  3. Vera
  4. Brand new Vera controller
33 Posts 5 Posters 15.3k Views 5 Watching
  • dbemowskD dbemowsk
    @korttoma I did get the plugin created and I do see the message to set up the serial port. I went to Develop Apps>Serial Port Configuration and it shows nothing available. I have an FTDI adapter connected to a 4 port hub. Currently the FTDI adapter is the only thing plugged into the hub. When I SSH into the unit and issue this:
    dmesg | grep USB
    I get this:
    [    4.012000] xhci-hcd xhci-hcd: new USB bus registered, assigned bus number 1
    [    4.040000] hub 1-0:1.0: USB hub found
    [    4.064000] xhci-hcd xhci-hcd: new USB bus registered, assigned bus number 2
    [    4.080000] hub 2-0:1.0: USB hub found
    [    4.120000] usbserial: USB Serial support registered for generic
    [    4.528000] usb 1-2: new high-speed USB device number 2 using xhci-hcd
    [    5.860000] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
    [   17.564000] usbserial: USB Serial support registered for Belkin / Peracom / GoHubs USB Serial Adapter
    [   17.600000] usbserial: USB Serial support registered for cp210x
    [   17.632000] usbserial: USB Serial support registered for FTDI USB Serial Device
    [   17.712000] usbserial: USB Serial support registered for Keyspan - (without firmware)
    [   17.728000] usbserial: USB Serial support registered for Keyspan 1 port adapter
    [   17.744000] usbserial: USB Serial support registered for Keyspan 2 port adapter
    [   17.760000] usbserial: USB Serial support registered for Keyspan 4 port adapter
    [   17.788000] usbserial: USB Serial support registered for MCT U232
    [   17.888000] usbserial: USB Serial support registered for pl2303
    [   17.948000] usbserial: USB Serial support registered for Sierra USB modem
    [   18.172000] usbserial: USB Serial support registered for IPWireless converter
    [   18.216000] usbserial: USB Serial support registered for GSM modem (1-port)
    [   18.264000] usbserial: USB Serial support registered for Qualcomm USB modem
    I thought it was the pl2303, but when I checked the "/dev" folder, I did not see a ttyUSBx device, so I knew that couldn't be it. I plugged a power adapter into the hub and tried again, this time when I did:
    dmesg | grep tty
    I got this:
    [ 1703.300000] usb 1-1.1: pl2303 converter now attached to ttyUSB0
    Then when I went back to Vera serial port configuration I saw it. I set the baud to 115200, and "Used By Device" to "MySensors Plugin[]"
    Now when I go to Devices, I see the MySensors Plugin "Connected to: 20(115200)". Now I am not sure how to add my device nodes.
    korttomaK
    korttomaK
    korttoma
    So far so good ;)
    You should see the text "Press start for inclusion" and a Start and Stop button on the Plugin Main Device. Now all you need to do is push the "Start" button to start "inclusion mode" and then you restart your sensor so that it can present itself.
    If new sensors are detected when in inclusion mode you should see the text "X devices found" Inclusion mode is active for 1 min. If new sensors are found the Vera will automatically restart the luup engine and create the devices. Wait until you are sure the restart is done and then "ctrl + F5" to refresh your browser.
    Your new devices should now be found under -> Devices -> No Room. If not all child sensors are found just try the inclusion again (sometimes I restart the node a few times while the inclusion mode is active so that all devices are picked up).
    Good luck ;)
    • Tomas
    dbemowskD 1 Reply Last reply
    • korttomaK korttoma
      So far so good ;)
      Good luck ;)
      dbemowskD
      dbemowskD
      @korttoma So I see this when I press the arrow next to the plugin icon under devices:
      0_1482191806960_upload-d5a6e29d-95c0-4cfb-b69e-bfb2ba193105
      So I click the arrow next to settings and I see this, which is what you are talking about:
      0_1482191925426_upload-bb13f11e-7656-47b0-b944-bd538c100cdc
      When I press Start I get this error:
      0_1482192017041_upload-4f04b3f4-c957-49a2-b6e0-42c11f12f2b5
      One other thing, I cannot change the Unit selector just above the Start/Stop buttons. I don't know if these two things are related in any way, but thought I'd mention it in case they are.
      blaceyB 1 Reply Last reply
      • korttomaK
        korttomaK
        korttoma
        Hi @dbemowsk this does not seem right at all.
        Here is what it should look like:
        The Plugin Main device looks like this with the Start/Stop button, you should be able to operate it from here:
        0_1482210522232_upload-21bcd566-efbf-471e-9fd1-71b7cba5708a
        Under settings it should look like this:
        0_1482210573835_upload-809306f4-08ae-4ed3-a29e-a99387f0d318
        And when you press start it should look like this:
        0_1482210608095_upload-9baeb4ae-44d0-4a08-9bbb-4a54dcf07c5a
        Are you sure you used the files from here?
        Try uploading the files again and then try the luup reload a few times and then browser refresh.
        • Tomas
          blaceyB
          blaceyB
          blacey
          @dbemowsk You might want to try some of the steps detailed in this thread https://forum.mysensors.org/topic/5289/ui5-to-ui7-update/14 to confirm that you have the right versions of the plugin files installed.
            dbemowskD
            dbemowskD
            @korttoma One other thing I am seeing is an error at the top of the screen.
            GET_LANG(system_error,System error) : Device: 8. Fail to load implementation file D_Codeset_1104.xml.lzo
            My Vera firmware version is 1.7.2138 if that makes a difference.
            I downloaded the UI7 files from the same github link that you posted. I even tried the steps from the link that blacey posted. This to me seemed like a slightly different set of plugin files. The zip file that I downloaded from https://github.com/mysensors/Vera/tree/UI7 created a folder named "Vera-UI7". The one I downloaded from blacey's link, https://api.github.com/repos/mysensors/Vera/zipball/UI7 created a folder named "mysensors-Vera-73ed9b7". I used meld to diff the 2 folders and I found that the files in both folders are identical.
