  3. Radio FAIL after ~3 weeks [SOLVED]
61 Posts 7 Posters 24.4k Views 5 Watching
  • R Reza
    0 MCO:BGN:INIT REPEATER,CP=RNNRA--,VER=2.0.1-beta
    4 TSM:INIT
    11 TSM:INIT:TSP OK
    12 TSM:INIT:STATID=4
    14 TSF:SID:OK,ID=4
    16 TSM:FPAR
    52 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    2059 !TSM:FPAR:NO REPLY
    2061 TSM:FPAR
    2097 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    2830 TSF:MSG:READ,2-2-4,s=255,c=3,t=8,pt=1,l=1,sg=0:1
    2835 TSF:MSG:FPAR OK,ID=2,D=2
    4105 TSM:FPAR:OK
    4106 TSM:ID
    4107 TSM:ID:OK
    4109 TSM:UPL
    4146 !TSF:MSG:SEND,4-4-2-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
    6153 TSM:UPL
    6190 !TSF:MSG:SEND,4-4-2-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
    8197 TSM:UPL
    8233 !TSF:MSG:SEND,4-4-2-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
    10241 TSM:UPL
    10277 !TSF:MSG:SEND,4-4-2-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=NACK:1
    12285 !TSM:UPL:FAIL
    12286 TSM:FPAR
    12323 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=4,st=OK:
    14332 !TSM:FPAR:NO REPLY
    14334 TSM:FPAR
    14371 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    16378 !TSM:FPAR:NO REPLY
    16380 TSM:FPAR
    16417 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    18424 !TSM:FPAR:NO REPLY
    18426 TSM:FPAR
    18463 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    20470 !TSM:FPAR:FAIL
    20471 TSM:FAIL:CNT=1
    20473 TSM:FAIL:PDT
    30476 TSM:FAIL:RE-INIT
    30478 TSM:INIT
    30485 TSM:INIT:TSP OK
    30487 TSM:INIT:STATID=4
    30489 TSF:SID:OK,ID=4
    30491 TSM:FPAR
    30528 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    32535 !TSM:FPAR:NO REPLY
    32537 TSM:FPAR
    32574 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    34581 !TSM:FPAR:NO REPLY
    34583 TSM:FPAR
    34620 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    36627 !TSM:FPAR:NO REPLY
    36629 TSM:FPAR
    36666 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    tboha
    @Reza I got your nodes behavior mostly reproduced (see protocol below).
    Only difference:
    4105 TSM:FPAR:OK
    4106 TSM:ID
    In my network I got direct connections to my gateway.
    so most messages in your logs document all nodes broadcasting all the time searching for your gateway and getting no response.
    If there is no connection - there can be no ACK.
    Would you please check your gateway sketch for the RF-channel in use?
    Protocol with non matching RF-channel (#define MY_RF24_CHANNEL 0)
    0 MCO:BGN:INIT REPEATER,CP=RNNRA--,VER=2.1.0
    3 TSM:INIT
    4 TSF:WUR:MS=0
    11 TSM:INIT:TSP OK
    13 TSM:INIT:STATID=5
    15 TSF:SID:OK,ID=5
    17 TSM:FPAR
    53 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    2060 !TSM:FPAR:NO REPLY
    2062 TSM:FPAR
    2098 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    4105 !TSM:FPAR:NO REPLY
    4107 TSM:FPAR
    4143 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    6150 !TSM:FPAR:NO REPLY
    6152 TSM:FPAR
    6188 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    8195 !TSM:FPAR:FAIL
    8196 TSM:FAIL:CNT=1
    8198 TSM:FAIL:PDT
    18201 TSM:FAIL:RE-INIT
    18203 TSM:INIT
    18210 TSM:INIT:TSP OK
    18212 TSM:INIT:STATID=5
    18214 TSF:SID:OK,ID=5
    18216 TSM:FPAR
    18253 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    20260 !TSM:FPAR:NO REPLY
    20262 TSM:FPAR
