  2. Announcements
  • H hausinger
    @hausinger said:
    @marceloaqno said:
    @hausinger You forgot "--" for my-rs485-baudrate=57600 in your configuration.
    It should be:
    ./configure --my-gateway=ethernet --my-port=5003 --my-transport=rs485 --my-rs485-serial-port=/dev/ttyUSB0 --my-rs485-baudrate=57600
    Hi @marceloaqno
    Thank you for your answers. Yes, i saw this, but I did the "--", i forgot it in the last post, because I can't use copy & paste on my raspberry (remote Desktop).
    Did this configuration work on your System?
    Are you sure, that my configuration is ok? (with the "--")
    Whats the normal behavior when i start the mysGateway with debug (mysGateway -d)? If i type the starting command in the terminal, the Gateway gives me the Messages (from my last post) and thats it (not more). I can now type a new command
    I'm now not at home (Business trip), if I get home, i will try your "Screen" command
    So I'm at home today and make some Test.
    The screen comand gives me some strange characters, thats ok I think.
    But if i start the Gateway, I only get the same messages as shown in my other post.
    Here are 2 Pics that show you, how it look like.
    I also tried to make the gw with a baudrate of 9600, but still the same issues.!0_1480068509863_mysGateway.JPG 0_1480068518084_screen.JPG
    marceloaqno
    Code Contributor
    @hausinger After the command:
    sudo ./bin/mysgw -d
    It wasn't supposed to go back to bash, the gateway would wait for new messages.
    I'm not sure what's going on with your setup because I tested your configuration options here and it worked.
    H 1 Reply Last reply
    • jmmorgan83J jmmorgan83
      I created a virtual serial port using this ./configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyMySensorsGateway. I can see the port in the dev folder, but when I run dmesg I do not see it listed and therefore my openhab can not find it. How can I fix this?
      marceloaqno
      Code Contributor
      @jmmorgan83 You may need another name for the port, such as
      ./configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyUSB020
      jmmorgan83J 1 Reply Last reply
      • M marceloaqno
        jmmorgan83J
        jmmorgan83J
        jmmorgan83
        @marceloaqno
        Unfortunately, no luck:(.
        • M marceloaqno
          sudo ./bin/mysgw -d
          H
          H
          hausinger
          sudo ./bin/mysgw -d
          Thank you for your answer. What can I do now? Can I check, that this port is unused? And how can I check this?
          Or is there another problem?
          • jmmorgan83J
            jmmorgan83J
            jmmorgan83
            FYI: I do not think the Rpi gateway works with Openhab on the same unit. I have tried both the virtual serial port and mqtt, and neither will work with Openhab 1.83.
            • G
              G
              gtortone
              • G
                G
                gtortone
                • skywatchS
                  skywatchS
                  skywatch
                  Hi all,
                  So I built this and all seems to be well. But.....how do I test it properly?
                  I also installed pidome and have that able to 'see' the MSYGW, but it advises to only add it if it is working.
                  So how to know if mysgw is working OK? Is there somewhere a step-by-step way to do this?
                  • G
                    G
                    gtortone
                    @skywatch try to run it with "mysgw -d" .
                    Enabling debug mode you can see on console every message and diagnostics...
                    • skywatchS
                      skywatchS
                      skywatch
                      @gtortone
                      sudo ./bin/mysgw -d and sudo ./bin/mysgw -h now both give 'command not found' - which is odd as they were both working eariler ???
                      A reboot makes no difference. Although after reboot I see mysgw running in 'top' but even stopping that service and trying sudo mysgw -d again doesn't seem to work.
                      Any idea whats wrong? Any suggestions to get this going?
                      • G
                        G
                        gtortone
                        wrote on last edited by gtortone
                        #150
                        @skywatch
                        if you did
                        make install
                        the mysgw executable is in /usr/local/bin directory then you have to launch it with:
                        /usr/local/bin/mysgw -d
                        • skywatchS
                          skywatchS
                          skywatch
                          @gtortone
                          That doesn't appear anywhere on this tutorial, so maybe it needs adding for completion?
                          Anyway the output is now......
                          pi@PiDomePi:~ $ sudo /usr/local/bin/mysgw -d
                          mysgw: Starting gateway...
                          mysgw: Protocol version - 2.0.1-beta
                          mysgw: MCO:BGN:INIT GW,CP=RNNG--Q,VER=2.0.1-beta
                          mysgw: TSF:LRT:OK
                          mysgw: TSM:INIT
                          mysgw: TSM:INIT:TSP OK
                          mysgw: TSM:INIT:GW MODE
                          mysgw: TSM:READY
                          mysgw: MCO:REG:NOT NEEDED
                          mysgw: MCO:BGN:STP
                          mysgw: MCO:BGN:INIT OK,ID=0,PAR=0,DIS=0,REG=1
                          When i did build install I missed out bit for the leds, can I just re-run the ./config and 'make' then 'make install' again? Or will that cause problems??
                          I just think that the lights will be useful in the early stages of getting this running...
                          Thanks for the help, no way would I have got that without you! :)
                          G 1 Reply Last reply
                          • skywatchS skywatch
                            @gtortone
                            mysgw: TSF:LRT:OK
                            mysgw: TSM:INIT
                            mysgw: TSM:READY
                            mysgw: MCO:BGN:STP
                            G
                            G
                            gtortone
                            @skywatch
                            You're welcome !
                            you can (re)run configure, make, make install when you want,
                            but I suggest to stop the mysgw executable before launch "make install"
                            • skywatchS
                              skywatchS
                              skywatch
                              Thank you! :)
                              • skywatchS
                                skywatchS
                                skywatch
                                Can I just check that this is OK? .....
                                ./configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyMySensorsGateway --my-transport=nrf24 --my-rf24-irq-pin=15 --my-leds-err-pin=12 --my-leds-rx-pin=16 --my-leds-tx-pin=18
                                Can you see any problems here, it seemed to work but I hope to test fully this week, maybe tomorrow.....
                                  G
                                  G
                                  gtortone
                                  @skywatch
                                  Hi, options for "configure" are ok, I suggest you to double check your cabling !
                                  • skywatchS
                                    skywatchS
                                    skywatch
                                    What makes you think that the cabling is wrong? - I checked and can't see any problem....can you be less cryptic please? :)
                                      G
                                      G
                                      gtortone
                                      @skywatch
                                      I meaning that often is also useful to check cable two (or three) times !
                                      but if you already did it... ok !
                                      • skywatchS
                                        skywatchS
                                        skywatch
                                        Ah, OK then :) - I thought there was something in the console data I posted that meant there was a problem! - Tomorrow to build a sensor and get that going.... Thanks again!
                                        • michlb1982M
                                          michlb1982M
                                          michlb1982
                                          hi
                                          yesterday i tried to build a rpi-gateway but i had trouble to access, after changeing the rights on the port to 777 and group to dialout i could access via
                                          fhem. and i didn't use the symlink, i used the port directly /dev/pts/0@115200 andthen it works perfectly!
                                          thanks...
                                          p.s.: i uses always sudo while make and the other installation commands.
                                          greets mike
