  3. Radio FAIL after ~3 weeks [SOLVED]
61 Posts 7 Posters 24.4k Views 5 Watching
  • T tboha
    @Reza Your code isn´t easy to understand. More Comments within your code would be very helpful.
    So I will try a little mind reading.....
    Basic concept seems to be decoupling switches/pushbuttons from the relais part and to control the relais action through your controller.
    Management of switches/pushbuttons is done in loop().
    "Master of states" is your controller (software).
    Actions are performed by receive().
    At last a clean soloution - but some parts aren´t that clean.
    The only reference to stateX is within receive() directly before digital_write(X). So any change to stateX from within the sketch will not have any effekt. So the introduction of the stateX variable isn´t actually necessary.
            digitalWrite(message.sensor + 2, message.getBool() ? RELAY_ON : RELAY_OFF);
    should work to. This eliminates thes risk of double originals which can get very tricky if things go wrong. (i.e. there should be only one set of stateX variables in your system because keeping copied sets tidy is a huge amount of work and prone to errors).
    In the first part of loop() you try to instantiate some basic mechanisms to accomplish this mission but I fear it will not succeed.
    Within loop you begin with a chain of modulo-operations which might be intended to send the state variable to your controller once every hour (?) with 1 second interval. This will fail eternally if your loop starts accidentally with millis() at xxxxxx1 and loop duration is xxxxxx2. The remainder of % operation will always be 1 (or more) but never zero. Precise timing down to 1 millisecond would be too critical to little errors and is not necessary.
    Spacing send() to one second should not be necessary either - MySensors framework can deal with lot of send() in a row.
    So maybe a statement like
    if (millis() >= lasttime+INTERVALL) {.....}
    could fit your needs. It isn´t that precise - but precise enough and robust.
    if (trigger == 0) {...;trigger=1;}
    This part is executed only once because you never reset trigger to zero. If you intend to reset your controller variables you might move this part to setup() - or better leave it to your controller.
    But if you omit stateX copying this whole section could be skipped.
    The rest of loop() consists of switch management which seems ok to me. Nevertheless a little proposal for optimisation:
    send(msgA.set(stateA ? true : false), true);
    There is no really need for the trinary operator ? because stateA is bool, it may be send directly like
     send(msgA.set(stateA ), true);
    debouncerA.update();
    I am not very familiar with debounce(). But omitting "&&valueA==0" will cause your statement to react to pressing your button as well as to releasing your button. So this statement will act twice on one keystroke -- so far I remember the debounce() function.
    Because stateA is not likely to be changed in this short amount of time, this statement will send stateA twice - which causes unnecessary traffic.
    These are surely no crucial points but I think the sketch woud be more robust.
    wdt_enable(WDTO_4S);
    Please don´t do this - it may have terrible side effects and may make you mad while searching for errors.
    So over all your sketch isn´t that bad for a first proof of concept and should be functional for your basic needs.
    So missing send should be due to the qualitiy of your connection. Maybe a longer log of debug messages (both sides?) would be helpful.
    R
    R
    Reza
    wrote on last edited by Reza
    @tboha
    thank you my friend for help
    i am beginner and sorry for this sketch. i tried hardly until build this sketch with use other sketch in site. in this code i want use a 6channel relay with 6 button(toggle button up/down). also i want after power supply off/on , all relay go to off and in app (for example domoticz) show me all relay go to off. about millis() when i use a repeater (for this 6channel relay) and if repeater to be fail so radio in relay can not found a new way for connect to gateway. because that is not any connection with gateway. so if every hours relay send her state so if see that connection is fail so search and found a new way for connection.
    sorry for weak in english :(
    so you think my problem in connection is related to my sketch ? but i can not change this because i am beginner . can you help me to fix this code ? please
    J 1 Reply Last reply
    • R Reza
      @tboha
      J
      J
      Jan Gatzke
      @Reza
      The Problem is most likely a problem with your hardware. Try to lower the distance and see if the problem still exists. If not you should replace your radios. Look for radios with pa / lna.
      R 1 Reply Last reply
      • J Jan Gatzke
        @Reza
        R
        R
        Reza
        i test with lower distance . there is problem yet. i think problem is related to my sketch. i can not fix this :(
        • J Jan Gatzke
          @tboha
          Great analysis. I will surely send you my code for review next time. :D
          tboha
          @Jan-Gatzke You are welcome.
          @Reza : don´t worry, there will be a simple solution.