            Is there any other information I can give you that will help me solve this issue?
            korttomaK 1 Reply Last reply
              korttomaK
              korttomaK
              korttoma
              @dbemowsk the GET_LANG system error is a new one for me is Device 8 the MySensors Plugin Main device? You can check this if you press the arrow and then go to the Advanced. Under Params there is a variable valled "id". This is the device id.
              I see allso form your previous pictures that the overall system state of your Vera says "Your installation is not complete" I wonder if this is causing problems if you have not set up your location properties properly.
              Maybe you should try completing the setup of your Vera first.
              • Tomas
                dbemowskD
                dbemowskD
                @korttoma I am not sure what device 8 is. The MySensors device is 5 if I am reading this correctly:
                0_1482233434375_upload-1a51477f-da6a-4104-b784-a23c1479f18c
                I am assuming that this is what you are referring to when you say "Your installation is not complete" :
                0_1482233069559_upload-d4ccb584-2cf1-4f04-9166-7f07866b332b
                That was in the beginning, but if you notice it says "still no device is connected". I am sure that is why it says it is not complete. Here is the current status from the dashboard:
                0_1482233191770_upload-78cce839-acee-4e1a-b81e-e45bf2750ee9
                I am beginning to wondering if I shouldn't do a factory reset and start over. I think before I do that I am going to use the "COntact Customer Care" button.
                  korttomaK
                  korttomaK
                  korttoma
                  @dbemowsk Seems like the GET_LANG system error is not related to MySensors then. What else have you installed? Can you find this Device 8?
                  Contacting Customer Care is a good idea but then you have to be patient because it can take a days before you get any answer and if you have not enabled the remote access and sent them the code they will just ask you to do this in their first answer and then you might have to wait for days again.
                  Also take a look at the thread @blacey mentioned about how you could check that the plugin files are correct.
                  • Tomas
                  • korttomaK
                    korttomaK
                    korttoma
                    I found this in the Vera forums:
                    The GET_LANG(system_error,System error) is a small displaying error caused by our language tool that failed to import this language token.
                    Regarding "Fail to load implementation file" issue, due to an old bug that we fixed recently, this message was not displayed. It appears when the implementation file for a device is not found on the gateway of the device parameters are wrong specified. This can be caused by manually created device from what I could see after debugging some units with this issue. To fix this issue you will need to delete the device that is showing the error like this :
                    Code: [Select]
                    http://gateway_address:3480/data_request?id=device&action=delete&device=device_id
                    • Tomas
                    • R
                      R
                      r-nox
                      As a side not I see Lib version is blank in the screen shot...
                      • R r-nox
                        dbemowskD
                        dbemowskD
                        @r-nox What should the lib version be?
                        So just to rule out other things that I may have done when trying to install some other apps, which by the way may have caused the error with device 8, I did a factory reset of the device and ran through the setup one more time. With the reset I was upgraded to a newer firmware version (1.7.2414). I re-uploaded the arduino files and created the device using the instructions on the MySensors website under the Vera controller. One thing I found curious is that when creating the device, the only thing it says to fill in on the "Create Device" page is the "Upnp Device FIlename". I was surprised that I didn't have to fill in any of the other fields such as the "Device Type" or the "Upnp Implementation Filename" . Again the device was created, and I configured the serial port as follows:
                        0_1482278094094_upload-77a5482c-8792-41c9-9463-56f600f57f1f
                        When I go to devices, things look the same as before. Here are the current screen shots:
                        0_1482278193935_upload-9b95e586-53cc-4411-a5d0-a0aa5e4f1790
                        0_1482278255917_upload-53ab1756-8086-4cb4-b701-8919f549e465
                        0_1482278300939_upload-f1ab41ae-c846-4eaf-a386-7ea4d06de141
                        0_1482278460104_upload-5287611b-e9df-4642-984a-e0838820878e
                        • korttomaK
                          korttomaK
                          korttoma
                          Hi @dbemowsk
                          You setup stil looked different from mine so I decided to wipe my VeraLite clean and see what I get.
                          Now my setup looks exactly like yours except I did get the Lib version ( witch should show the Library version used in your MySensors Gateway ) efter hitting the reset button on my GW arduino and restart the Luup engine a few times.
                          Then when I press the "Start" button I get the text bellow the buttons like this:
                          0_1482299688258_upload-09006f39-4dfb-4f7d-a232-97ff83a1e1ff
                          As I then restart a Sensor node the number count up according to the devices found and when I know it has fund them all I press "Stop". Then the luup engine restarts automatically and the new devices are created.
                          I hit ctrl + F5 to refresh my browser and then go to devises and find this:
                          0_1482299875190_upload-6e2835cc-1739-452c-96f8-e99164019fae
                          So I think your system is fine, you just need to restart the GW and run a few luup restarts and refresh your browser. Then try including a Sensor.
                          • Tomas
                            Hi @dbemowsk
                            dbemowskD
                            dbemowskD
                            @korttoma Is there any kind of command line serial monitor that I can use on the Vera to test my gateway communication coming into it? If not, that may be something for them to include on the unit. I double checked my wiring from my USB FTDI adapter to the gateway last night and I have my 3 wires as follows:
                            FTDI.......GW
                            GND ----GND
                            TX --------- RX
                            RX --------- TX
                            I tried hitting the reset button on the gateway a number of times and restarted the luup engine a few times and also rebooted the Vera a few times. That is why I want to test that the Vera is receiving data from the FTDI properly.
                            I am betting that it is something that I am doing wrong, and I am going to kick myself in the arse when I figure out what it is.
                            J 1 Reply Last reply
                            • korttomaK
                              korttomaK
                              korttoma
                              You can see the vera log file if you enter this adress in your browser
                              http://<YourVeraIP>/cgi-bin/cmh/log.sh?Device=LuaUPnP
                              • Tomas
                                FTDI.......GW
                                GND ----GND
                                TX --------- RX
                                RX --------- TX
                                J
                                J
                                jlieffort
                                @dbemowsk
                                Check out this tool if you don't know about it already.
