  3. Vera
  4. Brand new Vera controller
33 Posts 5 Posters 15.3k Views 5 Watching
  • R
    R
    r-nox
    As a side not I see Lib version is blank in the screen shot...
    dbemowskD 1 Reply Last reply
    • R r-nox
      dbemowskD
      dbemowskD
      @r-nox What should the lib version be?
      So just to rule out other things that I may have done when trying to install some other apps, which by the way may have caused the error with device 8, I did a factory reset of the device and ran through the setup one more time. With the reset I was upgraded to a newer firmware version (1.7.2414). I re-uploaded the arduino files and created the device using the instructions on the MySensors website under the Vera controller. One thing I found curious is that when creating the device, the only thing it says to fill in on the "Create Device" page is the "Upnp Device FIlename". I was surprised that I didn't have to fill in any of the other fields such as the "Device Type" or the "Upnp Implementation Filename" . Again the device was created, and I configured the serial port as follows:
      0_1482278094094_upload-77a5482c-8792-41c9-9463-56f600f57f1f
      When I go to devices, things look the same as before. Here are the current screen shots:
      0_1482278193935_upload-9b95e586-53cc-4411-a5d0-a0aa5e4f1790
      0_1482278255917_upload-53ab1756-8086-4cb4-b701-8919f549e465
      0_1482278300939_upload-f1ab41ae-c846-4eaf-a386-7ea4d06de141
      0_1482278460104_upload-5287611b-e9df-4642-984a-e0838820878e
      • korttomaK
        korttomaK
        korttoma
        Hi @dbemowsk
        You setup stil looked different from mine so I decided to wipe my VeraLite clean and see what I get.
        Now my setup looks exactly like yours except I did get the Lib version ( witch should show the Library version used in your MySensors Gateway ) efter hitting the reset button on my GW arduino and restart the Luup engine a few times.
        Then when I press the "Start" button I get the text bellow the buttons like this:
        0_1482299688258_upload-09006f39-4dfb-4f7d-a232-97ff83a1e1ff
        As I then restart a Sensor node the number count up according to the devices found and when I know it has fund them all I press "Stop". Then the luup engine restarts automatically and the new devices are created.
        I hit ctrl + F5 to refresh my browser and then go to devises and find this:
        0_1482299875190_upload-6e2835cc-1739-452c-96f8-e99164019fae
        So I think your system is fine, you just need to restart the GW and run a few luup restarts and refresh your browser. Then try including a Sensor.
        • Tomas
        • korttomaK korttoma
          Hi @dbemowsk
          dbemowskD
          dbemowskD
          @korttoma Is there any kind of command line serial monitor that I can use on the Vera to test my gateway communication coming into it? If not, that may be something for them to include on the unit. I double checked my wiring from my USB FTDI adapter to the gateway last night and I have my 3 wires as follows:
          FTDI.......GW
          GND ----GND
          TX --------- RX
          RX --------- TX
          I tried hitting the reset button on the gateway a number of times and restarted the luup engine a few times and also rebooted the Vera a few times. That is why I want to test that the Vera is receiving data from the FTDI properly.
          I am betting that it is something that I am doing wrong, and I am going to kick myself in the arse when I figure out what it is.
          J 1 Reply Last reply
          • korttomaK
            korttomaK
            korttoma
            You can see the vera log file if you enter this adress in your browser
            http://<YourVeraIP>/cgi-bin/cmh/log.sh?Device=LuaUPnP
            • Tomas
            • dbemowskD dbemowsk
              FTDI.......GW
              GND ----GND
              TX --------- RX
              RX --------- TX
              J
              J
              jlieffort
              @dbemowsk
              Check out this tool if you don't know about it already.
              https://www.mysensors.org/controller/myscontroller
              • J jlieffort
                @dbemowsk
                dbemowskD
                dbemowskD
                @jlieffort I know about this tool, but this will not help. I need to debug the serial connection from my gateway to my Vera controller. This is a Windows based tool.
                • dbemowskD
                  dbemowskD
                  OK, I have an update with some log information, thanks @korttoma for the link. This is a snipet of the log:
                  50	12/22/16 6:06:48.240	luup_log:9: Arduino: Requesting status for: 20;3 <0x74229520>
                  50	12/22/16 6:06:49.270	luup_log:9: Arduino: Log: TSP:MSG:READ 20-20-0 s=0,c=1,t=0,pt=7,l=5,sg=0:19.44 <0x74229520>
