  3. Home Assistant
  4. MySensors Hvac device
6 Posts 2 Posters 2.8k Views 2 Watching
  • dpressleD
    dpressleD
    dpressle
    Hi All,
    i Successfully created a hvac node and connected it to HASS, i can see that the climate device on HASS has the option to get the current temperature from the device.
    Does any one knows if the MySensors Havc platform supports sending temperature? if i send V_TEMP message from that node will it be shown in HASS in the climate device as current temp?
    • dpressleD dpressle
      Hi All,
      martinhjelmareM
      martinhjelmareM
      martinhjelmare
      Yes, the platform supports reporting current temperature using V_TEMP. The documentation doesn't mention this and needs updating:
      https://home-assistant.io/components/climate.mysensors/
      PR for this is welcome.
      dpressleD 1 Reply Last reply
        dpressleD
        dpressleD
        dpressle
        @martinhjelmare cool, thanks i will try to PR this later.
        • dpressleD
          dpressleD
          dpressle
          It works, and i PR the page, Thanks Martin...
            martinhjelmareM
            martinhjelmareM
            martinhjelmare
            @dpressle
            Great! I haven't seen a PR for this. Did you make one?
            • dpressleD
              dpressleD
              dpressle
              https://github.com/home-assistant/home-assistant.github.io/pull/1484
