  3. My basement flooding alarm
14 Posts 6 Posters 8.6k Views 7 Watching
  • E ericvdb
    @GertSanders said:
    The node resets itself to a start position on startup. This means that during startup a first distance measurement is done. This is the "zero" level. Any deviation from that first measured distance is "the change".
    Small caveat @GertSanders , if your basement is flooded with 9cm of water and still rising, when at that moment the power interrupts for a few seconds, your node will reset and take the 9cm as the zero level, meaning, your pump will start then when there's 19cm of water. Will not be a big issue, but your pump will need to run longer, and hoping there won't be any other power interruptions.
    Great project btw.
    GertSandersG
    GertSandersG
    GertSanders
    @ericvdb
    New version of sketch should solve the issue of powerlosses:
    0_1472566354348_BasementAlarmUltrasonic.ino
    • Nca78N
      Nice project and nice board, I have ordered a bunch and they are on the way from dirtyPCB.
      Why not use a water level sensor like the one below, I bought some and they are quite precise with very reproductible values, is it to avoid any risk from wires coming from the main-powered box going into the water ?
      https://www.aliexpress.com/item/5pcs-Rain-Water-Level-Sensor-Module-Detection-Liquid-Surface-Depth-Height-for-Arduino-T1592-P-for/32673256075.html
      TheoLT GertSandersG 2 Replies Last reply
      • Nca78N Nca78
        TheoLT
        TheoLT
        TheoL
        @Nca78 I'm just curious what's the max depth that you can measure with those water level sensors?
        Nca78N 1 Reply Last reply
        • TheoLT TheoL
          The length of the "stripes" is 4cms so that's all you've got to measure the level. But in this case it's enough to know if basement is flooded or not and start the pump. With the components on the top part + connectors protected by oxime (non acid) silicon sealant it won't be a problem if the water level rises higher than the sensor.
          Just in case if someone is thinking about water level for drinkable water, I would avoid these sensors as the stripes are covered with solder. Given the very low price, there's a high chance it's not lead-free...
          crodgersC 1 Reply Last reply
          • Nca78N Nca78
            GertSandersG
            GertSandersG
            GertSanders
            @Nca78
            The reason I use the ultrasonic sensor is because I do not like to put a wire along the wall and a sensor on ground level. Now I only have a small case at cabinet level, with the US sensor directed to the floor. And I can measure any water level up to 255 cm with this.
            A collegue of mine uses this same node to measure the amount of rainwater collected in his rainwater tank.
            In Domoticz I have set up several triggers so that I get notifications on specific waterlevels. This is needed if waterlevels keep rising while the pump is working, meaning the pump can not handle the flooding and needs to be assisted by extra equipment.
            TheoLT 1 Reply Last reply
            • GertSandersG GertSanders
              @Nca78
              TheoLT
              TheoLT
              TheoL
              @GertSanders I'd had a feeling that you used the ultra sonic sensors for a particular reason. Measuring the level of rain in my rainwater tank is definitely a project I've put in my todo list.
              • TheoLT TheoL
                GertSandersG
                GertSandersG
                GertSanders
                @TheoL
                The 4cm sensor is nice to have some alarm under a washing machine for example, but in my "watertank" like problem (I have had up to 122cm of water in the basement) that would not tell me much.
                The Ultrasonic sensor I use now also exists in a waterproof variant (as used in car-bumpers). Still need to experiment with that, as it would be nicer to use that in a watertank (is better protected against corrosion).
                In my current setup, I expect the electronics to degrade after some time, since they are used in a very humid environment. The box all this is mounted in, is certainly NOT waterproof.
                • Nca78N Nca78
                  crodgersC
                  crodgersC
                  crodgers
                  wrote on last edited by crodgers
                  @Nca78 have you been using the Rain Water Level Sensor modules for a while? Can you run more than one on a pro mini? I was thinking, since they are small, that I could use a few at different levels to have different actions. I saw a water level eTape, but it is a bit expensive (haven't seen a Chinese knockoff yet). Or I suppose I could combine the sensor for initial water detection, then the ultra sonic to figure out depth.
                  • crodgersC crodgers
                    @crodgers no I just tested them at the moment. But they all gave me close values for similar levels of water. It has an analog output, so you can combine as many as the analog pins on your arduino, so up to 8 on a pro-mini if you are not using I2C devices (I2C uses A4/A5).
                    I plan to use these for simple flooding or rain detection more than for the water level.
                    I found this sensors too, they look a bit bigger and have gold coating which would solve the potential hazard of lead solder and increase durability, but there are no dimensions on the website. They also don't have the led which is an advantage for me to run on batteries, no use to remove it by hand.
                    http://www.aliexpress.com/store/product/Water-Level-Sensor-gold-coating/1950989_32713161293.html
                    • micahM
                      micahM
                      micah
                      Nice build, and great idea using the ultra sonic sensor.
                      This sort of thing was the exact reason I got into arduino and eventually mysensors. I had a concern about a damp basement and went looking for a water leak detection alarm but the prices were so high at the time... eventually I stumbled upon arduino and the obsession went from there.
                      The first node I ever made was a water leak detection system that used the 4cm thing mentioned above... then I realized I had all these left over pins ;) so I filled them up with a gas, flame, temperature, humidity and light sensor.
                      Forget nest protect and commercial water leak detection systems... I now have an all in one DIY solution that probably only cost $30