                  50	12/22/16 6:06:49.274	luup_log:9: Arduino: Set variable: 20;0;1;0;0;19.44 <0x74229520>
                  50	12/22/16 6:06:49.279	luup_log:9: Arduino: Log: TSP:MSG:READ 20-20-0 s=0,c=1,t=44,pt=7,l=5,sg=0:18.89 <0x74229520>
                  50	12/22/16 6:06:49.280	luup_log:9: Arduino: Set variable: 20;0;1;0;44;18.89 <0x74229520>
                  50	12/22/16 6:06:49.297	luup_log:9: Arduino: Log: TSP:MSG:READ 20-20-0 s=0,c=1,t=45,pt=7,l=5,sg=0:18.89 <0x74229520>
                  50	12/22/16 6:06:49.298	luup_log:9: Arduino: Set variable: 20;0;1;0;45;18.89 <0x74229520>
                  50	12/22/16 6:06:49.305	luup_log:9: Arduino: Log: TSP:MSG:READ 20-20-0 s=0,c=1,t=44,pt=7,l=5,sg=0:27.22 <0x74229520>
                  50	12/22/16 6:06:49.306	luup_log:9: Arduino: Set variable: 20;0;1;0;44;27.22 <0x74229520>
                  50	12/22/16 6:06:49.857	luup_log:9: Arduino: Log: TSP:MSG:READ 20-20-0 s=2,c=2,t=47,pt=0,l=0,sg=0: <0x74229520>
                  50	12/22/16 6:06:49.858	luup_log:9: Arduino: Request: 20;2;2;0;47; <0x74229520>
                  50	12/22/16 6:06:49.859	luup_log:9: Arduino: Requesting status for: 20;2 <0x74229520>
                  50	12/22/16 6:06:51.416	luup_log:9: Arduino: Log: TSP:MSG:READ 20-20-0 s=3,c=2,t=47,pt=0,l=0,sg=0: <0x74229520>
                  50	12/22/16 6:06:51.417	luup_log:9: Arduino: Request: 20;3;2;0;47; <0x74229520>
                  50	12/22/16 6:06:51.417	luup_log:9: Arduino: Requesting status for: 20;3 <0x74229520>
                  50	12/22/16 6:06:52.445	luup_log:9: Arduino: Log: TSP:MSG:READ 20-20-0 s=0,c=1,t=0,pt=7,l=5,sg=0:19.44 <0x74229520>
                  50	12/22/16 6:06:52.447	luup_log:9: Arduino: Set variable: 20;0;1;0;0;19.44 <0x74229520>
                  50	12/22/16 6:06:52.496	luup_log:9: Arduino: Log: TSP:MSG:READ 20-20-0 s=0,c=1,t=45,pt=7,l=5,sg=0:18.89 <0x74229520>
                  50	12/22/16 6:06:52.497	luup_log:9: Arduino: Set variable: 20;0;1;0;45;18.89 <0x74229520>
                  50	12/22/16 6:06:53.090	luup_log:9: Arduino: Log: TSP:MSG:READ 20-20-0 s=2,c=2,t=47,pt=0,l=0,sg=0: <0x74229520>
                  50	12/22/16 6:06:53.091	luup_log:9: Arduino: Request: 20;2;2;0;47; <0x74229520>
                  50	12/22/16 6:06:53.091	luup_log:9: Arduino: Requesting status for: 20;2 <0x74229520>
                  50	12/22/16 6:06:54.657	luup_log:9: Arduino: Log: TSP:MSG:READ 20-20-0 s=3,c=2,t=47,pt=0,l=0,sg=0: <0x74229520>
                  50	12/22/16 6:06:54.657	luup_log:9: Arduino: Request: 20;3;2;0;47; <0x74229520>
                  50	12/22/16 6:06:54.658	luup_log:9: Arduino: Requesting status for: 20;3 <0x74229520>
                  50	12/22/16 6:06:55.160	luup_log:9: Arduino: Log: TSP:MSG:READ 255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0: <0x74229520>
                  50	12/22/16 6:06:55.161	luup_log:9: Arduino: Log: TSP:MSG:BC <0x74229520>
                  50	12/22/16 6:06:55.164	luup_log:9: Arduino: Log: TSP:MSG:FPAR REQ (sender=255) <0x74229520>
                  50	12/22/16 6:06:55.165	luup_log:9: Arduino: Log: TSP:CHKUPL:OK <0x74229520>
                  50	12/22/16 6:06:55.167	luup_log:9: Arduino: Log: TSP:MSG:GWL OK <0x74229520>
                  50	12/22/16 6:06:55.750	luup_log:9: Arduino: Log: TSP:MSG:SEND 0-0-255-255 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=bc:0 <0x74229520>
                  50	12/22/16 6:06:55.758	luup_log:9: Arduino: Log: TSP:MSG:READ 20-20-0 s=0,c=1,t=0,pt=7,l=5,sg=0:19.44 <0x74229520>
                  50	12/22/16 6:06:55.761	luup_log:9: Arduino: Set variable: 20;0;1;0;0;19.44 <0x74229520>
                  50	12/22/16 6:06:55.764	luup_log:9: Arduino: Log: TSP:MSG:READ 20-20-0 s=0,c=1,t=44,pt=7,l=5,sg=0:18.89 <0x74229520>
                  50	12/22/16 6:06:55.765	luup_log:9: Arduino: Set variable: 20;0;1;0;44;18.89 <0x74229520>
                  50	12/22/16 6:06:56.348	luup_log:9: Arduino: Log: TSP:MSG:READ 20-20-0 s=2,c=2,t=47,pt=0,l=0,sg=0: <0x74229520>
                  50	12/22/16 6:06:56.349	luup_log:9: Arduino: Request: 20;2;2;0;47; <0x74229520>
                  50	12/22/16 6:06:56.350	luup_log:9: Arduino: Requesting status for: 20;2 <0x74229520>
                  50	12/22/16 6:06:57.178	luup_log:9: Arduino: Log: TSP:MSG:READ 255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0: <0x74229520>
                  50	12/22/16 6:06:57.180	luup_log:9: Arduino: Log: TSP:MSG:BC <0x74229520>
                  50	12/22/16 6:06:57.186	luup_log:9: Arduino: Log: TSP:MSG:FPAR REQ (sender=255) <0x74229520>
                  50	12/22/16 6:06:57.188	luup_log:9: Arduino: Log: TSP:CHKUPL:OK (FLDCTRL) <0x74229520>
                  50	12/22/16 6:06:57.189	luup_log:9: Arduino: Log: TSP:MSG:GWL OK <0x74229520>
                  50	12/22/16 6:06:57.735	luup_log:9: Arduino: Log: TSP:MSG:SEND 0-0-255-255 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=bc:0 <0x74229520>
