HUM, S_HUM);
      // Wait for the time of the minimum sampling period to give the sensor time to power up
      wait(2000);
      float temperature = dht.readTemperature();
      if (isnan(temperature)) {
        lastTemp = temperature;
        // Reset no updates counter
        nNoUpdatesTemp = 0;
        #ifdef MY_DEBUG
        Serial.print("T: ");
        nNoUpdatesTemp++;
      float humidity = dht.readHumidity();
      if (isnan(humidity)) {
        lastHum = humidity;
        nNoUpdatesHum = 0;
        #ifdef MY_DEBUG
        Serial.print("H: ");
        Serial.println(humidity);
        nNoUpdatesHum++;
      wait(UPDATE_INTERVAL);
    It seems to somehow sniff the wlan information from gateway as it registers itself to the wlan network:
    TSM:INIT
    TSM:RADIO:OK
    TSP:ASSIGNID:OK (ID=1)
    TSM:FPAR
    TSP:MSG:SEND 1-1-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
    scandone
    state: 0 -> 2 (b0)
    state: 2 -> 3 (0)
    state: 3 -> 5 (10)
    add 0
    aid 6
    cnt
    TSM:FPAR
    ip:192.168.0.59,mask:255.255.255.0,gw:192.168.0.1
    TSM:FPAR
    TSM:FPAR
    !TSM:FPAR:FAIL
    !TSM:FAILURE
    TSM:PDT
    TSM:INIT
    TSM:RADIO:OK
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    I can see them in my router's DHCP table:
    ESP8266-sensor-gateway	Wireless 192.168.0.70	 	5C:CF:7F:2B:D5:22
    ESP_DE24D3	Wireless 192.168.0.59 	18:FE:34:DE:24:D3
    Gateway continues writing:
    0;255;3;0;9;TSP:SANCHK:OK
    and client:
    TSM:FPAR
    It seems that whatever serial.print-lines I write on the sensor sketch (in presentation, setup, loop) they never end up to the actual serial log. Don't know why. :(
    Finally to the Homeassistant. I have defined in configuration.yaml:
    mysensors:
      gateways:
        - device: '192.168.0.70'
          persistence_file: '/home/homeassistant/.homeassistant/mysensors3.json'
          tcp_port: 5003
      debug: true
      optimistic: false
      persistence: true
      retain: true
      version: 2.0
    And when starting Homeassistant it says:
    16-11-17 11:48:58 INFO (MainThread) [homeassistant.core] Timer:starting
    16-11-17 11:48:58 INFO (Thread-5) [mysensors.mysensors] Trying to connect to ('192.168.0.70', 5003)
    16-11-17 11:48:58 INFO (Thread-5) [mysensors.mysensors] Connected to ('192.168.0.70', 5003)
    But tells nothing more nor comes any updates of my DHT22 sensor in the log.
    This is currently the whole environment. Homeautomation is running correctly on my Raspberry Pi3 and I can access the web interface with no problem. Then there are these two Wemos D1 mini ESP8266 boards currently connected via USB to my laptop. One has nothing but USB cable feeding power (=gateway), other has USB cable + DHT22 sensor connected. DHT22 sensor works as I have tested it alone without Mysensors libraries having a web server running on that Wemos showing the temperature/humidity information on a web page. Running out of ideas, hopefully someone can help. :s
    • H Offline
      H Offline
      Hmm. does your DHT node also run on a Wemos D1?
      • SushukkaS Offline
        SushukkaS Offline
        Sushukka
        Yes, they both run on similar Wemos D1 Mini board.
        • H Offline
          H Offline
          wrote on last edited by hek
          Hmm.. we don't support that kind of setup.
          Why not just connect the DHT sensor directly to your controller over WiFi? That is, reconfigure it as a gateway. There is no need for RFM radio on ESP nodes/gateways.
          • SushukkaS Offline
            SushukkaS Offline
            Sushukka
            Ok, thanks! :) I thought that a gateway is also needed when using ESP8266. Is there then any idea to use Mysensors with ESP8266 and Homeassistant? Wouldn't it just be better to setup a MQTT server on Homeassistant server and connect sensors directly as MQTT clients to it? I have also some nrf24l01 boards waiting to be implemented. Those would then connect through Mysensors gateway (serial/ethernet).
            • H Offline
              H Offline
              You can setup your ESP as a mysensors MQTT client or use the "normal" mysensors protocol over a socket. It all depend on what variants Home Assistant supports.
              The good thing with sticking with MySensors is that you can reuse mysensors example sketches and (hopefully) have a protocol Home Assistant understands (which create the desired devices).
              But you can of course roll your own thing over MQTT and create your own extensions/plugin to Home Assistant if you prefer.
              SushukkaS 1 Reply Last reply
              • H hek
                SushukkaS Offline
                SushukkaS Offline
                Sushukka
                @hek Thanks again and a very good point there. Mysensors sketch examples have been very useful so far so maybe better to stick with them. One question about the ESP8266 gateways: If I change my sensor node sketch to gateway sketch will the node still act like some kind of a hub? I mean when I'm going to build tens of sensors around the house, I don't want to have too many repeater nodes slowing down the Wifi network.
                • H Offline
                  H Offline
                  No, it will act standalone, unless you enable the radio sub network.
                  • H hek
                    SushukkaS Offline
                    SushukkaS Offline
                    Sushukka
                    Ok, I managed to add DHT part to the ESP8266GW sketch, but still have the problem with reading the DHT22 data.
                     * LED purposes:
                     * nRF24L01+  ESP8266
                     * VCC        VCC
                     * CE         GPIO4
                     * CSN/CS     GPIO15
                     * SCK        GPIO14
                     * MISO       GPIO12
                     * MOSI       GPIO13
                     * GND        GND
                    #include <EEPROM.h>
                    #define MY_ESP8266_PASSWORD "xxxxxxx"
                    #define MY_ESP8266_HOSTNAME "ESP8266-sensorNode1"
                    //#define MY_IP_ADDRESS 192,168,0,80
                    //-------- DHT22 related definitions ----->>>
                    #define DHTPIN 4
                    float lastTemp;
                    float lastHum;
                    bool metric = true;
                    float temperature;
                    //<<<----- DHT22 related definitions --------
                       dht.begin();
                      wait(2000);
                      Serial.print("Temperature:");
                        lastHum = humidity;
                    Serial log shows:
                    ȤlÍkh$M´H>hä?ü0;255;3;0;9;Starting gateway (RRNGE-, 2.0.0)
                    scandone
                    state: 0 -> 2 (b0)
                    state: 2 -> 3 (0)
                    state: 3 -> 5 (10)
                    add 0
                    aid 10
                    cnt
                    f r0, scandone
                    .....ip:192.168.0.59,mask:255.255.255.0,gw:192.168.0.1
                    .IP: 192.168.0.59
                    Temperature:nan
                    pm open,type:2 0
                    Temperature:nan
                    Temperature:nan
                    It seems that MySensors somehow screws the ESP8266 pinout layout or the normal Adafruit Arduino DHT library won't work correctly with it. If I dump the Mysensor stuff and just use the same Wemos D1 mini board with the same DHT22 sensor and DHT library it shows the temperature/humidity values no problem.
                    • H Offline
                      H Offline
                      Nope, we don't screw with any pin mapping.
                      https://github.com/esp8266/Arduino/blob/master/variants/d1_mini/pins_arduino.h#L40-L50
                      12.1k
