  3. [Beginner] WS2811 lights just doesn't light up normally
14 Posts 3 Posters 4.3k Views 3 Watching
  • Mantvydas RiM Mantvydas Ri
    Reversed wiring (connected 5v and ground at the end of strip) and connected BOTH sides data wire (the one from beginning and one at the end). Don't know why, but it started working now. Any ideas now? :laughing:
    @Mantvydas-Ri Interesting :) Could you post photos of both ends of the strip?
    • Mantvydas RiM
      Mantvydas RiM
      Mantvydas Ri
      The ends looked like this http://www.ipix.lt/image/6kFGp but I cut them off because of huge interference (The lights worked after disconnecting 5v pin :smiley: - probably data pin was colliding with 5v or something ). Now there are just plain wires.
      I feel so dumb because I don't even know how and why this happens.
      For example sometimes lights just works by simply connecting those pins as they should be, sometimes the lights just blinking randomly, sometimes nothing happens, but this often can get fixed if I attach both ends of data pin to arduino (and sometimes not). :confused:
      Feeling like I have bought defected strip or just don't have enough brains to connect it :laughing:
        @Mantvydas-Ri sorry I meant the strip itself, to see the markings for the connectors. Like this:
        (not that this image is from a different type of strip though)
        • Mantvydas RiM
          Mantvydas RiM
          Mantvydas Ri
          Every pixel looks like this http://www.ipix.lt/image/6kzdh and the other side like this http://www.ipix.lt/image/6kBSl. Don't know if you can see here, but there is written "+" , "DI" (data input probably), and "GND", so I guess contacts are marked correctly.
            @Mantvydas-Ri can't see the markings but I don't see anything strange so they are probably fine.
            How are you powering the strips? Is gnd on the power source connected to gnd on the Mega?
              Good question :+1:
              @Mantvydas-Ri How many LEDs are you trying to control?
              Each LED consumes 0.3W (60mA) according to the link in the 1st post, so a strand of 50 consumes 3A at maximum brightness.
              That's far too much for the 5V supply of the Arduino Mega, so try powering the LEDs from a separate, beefy (min. 4 Amps) power supply, or test with a much shorter strand (e.g. start with 1 LED only).
              • Mantvydas RiM
                Mantvydas RiM
                Mantvydas Ri
                Tried external power supply, same problem as on Arduino mega. I have also decreased brightness of the bulbs to ensure this is not an issue.
                Also, as I said, connecting both ends of data pin most likely solves the problem, but it is a little impractical.
                • Mantvydas RiM
                  Mantvydas RiM
                  Mantvydas Ri
                  But I will try it again anyway- maybe this time i'll be lucky
                  • Mantvydas RiM
                    Mantvydas RiM
                    Mantvydas Ri
                    Alright, tested it with 10A 5V power supply. But now lights doesn't work at all. Even from battery it works, but not from the external power supply.
                    And yes, I have checked that power supply is working with multimeter.
                    Weird..
                    • Mantvydas RiM
                      Mantvydas RiM
                      Mantvydas Ri
                      wrote on last edited by Mantvydas Ri
                      Btw is it normal that after removing GND wire lights are still glowing? :laughing:
                        @Mantvydas-Ri Might be. Data line serves as gnd. But don't operate them like that, things might break!
                        12.5k