                  50	12/22/16 6:06:57.920	luup_log:9: Arduino: Log: TSP:MSG:READ 20-20-0 s=3,c=2,t=47,pt=0,l=0,sg=0: <0x74229520>
                  50	12/22/16 6:06:57.920	luup_log:9: Arduino: Request: 20;3;2;0;47; <0x74229520>
                  50	12/22/16 6:06:57.921	luup_log:9: Arduino: Requesting status for: 20;3 <0x74229520>
                  50	12/22/16 6:06:58.941	luup_log:9: Arduino: Log: TSP:MSG:READ 20-20-0 s=0,c=1,t=0,pt=7,l=5,sg=0:19.44 <0x74229520>
                  50	12/22/16 6:06:58.943	luup_log:9: Arduino: Set variable: 20;0;1;0;0;19.44 <0x74229520>
                  50	12/22/16 6:06:58.961	luup_log:9: Arduino: Log: TSP:MSG:READ 20-20-0 s=0,c=1,t=44,pt=7,l=5,sg=0:18.89 <0x74229520>
                  50	12/22/16 6:06:58.962	luup_log:9: Arduino: Set variable: 20;0;1;0;44;18.89 <0x74229520>
                  50	12/22/16 6:06:58.973	luup_log:9: Arduino: Log: TSP:MSG:READ 20-20-0 s=0,c=1,t=45,pt=7,l=5,sg=0:18.89
                  To me that looks like the gateway is receiving data. As I scanned through the log though, I noticed this:
                  01	12/22/16 4:29:02.122	UserData::WriteUserData saved--before move File Size: 4541 save size 4541 <0x77229520>
                  02	12/22/16 4:29:02.122	UserData::TempLogFileSystemFailure start 0 <0x77229520>
                  02	12/22/16 4:29:02.140	UserData::TempLogFileSystemFailure 4287 res:1
                  -rw-r--r--    1 root     root            33 Dec 20 16:30 /etc/cmh/HW_Key
                  -rw-r--r--    1 root     root            32 Dec 31  1999 /etc/cmh/HW_Key2
                  -rw-r--r--    1 root     root             9 Dec 20 16:30 /etc/cmh/PK_AccessPoint
                  -rw-r--r--    1 root     root             7 Dec 20 17:14 /etc/cmh/PK_Account
                  -rw-r--r--    1 root     root           425 Dec 21 01:29 /etc/cmh/cmh.conf
                  -rw-r--r--    1 root     root             0 Aug 22 08:36 /etc/cmh/devices
                  -rw-r--r--    1 root     root         16383 Dec 21 03:00 /etc/cmh/dongle.4.5.dump.0
                  -rw-r--r--    1 root     root            41 Dec 20 16:21 /etc/cmh/ergy_key
                  -rw-r--r--    1 root     root             0 Aug 22 08:36 /etc/cmh/first_boot
                  -rw-r--r--    1 root     root             0 Dec 21 01:25 /etc/cmh/fresh_install
                  -rw-r--r--    1 root     root             1 Dec 21 01:52 /etc/cmh/ip_mode
                  -rw-r--r--    1 root     root            48 Dec 31  1999 /etc/cmh/keys
                  -rw-r--r--    1 root     root             3 Dec  9 09:30 /etc/cmh/language
                  -rw-r--r--    1 root     root             2 Dec  9 09:30 /etc/cmh/language_id
                  -rw-r--r--    1 root     root            10 Dec 21 16:34 /etc/cmh/last_backup
                  -rw-r--r--    1 root     root            11 Dec 22 01:52 /etc/cmh/last_report
                  -rw-r--r--    1 root     root            70 Dec 20 16:36 /etc/cmh/lighttpd_failures
                  -rw-r--r--    1 root     root         36316 Oct  3 00:25 /etc/cmh/network_pnp.lua
                  -rw-r--r--    1 root     root            12 Dec  9 09:30 /etc/cmh/platform
                  -rw-r--r--    1 root     root           458 Oct  3 00:25 /etc/cmh/ra_key
                  -rw-r--r--    1 root     root             0 Dec  9 09:30 /etc/cmh/scenarios
                  -rw-r--r--    1 root     root          2032 Dec 20 16:30 /etc/cmh/servers.conf
                  -rw-r--r--    1 root     root          1520 Aug 22 08:34 /etc/cmh/servers.conf.default
                  -rw-r--r--    1 root     root            20 Dec 20 16:35 /etc/cmh/servers.conf.timestamp
                  -rw-r--r--    1 root     root           154 Oct  3 00:25 /etc/cmh/servers_whitelist
                  -rw-r--r--    1 root     root          1598 Dec 22 01:52 /etc/cmh/services.conf
                  -rw-r--r--    1 root     root            20 Dec 20 16:19 /etc/cmh/sync_kit
                  -rw-r--r--    1 root     root            20 Dec 20 16:19 /etc/cmh/sync_rediscover
                  -rw-r--r--    1 root     root             2 Dec  9 09:30 /etc/cmh/ui
                  -rw-r--r--    1 root     root             2 Dec  9 09:30 /etc/cmh/ui_man
                  -rw-r--r--    1 root     root             5 Dec  9 09:30 /etc/cmh/ui_skin
                  -rw-r--r--    1 root     root           504 Jul 22 09:31 /etc/cmh/user_data.json.luup.lzo
                  -rw-r--r--    1 root     root          4541 Dec 22 02:41 /etc/cmh/user_data.json.lzo
                  -rw-r--r--    1 root     root          4540 Dec 22 02:05 /etc/cmh/user_data.json.lzo.1
                  -rw-r--r--    1 root     root          4540 Dec 21 23:17 /etc/cmh/user_data.json.lzo.2
                  -rw-r--r--    1 root     root          4541 Dec 21 21:53 /etc/cmh/user_data.json.lzo.3
                  -rw-r--r--    1 root     root          4547 Dec 21 21:23 /etc/cmh/user_data.json.lzo.4