                                https://www.mysensors.org/controller/myscontroller
                                • J jlieffort
                                  @dbemowsk
                                  dbemowskD
                                  dbemowskD
                                  @jlieffort I know about this tool, but this will not help. I need to debug the serial connection from my gateway to my Vera controller. This is a Windows based tool.
                                  • dbemowskD
                                    dbemowskD
                                    OK, I have an update with some log information, thanks @korttoma for the link. This is a snipet of the log:
                                    50	12/22/16 6:06:48.240	luup_log:9: Arduino: Requesting status for: 20;3 <0x74229520>
                                    50	12/22/16 6:06:49.270	luup_log:9: Arduino: Log: TSP:MSG:READ 20-20-0 s=0,c=1,t=0,pt=7,l=5,sg=0:19.44 <0x74229520>
                                    50	12/22/16 6:06:49.274	luup_log:9: Arduino: Set variable: 20;0;1;0;0;19.44 <0x74229520>
                                    50	12/22/16 6:06:49.279	luup_log:9: Arduino: Log: TSP:MSG:READ 20-20-0 s=0,c=1,t=44,pt=7,l=5,sg=0:18.89 <0x74229520>
                                    50	12/22/16 6:06:49.280	luup_log:9: Arduino: Set variable: 20;0;1;0;44;18.89 <0x74229520>
                                    50	12/22/16 6:06:49.297	luup_log:9: Arduino: Log: TSP:MSG:READ 20-20-0 s=0,c=1,t=45,pt=7,l=5,sg=0:18.89 <0x74229520>
                                    50	12/22/16 6:06:49.298	luup_log:9: Arduino: Set variable: 20;0;1;0;45;18.89 <0x74229520>
                                    50	12/22/16 6:06:49.305	luup_log:9: Arduino: Log: TSP:MSG:READ 20-20-0 s=0,c=1,t=44,pt=7,l=5,sg=0:27.22 <0x74229520>
                                    50	12/22/16 6:06:49.306	luup_log:9: Arduino: Set variable: 20;0;1;0;44;27.22 <0x74229520>
                                    50	12/22/16 6:06:49.857	luup_log:9: Arduino: Log: TSP:MSG:READ 20-20-0 s=2,c=2,t=47,pt=0,l=0,sg=0: <0x74229520>
                                    50	12/22/16 6:06:49.858	luup_log:9: Arduino: Request: 20;2;2;0;47; <0x74229520>
                                    50	12/22/16 6:06:49.859	luup_log:9: Arduino: Requesting status for: 20;2 <0x74229520>
                                    50	12/22/16 6:06:51.416	luup_log:9: Arduino: Log: TSP:MSG:READ 20-20-0 s=3,c=2,t=47,pt=0,l=0,sg=0: <0x74229520>
                                    50	12/22/16 6:06:51.417	luup_log:9: Arduino: Request: 20;3;2;0;47; <0x74229520>
                                    50	12/22/16 6:06:51.417	luup_log:9: Arduino: Requesting status for: 20;3 <0x74229520>
                                    50	12/22/16 6:06:52.445	luup_log:9: Arduino: Log: TSP:MSG:READ 20-20-0 s=0,c=1,t=0,pt=7,l=5,sg=0:19.44 <0x74229520>
                                    50	12/22/16 6:06:52.447	luup_log:9: Arduino: Set variable: 20;0;1;0;0;19.44 <0x74229520>
                                    50	12/22/16 6:06:52.496	luup_log:9: Arduino: Log: TSP:MSG:READ 20-20-0 s=0,c=1,t=45,pt=7,l=5,sg=0:18.89 <0x74229520>
                                    50	12/22/16 6:06:52.497	luup_log:9: Arduino: Set variable: 20;0;1;0;45;18.89 <0x74229520>
                                    50	12/22/16 6:06:53.090	luup_log:9: Arduino: Log: TSP:MSG:READ 20-20-0 s=2,c=2,t=47,pt=0,l=0,sg=0: <0x74229520>
                                    50	12/22/16 6:06:53.091	luup_log:9: Arduino: Request: 20;2;2;0;47; <0x74229520>
                                    50	12/22/16 6:06:53.091	luup_log:9: Arduino: Requesting status for: 20;2 <0x74229520>
                                    50	12/22/16 6:06:54.657	luup_log:9: Arduino: Log: TSP:MSG:READ 20-20-0 s=3,c=2,t=47,pt=0,l=0,sg=0: <0x74229520>
                                    50	12/22/16 6:06:54.657	luup_log:9: Arduino: Request: 20;3;2;0;47; <0x74229520>
                                    50	12/22/16 6:06:54.658	luup_log:9: Arduino: Requesting status for: 20;3 <0x74229520>
                                    50	12/22/16 6:06:55.160	luup_log:9: Arduino: Log: TSP:MSG:READ 255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0: <0x74229520>
                                    50	12/22/16 6:06:55.161	luup_log:9: Arduino: Log: TSP:MSG:BC <0x74229520>
                                    50	12/22/16 6:06:55.164	luup_log:9: Arduino: Log: TSP:MSG:FPAR REQ (sender=255) <0x74229520>
                                    50	12/22/16 6:06:55.165	luup_log:9: Arduino: Log: TSP:CHKUPL:OK <0x74229520>
                                    50	12/22/16 6:06:55.167	luup_log:9: Arduino: Log: TSP:MSG:GWL OK <0x74229520>
                                    50	12/22/16 6:06:55.750	luup_log:9: Arduino: Log: TSP:MSG:SEND 0-0-255-255 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=bc:0 <0x74229520>
                                    50	12/22/16 6:06:55.758	luup_log:9: Arduino: Log: TSP:MSG:READ 20-20-0 s=0,c=1,t=0,pt=7,l=5,sg=0:19.44 <0x74229520>
                                    50	12/22/16 6:06:55.761	luup_log:9: Arduino: Set variable: 20;0;1;0;0;19.44 <0x74229520>
                                    50	12/22/16 6:06:55.764	luup_log:9: Arduino: Log: TSP:MSG:READ 20-20-0 s=0,c=1,t=44,pt=7,l=5,sg=0:18.89 <0x74229520>
                                    50	12/22/16 6:06:55.765	luup_log:9: Arduino: Set variable: 20;0;1;0;44;18.89 <0x74229520>
                                    50	12/22/16 6:06:56.348	luup_log:9: Arduino: Log: TSP:MSG:READ 20-20-0 s=2,c=2,t=47,pt=0,l=0,sg=0: <0x74229520>
                                    50	12/22/16 6:06:56.349	luup_log:9: Arduino: Request: 20;2;2;0;47; <0x74229520>
