  3. sleep with timer and level interrupt
6 Posts 4 Posters 3.3k Views 4 Watching
  • eboE Offline
    eboE Offline
    ebo
    I have a question on how to use the sleep with the timer and with a level interrupt.
    I want to use a level interrupt to catch a tipping bucket
    and want to do periodic checks (battery, temperature, etc)
    I''m looking at the sleep function from mysensors, but could not find a way to catch the level interrupt when it is falling.
    also I need to do some debouncing..
    What is your advice?
    Regards,
    Edward
    S 1 Reply Last reply
    • eboE ebo
      Regards,
      Edward
      @ebo - have a look at some rain sensors sketches.
      Also check https://www.mysensors.org/download/sensor_api_20#sleeping
      • eboE Offline
        eboE Offline
        ebo
        I did already, but none is implementing the time and the level interrupt with falling.
        could be that I'm not understanding it right... ;)
        if I use the sleep function with level interrupt I can not specify the function to run when awaking from the level interrupt.
        maybe i'm missing something?
        in my current sketch with only level interrupt I have the following:
        void enterSleep(void)
        	/* Setup tipInterrupt as an interrupt and attach handler. */
        	attachInterrupt(tipInterrupt, awake, FALLING);
        	delay(100);
        	set_sleep_mode(SLEEP_MODE_PWR_DOWN);
        	sleep_enable();
        	sleep_mode();
        	/* The program will continue from here. */
        	sleep_disable();
        void awake(void)
        	detachInterrupt(tipInterrupt);
        	tipCount++;
        	attachInterrupt(tipInterrupt, tip, FALLING);
        	tipped = true;
        how to convert this to mysensors sleep with a timer?
        Edward
        mfalkviddM N 2 Replies Last reply
        • eboE ebo
          	delay(100);
          	sleep_enable();
          	sleep_mode();
          	sleep_disable();
          void awake(void)
          	tipCount++;
          	tipped = true;
          Edward
          @ebo when the MySensors sleep function returns, the return value will tell you whether it woke up because of the timer or because of the external interrupt. Just use an if clause to do different things based on that return value.
          • eboE ebo
            	delay(100);
            	sleep_enable();
            	sleep_mode();
            	sleep_disable();
            void awake(void)
            	tipCount++;
            	tipped = true;
            Edward
            N Offline
            N Offline
            Hello, you should not use your own interrupt function, check the link sundberg84 gave you in his reply and you will see the MySensors sleep function can manage RAISING, FALLING and CHANGE level interrupts, and timer interrupt at the same time.
            It will stop your code and restart it when an interrupt is triggered, and then you just have to check the integer value that is returned to know if it's because of level interrupt 1, level interrupt 2, or timer interrupt. Then you can call your function according to the value.
            • eboE Offline
              eboE Offline
              ebo
              ok, that make things clear!
              I will give that a try.
              Thanks so far.