                  -rw-r--r--    1 root     root          4544 Dec 21 17:05 /etc/cmh/user_data.json.lzo.5
                  -rw-r--r--    1 root     root          4541 Dec 22 04:29 /etc/cmh/user_data.json.lzo.new
                  -rw-r--r--    1 root     root            21 Dec 20 17:14 /etc/cmh/users.conf
                  -rw-r--r--    1 root     root            20 Dec 20 17:14 /etc/cmh/users.conf.timestamp
                  -rw-r--r--    1 root     root             3 Aug 22 08:36 /etc/cmh/vera_model
                  -rw-r--r--    1 root     root             9 Dec  9 09:30 /etc/cmh/version
                  -rw-r--r--    1 root     root             9 Dec 21 21:24 /etc/cmh/version_latest
                  -rw-r--r--    1 root     root             5 Dec 31  1999 /etc/cmh/zigbee_version
                  -rw-r--r--    1 root     root             8 Dec 22 04:17 /etc/cmh/zwave_house_id
                  -rw-r--r--    1 root     root             3 Dec 31  1999 /etc/cmh/zwave_locale
                  -rw-r--r--    1 root     root            48 Dec 21 01:56 /etc/cmh/zwave_version
                  /etc/cmh/orig:
                  -rw-r--r--    1 root     root             0 Dec  9 09:30 devices
                  -rw-r--r--    1 root     root             0 Dec  9 09:30 first_boot
                  -rw-r--r--    1 root     root             0 Dec  9 09:30 fresh_install
                  -rw-r--r--    1 root     root             0 Dec  9 09:30 scenarios
                  -rw-r--r--    1 root     root           520 Dec  9 09:30 user_data.json.lzo
                  /etc/cmh/wan_failover:
                  -rw-r--r--    1 root     root            44 Jul 22 09:31 check_internet.hosts
                   <0x77229520>
                  02	12/22/16 4:29:02.204	UserData::TempLogFileSystemFailure start 0 <0x77229520>
                  02	12/22/16 4:29:02.223	UserData::TempLogFileSystemFailure 4198 res:1
                  -rw-r--r--    1 root     root          4541 Dec 22 02:41 /etc/cmh/user_data.json.lzo.1
                  -rw-r--r--    1 root     root          4540 Dec 22 02:05 /etc/cmh/user_data.json.lzo.2
                  -rw-r--r--    1 root     root          4540 Dec 21 23:17 /etc/cmh/user_data.json.lzo.3
                  -rw-r--r--    1 root     root          4541 Dec 21 21:53 /etc/cmh/user_data.json.lzo.4
                  -rw-r--r--    1 root     root          4547 Dec 21 21:23 /etc/cmh/user_data.json.lzo.5
                  /etc/cmh/orig:
                   <0x77229520>
                  The things that say TempLogFileSystemFailure are a bit of a red flag for me.
                  Also, here is a log of what happens when I hit the start button to start inclusion.
                  50	12/22/16 6:12:44.804	luup_log:9: Arduino: Requesting status for: 20;2 <0x74229520>
                  08	12/22/16 6:12:45.587	JobHandler_LuaUPnP::HandleActionRequest device: 9 service: urn:upnp-arduino-cc:serviceId:arduino1 action: StartInclusion <0x75429520>
                  08	12/22/16 6:12:45.588	JobHandler_LuaUPnP::HandleActionRequest argument DeviceNum=9 <0x75429520>
                  08	12/22/16 6:12:45.588	JobHandler_LuaUPnP::HandleActionRequest argument serviceId=urn:upnp-arduino-cc:serviceId:arduino1 <0x75429520>
                  08	12/22/16 6:12:45.588	JobHandler_LuaUPnP::HandleActionRequest argument action=StartInclusion <0x75429520>
                  50	12/22/16 6:12:45.590	luup_log:9: Arduino: Sending: 0;0;3;0;5;1 <0x77bf1320>
                  04	12/22/16 6:12:45.593	 <0x77bf1320>
                  50	12/22/16 6:12:46.361	luup_log:9: Arduino: Log: TSP:MSG:READ 20-20-0 s=3,c=2,t=47,pt=0,l=0,sg=0: <0x74229520>
                  It looks as if inclusion mode is starting, but nothing is happening.
                  Maybe one of you has some insight as to what all of this information means.
                  • korttomaK
                    korttomaK
                    korttoma
                    #24
                    I'm not sure what to make of it, maybe @blacey, @petewill, @BartE or @hek could comment on this?
                    • Tomas
                    • dbemowskD
                      dbemowskD
                      #25
                      I am leaving for work in a few minutes, but if I don't hear something by the time I get off work, I am going to call tech support. I REALLY appreciate the help everyone has given.
                      korttomaK 1 Reply Last reply
                        korttomaK
                        korttomaK
                        korttoma
                        Hi @dbemowsk ,
                        I wish I could do more to help you. I took a look at the log in my test environment and I found that I also have this:
                        Maybe this is something that is printed each time the device restarts?? Let me know if Vera support gives you any explanation for it.
