  2. Bug Reports
  3. Dust sensor and wrong values
6 Posts 2 Posters 4.3k Views 2 Watching
  • 1kohm1 Offline
    1kohm1 Offline
    1kohm
    Re: Dust Sensor
    My Sensors team,
    I'd like to refresh this topic with a question.
    I'm trying to setup dust senor by my own on MySensors 2.0 lib., but have dificulities with correct GP2Y1010AU0F values in my controller (Domoticz).
    To check if my wiring is ok I've used regular arduino sketch:
    #define MIN_VOLTAGE     600 // mv - the lower threshold voltage range for the lack of dust
    #define VREF           1100 // mv - reference voltage of the comparator
    #define PIN_LED           3 // pin number ILED
    #define PIN_ANALOG        1 // pin number AOUT
    #define MAX_ITERS        10 // liczba pomiarow do sredniej
    int ADC_VALUE; // read value A1
    int ITER; // value read
    float VOLTAGE; // voltage value
    float DUST; // result
    float AVG_DUST; // average result
    void setup(void)
      analogReference(INTERNAL);
      Serial.begin(9600);
      pinMode(PIN_LED, OUTPUT);
      digitalWrite(PIN_LED, LOW);
    float computeDust()
      // Flash IR, wait 280ms, read ADC voltage
      digitalWrite(PIN_LED, HIGH);
      delayMicroseconds(280);
      ADC_VALUE = analogRead(PIN_ANALOG);
      // Calculate to mV. whole multiplied by 11, because in the module
      // applied voltage divider 1k/10k
      VOLTAGE = (VREF / 1024.0) * ADC_VALUE * 11;
      // Calculate pollution if the measured voltage over prog
      if (VOLTAGE > MIN_VOLTAGE)
        return (VOLTAGE - MIN_VOLTAGE) * 0.2;
      return 0;
    void loop(void)
       AVG_DUST = 0;
       ITER = 0;
       while (ITER < MAX_ITERS)
         DUST = computeDust();
         // For medium liczmy only correct measurements
         if (DUST > 0)
           AVG_DUST += DUST;
           ITER++;
           delay(50);
       AVG_DUST /= MAX_ITERS;
       Serial.print("D = ");
       Serial.print(AVG_DUST);
       Serial.println("ug/m3");
       delay(500);
    The output seems to be ok:
    (yellow marked is smoke test).
    Then I've applied following sketch:
    // Enable debug prints
    #define CHILD_ID_DUST 0
    #define DUST_SENSOR_ANALOG_PIN 1
    #define DUST_SENSOR_DIGITAL_PIN 3
    const int numreadings = 60;
    unsigned long SLEEP_TIME = 1000;
    int val = 0;
    float valDUST =0.0;
    float lastDUST =0.0;
    int samplingTime = 280;
    int deltaTime = 40;
    int sleepTime = 9680;
    float voMeasured = 0;
    float calcVoltage = 0;
    float dustDensity = 0;
    MyMessage dustMsg(CHILD_ID_DUST, V_LEVEL);
    void setup(){
      pinMode(DUST_SENSOR_DIGITAL_PIN,OUTPUT);
      sendSketchInfo("Dust Sensor", "1.0");
      present(CHILD_ID_DUST, S_DUST);
      float cumsum = 0;
      float temp = 0;
     // float temp1 = 0;
     // float cum_density = 0;
      for (int sample = 0; sample < numreadings; sample ++){
      digitalWrite(DUST_SENSOR_DIGITAL_PIN,LOW); // power off the LED
      delayMicroseconds(samplingTime);
      uint16_t voMeasured = analogRead(DUST_SENSOR_ANALOG_PIN);// Get DUST value
      delayMicroseconds(deltaTime);
      digitalWrite(DUST_SENSOR_DIGITAL_PIN,HIGH); // turn on the LED
      // 0 - 5V mapped to 0 - 1023 integer values
      // recover voltage
      temp = voMeasured * (5.0 / 1024.0);
      cumsum = cumsum + temp;// cumulative sum over 60 seconds
      delay(500);
      Serial.print("Raw Signal Value (0-1023): ");
      Serial.print(voMeasured);
      Serial.print(" - Voltage: ");
      Serial.print(calcVoltage);
      Serial.print(" - Dust Density: ");
      Serial.println(dustDensity);
      // linear eqaution taken from http://www.howmuchsnow.com/arduino/airquality/
      // Chris Nafis (c) 2012
      dustDensity = (0.17 * cumsum - 0.1)* (1000/60);
      Serial.println(dustDensity); // unit: ug/m3
      send(dustMsg.set((int)ceil(dustDensity)));
      sleep(SLEEP_TIME);
    and the output is:
    In Domoticz it looks:
    It seems that my room air polution is super high :), but, it isn't :)
    Ideas, what should be changed in the code?