                                    50	12/22/16 6:06:56.350	luup_log:9: Arduino: Requesting status for: 20;2 <0x74229520>
                                    50	12/22/16 6:06:57.178	luup_log:9: Arduino: Log: TSP:MSG:READ 255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0: <0x74229520>
                                    50	12/22/16 6:06:57.180	luup_log:9: Arduino: Log: TSP:MSG:BC <0x74229520>
                                    50	12/22/16 6:06:57.186	luup_log:9: Arduino: Log: TSP:MSG:FPAR REQ (sender=255) <0x74229520>
                                    50	12/22/16 6:06:57.188	luup_log:9: Arduino: Log: TSP:CHKUPL:OK (FLDCTRL) <0x74229520>
                                    50	12/22/16 6:06:57.189	luup_log:9: Arduino: Log: TSP:MSG:GWL OK <0x74229520>
                                    50	12/22/16 6:06:57.735	luup_log:9: Arduino: Log: TSP:MSG:SEND 0-0-255-255 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=bc:0 <0x74229520>
                                    50	12/22/16 6:06:57.920	luup_log:9: Arduino: Log: TSP:MSG:READ 20-20-0 s=3,c=2,t=47,pt=0,l=0,sg=0: <0x74229520>
                                    50	12/22/16 6:06:57.920	luup_log:9: Arduino: Request: 20;3;2;0;47; <0x74229520>
                                    50	12/22/16 6:06:57.921	luup_log:9: Arduino: Requesting status for: 20;3 <0x74229520>
                                    50	12/22/16 6:06:58.941	luup_log:9: Arduino: Log: TSP:MSG:READ 20-20-0 s=0,c=1,t=0,pt=7,l=5,sg=0:19.44 <0x74229520>
                                    50	12/22/16 6:06:58.943	luup_log:9: Arduino: Set variable: 20;0;1;0;0;19.44 <0x74229520>
                                    50	12/22/16 6:06:58.961	luup_log:9: Arduino: Log: TSP:MSG:READ 20-20-0 s=0,c=1,t=44,pt=7,l=5,sg=0:18.89 <0x74229520>
                                    50	12/22/16 6:06:58.962	luup_log:9: Arduino: Set variable: 20;0;1;0;44;18.89 <0x74229520>
                                    50	12/22/16 6:06:58.973	luup_log:9: Arduino: Log: TSP:MSG:READ 20-20-0 s=0,c=1,t=45,pt=7,l=5,sg=0:18.89
                                    To me that looks like the gateway is receiving data. As I scanned through the log though, I noticed this:
                                    01	12/22/16 4:29:02.122	UserData::WriteUserData saved--before move File Size: 4541 save size 4541 <0x77229520>
                                    02	12/22/16 4:29:02.122	UserData::TempLogFileSystemFailure start 0 <0x77229520>
                                    02	12/22/16 4:29:02.140	UserData::TempLogFileSystemFailure 4287 res:1
                                    -rw-r--r--    1 root     root            33 Dec 20 16:30 /etc/cmh/HW_Key
                                    -rw-r--r--    1 root     root            32 Dec 31  1999 /etc/cmh/HW_Key2
                                    -rw-r--r--    1 root     root             9 Dec 20 16:30 /etc/cmh/PK_AccessPoint
                                    -rw-r--r--    1 root     root             7 Dec 20 17:14 /etc/cmh/PK_Account
                                    -rw-r--r--    1 root     root           425 Dec 21 01:29 /etc/cmh/cmh.conf
                                    -rw-r--r--    1 root     root             0 Aug 22 08:36 /etc/cmh/devices
                                    -rw-r--r--    1 root     root         16383 Dec 21 03:00 /etc/cmh/dongle.4.5.dump.0
                                    -rw-r--r--    1 root     root            41 Dec 20 16:21 /etc/cmh/ergy_key
                                    -rw-r--r--    1 root     root             0 Aug 22 08:36 /etc/cmh/first_boot
                                    -rw-r--r--    1 root     root             0 Dec 21 01:25 /etc/cmh/fresh_install
                                    -rw-r--r--    1 root     root             1 Dec 21 01:52 /etc/cmh/ip_mode
                                    -rw-r--r--    1 root     root            48 Dec 31  1999 /etc/cmh/keys
                                    -rw-r--r--    1 root     root             3 Dec  9 09:30 /etc/cmh/language
                                    -rw-r--r--    1 root     root             2 Dec  9 09:30 /etc/cmh/language_id
                                    -rw-r--r--    1 root     root            10 Dec 21 16:34 /etc/cmh/last_backup
                                    -rw-r--r--    1 root     root            11 Dec 22 01:52 /etc/cmh/last_report
                                    -rw-r--r--    1 root     root            70 Dec 20 16:36 /etc/cmh/lighttpd_failures
                                    -rw-r--r--    1 root     root         36316 Oct  3 00:25 /etc/cmh/network_pnp.lua
                                    -rw-r--r--    1 root     root            12 Dec  9 09:30 /etc/cmh/platform
                                    -rw-r--r--    1 root     root           458 Oct  3 00:25 /etc/cmh/ra_key
                                    -rw-r--r--    1 root     root             0 Dec  9 09:30 /etc/cmh/scenarios
                                    -rw-r--r--    1 root     root          2032 Dec 20 16:30 /etc/cmh/servers.conf
                                    -rw-r--r--    1 root     root          1520 Aug 22 08:34 /etc/cmh/servers.conf.default
                                    -rw-r--r--    1 root     root            20 Dec 20 16:35 /etc/cmh/servers.conf.timestamp
                                    -rw-r--r--    1 root     root           154 Oct  3 00:25 /etc/cmh/servers_whitelist
                                    -rw-r--r--    1 root     root          1598 Dec 22 01:52 /etc/cmh/services.conf
                                    -rw-r--r--    1 root     root            20 Dec 20 16:19 /etc/cmh/sync_kit