                        But the MySensors Part seems to work fine for me:
                        Here the USB port gets connected and Vera receives the Lib version of the GW:
                        50	12/23/16 7:51:43.454	luup_log:5: Arduino: Trying for a serial connection <0x2bf65680>
                        50	12/23/16 7:51:43.454	luup_log:5: Arduino: Serial port is connected <0x2bf65680>
                        50	12/23/16 7:51:43.455	luup_log:5: Arduino: Baud is 115200 <0x2bf65680>
                        50	12/23/16 7:51:43.456	luup_log:5: Arduino: urn:upnp-arduino-cc:serviceId:arduino1,GWAddress, 4(115200), 5 <0x2bf65680>
                        06	12/23/16 7:51:43.456	Device_Variable::m_szValue_set device: 5 service: urn:upnp-arduino-cc:serviceId:arduino1 variable: GWAddress was: - now: 4(115200) #hooks: 0 upnp: 0 skip: 0 v:0xbcbed0/NONE duplicate:0 <0x2bf65680>
                        50	12/23/16 7:51:43.459	luup_log:5: Arduino: Sending: 0;0;3;0;2;Get Version <0x2bf65680>
                        50	12/23/16 7:51:43.471	luup_log:5: Arduino: urn:upnp-arduino-cc:serviceId:arduino1,ArduinoLibVersion, 2.0.0, 5 <0x2d565680>
                        Here is what it looks like when I start inclusion mode and find one device:
                        50	12/23/16 7:52:20.057	luup_log:5: Arduino: Sending: 0;0;3;0;5;1 <0x2b51c310>
                        04	12/23/16 7:52:20.059	 <0x2b51c310>
                        50	12/23/16 7:52:20.070	luup_log:5: Arduino: urn:upnp-arduino-cc:serviceId:arduino1,InclusionMode, 1, 5 <0x2d565680>
                        06	12/23/16 7:52:20.071	Device_Variable::m_szValue_set device: 5 service: urn:upnp-arduino-cc:serviceId:arduino1 variable: InclusionMode was: 0 now: 1 #hooks: 0 upnp: 0 skip: 0 v:0xbb2eb8/NONE duplicate:0 <0x2d565680>
                        50	12/23/16 7:52:20.072	luup_log:5: Arduino: urn:upnp-arduino-cc:serviceId:arduino1,InclusionFoundCountHR, 0 devices found, 5 <0x2d565680>
                        06	12/23/16 7:52:20.073	Device_Variable::m_szValue_set device: 5 service: urn:upnp-arduino-cc:serviceId:arduino1 variable: InclusionFoundCountHR was:  now: 0 devices found #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x2d565680>
                        50	12/23/16 7:52:35.941	luup_log:5: Arduino: Log: TSP:MSG:READ 3-3-255 s=255,c=3,t=7,pt=0,l=0,sg=0: <0x2d565680>
                        50	12/23/16 7:52:35.950	luup_log:5: Arduino: Log: TSP:MSG:BC <0x2d565680>
                        50	12/23/16 7:52:35.952	luup_log:5: Arduino: Log: TSP:MSG:FPAR REQ (sender=3) <0x2d565680>
                        50	12/23/16 7:52:35.954	luup_log:5: Arduino: Log: TSP:CHKUPL:OK <0x2d565680>
                        50	12/23/16 7:52:35.955	luup_log:5: Arduino: Log: TSP:MSG:GWL OK <0x2d565680>
                        50	12/23/16 7:52:36.711	luup_log:5: Arduino: Log: TSP:MSG:SEND 0-0-3-3 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=ok:0 <0x2d565680>
                        50	12/23/16 7:52:37.981	luup_log:5: Arduino: Log: TSP:MSG:READ 3-3-0 s=255,c=3,t=24,pt=1,l=1,sg=0:1 <0x2d565680>
                        50	12/23/16 7:52:37.991	luup_log:5: Arduino: Log: TSP:MSG:PINGED (ID=3, hops=1) <0x2d565680>
                        50	12/23/16 7:52:38.001	luup_log:5: Arduino: Log: TSP:MSG:SEND 0-0-3-3 s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=ok:1 <0x2d565680>
                        50	12/23/16 7:52:38.003	luup_log:5: Arduino: Log: TSP:MSG:READ 3-3-0 s=255,c=3,t=15,pt=6,l=2,sg=0:0100 <0x2d565680>
                        50	12/23/16 7:52:38.011	luup_log:5: Arduino: Log: TSP:MSG:SEND 0-0-3-3 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100 <0x2d565680>
                        50	12/23/16 7:52:38.021	luup_log:5: Arduino: Log: TSP:MSG:READ 3-3-0 s=255,c=0,t=17,pt=0,l=10,sg=0:2.0.1-beta <0x2d565680>
                        50	12/23/16 7:52:38.022	luup_log:5: Arduino: Presentation: 3;255;0;0;17;2.0.1-beta <0x2d565680>
                        50	12/23/16 7:52:38.025	luup_log:5: Arduino: Log: TSP:MSG:READ 3-3-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0 <0x2d565680>
                        50	12/23/16 7:52:38.031	luup_log:5: Arduino: urn:micasaverde-com:serviceId:HaDevice1,LastUpdate, 1482472358, 7 <0x2d565680>
                        06	12/23/16 7:52:38.031	Device_Variable::m_szValue_set device: 7 service: urn:micasaverde-com:serviceId:HaDevice1 variable: LastUpdate was: 1482411882 now: 1482472358 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x2d565680>
                        50	12/23/16 7:52:38.033	luup_log:5: Arduino: urn:micasaverde-com:serviceId:HaDevice1,LastUpdateHR, 07:52, 7 <0x2d565680>
                        06	12/23/16 7:52:38.033	Device_Variable::m_szValue_set device: 7 service: urn:micasaverde-com:serviceId:HaDevice1 variable: LastUpdateHR was: 15:04 now: 07:52 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x2d565680>