          I´m in a hurry at the moment, I was ordered to do some party tonight. If my supreme command detects my current activities I will have very bad Karma for the next days.
          To whom it may already apply: Happy new Year!! :boom:
          if (applies == 0) {
          wait.some(hours);
          read.again();
          rayanR R 2 Replies Last reply
          • T tboha
            if (applies == 0) {
            wait.some(hours);
            read.again();
            rayanR
            rayanR
            rayan
            wrote on last edited by rayan
            #23
            • T tboha
              if (applies == 0) {
              wait.some(hours);
              read.again();
              R
              R
              Reza
              @tboha
              happy new year to you and your family <3
              my friend i am beginner . can you edit and fix my sketch next day? and paste here ? please .thank you
              • R Reza
                @tboha
                tboha
                @reza:
                I made some modifications to your sketch, trying to adhere to your style of programming. So it may be easier to adapt it to your needs.
                #define MY_RF24_CHANNEL 0
                #define MY_REPEATER_FEATURE
                #define MY_NODE_ID 5
                #define RELAY_ON 0
                #define RELAY_OFF 1
                #define A_ID 1
                #define B_ID 2
                #define C_ID 3
                #define D_ID 4
                #define E_ID 5
                #define F_ID 6
                #define DISPLAY_INTERVALL 10000
                const int buttonPinA = 14;
                const int buttonPinB = 15;
                const int buttonPinC = 16;
                const int buttonPinD = 17;
                const int buttonPinE = 18;
                const int buttonPinF = 19;
                const int relayPinA = 3;
                const int relayPinB = 4;
                const int relayPinC = 5;
                const int relayPinD = 6;
                const int relayPinE = 7;
                const int relayPinF = 8;
                int oldValueA = 0;
                int oldValueB = 0;
                int oldValueC = 0;
                int oldValueD = 0;
                int oldValueE = 0;
                int oldValueF = 0;
                unsigned long loop_count = 0;           // counter for loop activity
                unsigned long last_time;
                bool toggleA = false, toggleB = false, toggleC = false, toggleD = false, toggleE = false, toggleF = false;
                Bounce debouncerA = Bounce();
                Bounce debouncerB = Bounce();
                Bounce debouncerC = Bounce();
                Bounce debouncerD = Bounce();
                Bounce debouncerE = Bounce();
                Bounce debouncerF = Bounce();
                MyMessage msgA(A_ID, V_STATUS);
                MyMessage msgB(B_ID, V_STATUS);
                MyMessage msgC(C_ID, V_STATUS);
                MyMessage msgD(D_ID, V_STATUS);
                MyMessage msgE(E_ID, V_STATUS);
                MyMessage msgF(F_ID, V_STATUS);
                  pinMode(buttonPinA, INPUT_PULLUP);
                  pinMode(buttonPinB, INPUT_PULLUP);
                  pinMode(buttonPinC, INPUT_PULLUP);
                  pinMode(buttonPinD, INPUT_PULLUP);
                  pinMode(buttonPinE, INPUT_PULLUP);
                  pinMode(buttonPinF, INPUT_PULLUP);
                  // After setting up the buttons, setup debouncer
                  debouncerA.attach(buttonPinA);
                  debouncerA.interval(5);
                  debouncerB.attach(buttonPinB);
                  debouncerB.interval(5);
                  debouncerC.attach(buttonPinC);
                  debouncerC.interval(5);
                  debouncerD.attach(buttonPinD);
                  debouncerD.interval(5);
                  debouncerE.attach(buttonPinE);
                  debouncerE.interval(5);
                  debouncerF.attach(buttonPinF);
                  debouncerF.interval(5);
                  digitalWrite(relayPinA, RELAY_OFF);
                  digitalWrite(relayPinB, RELAY_OFF);
                  digitalWrite(relayPinC, RELAY_OFF);
                  digitalWrite(relayPinD, RELAY_OFF);
                  digitalWrite(relayPinE, RELAY_OFF);
                  digitalWrite(relayPinF, RELAY_OFF);
                  pinMode(relayPinA, OUTPUT);
                  pinMode(relayPinB, OUTPUT);
                  pinMode(relayPinC, OUTPUT);
                  pinMode(relayPinD, OUTPUT);
                  pinMode(relayPinE, OUTPUT);
                  pinMode(relayPinF, OUTPUT);
                  wait(1000);                                    // testing LEDs. should be omitted for Relais.