                                    -rw-r--r--    1 root     root            20 Dec 20 16:19 /etc/cmh/sync_rediscover
                                    -rw-r--r--    1 root     root             2 Dec  9 09:30 /etc/cmh/ui
                                    -rw-r--r--    1 root     root             2 Dec  9 09:30 /etc/cmh/ui_man
                                    -rw-r--r--    1 root     root             5 Dec  9 09:30 /etc/cmh/ui_skin
                                    -rw-r--r--    1 root     root           504 Jul 22 09:31 /etc/cmh/user_data.json.luup.lzo
                                    -rw-r--r--    1 root     root          4541 Dec 22 02:41 /etc/cmh/user_data.json.lzo
                                    -rw-r--r--    1 root     root          4540 Dec 22 02:05 /etc/cmh/user_data.json.lzo.1
                                    -rw-r--r--    1 root     root          4540 Dec 21 23:17 /etc/cmh/user_data.json.lzo.2
                                    -rw-r--r--    1 root     root          4541 Dec 21 21:53 /etc/cmh/user_data.json.lzo.3
                                    -rw-r--r--    1 root     root          4547 Dec 21 21:23 /etc/cmh/user_data.json.lzo.4
                                    -rw-r--r--    1 root     root          4544 Dec 21 17:05 /etc/cmh/user_data.json.lzo.5
                                    -rw-r--r--    1 root     root          4541 Dec 22 04:29 /etc/cmh/user_data.json.lzo.new
                                    -rw-r--r--    1 root     root            21 Dec 20 17:14 /etc/cmh/users.conf
                                    -rw-r--r--    1 root     root            20 Dec 20 17:14 /etc/cmh/users.conf.timestamp
                                    -rw-r--r--    1 root     root             3 Aug 22 08:36 /etc/cmh/vera_model
                                    -rw-r--r--    1 root     root             9 Dec  9 09:30 /etc/cmh/version
                                    -rw-r--r--    1 root     root             9 Dec 21 21:24 /etc/cmh/version_latest
                                    -rw-r--r--    1 root     root             5 Dec 31  1999 /etc/cmh/zigbee_version
                                    -rw-r--r--    1 root     root             8 Dec 22 04:17 /etc/cmh/zwave_house_id
                                    -rw-r--r--    1 root     root             3 Dec 31  1999 /etc/cmh/zwave_locale
                                    -rw-r--r--    1 root     root            48 Dec 21 01:56 /etc/cmh/zwave_version
                                    /etc/cmh/orig:
                                    -rw-r--r--    1 root     root             0 Dec  9 09:30 devices
                                    -rw-r--r--    1 root     root             0 Dec  9 09:30 first_boot
                                    -rw-r--r--    1 root     root             0 Dec  9 09:30 fresh_install
                                    -rw-r--r--    1 root     root             0 Dec  9 09:30 scenarios
                                    -rw-r--r--    1 root     root           520 Dec  9 09:30 user_data.json.lzo
                                    /etc/cmh/wan_failover:
                                    -rw-r--r--    1 root     root            44 Jul 22 09:31 check_internet.hosts
                                     <0x77229520>
                                    02	12/22/16 4:29:02.204	UserData::TempLogFileSystemFailure start 0 <0x77229520>
                                    02	12/22/16 4:29:02.223	UserData::TempLogFileSystemFailure 4198 res:1
                                    -rw-r--r--    1 root     root          4541 Dec 22 02:41 /etc/cmh/user_data.json.lzo.1
                                    -rw-r--r--    1 root     root          4540 Dec 22 02:05 /etc/cmh/user_data.json.lzo.2
                                    -rw-r--r--    1 root     root          4540 Dec 21 23:17 /etc/cmh/user_data.json.lzo.3
                                    -rw-r--r--    1 root     root          4541 Dec 21 21:53 /etc/cmh/user_data.json.lzo.4
                                    -rw-r--r--    1 root     root          4547 Dec 21 21:23 /etc/cmh/user_data.json.lzo.5
                                    /etc/cmh/orig:
                                     <0x77229520>
                                    The things that say TempLogFileSystemFailure are a bit of a red flag for me.
                                    Also, here is a log of what happens when I hit the start button to start inclusion.
                                    50	12/22/16 6:12:44.804	luup_log:9: Arduino: Requesting status for: 20;2 <0x74229520>
                                    08	12/22/16 6:12:45.587	JobHandler_LuaUPnP::HandleActionRequest device: 9 service: urn:upnp-arduino-cc:serviceId:arduino1 action: StartInclusion <0x75429520>
                                    08	12/22/16 6:12:45.588	JobHandler_LuaUPnP::HandleActionRequest argument DeviceNum=9 <0x75429520>
                                    08	12/22/16 6:12:45.588	JobHandler_LuaUPnP::HandleActionRequest argument serviceId=urn:upnp-arduino-cc:serviceId:arduino1 <0x75429520>
                                    08	12/22/16 6:12:45.588	JobHandler_LuaUPnP::HandleActionRequest argument action=StartInclusion <0x75429520>
                                    50	12/22/16 6:12:45.590	luup_log:9: Arduino: Sending: 0;0;3;0;5;1 <0x77bf1320>
                                    04	12/22/16 6:12:45.593	 <0x77bf1320>
                                    50	12/22/16 6:12:46.361	luup_log:9: Arduino: Log: TSP:MSG:READ 20-20-0 s=3,c=2,t=47,pt=0,l=0,sg=0: <0x74229520>
                                    It looks as if inclusion mode is starting, but nothing is happening.