                        50	12/23/16 7:52:38.034	luup_log:5: Arduino: urn:upnp-arduino-cc:serviceId:arduinonode1,RelayNode, 0, 7 <0x2d565680>
                        50	12/23/16 7:52:38.035	luup_log:5: Arduino: urn:upnp-arduino-cc:serviceId:arduinonode1,RelayNodeHR, GW, 7 <0x2d565680>
                        50	12/23/16 7:52:38.036	luup_log:5: Arduino: Sending: 3;255;3;0;6;M <0x2d565680>
                        50	12/23/16 7:52:38.061	luup_log:5: Arduino: Log: TSP:MSG:SEND 0-0-3-3 s=255,c=3,t=6,pt=0,l=1,sg=0,ft=0,st=ok:M <0x2d565680>
                        50	12/23/16 7:52:38.261	luup_log:5: Arduino: Log: TSP:MSG:READ 3-3-0 s=255,c=3,t=11,pt=0,l=7,sg=0:TempLux <0x2d565680>
                        50	12/23/16 7:52:38.263	luup_log:5: Arduino: urn:upnp-arduino-cc:serviceId:arduinonode1,SketchName, TempLux, 7 <0x2d565680>
                        50	12/23/16 7:52:38.265	luup_log:5: Arduino: Log: TSP:MSG:READ 3-3-0 s=255,c=3,t=12,pt=0,l=3,sg=0:2.0 <0x2d565680>
                        50	12/23/16 7:52:38.270	luup_log:5: Arduino: urn:upnp-arduino-cc:serviceId:arduinonode1,SketchVersion, 2.0, 7 <0x2d565680>
                        50	12/23/16 7:52:38.461	luup_log:5: Arduino: Log: TSP:MSG:READ 3-3-0 s=20,c=0,t=16,pt=0,l=0,sg=0: <0x2d565680>
                        50	12/23/16 7:52:38.462	luup_log:5: Arduino: Presentation: 3;20;0;0;16; <0x2d565680>
                        50	12/23/16 7:52:38.463	luup_log:5: Arduino: Found new device 3;20 <0x2d565680>
                        50	12/23/16 7:52:38.464	luup_log:5: Arduino: urn:upnp-arduino-cc:serviceId:arduino1,InclusionFoundCountHR, 1 devices found, 5 <0x2d565680>
                        06	12/23/16 7:52:38.465	Device_Variable::m_szValue_set device: 5 service: urn:upnp-arduino-cc:serviceId:arduino1 variable: InclusionFoundCountHR was: 0 devices found now: 1 devices found #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x2d565680>
                        50	12/23/16 7:52:38.471	luup_log:5: Arduino: Log: TSP:MSG:READ 3-3-0 s=0,c=0,t=6,pt=0,l=0,sg=0: <0x2d565680>
                        50	12/23/16 7:52:38.472	luup_log:5: Arduino: Presentation: 3;0;0;0;6; <0x2d565680>
                        50	12/23/16 7:52:38.474	luup_log:5: Arduino: Log: TSP:MSG:READ 3-3-0 s=255,c=3,t=26,pt=1,l=1,sg=0:2 <0x2d565680>
                        50	12/23/16 7:52:38.521	luup_log:5: Arduino: Log: !TSP:MSG:SEND 0-0-3-3 s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=fail:1 <0x2d565680>
                        50	12/23/16 7:52:39.041	luup_log:5: Arduino: Log: TSP:MSG:READ 3-3-0 s=20,c=1,t=23,pt=2,l=2,sg=0:912 <0x2d565680>
                        50	12/23/16 7:52:39.042	luup_log:5: Arduino: Set variable: 3;20;1;0;23;912 <0x2d565680>
                        50	12/23/16 7:52:39.901	luup_log:5: Arduino: Log: TSP:MSG:READ 3-3-0 s=0,c=1,t=0,pt=7,l=5,sg=0:22.6 <0x2d565680>
                        50	12/23/16 7:52:39.902	luup_log:5: Arduino: Set variable: 3;0;1;0;0;22.6 <0x2d565680>
                        50	12/23/16 7:52:39.903	luup_log:5: Arduino: Setting variable 'CurrentTemperature' to value '22.6' <0x2d565680>
                        50	12/23/16 7:52:39.904	luup_log:5: Arduino: urn:upnp-org:serviceId:TemperatureSensor1,CurrentTemperature, 22.6, 6 <0x2d565680>
                        06	12/23/16 7:52:39.905	Device_Variable::m_szValue_set device: 6 service: urn:upnp-org:serviceId:TemperatureSensor1 variable: CurrentTemperature was: 23.1 now: 22.6 #hooks: 0 upnp: 0 skip: 0 v:0xbcdf98/NONE duplicate:0 <0x2d565680>
                        50	12/23/16 7:52:39.906	luup_log:5: Arduino: urn:micasaverde-com:serviceId:HaDevice1,LastUpdate, 1482472359, 6 <0x2d565680>
                        06	12/23/16 7:52:39.906	Device_Variable::m_szValue_set device: 6 service: urn:micasaverde-com:serviceId:HaDevice1 variable: LastUpdate was: 1482411882 now: 1482472359 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x2d565680>
                        50	12/23/16 7:52:39.907	luup_log:5: Arduino: urn:micasaverde-com:serviceId:HaDevice1,LastUpdate, 1482472359, 7 <0x2d565680>
                        06	12/23/16 7:52:39.908	Device_Variable::m_szValue_set device: 7 service: urn:micasaverde-com:serviceId:HaDevice1 variable: LastUpdate was: 1482472358 now: 1482472359 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x2d565680>
                        50	12/23/16 7:52:39.909	luup_log:5: Arduino: urn:micasaverde-com:serviceId:HaDevice1,LastUpdateHR, 07:52, 7 <0x2d565680>
                        08	12/23/16 7:53:00.180	JobHandler_LuaUPnP::HandleActionRequest device: 0 service: urn:micasaverde-com:serviceId:HomeAutomationGateway1 action: LogIpRequest <0x2e565680>
                        08	12/23/16 7:53:00.181	JobHandler_LuaUPnP::HandleActionRequest argument serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1 <0x2e565680>