                  digitalWrite(relayPinA, RELAY_ON);
                  digitalWrite(relayPinB, RELAY_ON);
                  digitalWrite(relayPinC, RELAY_ON);
                  digitalWrite(relayPinD, RELAY_ON);
                  digitalWrite(relayPinE, RELAY_ON);
                  digitalWrite(relayPinF, RELAY_ON);
                  /*--------------------- Added these lines for toggle switch-------------------------*/
                  oldValueA = digitalRead(buttonPinA);  // set oldValueA to the current status of the toggle switch
                  oldValueB = digitalRead(buttonPinB);  // set oldValueB to the current status of the toggle switch
                  oldValueC = digitalRead(buttonPinC);
                  oldValueD = digitalRead(buttonPinD);
                  oldValueE = digitalRead(buttonPinE);
                  oldValueF = digitalRead(buttonPinF);
                void presentation()  {
                  sendSketchInfo("RELAY6", "0.1");
                  present(A_ID, S_LIGHT, "Relais A");
                  present(B_ID, S_LIGHT, "Relais B");
                  present(C_ID, S_LIGHT, "Relais C");
                  present(D_ID, S_LIGHT, "Relais D");
                  present(E_ID, S_LIGHT, "Relais E");
                  present(F_ID, S_LIGHT, "Relais F");
                    loop_count ++;                                        // increment loop count
                    if ( millis() >= last_time + DISPLAY_INTERVALL ) {    // Display Loop-cycles every DISPLAY_INTERVALL milliseconds
                      last_time = millis();                               // reset and start over again
                      Serial.print("loop_count: ");
                      Serial.println(loop_count);
                      loop_count = 0;
                  // Get the update value
                  int valueA = debouncerA.read();
                  if (valueA != oldValueA && valueA == 0) {
                    send(msgA.set(toggleA, true));                        // Send new state and request ack back
                    digitalWrite(relayPinA, toggleA);                     // switch relais
                    Serial.println("Switch A pressed");
                    toggleA = !toggleA;                                   // this is the actual toggle switch
                  oldValueA = valueA;
                  debouncerB.update();
                  int valueB = debouncerB.read();
                  if (valueB != oldValueB) {
                    send(msgB.set(valueB ? false : true), true); // Send new state and request ack back
                    Serial.println("Switch B pressed");
                    oldValueB = valueB;
                  debouncerC.update();
                  int valueC = debouncerC.read();
                  if (valueC != oldValueC) {
                    send(msgC.set(valueC ? false : true), true); // Send new state and request ack back
                    Serial.println("Switch C pressed");
                    oldValueC = valueC;
                  debouncerD.update();
                  int valueD = debouncerD.read();
                  if (valueD != oldValueD) {
                    send(msgD.set(valueD ? false : true), true); // Send new state and request ack back
                    Serial.println("Switch D pressed");
                    oldValueD = valueD;
                  debouncerE.update();
                  int valueE = debouncerE.read();
                  if (valueE != oldValueE) {
                    send(msgE.set(valueE ? false : true), true); // Send new state and request ack back
                    Serial.println("Switch E pressed");
                    oldValueE = valueE;
                  debouncerF.update();
                  int valueF = debouncerF.read();
                  if (valueF != oldValueF) {
                    send(msgF.set(valueF ? false : true), true); // Send new state and request ack back
                    Serial.println("Switch F pressed");
                    oldValueF = valueF;
                    switch (message.sensor) {
                      case 1:
                      case 2:
                      case 3:
                      case 4:
                      case 5:
                      case 6:
                      default:
                        Serial.println("bad message (child_id >6)");
                    Serial.print("  from node:");
                    Serial.print(message.sender);
                I haven`t copied the code for all push-buttons - I leave this to you if this sketch is functional for your needs.
                Acting carefully, you may mingle some parts with blacey´s sketch successfully (by the way - impressing coding style).
                Reenacting your sketch I found some strange behavior: no reaction to push-button-press - meaning the sketch didn´t even take notice of the push-button after it had been pressed once - or sometimes twice.
                Adding an external pull-up resistor (4.7k) fixed this problem.
                So maybe it has not been a sending problem but a hardware problem (internal pull-ups to weak?).
                Please flood your sketch with print statements - like "button A pressed" "send command issued" etc. and watch your serial terminal carefully and/or post your logs.