                                    Maybe one of you has some insight as to what all of this information means.
                                    • korttomaK
                                      korttomaK
                                      korttoma
                                      #24
                                      I'm not sure what to make of it, maybe @blacey, @petewill, @BartE or @hek could comment on this?
                                      • Tomas
                                      • dbemowskD
                                        dbemowskD
                                        #25
                                        I am leaving for work in a few minutes, but if I don't hear something by the time I get off work, I am going to call tech support. I REALLY appreciate the help everyone has given.
                                          korttomaK
                                          korttomaK
                                          korttoma
                                          Hi @dbemowsk ,
                                          I wish I could do more to help you. I took a look at the log in my test environment and I found that I also have this:
                                          Maybe this is something that is printed each time the device restarts?? Let me know if Vera support gives you any explanation for it.
                                          But the MySensors Part seems to work fine for me:
                                          Here the USB port gets connected and Vera receives the Lib version of the GW:
                                          50	12/23/16 7:51:43.454	luup_log:5: Arduino: Trying for a serial connection <0x2bf65680>
                                          50	12/23/16 7:51:43.454	luup_log:5: Arduino: Serial port is connected <0x2bf65680>
                                          50	12/23/16 7:51:43.455	luup_log:5: Arduino: Baud is 115200 <0x2bf65680>
                                          50	12/23/16 7:51:43.456	luup_log:5: Arduino: urn:upnp-arduino-cc:serviceId:arduino1,GWAddress, 4(115200), 5 <0x2bf65680>
                                          06	12/23/16 7:51:43.456	Device_Variable::m_szValue_set device: 5 service: urn:upnp-arduino-cc:serviceId:arduino1 variable: GWAddress was: - now: 4(115200) #hooks: 0 upnp: 0 skip: 0 v:0xbcbed0/NONE duplicate:0 <0x2bf65680>
                                          50	12/23/16 7:51:43.459	luup_log:5: Arduino: Sending: 0;0;3;0;2;Get Version <0x2bf65680>
                                          50	12/23/16 7:51:43.471	luup_log:5: Arduino: urn:upnp-arduino-cc:serviceId:arduino1,ArduinoLibVersion, 2.0.0, 5 <0x2d565680>
                                          Here is what it looks like when I start inclusion mode and find one device:
                                          50	12/23/16 7:52:20.057	luup_log:5: Arduino: Sending: 0;0;3;0;5;1 <0x2b51c310>
                                          04	12/23/16 7:52:20.059	 <0x2b51c310>
                                          50	12/23/16 7:52:20.070	luup_log:5: Arduino: urn:upnp-arduino-cc:serviceId:arduino1,InclusionMode, 1, 5 <0x2d565680>
                                          06	12/23/16 7:52:20.071	Device_Variable::m_szValue_set device: 5 service: urn:upnp-arduino-cc:serviceId:arduino1 variable: InclusionMode was: 0 now: 1 #hooks: 0 upnp: 0 skip: 0 v:0xbb2eb8/NONE duplicate:0 <0x2d565680>
                                          50	12/23/16 7:52:20.072	luup_log:5: Arduino: urn:upnp-arduino-cc:serviceId:arduino1,InclusionFoundCountHR, 0 devices found, 5 <0x2d565680>
                                          06	12/23/16 7:52:20.073	Device_Variable::m_szValue_set device: 5 service: urn:upnp-arduino-cc:serviceId:arduino1 variable: InclusionFoundCountHR was:  now: 0 devices found #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x2d565680>
                                          50	12/23/16 7:52:35.941	luup_log:5: Arduino: Log: TSP:MSG:READ 3-3-255 s=255,c=3,t=7,pt=0,l=0,sg=0: <0x2d565680>
                                          50	12/23/16 7:52:35.950	luup_log:5: Arduino: Log: TSP:MSG:BC <0x2d565680>
                                          50	12/23/16 7:52:35.952	luup_log:5: Arduino: Log: TSP:MSG:FPAR REQ (sender=3) <0x2d565680>
                                          50	12/23/16 7:52:35.954	luup_log:5: Arduino: Log: TSP:CHKUPL:OK <0x2d565680>
                                          50	12/23/16 7:52:35.955	luup_log:5: Arduino: Log: TSP:MSG:GWL OK <0x2d565680>
                                          50	12/23/16 7:52:36.711	luup_log:5: Arduino: Log: TSP:MSG:SEND 0-0-3-3 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=ok:0 <0x2d565680>
                                          50	12/23/16 7:52:37.981	luup_log:5: Arduino: Log: TSP:MSG:READ 3-3-0 s=255,c=3,t=24,pt=1,l=1,sg=0:1 <0x2d565680>
                                          50	12/23/16 7:52:37.991	luup_log:5: Arduino: Log: TSP:MSG:PINGED (ID=3, hops=1) <0x2d565680>
                                          50	12/23/16 7:52:38.001	luup_log:5: Arduino: Log: TSP:MSG:SEND 0-0-3-3 s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=ok:1 <0x2d565680>
                                          50	12/23/16 7:52:38.003	luup_log:5: Arduino: Log: TSP:MSG:READ 3-3-0 s=255,c=3,t=15,pt=6,l=2,sg=0:0100 <0x2d565680>