    Best,
    • 1kohm1 1kohm
      Re: Dust Sensor
      My Sensors team,
      void setup(void)
        Serial.begin(9600);
      float computeDust()
        return 0;
      void loop(void)
         AVG_DUST = 0;
         ITER = 0;
           if (DUST > 0)
             AVG_DUST += DUST;
             ITER++;
             delay(50);
         delay(500);
      int val = 0;
      float valDUST =0.0;
      int deltaTime = 40;
      void setup(){
        float cumsum = 0;
        float temp = 0;
       // float temp1 = 0;
        // recover voltage
        delay(500);
        sleep(SLEEP_TIME);
      and the output is:
      Best,
      @1kohm how come you don't use the computedust function in the second sketch?
      • 1kohm1 Offline
        1kohm1 Offline
        1kohm
        becouse I don't konw it and where to put it :)
        Advise would be apriciate.
        best,
        • 1kohm1 Offline
          1kohm1 Offline
          1kohm
          OK,
          I was tired...
          I've figure it out and have sketch running :)
          Beta version:
          #define DUST_SENSOR_DIGITAL_PIN    3 // pin number ILED
          #define DUST_SENSOR_ANALOG_PIN     1 // pin number AOUT
          unsigned long SLEEP_TIME = 1000;    // Sleep time between reads (in milliseconds)
          int SAMPLING_TIME = 280;
          void setup(){
            digitalWrite(DUST_SENSOR_DIGITAL_PIN, LOW);
          float computeDust()
            digitalWrite(DUST_SENSOR_DIGITAL_PIN, HIGH);
            delayMicroseconds(SAMPLING_TIME);
            ADC_VALUE = analogRead(DUST_SENSOR_ANALOG_PIN);
            return 0;
             AVG_DUST = 0;
             ITER = 0;
               if (DUST > 0)
                 AVG_DUST += DUST;
                 ITER++;
                 delay(50);
            send(dustMsg.set((int)ceil(AVG_DUST)));
            sleep(SLEEP_TIME);
          Values are send, but I want to send to gateway values exact as computed by sketch, wih 4 ditits - D = 60.79ug/m3
          But sketch is sending only 2 digit - ok:61
          D = 60.79ug/m3
          TSP:MSG:SEND 8-8-0-0 s=0,c=1,t=37,pt=2,l=2,sg=0,ft=0,st=ok:61
          D = 59.61ug/m3
          TSP:MSG:SEND 8-8-0-0 s=0,c=1,t=37,pt=2,l=2,sg=0,ft=0,st=ok:60
          I guess that I should change something here:
          But not know what to change.
          Help here.
          • 1kohm1 1kohm
            OK,
            I was tired...
            Beta version:
            void setup(){
            float computeDust()
              return 0;
               AVG_DUST = 0;
               ITER = 0;
                 if (DUST > 0)
                   AVG_DUST += DUST;
                   ITER++;
                   delay(50);
              sleep(SLEEP_TIME);
            D = 60.79ug/m3
            D = 59.61ug/m3
            Help here.
            @1kohm Great work! I think this is what you want:
            send(dustMsg.set(AVG_DUST,2));
            The number 2 means two decimals
            • 1kohm1 Offline
              1kohm1 Offline
              1kohm
              @mfalkvidd, Thanks!
              Works like a charm now!
              I've included now DHT sensor in this sketch as well :) Testing so far.
              So, another question :)
              To tell sketch when to send data I'm using:
              Now it's sending every 1 second. But my goal is to change it to send data only when there's a value change.
              I've found following code (it's for Dallas temp sensor), that is sending only changed values:
                sleep(conversionTime);
                  float temperature = static_cast<float>(static_cast<int>((getConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
                  #if COMPARE_TEMP == 1
              How to implement it in my case?
              Help here would be great
              Best,