                Thinking about the modulo-driven time-statement - actually it is a cute idea. Something like
                 time_m = millis();
                    a = (time_m / 1000) % 3600;
                should make it immune to uneven starting values an even loop-cycle duration. (loop-cycle-time of the above sketch: approximately 125 µs)
                These are the lesser problems. I fear you have to do some boring English lecture.
                Please read: https://en.wikipedia.org/wiki/Finite-state_machine
                https://en.wikipedia.org/wiki/State_machine_replication
                and first: https://en.wikipedia.org/wiki/Two_Generals'_Problem
                https://en.wikipedia.org/wiki/Byzantine_fault_tolerance
                as an excerpt :
                The Two Generals Problem was the first computer communication problem to be proved to be unsolvable.
                This is not "we don´t have a solution until now" but: "it is sure there can´t be a solution"
                So you will have to live with a certain amount of uncertainty .....
                Conclusion:
                1. Check correct function of push-button with Serial.print(), with and without external pull-up resistor.
                2. Please post your logs afterwards.
                3. be prepared to make some decisions concerning tolerable fuzziness.
                4. if necessary start learning about scripting capabilities of your controller.
                • T tboha
                  @reza:
                  #define RELAY_ON 0
                  #define RELAY_OFF 1
                  #define A_ID 1
                  #define B_ID 2
                  #define C_ID 3
                  #define D_ID 4
                  #define E_ID 5
                  #define F_ID 6
                  int oldValueA = 0;
                  int oldValueB = 0;
                  int oldValueC = 0;
                  int oldValueD = 0;
                  int oldValueE = 0;
                  int oldValueF = 0;
                        loop_count = 0;
                    oldValueA = valueA;
                      oldValueB = valueB;
                      oldValueC = valueC;
                      oldValueD = valueD;
                      oldValueE = valueE;
                      oldValueF = valueF;
                        case 1:
                        case 2:
                        case 3:
                        case 4:
                        case 5:
                        case 6:
                        default:
                   time_m = millis();
                  as an excerpt :
                  Conclusion:
                  R
                  R
                  Reza
                  @tboha
                  i think my problem is related to other reason
                  this is out of sketch with change you:
                  0 MCO:BGN:INIT REPEATER,CP=RNNRA--,VER=2.0.1-beta
                  4 TSM:INIT
                  11 TSM:INIT:TSP OK
                  12 TSM:INIT:STATID=4
                  14 TSF:SID:OK,ID=4
                  16 TSM:FPAR
                  52 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  2059 !TSM:FPAR:NO REPLY
                  2061 TSM:FPAR
                  2097 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  2165 TSF:MSG:READ,2-2-4,s=255,c=3,t=8,pt=1,l=1,sg=0:1
                  2170 TSF:MSG:FPAR OK,ID=2,D=2
                  2340 TSF:MSG:READ,3-3-4,s=255,c=3,t=8,pt=1,l=1,sg=0:3
                  4105 TSM:FPAR:OK
                  4106 TSM:ID
                  4107 TSM:ID:OK
                  4109 TSM:UPL
                  4146 !TSF:MSG:SEND,4-4-2-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
                  6153 TSM:UPL
                  6190 !TSF:MSG:SEND,4-4-2-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
                  8197 TSM:UPL
                  8206 TSF:MSG:SEND,4-4-2-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=OK:1
                  8240 TSF:MSG:READ,0-2-4,s=255,c=3,t=25,pt=1,l=1,sg=0:2
                  8245 TSF:MSG:PONG RECV,HP=2
                  8248 TSM:UPL:OK
                  8249 TSM:READY
                  8266 TSF:MSG:SEND,4-4-2-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                  8292 TSF:MSG:READ,0-2-4,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                  8338 !TSF:MSG:SEND,4-4-2-0,s=255,c=0,t=18,pt=0,l=10,sg=0,ft=0,st=NACK:2.0.1-beta
                  8373 TSF:MSG:SEND,4-4-2-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=1,st=OK:2
                  8402 TSF:MSG:READ,0-2-4,s=255,c=3,t=6,pt=0,l=1,sg=0:M
                  8445 !TSF:MSG:SEND,4-4-2-0,s=255,c=3,t=11,pt=0,l=6,sg=0,ft=0,st=NACK:RELAY6
                  8477 TSF:MSG:SEND,4-4-2-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=1,st=OK:0.1
                  8523 !TSF:MSG:SEND,4-4-2-0,s=1,c=0,t=3,pt=0,l=8,sg=0,ft=0,st=NACK:Relais A
