  2. Announcements
  3. 💬 Connecting the Radio
162 Posts 49 Posters 109.3k Views 40 Watching
  • martinsM
    martinsM
    martins
    I'm having trouble with the distance between my 2 RFM69 radios. If I use this tutorial and change the frequency to 433 mhz I get distances of up to 10 meters - https://learn.adafruit.com/adafruit-rfm69hcw-and-rfm96-rfm95-rfm98-lora-packet-padio-breakouts/rfm69-test
    However if I use the Mysensor libraries for the SerialGateway and the door sensor I don't even get 1 meter.
    I tried to declare these variables as well but no success.
    #define RFM69_FREQUENCY RF69_433MHZ
    #define IS_RFM69HW
    Any suggestions I might try out?
    Martin
    martinsM 1 Reply Last reply
    • pepsonP
      pepsonP
      pepson
      If i buy from aliexpress RFM69HW and when buy i select to seller info that i want 868MHz and on PCB RFM69HW has select/write 868MHz in sketch i must use item:
      #define RFM69_FREQUENCY RF69_868MHZ ?
      • martinsM martins
        #define IS_RFM69HW
        Martin
        martinsM
        martinsM
        martins
        @martins
        Solved. This is the extra variables for the RFM69H / HW versions and to set the frequency.
        #define MY_IS_RFM69HW
        Range is now acceptible.
        Regards,
        Martin
        • pepsonP pepson
          martinsM
          martinsM
          martins
          @pepson
          From library API:
          MY_RFM69_FREQUENCY RF69_868MHZ For other frequency, add this define to your sketch and set it to your preferred value in RF69_433MHZ, RF69_868MHZ or RF69_915MHZ
          So it seems that 868MHZ is the default value.
          Regards
          • pepsonP
            pepsonP
            pepson
            Ok thanks
            • LaMB95L
              LaMB95L
              LaMB95
              I m getting symbols when I send Hello World message from Arduino Uno to an Arduino Pro Mini (5V).
              Yes I have put an input of 3.3V to the pro mini.
              Baud rate used is 9600.
              Any clue why this is happening? I can provide the code.
              • LaMB95L LaMB95
                @LaMB95 are you using a Pro Mini 5V 16MHz or Pro Mini 3.3V 8MHz?
                If the wrong variant is selected in the Arduino IDE, all timings will be off, including the timings for serial communication.
                LaMB95L 1 Reply Last reply
                  LaMB95L
                  LaMB95L
                  LaMB95
                  @mfalkvidd
                  I have an arduino pro mini 5V. But I have attached a breakout CP2102 usb connection to it. On the board there is a 3.3V point which I have plugged in as Vcc to the NRF24L01+ module.
                  To upload the code I have selected the 5V 16Mhz as processor.
                  • LaMB95L LaMB95
                    @mfalkvidd
                    @LaMB95 Interesting. I have never seen a 5V Pro Mini with 3.3V output. Where did you get it?
                    Try different serial speeds in the serial monitor and see if you get something readable.
                    • F
                      F
                      flopp
                      wrote on last edited by flopp
                      #63
                      mfalkviddM T 2 Replies Last reply
                      • F flopp
                        [[topic:post-is-deleted]]
                        • F flopp
                          tboha
                          @flopp :
                          No, it isn't that easy.
                          To improve your NRF, please have a look at https://forum.mysensors.org/topic/1851/extending-range-of-regular-nrf24l01.
                          I tried solution Nr. 2. It is easy to do and cheap. Improvements are noticeable but not dramatically.
                          In regard to effort it is worth trying.
                          If you aimed at changing NRF's frequency - no this is not possible at all. Base frequencies are selected within the chip itself and antenna resonant frequency has to match oscillator frequency.
                            LaMB95L
                            LaMB95L
                            LaMB95
                            @mfalkvidd Haha not really a 3.3 output I changed its input voltge to 3.3 hoping it would work.
                            But nevertheless I managed to solve the issue.
                            It seems to be an error in the Hardware serial.
                            Refer: http://forum.arduino.cc/index.php?topic=46458.0
                            The code bhagman has posted worked !
                            • LaMB95L LaMB95
                              LaMB95L
                              LaMB95L
                              LaMB95
                              @mfalkvidd
                              It worked yesterday now I am back to the same problem.
                              What a wonder !
                              • N
                                N
                                napo7
                                Hi !
                                It seems that the FRM69 library set the IRQ pin as optionnal. Can someone confirm that the IRQ pin is mandatory ?
                                tekkaT 1 Reply Last reply
                                • N napo7
                                  Hi !
                                  tekkaT
                                  tekkaT
                                  tekka
                                  @napo7 yes, it is mandatory since the driver is IRQ-dependent
                                  • N
                                    N
                                    napo7
                                    wrote on last edited by napo7
                                    #70
                                    Well, I had a look in RFM69 driver, and it seems that the interrupts handlers are never sets ?
                                    Am I wrong ?
                                    Edit : In facts, DIO0 is not used as an Interrupt source in RFM69 driver : it's a pin that informs the library that, either, a packet has been received, or , the frame we try to send has been sent.
                                    So, the code doesn't use interrupts, but this pin is more a "Data available" pin.
                                      @napo7
                                      so, if data available or data sent, this can be an interrupt source for an mcu ;)
                                      It's enabled in the init there https://github.com/mysensors/MySensors/blob/development/drivers/RFM69/RFM69.cpp#L123
                                      • N
                                        N
                                        napo7
                                        Yes I noticed it !
                                        Since it didn't mention IRQ pin, I didn't seen it at first !
                                        What misleaded me, is that on LowPowerLab forums, some users says that you can absolutely discard this interrupt and poll the radio frequently to ask if a packet is available.
                                        • A
                                          adamp237
                                          I had this working perfectly on my Arduino Uno. I soldered it up to my Arduino Nano and it seems to work ok, but I'm not getting any data sent. The serial says it's connected OK but never sends any motion 1s or 0s. My MQTT server shows the following: Client mosqsub/3449-raspberryp received PUBLISH (d0, q0, r0, m0, 'mygateway1-out/255/255/3/0/3', ... (0 bytes))
                                          Any idea what is going on? I've tested the motion sensor separately and that is sending a high value to pin 3 no worries.
                                          gohanG 1 Reply Last reply
