  2. Announcements
  • PureGrainP
    PureGrainP
    PureGrain
    Has anyone been able to get this to successfully work with a Vera?
    • RogerB68R
      RogerB68R
      RogerB68
      Have been running MySensors for some time now with a EthernetGW running on Arduino. To clean-up the installation, I'm trying to get the Gateway running on my Raspberry instead but something stops the make process.
      pi@raspberrypi ~/MySensors $ ./configure --my-gateway=ethernet --my-port=5003 --my-transport=nrf24                       [SECTION] Detecting target machine.
      [OK] machine detected: SoC=BCM2836, Type=Rpi2, CPU=armv7l, REV=a01041.
      [OK] init system detected: sysvinit
      [OK] Finished.
      gcc -MT build/drivers/Linux/log.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_ARCH_RASPBERRYPI -DMY_PORT=5003  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/RPi -c drivers/Linux/log.c -o build/drivers/Linux/log.o
      cc1: error: bad value (cortex-a7) for -mtune switch
      Makefile:102: recipe for target 'build/drivers/Linux/log.o' failed
      Any hints what I have done wrong ?
      TigroenotT 1 Reply Last reply
      • RogerB68R
        RogerB68R
        RogerB68
        Issue solved, manual update of compiler from 4.6,3 -> 4.7.2 enables the make process. Similar problem also reported in post.
        Using
        • sudo apt-get update
        • sudo apt-get upgrade
        does not upgrade compiler. I used instruction according to How to upgrade GCC to 4.7+.
        • RogerB68R RogerB68
          [OK] Finished.
          TigroenotT
          TigroenotT
          Tigroenot
          @RogerB68 I had the same situation. I have removed the mtune parameter from the config file and compilation went fine. I don't know what it affects though. :)
          • jmmorgan83J
            jmmorgan83J
            jmmorgan83
            I created a virtual serial port using this ./configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyMySensorsGateway. I can see the port in the dev folder, but when I run dmesg I do not see it listed and therefore my openhab can not find it. How can I fix this?
            • H hausinger
              @hausinger said:
              @marceloaqno said:
              @hausinger You forgot "--" for my-rs485-baudrate=57600 in your configuration.
              It should be:
              ./configure --my-gateway=ethernet --my-port=5003 --my-transport=rs485 --my-rs485-serial-port=/dev/ttyUSB0 --my-rs485-baudrate=57600
              Hi @marceloaqno
              Thank you for your answers. Yes, i saw this, but I did the "--", i forgot it in the last post, because I can't use copy & paste on my raspberry (remote Desktop).
              Did this configuration work on your System?
              Are you sure, that my configuration is ok? (with the "--")
              Whats the normal behavior when i start the mysGateway with debug (mysGateway -d)? If i type the starting command in the terminal, the Gateway gives me the Messages (from my last post) and thats it (not more). I can now type a new command
              I'm now not at home (Business trip), if I get home, i will try your "Screen" command
              So I'm at home today and make some Test.
              The screen comand gives me some strange characters, thats ok I think.
              But if i start the Gateway, I only get the same messages as shown in my other post.
              Here are 2 Pics that show you, how it look like.
              I also tried to make the gw with a baudrate of 9600, but still the same issues.!0_1480068509863_mysGateway.JPG 0_1480068518084_screen.JPG
              marceloaqno
              Code Contributor
              @hausinger After the command:
              sudo ./bin/mysgw -d
              It wasn't supposed to go back to bash, the gateway would wait for new messages.
              I'm not sure what's going on with your setup because I tested your configuration options here and it worked.
              H 1 Reply Last reply
              • jmmorgan83J jmmorgan83
                marceloaqno
                Code Contributor
                @jmmorgan83 You may need another name for the port, such as
                ./configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyUSB020
                jmmorgan83J 1 Reply Last reply
                • M marceloaqno
                  jmmorgan83J
                  jmmorgan83J
                  jmmorgan83
                  @marceloaqno
                  Unfortunately, no luck:(.