                        08	12/23/16 7:53:00.181	JobHandler_LuaUPnP::HandleActionRequest argument action=LogIpRequest <0x2e565680>
                        08	12/23/16 7:53:00.182	JobHandler_LuaUPnP::HandleActionRequest argument IpAddress=192.168.1.6 <0x2e565680>
                        08	12/23/16 7:53:00.182	JobHandler_LuaUPnP::HandleActionRequest argument MacAddress=e0:5f:45:12:68:73 <0x2e565680>
                        08	12/23/16 7:53:03.507	JobHandler_LuaUPnP::HandleActionRequest device: 5 service: urn:upnp-arduino-cc:serviceId:arduino1 action: StopInclusion <0x2e565680>
                        08	12/23/16 7:53:03.507	JobHandler_LuaUPnP::HandleActionRequest argument DeviceNum=5 <0x2e565680>
                        08	12/23/16 7:53:03.508	JobHandler_LuaUPnP::HandleActionRequest argument serviceId=urn:upnp-arduino-cc:serviceId:arduino1 <0x2e565680>
                        08	12/23/16 7:53:03.508	JobHandler_LuaUPnP::HandleActionRequest argument action=StopInclusion <0x2e565680>
                        50	12/23/16 7:53:03.510	luup_log:5: Arduino: Sending: 0;0;3;0;5;0 <0x2b51c310>
                        04	12/23/16 7:53:03.512	 <0x2b51c310>
                        50	12/23/16 7:53:03.521	luup_log:5: Arduino: urn:upnp-arduino-cc:serviceId:arduino1,InclusionMode, 0, 5 <0x2d565680>
                        06	12/23/16 7:53:03.521	Device_Variable::m_szValue_set device: 5 service: urn:upnp-arduino-cc:serviceId:arduino1 variable: InclusionMode was: 1 now: 0 #hooks: 0 upnp: 0 skip: 0 v:0xbb2eb8/NONE duplicate:0 <0x2d565680>
                        50	12/23/16 7:53:03.522	luup_log:5: Arduino: urn:upnp-arduino-cc:serviceId:arduino1,InclusionFoundCountHR, , 5 <0x2d565680>
                        06	12/23/16 7:53:03.523	Device_Variable::m_szValue_set device: 5 service: urn:upnp-arduino-cc:serviceId:arduino1 variable: InclusionFoundCountHR was: 1 devices found now:  #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x2d565680>
                        50	12/23/16 7:53:03.524	luup_log:5: Arduino: Inclusion mode ended. <0x2d565680>
                        02	12/23/16 7:53:03.525	luup_log:5: Arduino: Found new sensor(s). Need to restart. Please wait. <0x2d565680>
                        09	12/23/16 7:53:03.528	Child_Devices::ProcessChildDevice created device 10 id 3;20 under 5 topmost parent 5 <0x2d565680>
                        Here is what it looks like when the device receives a value:
                        50	12/23/16 7:54:15.122	luup_log:5: Arduino: Log: TSP:SANCHK:OK <0x2e07b680>
                        50	12/23/16 7:54:52.352	luup_log:5: Arduino: Log: TSP:MSG:READ 3-3-0 s=20,c=1,t=23,pt=2,l=2,sg=0:913 <0x2e07b680>
                        50	12/23/16 7:54:52.354	luup_log:5: Arduino: Set variable: 3;20;1;0;23;913 <0x2e07b680>
                        50	12/23/16 7:54:52.354	luup_log:5: Arduino: Setting variable 'CurrentLevel' to value '913' <0x2e07b680>
                        50	12/23/16 7:54:52.355	luup_log:5: Arduino: urn:micasaverde-com:serviceId:LightSensor1,CurrentLevel, 913, 10 <0x2e07b680>
                        06	12/23/16 7:54:52.356	Device_Variable::m_szValue_set device: 10 service: urn:micasaverde-com:serviceId:LightSensor1 variable: CurrentLevel was: EMPTY now: 913 #hooks: 0 upnp: 0 skip: 0 v:0x911d88/NONE duplicate:0 <0x2e07b680>
                        50	12/23/16 7:54:52.357	luup_log:5: Arduino: urn:micasaverde-com:serviceId:HaDevice1,LastUpdate, 1482472492, 10 <0x2e07b680>
                        • Tomas
                        • dbemowskD
                          dbemowskD
                          I placed a call to Vera yesterday The lady that I spoke with wasn't able to get anywhere and suggested that I email support@getvera.com and to leave remote assistance on. I referenced this thread in the email. Hopefully they will get back to me sometime today.
                          • dbemowskD
                            dbemowskD
                            Another thing. Last night I decided that I would try getting some of my X10 stuff going with the Mochad X10 Gateway plugin. I seem to be having trouble with that too. I thought I would then just uninstall the plugin and wait for the Vera team to do their thing today, but it won't let me uninstall the plugin now. I click uninstall, it asks if I am sure I want to uninstall, I say yes, the green spinner comes up for about 10 seconds and then it says "Error uninstalling app, please try again".
                            I have owned this box for going on a week now and I don't have anything running on it yet.
                            • dbemowskD
                              dbemowskD
                              So, a question I have on this. Does Vera automatically define IDs for sensors or do I need to define them in my sketches?
