  3. How to build a repeater
14 Posts 4 Posters 9.2k Views 3 Watching
  • scalzS scalz
    Here it is https://www.mysensors.org/download/sensor_api_20#create-repeating-nodes
    lot of great docs on main site though ;)
    ramoncarranzaR
    ramoncarranzaR
    ramoncarranza
    @scalz Thanks so much I was looking for something like this as well, thanks again
    • ramoncarranzaR ramoncarranza
      @stingone hi, the mysensor master library comes with an example file to create a "RepeaterNode" I've built 4 of them using an Arduino nano and a radio module ( https://www.mysensors.org/build/connect_radio) they work very well for me.
      stingone
      @ramoncarranza
      So just using that example code is enough?
      ramoncarranzaR 1 Reply Last reply
      • S stingone
        @ramoncarranza
        ramoncarranzaR
        ramoncarranzaR
        ramoncarranza
        @stingone yep all you have to do is upload it to your radio set-up and that's it, but you do waste a board and a radio unit, but in MY case is well worth it.
        S 1 Reply Last reply
          stingone
          @ramoncarranza
          Ok so no need to change any code in my original sensor? and will it send multiple values from more sensors if picked-up?
          • ramoncarranzaR
            ramoncarranzaR
            ramoncarranza
            no need to change anything on your original sensors and and yes it will relay signals from multiple sensors to your gateway/controller. Just our of curiosity, what controller are you using???
            S 2 Replies Last reply
              stingone
              wrote on last edited by stingone
              Using pimatic v9. on a raspberry pi 3. I already build a mysensors combined temp/ph sensor. But had to change the code in mysensors v2.0. I'm using lot of 433mhz over more then 25 devices.. but im now changing also towards mysensors :). so the mysensors is a little bit new to me.
                stingone
                Just build the repeater today..how can i see check if it is working properly??
                Nevermind its working :):) just received the information on the repeater... great support thanks
                  stingone
                  Now testing for few day's and i see that one of my sensors stops working after few minutes.. the one that is most close to the gateway... after resetting it sends af few minutes and then stops working again...
                  • S stingone
                    @stingone what does the serial debug output say?
                      stingone
                      TSM:UPL
                      TSP:PING:SEND (dest=0)
                      !TSP:MSG:SEND 6-6-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=fail:1
                      TSP:CHKUPL:FAIL (hops=255)
                      !TSM:UPL:FAIL
                      TSM:FPAR
                      TSP:MSG:SEND 6-6-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                      !TSP:SEND:TNR
                      TSP:MSG:READ 5-5-6 s=255,c=3,t=8,pt=1,l=1,sg=0:1
                      TSP:MSG:FPAR RES (ID=5, dist=1)
                      TSP:MSG:PAR OK (ID=5, dist=2)
                      !TSP:SEND:TNR
                      TSM:FPAR:OK
                      TSM:ID
                      TSM:CHKID:OK (ID=6)
                      TSM:UPL
                      !TSP:MSG:SEND 6-6-5-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=fail:1
                      !TSM:UPL:FAIL
                      TSM:FPAR
                      Init complete, id=6, parent=255, distance=255, registration=1
                      !TSP:SEND:TNR```
                      TSM:INIT
                      TSM:RADIO:OK
                      TSP:ASSIGNID:OK (ID=6)
                      TSM:FPAR
                      TSM:FPAR
                      TSM:FPAR
                      TSM:FPAR
                      !TSM:FPAR:FAIL
                      !TSM:FAILURE
                      TSM:PDT
                      TSM:INIT
                      TSM:RADIO:OK
                      TSM:FPAR
                      TSM:FPAR
                      TSM:FPAR
                      TSM:FPAR
                      !TSM:FPAR:FAIL
                      !TSM:FAILURE
                      TSM:PDT
                      TSM:INIT
                      TSM:RADIO:OK
                      TSM:FPAR
                      TSM:FPAR
                      TSM:FPAR
                      TSM:FPAR
                      !TSM:FPAR:FAIL
                      !TSM:FAILURE
                      TSM:PDT