                  8569 !TSF:MSG:SEND,4-4-2-0,s=2,c=0,t=3,pt=0,l=8,sg=0,ft=1,st=NACK:Relais B
                  8615 !TSF:MSG:SEND,4-4-2-0,s=3,c=0,t=3,pt=0,l=8,sg=0,ft=2,st=NACK:Relais C
                  8662 !TSF:MSG:SEND,4-4-2-0,s=4,c=0,t=3,pt=0,l=8,sg=0,ft=3,st=NACK:Relais D
                  8708 !TSF:MSG:SEND,4-4-2-0,s=5,c=0,t=3,pt=0,l=8,sg=0,ft=4,st=NACK:Relais E
                  8754 !TSF:MSG:SEND,4-4-2-0,s=6,c=0,t=3,pt=0,l=8,sg=0,ft=5,st=NACK:Relais F
                  8761 MCO:REG:REQ
                  8783 TSF:MSG:SEND,4-4-2-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=6,st=OK:2
                  8809 TSF:MSG:READ,0-2-4,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                  8814 MCO:PIM:NODE REG=1
                  8816 MCO:BGN:STP
                  9818 MCO:BGN:INIT OK,ID=4,PAR=2,DIS=2,REG=1
                  loop_count: 1552
                  loop_count: 87002
                  loop_count: 86993
                  loop_count: 87002
                  loop_count: 87002
                  • R
                    R
                    Reza
                    #27
                    i have problem in send and receive ack ! i dont know where is problem ! i change radio and wire and arduino ... but this problem dont resolve :(
                    also in my sketch i want when relay module is power on (relays off (LED OFF) ) and when i send command LED on and relay on. also i use a key with up / down button. so i want when key is up send one command and when key is down send other command...
                    • R
                      R
                      Reza
                      4 TSM:INIT
                      11 TSM:INIT:TSP OK
                      14 TSF:SID:OK,ID=4
                      16 TSM:FPAR
                      2061 TSM:FPAR
                      2830 TSF:MSG:READ,2-2-4,s=255,c=3,t=8,pt=1,l=1,sg=0:1
                      2835 TSF:MSG:FPAR OK,ID=2,D=2
                      4105 TSM:FPAR:OK
                      4106 TSM:ID
                      4107 TSM:ID:OK
                      4109 TSM:UPL
                      6153 TSM:UPL
                      8197 TSM:UPL
                      8233 !TSF:MSG:SEND,4-4-2-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
                      10241 TSM:UPL
                      10277 !TSF:MSG:SEND,4-4-2-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
                      12285 !TSM:UPL:FAIL
                      12286 TSM:FPAR
                      12323 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=4,st=OK:
                      14332 !TSM:FPAR:NO REPLY
                      14334 TSM:FPAR
                      14371 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      16378 !TSM:FPAR:NO REPLY
                      16380 TSM:FPAR
                      16417 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      18424 !TSM:FPAR:NO REPLY
                      18426 TSM:FPAR
                      18463 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      20470 !TSM:FPAR:FAIL
                      20471 TSM:FAIL:CNT=1
                      20473 TSM:FAIL:PDT
                      30476 TSM:FAIL:RE-INIT
                      30478 TSM:INIT
                      30485 TSM:INIT:TSP OK
                      30487 TSM:INIT:STATID=4
                      30489 TSF:SID:OK,ID=4
                      30491 TSM:FPAR
                      30528 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      32535 !TSM:FPAR:NO REPLY
                      32537 TSM:FPAR
                      32574 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      34581 !TSM:FPAR:NO REPLY
                      34583 TSM:FPAR
                      34620 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      36627 !TSM:FPAR:NO REPLY
                      36629 TSM:FPAR
                      36666 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      • R Reza
                        4 TSM:INIT
                        11 TSM:INIT:TSP OK
                        14 TSF:SID:OK,ID=4
                        16 TSM:FPAR
                        2061 TSM:FPAR
                        4105 TSM:FPAR:OK
                        4106 TSM:ID
                        4107 TSM:ID:OK
                        4109 TSM:UPL
                        6153 TSM:UPL
                        8197 TSM:UPL
                        10241 TSM:UPL
                        12285 !TSM:UPL:FAIL
                        12286 TSM:FPAR
                        14334 TSM:FPAR
                        16380 TSM:FPAR
                        18426 TSM:FPAR
                        20473 TSM:FAIL:PDT
                        30478 TSM:INIT
                        30491 TSM:FPAR
                        32537 TSM:FPAR
                        34583 TSM:FPAR
                        36629 TSM:FPAR
                        tboha
                        @Reza I got your nodes behavior mostly reproduced (see protocol below).