                  • M marceloaqno
                    sudo ./bin/mysgw -d
                    H
                    H
                    hausinger
                    sudo ./bin/mysgw -d
                    Thank you for your answer. What can I do now? Can I check, that this port is unused? And how can I check this?
                    Or is there another problem?
                    • jmmorgan83J
                      jmmorgan83J
                      jmmorgan83
                      FYI: I do not think the Rpi gateway works with Openhab on the same unit. I have tried both the virtual serial port and mqtt, and neither will work with Openhab 1.83.
                      • G
                        G
                        gtortone
                        • G
                          G
                          gtortone
                          • skywatchS
                            skywatchS
                            skywatch
                            Hi all,
                            So I built this and all seems to be well. But.....how do I test it properly?
                            I also installed pidome and have that able to 'see' the MSYGW, but it advises to only add it if it is working.
                            So how to know if mysgw is working OK? Is there somewhere a step-by-step way to do this?
                            • G
                              G
                              gtortone
                              @skywatch try to run it with "mysgw -d" .
                              Enabling debug mode you can see on console every message and diagnostics...
                              • skywatchS
                                skywatchS
                                skywatch
                                @gtortone
                                sudo ./bin/mysgw -d and sudo ./bin/mysgw -h now both give 'command not found' - which is odd as they were both working eariler ???
                                A reboot makes no difference. Although after reboot I see mysgw running in 'top' but even stopping that service and trying sudo mysgw -d again doesn't seem to work.
                                Any idea whats wrong? Any suggestions to get this going?
                                • G
                                  G
                                  gtortone
                                  wrote on last edited by gtortone
                                  #150
                                  @skywatch
                                  if you did
                                  make install
                                  the mysgw executable is in /usr/local/bin directory then you have to launch it with:
                                  /usr/local/bin/mysgw -d
                                  • skywatchS
                                    skywatchS
                                    skywatch
                                    @gtortone
                                    That doesn't appear anywhere on this tutorial, so maybe it needs adding for completion?
                                    Anyway the output is now......
                                    pi@PiDomePi:~ $ sudo /usr/local/bin/mysgw -d
                                    mysgw: Starting gateway...
                                    mysgw: Protocol version - 2.0.1-beta
                                    mysgw: MCO:BGN:INIT GW,CP=RNNG--Q,VER=2.0.1-beta
                                    mysgw: TSF:LRT:OK
                                    mysgw: TSM:INIT
                                    mysgw: TSM:INIT:TSP OK
                                    mysgw: TSM:INIT:GW MODE
                                    mysgw: TSM:READY
                                    mysgw: MCO:REG:NOT NEEDED
                                    mysgw: MCO:BGN:STP
                                    mysgw: MCO:BGN:INIT OK,ID=0,PAR=0,DIS=0,REG=1
                                    When i did build install I missed out bit for the leds, can I just re-run the ./config and 'make' then 'make install' again? Or will that cause problems??
                                    I just think that the lights will be useful in the early stages of getting this running...
                                    Thanks for the help, no way would I have got that without you! :)
                                    G 1 Reply Last reply
                                    • skywatchS skywatch
                                      @gtortone
                                      mysgw: TSF:LRT:OK
                                      mysgw: TSM:INIT
                                      mysgw: TSM:READY
                                      mysgw: MCO:BGN:STP
                                      G
                                      G
                                      gtortone
                                      @skywatch
                                      You're welcome !
                                      you can (re)run configure, make, make install when you want,
                                      but I suggest to stop the mysgw executable before launch "make install"
                                      • skywatchS
                                        skywatchS
                                        skywatch
                                        Thank you! :)
                                        • skywatchS
                                          skywatchS
                                          skywatch
                                          Can I just check that this is OK? .....
                                          ./configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyMySensorsGateway --my-transport=nrf24 --my-rf24-irq-pin=15 --my-leds-err-pin=12 --my-leds-rx-pin=16 --my-leds-tx-pin=18
                                          Can you see any problems here, it seemed to work but I hope to test fully this week, maybe tomorrow.....
