  3. How to build a repeater
14 Posts 4 Posters 9.2k Views 3 Watching
  • S stingone
    Hello everyone.
    I cant find a clear solution how to build a repeater. i have a tempsensor on 40m distance from my gateway and want to build a repeater in between.
    Can anyone tell me what to do achieving this e.g. sample code etc..
    Thanks..
    ramoncarranzaR
    ramoncarranzaR
    ramoncarranza
    @stingone hi, the mysensor master library comes with an example file to create a "RepeaterNode" I've built 4 of them using an Arduino nano and a radio module ( https://www.mysensors.org/build/connect_radio) they work very well for me.
    S 1 Reply Last reply
    • scalzS scalz
      Here it is https://www.mysensors.org/download/sensor_api_20#create-repeating-nodes
      lot of great docs on main site though ;)
      ramoncarranzaR
      ramoncarranzaR
      ramoncarranza
      @scalz Thanks so much I was looking for something like this as well, thanks again
      • ramoncarranzaR ramoncarranza
        stingone
        @ramoncarranza
        So just using that example code is enough?
        ramoncarranzaR 1 Reply Last reply
        • S stingone
          @ramoncarranza
          ramoncarranzaR
          ramoncarranzaR
          ramoncarranza
          @stingone yep all you have to do is upload it to your radio set-up and that's it, but you do waste a board and a radio unit, but in MY case is well worth it.
            stingone
            @ramoncarranza
            Ok so no need to change any code in my original sensor? and will it send multiple values from more sensors if picked-up?
            • ramoncarranzaR
              ramoncarranzaR
              ramoncarranza
              no need to change anything on your original sensors and and yes it will relay signals from multiple sensors to your gateway/controller. Just our of curiosity, what controller are you using???
              S 2 Replies Last reply
                stingone
                wrote on last edited by stingone
                Using pimatic v9. on a raspberry pi 3. I already build a mysensors combined temp/ph sensor. But had to change the code in mysensors v2.0. I'm using lot of 433mhz over more then 25 devices.. but im now changing also towards mysensors :). so the mysensors is a little bit new to me.
                  stingone
                  Just build the repeater today..how can i see check if it is working properly??
                  Nevermind its working :):) just received the information on the repeater... great support thanks
                    stingone
                    Now testing for few day's and i see that one of my sensors stops working after few minutes.. the one that is most close to the gateway... after resetting it sends af few minutes and then stops working again...
                    • S stingone
                      @stingone what does the serial debug output say?
                        stingone
                        TSM:UPL
                        TSP:PING:SEND (dest=0)
                        !TSP:MSG:SEND 6-6-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=fail:1
                        TSP:CHKUPL:FAIL (hops=255)
                        !TSM:UPL:FAIL
                        TSM:FPAR
                        TSP:MSG:SEND 6-6-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                        !TSP:SEND:TNR
                        TSP:MSG:READ 5-5-6 s=255,c=3,t=8,pt=1,l=1,sg=0:1
                        TSP:MSG:FPAR RES (ID=5, dist=1)
                        TSP:MSG:PAR OK (ID=5, dist=2)
                        !TSP:SEND:TNR
                        TSM:FPAR:OK
                        TSM:ID
                        TSM:CHKID:OK (ID=6)
                        TSM:UPL
                        !TSP:MSG:SEND 6-6-5-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=fail:1
                        !TSM:UPL:FAIL
                        TSM:FPAR
                        Init complete, id=6, parent=255, distance=255, registration=1
                        !TSP:SEND:TNR```
                        TSM:INIT
                        TSM:RADIO:OK
                        TSP:ASSIGNID:OK (ID=6)
                        TSM:FPAR
                        TSM:FPAR
                        TSM:FPAR
                        TSM:FPAR
                        !TSM:FPAR:FAIL
                        !TSM:FAILURE
                        TSM:PDT
                        TSM:INIT
                        TSM:RADIO:OK
                        TSM:FPAR
                        TSM:FPAR
                        TSM:FPAR
                        TSM:FPAR
                        !TSM:FPAR:FAIL
                        !TSM:FAILURE
                        TSM:PDT
                        TSM:INIT
                        TSM:RADIO:OK
                        TSM:FPAR
                        TSM:FPAR
                        TSM:FPAR
                        TSM:FPAR
                        !TSM:FPAR:FAIL
                        !TSM:FAILURE
                        TSM:PDT