                        Only difference:
                        4105 TSM:FPAR:OK
                        4106 TSM:ID
                        In my network I got direct connections to my gateway.
                        so most messages in your logs document all nodes broadcasting all the time searching for your gateway and getting no response.
                        If there is no connection - there can be no ACK.
                        Would you please check your gateway sketch for the RF-channel in use?
                        Protocol with non matching RF-channel (#define MY_RF24_CHANNEL 0)
                        0 MCO:BGN:INIT REPEATER,CP=RNNRA--,VER=2.1.0
                        3 TSM:INIT
                        4 TSF:WUR:MS=0
                        11 TSM:INIT:TSP OK
                        13 TSM:INIT:STATID=5
                        15 TSF:SID:OK,ID=5
                        17 TSM:FPAR
                        53 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                        2060 !TSM:FPAR:NO REPLY
                        2062 TSM:FPAR
                        2098 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                        4105 !TSM:FPAR:NO REPLY
                        4107 TSM:FPAR
                        4143 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                        6150 !TSM:FPAR:NO REPLY
                        6152 TSM:FPAR
                        6188 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                        8195 !TSM:FPAR:FAIL
                        8196 TSM:FAIL:CNT=1
                        8198 TSM:FAIL:PDT
                        18201 TSM:FAIL:RE-INIT
                        18203 TSM:INIT
                        18210 TSM:INIT:TSP OK
                        18212 TSM:INIT:STATID=5
                        18214 TSF:SID:OK,ID=5
                        18216 TSM:FPAR
                        18253 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                        20260 !TSM:FPAR:NO REPLY
                        20262 TSM:FPAR
                        20298 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                        22306 !TSM:FPAR:NO REPLY
                        22308 TSM:FPAR
                        22344 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                        24352 !TSM:FPAR:NO REPLY
                        24354 TSM:FPAR
                        24390 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                        26398 !TSM:FPAR:FAIL
                        26399 TSM:FAIL:CNT=2
                        26401 TSM:FAIL:PDT
                        Protocol with matching RF-Channel (without #define MY_RF24_CHANNEL 0,i.e. using default channel)
                        3 TSM:INIT
                        4 TSF:WUR:MS=0
                        11 TSM:INIT:TSP OK
                        15 TSF:SID:OK,ID=5
                        17 TSM:FPAR
                        2062 TSM:FPAR
                        2377 TSF:MSG:READ,14-14-5,s=255,c=3,t=8,pt=1,l=1,sg=0:1
                        2382 TSF:MSG:FPAR OK,ID=14,D=2
                        2811 TSF:MSG:READ,0-0-5,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                        2817 TSF:MSG:FPAR OK,ID=0,D=1
                        3289 TSF:MSG:READ,7-7-5,s=255,c=3,t=8,pt=1,l=1,sg=0:2
                        3734 TSF:MSG:READ,4-4-5,s=255,c=3,t=8,pt=1,l=1,sg=0:1
                        4105 TSM:FPAR:OK
                        4106 TSM:ID
                        4107 TSM:ID:OK
                        4109 TSM:UPL
                        4112 TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                        4118 TSF:MSG:READ,0-0-5,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                        4123 TSF:MSG:PONG RECV,HP=1
                        4126 TSM:UPL:OK
                        4127 TSM:READY:ID=5,PAR=0,DIS=1
                        4132 TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                        4139 TSF:MSG:READ,0-0-5,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                        4146 TSF:MSG:SEND,5-5-0-0,s=255,c=0,t=18,pt=0,l=5,sg=0,ft=0,st=OK:2.1.0
                        4155 TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                        4584 TSF:MSG:READ,0-0-5,s=255,c=3,t=6,pt=0,l=6,sg=0:Metric
                        4590 TSF:MSG:ACK REQ
                        4594 TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=6,pt=0,l=6,sg=0,ft=0,st=OK:Metric
                        4602 TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=11,pt=0,l=6,sg=0,ft=0,st=OK:RELAY6
                        4611 TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:0.1
