  2. Announcements
  • H hausinger
    @marceloaqno said:
    @hausinger You forgot "--" for my-rs485-baudrate=57600 in your configuration.
    It should be:
    ./configure --my-gateway=ethernet --my-port=5003 --my-transport=rs485 --my-rs485-serial-port=/dev/ttyUSB0 --my-rs485-baudrate=57600
    Hi @marceloaqno
    Thank you for your answers. Yes, i saw this, but I did the "--", i forgot it in the last post, because I can't use copy & paste on my raspberry (remote Desktop).
    Did this configuration work on your System?
    Are you sure, that my configuration is ok? (with the "--")
    Whats the normal behavior when i start the mysGateway with debug (mysGateway -d)? If i type the starting command in the terminal, the Gateway gives me the Messages (from my last post) and thats it (not more). I can now type a new command
    I'm now not at home (Business trip), if I get home, i will try your "Screen" command
    H
    H
    hausinger
    @hausinger said:
    It should be:
    Hi @marceloaqno
    So I'm at home today and make some Test.
    The screen comand gives me some strange characters, thats ok I think.
    But if i start the Gateway, I only get the same messages as shown in my other post.
    Here are 2 Pics that show you, how it look like.
    I also tried to make the gw with a baudrate of 9600, but still the same issues.!0_1480068509863_mysGateway.JPG 0_1480068518084_screen.JPG
    • PureGrainP
      PureGrainP
      PureGrain
      Has anyone been able to get this to successfully work with a Vera?
      • RogerB68R
        RogerB68R
        RogerB68
        Have been running MySensors for some time now with a EthernetGW running on Arduino. To clean-up the installation, I'm trying to get the Gateway running on my Raspberry instead but something stops the make process.
        pi@raspberrypi ~/MySensors $ ./configure --my-gateway=ethernet --my-port=5003 --my-transport=nrf24                       [SECTION] Detecting target machine.
        [OK] machine detected: SoC=BCM2836, Type=Rpi2, CPU=armv7l, REV=a01041.
        [OK] init system detected: sysvinit
        [OK] Finished.
        gcc -MT build/drivers/Linux/log.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_ARCH_RASPBERRYPI -DMY_PORT=5003  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/RPi -c drivers/Linux/log.c -o build/drivers/Linux/log.o
        cc1: error: bad value (cortex-a7) for -mtune switch
        Makefile:102: recipe for target 'build/drivers/Linux/log.o' failed
        Any hints what I have done wrong ?
        TigroenotT 1 Reply Last reply
        • RogerB68R
          RogerB68R
          RogerB68
          Issue solved, manual update of compiler from 4.6,3 -> 4.7.2 enables the make process. Similar problem also reported in post.
          Using
          • sudo apt-get update
          • sudo apt-get upgrade
          does not upgrade compiler. I used instruction according to How to upgrade GCC to 4.7+.
          • RogerB68R RogerB68
            [OK] Finished.
            TigroenotT
            TigroenotT
            Tigroenot
            @RogerB68 I had the same situation. I have removed the mtune parameter from the config file and compilation went fine. I don't know what it affects though. :)
            • jmmorgan83J
              jmmorgan83J
              jmmorgan83
              I created a virtual serial port using this ./configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyMySensorsGateway. I can see the port in the dev folder, but when I run dmesg I do not see it listed and therefore my openhab can not find it. How can I fix this?
              • H hausinger
                @hausinger said:
                It should be:
                Hi @marceloaqno
                marceloaqno
                Code Contributor
                @hausinger After the command:
                sudo ./bin/mysgw -d
                It wasn't supposed to go back to bash, the gateway would wait for new messages.
                I'm not sure what's going on with your setup because I tested your configuration options here and it worked.