                              • dbemowskD
                                dbemowskD
                                Can anyone tell me what this means? Specifically the lines that end in "discarded for child: nil". In the Vera log, these lines show in yellow.
                                50	12/25/16 23:01:50.974	luup_log:10: Arduino: Log: TSP:MSG:READ 4-4-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0 <0x7438f520>
                                02	12/25/16 23:01:50.975	luup_log:10: Arduino: Incoming internal command '4;255;3;0;6;0' discarded for child: nil <0x7438f520>
                                50	12/25/16 23:01:51.692	luup_log:10: Arduino: Log: TSP:MSG:READ 20-20-0 s=3,c=2,t=47,pt=0,l=0,sg=0: <0x7438f520>
                                50	12/25/16 23:01:51.693	luup_log:10: Arduino: Request: 20;3;2;0;47; <0x7438f520>
                                50	12/25/16 23:01:51.693	luup_log:10: Arduino: Requesting status for: 20;3 <0x7438f520>
                                50	12/25/16 23:01:52.728	luup_log:10: Arduino: Log: TSP:MSG:READ 20-20-0 s=0,c=1,t=0,pt=7,l=5,sg=0:21.11 <0x7438f520>
                                50	12/25/16 23:01:52.729	luup_log:10: Arduino: Set variable: 20;0;1;0;0;21.11 <0x7438f520>
                                50	12/25/16 23:01:52.735	luup_log:10: Arduino: Log: TSP:MSG:READ 20-20-0 s=0,c=1,t=44,pt=7,l=5,sg=0:21.11 <0x7438f520>
                                50	12/25/16 23:01:52.738	luup_log:10: Arduino: Set variable: 20;0;1;0;44;21.11 <0x7438f520>
                                50	12/25/16 23:01:52.743	luup_log:10: Arduino: Log: TSP:MSG:READ 20-20-0 s=0,c=1,t=45,pt=7,l=5,sg=0:21.11 <0x7438f520>
                                50	12/25/16 23:01:52.747	luup_log:10: Arduino: Set variable: 20;0;1;0;45;21.11 <0x7438f520>
                                50	12/25/16 23:01:52.763	luup_log:10: Arduino: Log: TSP:MSG:READ 20-20-0 s=0,c=1,t=44,pt=7,l=5,sg=0:27.22 <0x7438f520>
                                50	12/25/16 23:01:52.765	luup_log:10: Arduino: Set variable: 20;0;1;0;44;27.22 <0x7438f520>
                                50	12/25/16 23:01:52.966	luup_log:10: Arduino: Log: TSP:MSG:READ 4-4-0 s=255,c=3,t=11,pt=0,l=12,sg=0:MyGarageDoor <0x7438f520>
                                02	12/25/16 23:01:52.968	luup_log:10: Arduino: Incoming internal command '4;255;3;0;11;MyGarageDoor' discarded for child: nil <0x7438f520>
                                50	12/25/16 23:01:52.976	luup_log:10: Arduino: Log: TSP:MSG:READ 4-4-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.2 <0x7438f520>
                                02	12/25/16 23:01:52.977	luup_log:10: Arduino: Incoming internal command '4;255;3;0;12;1.2' discarded for child: nil <0x7438f520>
                                50	12/25/16 23:01:52.980	luup_log:10: Arduino: Log: TSP:MSG:READ 4-4-0 s=0,c=0,t=3,pt=0,l=0,sg=0: <0x7438f520>
                                • dbemowskD
                                  dbemowskD
                                  So I got a response from Vera on my issue. Here was their response:
                                  I’ve checked your unit and the Arduino is flooding the Vera in a such way that it is crashing the engine. There is a configuration on the Arduino that is flooding the Vera unit or maybe there is an issue with the Arduino directly. Can’t tell for sure.
                                  CUT some log info CUT
                                  If you remove the Arduino from the Vera, the engine will stop flooding and you will be able to access it the Vera unit and check it.
                                  Once you do that and check the configuration of the Arduino and also check to see if everything is alright with it, you will be able to plug it back in and the engine should not crash anymore and you shall be able to use the MySensor.
                                  With the configuration of the sensor you will need to check with MySensor directly as they have this information.
                                  Anyways, so I found that I had my thermostat bridge updating too often which was what was causing the supposed flooding. The bridge worked fine with Domoticz, so I really don't think that was the issue, though I could tone down the updates from it. I am not sure how he determined that it was crashing the engine, but for now I have the bridge disconnected and not flooding the gateway, and I still cannot add sensors.
                                  Any help that anyone can provide would be GREATLY appreciated. I have had the unit for over a week now and cannot add my MySensors devices.
                                  One good thing though, I did finally resolve the issue with my 1-wire server and I at least have my temp sensors online.
                                  Thanks guys
                                  • korttomaK
                                    korttomaK
                                    korttoma
                                    #32
                                    Sorry I could not assist you during the holidays, I took a brake from tinkering and spent time with the family.
                                    I saw that you managed to narrow down the Vera MySensors issue to the FTDI adapter in the other thread.
                                    Just thought I would add the link to this in case someone else experiences the same problem, although it seems quite rare that this happens since you are the only one we know of so far.
                                    Lets hope your continued use of MySensors in Vera is smooth sailing from now on.
                                    • Tomas
                                      dbemowskD
                                      dbemowskD
                                      @korttoma Thanks. I completely understand the need for family.I should have thought to link the two topics myself.
                                      So far, since changing the FTDI adapter things have been for the most part smooth. The only thing I am having an issue with is my thermostat bridge node. Details are in this thread if you have any suggestions.