                        4620 TSF:MSG:SEND,5-5-0-0,s=1,c=0,t=3,pt=0,l=8,sg=0,ft=0,st=OK:Relais A
                        4628 TSF:MSG:SEND,5-5-0-0,s=2,c=0,t=3,pt=0,l=8,sg=0,ft=0,st=OK:Relais B
                        4637 TSF:MSG:SEND,5-5-0-0,s=3,c=0,t=3,pt=0,l=8,sg=0,ft=0,st=OK:Relais C
                        4645 TSF:MSG:SEND,5-5-0-0,s=4,c=0,t=3,pt=0,l=8,sg=0,ft=0,st=OK:Relais D
                        4655 TSF:MSG:SEND,5-5-0-0,s=5,c=0,t=3,pt=0,l=8,sg=0,ft=0,st=OK:Relais E
                        4663 TSF:MSG:SEND,5-5-0-0,s=6,c=0,t=3,pt=0,l=8,sg=0,ft=0,st=OK:Relais F
                        4670 MCO:REG:REQ
                        4673 TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                        4679 TSF:MSG:READ,0-0-5,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                        4684 MCO:PIM:NODE REG=1
                        4686 MCO:BGN:STP
                        4714 TSF:MSG:READ,0-0-5,s=255,c=3,t=6,pt=0,l=6,sg=0:Metric
                        5688 MCO:BGN:INIT OK,TSP=1
                        7503 TSF:MSG:READ,8-8-5,s=255,c=3,t=8,pt=1,l=1,sg=0:1
                        7508 !TSF:MSG:FPAR INACTIVE
                        loop_count: 36610
                        loop_count: 85099
                        loop_count: 85091
                        31153 TSF:MSG:SEND,5-5-0-0,s=1,c=1,t=2,pt=7,l=5,sg=0,ft=0,st=OK:0.0
                        Switch A pressed
                        34217 TSF:MSG:SEND,5-5-0-0,s=1,c=1,t=2,pt=7,l=5,sg=0,ft=0,st=OK:1.0
                        Switch A pressed
                        36277 TSF:MSG:SEND,5-5-0-0,s=1,c=1,t=2,pt=7,l=5,sg=0,ft=0,st=OK:0.0
                        Switch A pressed
                        loop_count: 84876
                        Which kind of Gateway are you using?
                        • T tboha
                          Only difference:
                          4105 TSM:FPAR:OK
                          4106 TSM:ID
                          3 TSM:INIT
                          4 TSF:WUR:MS=0
                          11 TSM:INIT:TSP OK
                          15 TSF:SID:OK,ID=5
                          17 TSM:FPAR
                          2062 TSM:FPAR
                          4107 TSM:FPAR
                          6152 TSM:FPAR
                          8195 !TSM:FPAR:FAIL
                          8196 TSM:FAIL:CNT=1
                          8198 TSM:FAIL:PDT
                          18203 TSM:INIT
                          18216 TSM:FPAR
                          20262 TSM:FPAR
                          22308 TSM:FPAR
                          24354 TSM:FPAR
                          26401 TSM:FAIL:PDT
                          3 TSM:INIT
                          4 TSF:WUR:MS=0
                          11 TSM:INIT:TSP OK
                          15 TSF:SID:OK,ID=5
                          17 TSM:FPAR
                          2062 TSM:FPAR
                          4105 TSM:FPAR:OK
                          4106 TSM:ID
                          4107 TSM:ID:OK
                          4109 TSM:UPL
                          4126 TSM:UPL:OK
                          4670 MCO:REG:REQ
                          4686 MCO:BGN:STP
                          loop_count: 36610
                          loop_count: 85099
                          loop_count: 85091
                          Switch A pressed
                          Switch A pressed
                          Switch A pressed
                          loop_count: 84876
                          R
                          R
                          Reza
                          @tboha
                          i use #define MY_RF24_CHANNEL 0 and all of node are #define MY_RF24_CHANNEL 0
                          T 2 Replies Last reply
                          • R Reza
                            @tboha
                            tboha
                            @Reza
                            Based on your answer I have to confess I didn´t read your log carefully enough - being fixed to missing ACKs I didn´t pay attention to successful transmissions.
                            Difference between Node 160 log and Node 4 log is the complete absence of any messages from Node 0 (GW) in Node 160 log, whereas in Node 4 log there are answers from GW.
                            So my next question would be: are these failures consistent?
                            If you are not feed up already, would you please log some boot sequences from Node 4? And some button-presses too?
                            I think it would be interesting if failures are the exact identical or just almost identical.
                            (exact identical favors software problem, almost identical favors hardware problem).