                                          50	12/23/16 7:52:38.011	luup_log:5: Arduino: Log: TSP:MSG:SEND 0-0-3-3 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100 <0x2d565680>
                                          50	12/23/16 7:52:38.021	luup_log:5: Arduino: Log: TSP:MSG:READ 3-3-0 s=255,c=0,t=17,pt=0,l=10,sg=0:2.0.1-beta <0x2d565680>
                                          50	12/23/16 7:52:38.022	luup_log:5: Arduino: Presentation: 3;255;0;0;17;2.0.1-beta <0x2d565680>
                                          50	12/23/16 7:52:38.025	luup_log:5: Arduino: Log: TSP:MSG:READ 3-3-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0 <0x2d565680>
                                          50	12/23/16 7:52:38.031	luup_log:5: Arduino: urn:micasaverde-com:serviceId:HaDevice1,LastUpdate, 1482472358, 7 <0x2d565680>
                                          06	12/23/16 7:52:38.031	Device_Variable::m_szValue_set device: 7 service: urn:micasaverde-com:serviceId:HaDevice1 variable: LastUpdate was: 1482411882 now: 1482472358 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x2d565680>
                                          50	12/23/16 7:52:38.033	luup_log:5: Arduino: urn:micasaverde-com:serviceId:HaDevice1,LastUpdateHR, 07:52, 7 <0x2d565680>
                                          06	12/23/16 7:52:38.033	Device_Variable::m_szValue_set device: 7 service: urn:micasaverde-com:serviceId:HaDevice1 variable: LastUpdateHR was: 15:04 now: 07:52 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x2d565680>
                                          50	12/23/16 7:52:38.034	luup_log:5: Arduino: urn:upnp-arduino-cc:serviceId:arduinonode1,RelayNode, 0, 7 <0x2d565680>
                                          50	12/23/16 7:52:38.035	luup_log:5: Arduino: urn:upnp-arduino-cc:serviceId:arduinonode1,RelayNodeHR, GW, 7 <0x2d565680>
                                          50	12/23/16 7:52:38.036	luup_log:5: Arduino: Sending: 3;255;3;0;6;M <0x2d565680>
                                          50	12/23/16 7:52:38.061	luup_log:5: Arduino: Log: TSP:MSG:SEND 0-0-3-3 s=255,c=3,t=6,pt=0,l=1,sg=0,ft=0,st=ok:M <0x2d565680>
                                          50	12/23/16 7:52:38.261	luup_log:5: Arduino: Log: TSP:MSG:READ 3-3-0 s=255,c=3,t=11,pt=0,l=7,sg=0:TempLux <0x2d565680>
                                          50	12/23/16 7:52:38.263	luup_log:5: Arduino: urn:upnp-arduino-cc:serviceId:arduinonode1,SketchName, TempLux, 7 <0x2d565680>
                                          50	12/23/16 7:52:38.265	luup_log:5: Arduino: Log: TSP:MSG:READ 3-3-0 s=255,c=3,t=12,pt=0,l=3,sg=0:2.0 <0x2d565680>
                                          50	12/23/16 7:52:38.270	luup_log:5: Arduino: urn:upnp-arduino-cc:serviceId:arduinonode1,SketchVersion, 2.0, 7 <0x2d565680>
                                          50	12/23/16 7:52:38.461	luup_log:5: Arduino: Log: TSP:MSG:READ 3-3-0 s=20,c=0,t=16,pt=0,l=0,sg=0: <0x2d565680>
                                          50	12/23/16 7:52:38.462	luup_log:5: Arduino: Presentation: 3;20;0;0;16; <0x2d565680>
                                          50	12/23/16 7:52:38.463	luup_log:5: Arduino: Found new device 3;20 <0x2d565680>
                                          50	12/23/16 7:52:38.464	luup_log:5: Arduino: urn:upnp-arduino-cc:serviceId:arduino1,InclusionFoundCountHR, 1 devices found, 5 <0x2d565680>
                                          06	12/23/16 7:52:38.465	Device_Variable::m_szValue_set device: 5 service: urn:upnp-arduino-cc:serviceId:arduino1 variable: InclusionFoundCountHR was: 0 devices found now: 1 devices found #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x2d565680>
                                          50	12/23/16 7:52:38.471	luup_log:5: Arduino: Log: TSP:MSG:READ 3-3-0 s=0,c=0,t=6,pt=0,l=0,sg=0: <0x2d565680>
                                          50	12/23/16 7:52:38.472	luup_log:5: Arduino: Presentation: 3;0;0;0;6; <0x2d565680>
                                          50	12/23/16 7:52:38.474	luup_log:5: Arduino: Log: TSP:MSG:READ 3-3-0 s=255,c=3,t=26,pt=1,l=1,sg=0:2 <0x2d565680>
                                          50	12/23/16 7:52:38.521	luup_log:5: Arduino: Log: !TSP:MSG:SEND 0-0-3-3 s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=fail:1 <0x2d565680>
                                          50	12/23/16 7:52:39.041	luup_log:5: Arduino: Log: TSP:MSG:READ 3-3-0 s=20,c=1,t=23,pt=2,l=2,sg=0:912 <0x2d565680>
                                          50	12/23/16 7:52:39.042	luup_log:5: Arduino: Set variable: 3;20;1;0;23;912 <0x2d565680>
                                          50	12/23/16 7:52:39.901	luup_log:5: Arduino: Log: TSP:MSG:READ 3-3-0 s=0,c=1,t=0,pt=7,l=5,sg=0:22.6 <0x2d565680>
                                          50	12/23/16 7:52:39.902	luup_log:5: Arduino: Set variable: 3;0;1;0;0;22.6 <0x2d565680>
                                          50	12/23/16 7:52:39.903	luup_log:5: Arduino: Setting variable 'CurrentTemperature' to value '22.6' <0x2d565680>
                                          50	12/23/16 7:52:39.904	luup_log:5: Arduino: urn:upnp-org:serviceId:TemperatureSensor1,CurrentTemperature, 22.6, 6 <0x2d565680>
                                          06	12/23/16 7:52:39.905	Device_Variable::m_szValue_set device: 6 service: urn:upnp-org:serviceId:TemperatureSensor1 variable: CurrentTemperature was: 23.1 now: 22.6 #hooks: 0 upnp: 0 skip: 0 v:0xbcdf98/NONE duplicate:0 <0x2d565680>
