  3. Vera
  4. Sensors not found
Sensors not found
10 Posts 3 Posters 1.9k Views 2 Watching
  • riochickenR Offline
    riochickenR Offline
    riochicken
    For some reason new sensors are not found in my network anymore, I have version 1.5.5 (I think) of the library in my Vera and used the latest MySensors 2.0 libraries within the Arduino software. After building a new Nano Pro with Temperature sensors, they don't seem to be found by the network?!? Is there a newer version of the Vera we should know about? I can't find the current version of the Vera Library on the site, that might be an idea to publish somewhere (if not already published, then again: where could it be?!)..
    Kind regards
    Richard
    • riochickenR riochicken
      Kind regards
      Richard
      @riochicken I don't use Vera myself but there are links to the plugins at https://www.mysensors.org/controller/vera#installing-the-vera-plugin maybe that helps.
      riochickenR 1 Reply Last reply
        riochickenR Offline
        riochickenR Offline
        riochicken
        @mfalkvidd
        Thank you for your answer...
        It did work! So I think I will try to use the old library files for the Arduino software, hopefully the Temperature software still works for the old library...
        • korttomaK Offline
          korttomaK Offline
          korttoma
          You need to update your Gateway to 2.0 to be able to include sensor nodes based on 2.0 library version. The serial api has not changed so you should not need to change anything in the Vera.
          • Tomas
          • korttomaK korttoma
            riochickenR Offline
            riochickenR Offline
            riochicken
            @korttoma
            Sound logical, thanks... I just upgraded my gateway but now it is not responding to the Vera for some other reason, I can ping and open port 5003 on telnet but when I click start inclusion it doesnt do anything... weird... maybe recreate the mysensors device?!
            korttomaK 1 Reply Last reply
              @korttoma
              korttomaK Offline
              korttomaK Offline
              korttoma
              @riochicken Usually I just restart luup on Vera to get Vera to reconnect if it is having trouble.
              • Tomas
                riochickenR Offline
                riochickenR Offline
                riochicken
                @korttoma: Normally it would say: device found 0 and if nodes are found it counts as much as it can find, but it doesn't do anything... I checked the serial monitor and that part says that it detects sensors etc so I am not really sure what is going wrong...
                  riochickenR Offline
                  riochickenR Offline
                  riochicken
                  0;255;3;0;9;Eth: 0;0;3;0;5;1
                  0;255;3;0;9;Eth:
                  0;255;3;0;9;TSP:MSG:BC
                  0;255;3;0;9;TSP:CHKUPL:OK
                  0;255;3;0;9;TSP:MSG:GWL OK
                  0;255;3;0;9;TSP:MSG:SEND 0-0-4-4 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=ok:0
                  0;255;3;0;9;TSP:MSG:READ 4-4-0 s=255,c=3,t=24,pt=1,l=1,sg=0:1
                  0;255;3;0;9;TSP:MSG:PINGED (ID=4, hops=1)
                  0;255;3;0;9;!TSP:MSG:SEND 0-0-4-4 s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=fail:1
                  0;255;3;0;9;TSP:MSG:READ 4-4-0 s=255,c=0,t=17,pt=0,l=5,sg=0:2.0.0
                  0;255;3;0;9;TSP:MSG:READ 4-4-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
                  0;255;3;0;9;TSP:MSG:READ 4-4-0 s=255,c=3,t=11,pt=0,l=18,sg=0:Temperature Sensor
                  0;255;3;0;9;TSP:MSG:READ 4-4-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.1
                  0;255;3;0;9;TSP:MSG:READ 4-4-0 s=0,c=0,t=6,pt=0,l=0,sg=0:
                  0;255;3;0;9;TSP:MSG:READ 4-4-0 s=255,c=3,t=26,pt=1,l=1,sg=0:2
                  0;255;3;0;9;!TSP:MSG:SEND 0-0-4-4 s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=fail:1
                  0;255;3;0;9;TSP:MSG:READ 4-4-0 s=0,c=1,t=0,pt=7,l=5,sg=0:28.1
                  0;255;3;0;9;TSP:SANCHK:OK
                    0;255;3;0;9;Eth:
                    riochickenR Offline
                    riochickenR Offline
                    riochicken
                    0;255;3;0;9;Eth:
                    It only seems to be communication not adding a sensor... when I do not click the start inclusion button and just repower the sensor I get the same messages...
                    • korttomaK Offline
                      korttomaK Offline
                      korttoma
                      I'm not sure what is going wrong either.
                      What firmware is used in your Vera?
                      It sounds like you are unable to put Vera in inclusion mode from the MySensors Plugin device.
                      But there is also some communication issue since there are 2 messages failing to be sent:
                      I_PONG 25 In return to ping, sent back to sender, payload incremental hop counter
                      I_REGISTRATION_RESPONSE 27 Register response from GW
                      • Tomas
                      113.2k