                            A parallel log from the GW would be nice too. Maybe there is a problem in the ACK system.
                            If you don´t trust your OrangePi hardware - would a temporarily switch to Laptop/Windows/Linux make much effort? Just to prove integrity of GW-Arduino and radio.
                            • R Reza
                              @tboha
                              tboha
                              @Reza
                              I forgot - you are completely right. Why is there any need for a repeater node in between at 1m distance?
                              To get a clean solution you could isolate your GW and Node 4 by changing RF-channels and have a look at their private conversation without being disturbed by other (healthy) nodes.
                              • J
                                J
                                Jan Gatzke
                                Coul it be you are using modules with different chips? See https://forum.mysensors.org/topic/1153/we-are-mostly-using-fake-nrf24l01-s-but-worse-fakes-are-emerging
                                • T tboha
                                  @Reza
                                  R
                                  R
                                  Reza
                                  @tboha
                                  sorry for english
                                  generally , my problem is connection.
                                  i have a controller (domoticz on orangepi) and one serial gateway with usb cable to controller. and some sensors in all of house (Sporadic) and some relay for test just in my room. id 4 or 160 is choose random for test. i am near controller and test some sketch, some relay , radio and etc...
                                  so my problem is just connection between relays and gateway. sensors is good and work well and report all of states. but relays. first can not connection and show error :
                                  (4143 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                  6152 TSM:FPAR
                                  8195 !TSM:FPAR:FAIL
                                  8196 TSM:FAIL:CNT=1
                                  8198 TSM:FAIL:PDT)
                                  but after some time (with some power off/on) relay can connect to gateway . but after connect this is very unstable and some command send and some command dont send and show error ( NACK...)
                                  i test and i change hardware and sketch but dont resolve :(
                                  this is a solution ?please explain more . what am i do ?
                                  use a repeater near gateway and use this for connect all of relays to gateway?
                                  • J Jan Gatzke
                                    R
                                    R
                                    Reza
                                    @Jan-Gatzke
                                    my radios is not fake. i use 3 type of radio nrf+ but i have problem
                                    • R Reza
                                      @Jan-Gatzke
                                      J
                                      J
                                      Jan Gatzke
                                      @Reza
                                      Can you try to add the following line to your sketch?
                                      Right at the top, along with the other defines. I had similar problems with a LED Dimmer node. This solved the problem.
                                      • R Reza
                                        @tboha
                                        sorry for english
                                        6152 TSM:FPAR
                                        8195 !TSM:FPAR:FAIL
                                        8196 TSM:FAIL:CNT=1
                                        8198 TSM:FAIL:PDT)
                                        tboha
                                        @Reza No, an additional repeater was not intended (though it may be a solution).
                                        From your "Node 4" log I conclude:
                                        • you got at least 3 fully functional nodes (node 2,3,4). These nodes talk to each other in the environment of MySensors in an expected way.
                                        • so hardware (radio and power) is ok. Software is ok too.
                                        • GW functionality is partially ok - maybe hard- or software issues.
                                        Now there is a decision to make: go on testing potentially defective hardware or start over with known intact hardware.
                                        Go on testing means: are this failures reproducible? So I asked for logs of repeated boot sequences.
                                        Until now we don´t know the exact failure. The parallel log from Gateway would show if there are really missing transmissions (and the extent of missing messages) or only missing ACKs.
                                        I used ACKs last time in MySensors 1.4 and those days it made more trouble than profit. At last is showed up transmissions were ok (enough) the ACK system was not ok.
                                        For my purposes MySensors keeps up with transmission difficulties so I have not to care about (15m Distance, in house, reinforced concrete). So I decided not to use ACKs anymore and this did not reduce performance.
                                        If there are not to many missing transmissions (compare node messages vs. GW messages) I would skip the whole ACK thing.
                                        I would test potentially defective hardware first because it is easy to get some logs an costs not much time.
                                        Jan Gatzkes proposal is done quickly too.
                                        An additional repeater would only obscure severe GW-problems. For the GW is the heart of MySensors system - you should not tolerate any problems (hard- or software) because it will come on top again in the very near future.
                                        Starting over with known hardware takes more effort but should be doable in a manageable amount of time.
                                        • J Jan Gatzke
                                          @Reza
                                          R
                                          R
                                          Reza
                                          @Jan-Gatzke
                                          use this just for nrf +pa+lna? now i use just usual nrf+