                                          50	12/23/16 7:52:39.906	luup_log:5: Arduino: urn:micasaverde-com:serviceId:HaDevice1,LastUpdate, 1482472359, 6 <0x2d565680>
                                          06	12/23/16 7:52:39.906	Device_Variable::m_szValue_set device: 6 service: urn:micasaverde-com:serviceId:HaDevice1 variable: LastUpdate was: 1482411882 now: 1482472359 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x2d565680>
                                          50	12/23/16 7:52:39.907	luup_log:5: Arduino: urn:micasaverde-com:serviceId:HaDevice1,LastUpdate, 1482472359, 7 <0x2d565680>
                                          06	12/23/16 7:52:39.908	Device_Variable::m_szValue_set device: 7 service: urn:micasaverde-com:serviceId:HaDevice1 variable: LastUpdate was: 1482472358 now: 1482472359 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x2d565680>
                                          50	12/23/16 7:52:39.909	luup_log:5: Arduino: urn:micasaverde-com:serviceId:HaDevice1,LastUpdateHR, 07:52, 7 <0x2d565680>
                                          08	12/23/16 7:53:00.180	JobHandler_LuaUPnP::HandleActionRequest device: 0 service: urn:micasaverde-com:serviceId:HomeAutomationGateway1 action: LogIpRequest <0x2e565680>
                                          08	12/23/16 7:53:00.181	JobHandler_LuaUPnP::HandleActionRequest argument serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1 <0x2e565680>
                                          08	12/23/16 7:53:00.181	JobHandler_LuaUPnP::HandleActionRequest argument action=LogIpRequest <0x2e565680>
                                          08	12/23/16 7:53:00.182	JobHandler_LuaUPnP::HandleActionRequest argument IpAddress=192.168.1.6 <0x2e565680>
                                          08	12/23/16 7:53:00.182	JobHandler_LuaUPnP::HandleActionRequest argument MacAddress=e0:5f:45:12:68:73 <0x2e565680>
                                          08	12/23/16 7:53:03.507	JobHandler_LuaUPnP::HandleActionRequest device: 5 service: urn:upnp-arduino-cc:serviceId:arduino1 action: StopInclusion <0x2e565680>
                                          08	12/23/16 7:53:03.507	JobHandler_LuaUPnP::HandleActionRequest argument DeviceNum=5 <0x2e565680>
                                          08	12/23/16 7:53:03.508	JobHandler_LuaUPnP::HandleActionRequest argument serviceId=urn:upnp-arduino-cc:serviceId:arduino1 <0x2e565680>
                                          08	12/23/16 7:53:03.508	JobHandler_LuaUPnP::HandleActionRequest argument action=StopInclusion <0x2e565680>
                                          50	12/23/16 7:53:03.510	luup_log:5: Arduino: Sending: 0;0;3;0;5;0 <0x2b51c310>
                                          04	12/23/16 7:53:03.512	 <0x2b51c310>
                                          50	12/23/16 7:53:03.521	luup_log:5: Arduino: urn:upnp-arduino-cc:serviceId:arduino1,InclusionMode, 0, 5 <0x2d565680>
                                          06	12/23/16 7:53:03.521	Device_Variable::m_szValue_set device: 5 service: urn:upnp-arduino-cc:serviceId:arduino1 variable: InclusionMode was: 1 now: 0 #hooks: 0 upnp: 0 skip: 0 v:0xbb2eb8/NONE duplicate:0 <0x2d565680>
                                          50	12/23/16 7:53:03.522	luup_log:5: Arduino: urn:upnp-arduino-cc:serviceId:arduino1,InclusionFoundCountHR, , 5 <0x2d565680>
                                          06	12/23/16 7:53:03.523	Device_Variable::m_szValue_set device: 5 service: urn:upnp-arduino-cc:serviceId:arduino1 variable: InclusionFoundCountHR was: 1 devices found now:  #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x2d565680>
                                          50	12/23/16 7:53:03.524	luup_log:5: Arduino: Inclusion mode ended. <0x2d565680>
                                          02	12/23/16 7:53:03.525	luup_log:5: Arduino: Found new sensor(s). Need to restart. Please wait. <0x2d565680>
                                          09	12/23/16 7:53:03.528	Child_Devices::ProcessChildDevice created device 10 id 3;20 under 5 topmost parent 5 <0x2d565680>
                                          Here is what it looks like when the device receives a value:
                                          50	12/23/16 7:54:15.122	luup_log:5: Arduino: Log: TSP:SANCHK:OK <0x2e07b680>
                                          50	12/23/16 7:54:52.352	luup_log:5: Arduino: Log: TSP:MSG:READ 3-3-0 s=20,c=1,t=23,pt=2,l=2,sg=0:913 <0x2e07b680>
                                          50	12/23/16 7:54:52.354	luup_log:5: Arduino: Set variable: 3;20;1;0;23;913 <0x2e07b680>
                                          50	12/23/16 7:54:52.354	luup_log:5: Arduino: Setting variable 'CurrentLevel' to value '913' <0x2e07b680>
                                          50	12/23/16 7:54:52.355	luup_log:5: Arduino: urn:micasaverde-com:serviceId:LightSensor1,CurrentLevel, 913, 10 <0x2e07b680>
                                          06	12/23/16 7:54:52.356	Device_Variable::m_szValue_set device: 10 service: urn:micasaverde-com:serviceId:LightSensor1 variable: CurrentLevel was: EMPTY now: 913 #hooks: 0 upnp: 0 skip: 0 v:0x911d88/NONE duplicate:0 <0x2e07b680>
                                          50	12/23/16 7:54:52.357	luup_log:5: Arduino: urn:micasaverde-com:serviceId:HaDevice1,LastUpdate, 1482472492, 10 <0x2e07b680>
                                          • Tomas
