  3. Vera
  4. [SOLVED] Pressure Sensor Will Not Add to Vera
verapressurebmp085
6 Posts 3 Posters 4.3k Views 1 Watching
  • R
    R
    RyanAHolland
    wrote on last edited by RyanAHolland
    Whenever I try and add my pressure sensor to Vera, nothing seems to happen. I can add other sensors to vera without issue, but when I try and add the pressure sensor, Vera detects nothing.
    I have verified wiring with the BMP085 test program and I see pressure and temperature. When I run the PressureSensor.ino, upload it and then check serial output, I see nothing.
    Any suggestions?
    I am running on a Mini Pro (3.3v) with a serial gateway. Thanks.
    RJ_MakeR 1 Reply Last reply
    • R RyanAHolland
      Any suggestions?
      RJ_MakeR
      RJ_MakeR
      RJ_Make
      @RyanAHolland
      MySensor Version?
      If you have debugging turned on (it's on by default in 1.4) and you're not seeing anything in the serial, then I would think that you have a hardware problem (as long as you have the serial monitor setup correctly)
      Well I guess you could still have a software problem, but.....
      I would add some debugging code directly to the sketch and see if that shows up in the serial monitor.
      Can you easily swap out the Mini with a different one?
      RJ_Make
      • RJ_MakeR RJ_Make
        @RyanAHolland
        MySensor Version?
        R
        R
        RyanAHolland
        @ServiceXp I am on 1.4.
        I can try a different Mini, but I have verified that the pressure sensor works, by using the included test sketch. Does the pressure sensor sketch output anything to the serial when debugging is enabled? Sorry, I am a newbie when it comes to Arduino.
        • R RyanAHolland
          RJ_MakeR
          RJ_MakeR
          RJ_Make
          @RyanAHolland
          I took a quick look at the sketch and it appears it does..
           Serial.print("Temperature = ");
           Serial.print(temperature);
           Serial.println(metric?" *C":" *F");
           Serial.print("Pressure = ");
           Serial.print(pressure);
           Serial.println(" Pa");
          RJ_Make
          • R
            R
            RyanAHolland
            I solved the issue, it turns out you have to have debug disabled for the program to execute. I believe I saw someone else mention it in another thread and that is what lead me there. Thanks for the help!
              Could you perhaps try to introduce a few delays and see if that fixes the problem?
              Would be good if the sketch works without debug enabled.
