💬 Connecting the Radio
I'm having trouble with the distance between my 2 RFM69 radios. If I use this tutorial and change the frequency to 433 mhz I get distances of up to 10 meters - https://learn.adafruit.com/adafruit-rfm69hcw-and-rfm96-rfm95-rfm98-lora-packet-padio-breakouts/rfm69-test
However if I use the Mysensor libraries for the SerialGateway and the door sensor I don't even get 1 meter.
I tried to declare these variables as well but no success.#define RFM69_FREQUENCY RF69_433MHZ
#define IS_RFM69HWAny suggestions I might try out?
Martin -
Martin -
If i buy from aliexpress RFM69HW and when buy i select to seller info that i want 868MHz and on PCB RFM69HW has select/write 868MHz in sketch i must use item:
#define RFM69_FREQUENCY RF69_868MHZ ? -
I m getting symbols when I send Hello World message from Arduino Uno to an Arduino Pro Mini (5V).
Yes I have put an input of 3.3V to the pro mini.
Baud rate used is 9600.
Any clue why this is happening? I can provide the code. -
@LaMB95 are you using a Pro Mini 5V 16MHz or Pro Mini 3.3V 8MHz?
If the wrong variant is selected in the Arduino IDE, all timings will be off, including the timings for serial communication.
I have an arduino pro mini 5V. But I have attached a breakout CP2102 usb connection to it. On the board there is a 3.3V point which I have plugged in as Vcc to the NRF24L01+ module.
To upload the code I have selected the 5V 16Mhz as processor.
@flopp :
No, it isn't that easy.
To improve your NRF, please have a look at https://forum.mysensors.org/topic/1851/extending-range-of-regular-nrf24l01.I tried solution Nr. 2. It is easy to do and cheap. Improvements are noticeable but not dramatically.
In regard to effort it is worth trying.
If you aimed at changing NRF's frequency - no this is not possible at all. Base frequencies are selected within the chip itself and antenna resonant frequency has to match oscillator frequency.
@LaMB95 Interesting. I have never seen a 5V Pro Mini with 3.3V output. Where did you get it?
Try different serial speeds in the serial monitor and see if you get something readable.
@mfalkvidd Haha not really a 3.3 output I changed its input voltge to 3.3 hoping it would work.
But nevertheless I managed to solve the issue.
It seems to be an error in the Hardware serial.Refer: http://forum.arduino.cc/index.php?topic=46458.0
The code bhagman has posted worked !
It worked yesterday now I am back to the same problem.
What a wonder !