                H 1 Reply Last reply
                • jmmorgan83J jmmorgan83
                  marceloaqno
                  Code Contributor
                  @jmmorgan83 You may need another name for the port, such as
                  ./configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyUSB020
                  jmmorgan83J 1 Reply Last reply
                  • M marceloaqno
                    jmmorgan83J
                    jmmorgan83J
                    jmmorgan83
                    @marceloaqno
                    Unfortunately, no luck:(.
                    • M marceloaqno
                      sudo ./bin/mysgw -d
                      H
                      H
                      hausinger
                      sudo ./bin/mysgw -d
                      Thank you for your answer. What can I do now? Can I check, that this port is unused? And how can I check this?
                      Or is there another problem?
                      • jmmorgan83J
                        jmmorgan83J
                        jmmorgan83
                        FYI: I do not think the Rpi gateway works with Openhab on the same unit. I have tried both the virtual serial port and mqtt, and neither will work with Openhab 1.83.
                        • G
                          G
                          gtortone
                          • G
                            G
                            gtortone
                            • skywatchS
                              skywatchS
                              skywatch
                              Hi all,
                              So I built this and all seems to be well. But.....how do I test it properly?
                              I also installed pidome and have that able to 'see' the MSYGW, but it advises to only add it if it is working.
                              So how to know if mysgw is working OK? Is there somewhere a step-by-step way to do this?
                              • G
                                G
                                gtortone
                                @skywatch try to run it with "mysgw -d" .
                                Enabling debug mode you can see on console every message and diagnostics...
                                • skywatchS
                                  skywatchS
                                  skywatch
                                  @gtortone
                                  sudo ./bin/mysgw -d and sudo ./bin/mysgw -h now both give 'command not found' - which is odd as they were both working eariler ???
                                  A reboot makes no difference. Although after reboot I see mysgw running in 'top' but even stopping that service and trying sudo mysgw -d again doesn't seem to work.
                                  Any idea whats wrong? Any suggestions to get this going?
                                  • G
                                    G
                                    gtortone
                                    wrote on last edited by gtortone
                                    #150
                                    @skywatch
                                    if you did
                                    make install
                                    the mysgw executable is in /usr/local/bin directory then you have to launch it with:
                                    /usr/local/bin/mysgw -d
                                    • skywatchS
                                      skywatchS
                                      skywatch
                                      @gtortone
                                      That doesn't appear anywhere on this tutorial, so maybe it needs adding for completion?
                                      Anyway the output is now......
                                      pi@PiDomePi:~ $ sudo /usr/local/bin/mysgw -d
                                      mysgw: Starting gateway...
                                      mysgw: Protocol version - 2.0.1-beta
                                      mysgw: MCO:BGN:INIT GW,CP=RNNG--Q,VER=2.0.1-beta
                                      mysgw: TSF:LRT:OK
                                      mysgw: TSM:INIT
                                      mysgw: TSM:INIT:TSP OK
                                      mysgw: TSM:INIT:GW MODE
                                      mysgw: TSM:READY
                                      mysgw: MCO:REG:NOT NEEDED
                                      mysgw: MCO:BGN:STP
                                      mysgw: MCO:BGN:INIT OK,ID=0,PAR=0,DIS=0,REG=1
                                      When i did build install I missed out bit for the leds, can I just re-run the ./config and 'make' then 'make install' again? Or will that cause problems??
                                      I just think that the lights will be useful in the early stages of getting this running...
                                      Thanks for the help, no way would I have got that without you! :)
                                      G 1 Reply Last reply
                                      • skywatchS skywatch
                                        @gtortone
                                        mysgw: TSF:LRT:OK
                                        mysgw: TSM:INIT
                                        mysgw: TSM:READY
                                        mysgw: MCO:BGN:STP
                                        G
                                        G
                                        gtortone
                                        @skywatch
                                        You're welcome !
                                        you can (re)run configure, make, make install when you want,
                                        but I suggest to stop the mysgw executable before launch "make install"
                                        • skywatchS
                                          skywatchS
                                          skywatch
                                          Thank you! :)