    20298 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    22306 !TSM:FPAR:NO REPLY
    22308 TSM:FPAR
    22344 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    24352 !TSM:FPAR:NO REPLY
    24354 TSM:FPAR
    24390 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    26398 !TSM:FPAR:FAIL
    26399 TSM:FAIL:CNT=2
    26401 TSM:FAIL:PDT
    Protocol with matching RF-Channel (without #define MY_RF24_CHANNEL 0,i.e. using default channel)
    3 TSM:INIT
    4 TSF:WUR:MS=0
    11 TSM:INIT:TSP OK
    15 TSF:SID:OK,ID=5
    17 TSM:FPAR
    2062 TSM:FPAR
    2377 TSF:MSG:READ,14-14-5,s=255,c=3,t=8,pt=1,l=1,sg=0:1
    2382 TSF:MSG:FPAR OK,ID=14,D=2
    2811 TSF:MSG:READ,0-0-5,s=255,c=3,t=8,pt=1,l=1,sg=0:0
    2817 TSF:MSG:FPAR OK,ID=0,D=1
    3289 TSF:MSG:READ,7-7-5,s=255,c=3,t=8,pt=1,l=1,sg=0:2
    3734 TSF:MSG:READ,4-4-5,s=255,c=3,t=8,pt=1,l=1,sg=0:1
    4105 TSM:FPAR:OK
    4106 TSM:ID
    4107 TSM:ID:OK
    4109 TSM:UPL
    4112 TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
    4118 TSF:MSG:READ,0-0-5,s=255,c=3,t=25,pt=1,l=1,sg=0:1
    4123 TSF:MSG:PONG RECV,HP=1
    4126 TSM:UPL:OK
    4127 TSM:READY:ID=5,PAR=0,DIS=1
    4132 TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
    4139 TSF:MSG:READ,0-0-5,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
    4146 TSF:MSG:SEND,5-5-0-0,s=255,c=0,t=18,pt=0,l=5,sg=0,ft=0,st=OK:2.1.0
    4155 TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
    4584 TSF:MSG:READ,0-0-5,s=255,c=3,t=6,pt=0,l=6,sg=0:Metric
    4590 TSF:MSG:ACK REQ
    4594 TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=6,pt=0,l=6,sg=0,ft=0,st=OK:Metric
    4602 TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=11,pt=0,l=6,sg=0,ft=0,st=OK:RELAY6
    4611 TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:0.1
    4620 TSF:MSG:SEND,5-5-0-0,s=1,c=0,t=3,pt=0,l=8,sg=0,ft=0,st=OK:Relais A
    4628 TSF:MSG:SEND,5-5-0-0,s=2,c=0,t=3,pt=0,l=8,sg=0,ft=0,st=OK:Relais B
    4637 TSF:MSG:SEND,5-5-0-0,s=3,c=0,t=3,pt=0,l=8,sg=0,ft=0,st=OK:Relais C
    4645 TSF:MSG:SEND,5-5-0-0,s=4,c=0,t=3,pt=0,l=8,sg=0,ft=0,st=OK:Relais D
    4655 TSF:MSG:SEND,5-5-0-0,s=5,c=0,t=3,pt=0,l=8,sg=0,ft=0,st=OK:Relais E
    4663 TSF:MSG:SEND,5-5-0-0,s=6,c=0,t=3,pt=0,l=8,sg=0,ft=0,st=OK:Relais F
    4670 MCO:REG:REQ
    4673 TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
    4679 TSF:MSG:READ,0-0-5,s=255,c=3,t=27,pt=1,l=1,sg=0:1
    4684 MCO:PIM:NODE REG=1
    4686 MCO:BGN:STP
    4714 TSF:MSG:READ,0-0-5,s=255,c=3,t=6,pt=0,l=6,sg=0:Metric
    5688 MCO:BGN:INIT OK,TSP=1
    7503 TSF:MSG:READ,8-8-5,s=255,c=3,t=8,pt=1,l=1,sg=0:1
    7508 !TSF:MSG:FPAR INACTIVE
    loop_count: 36610
    loop_count: 85099
    loop_count: 85091
    31153 TSF:MSG:SEND,5-5-0-0,s=1,c=1,t=2,pt=7,l=5,sg=0,ft=0,st=OK:0.0
    Switch A pressed
    34217 TSF:MSG:SEND,5-5-0-0,s=1,c=1,t=2,pt=7,l=5,sg=0,ft=0,st=OK:1.0
    Switch A pressed
    36277 TSF:MSG:SEND,5-5-0-0,s=1,c=1,t=2,pt=7,l=5,sg=0,ft=0,st=OK:0.0
    Switch A pressed
    loop_count: 84876
    Which kind of Gateway are you using?
    R 1 Reply Last reply
    • T tboha
      Only difference:
      4105 TSM:FPAR:OK
      4106 TSM:ID
      3 TSM:INIT
      4 TSF:WUR:MS=0
      11 TSM:INIT:TSP OK
      15 TSF:SID:OK,ID=5
      17 TSM:FPAR
      2062 TSM:FPAR
      4107 TSM:FPAR
      6152 TSM:FPAR
      8195 !TSM:FPAR:FAIL
      8196 TSM:FAIL:CNT=1
      8198 TSM:FAIL:PDT
      18203 TSM:INIT
      18216 TSM:FPAR
      20262 TSM:FPAR
      22308 TSM:FPAR
      24354 TSM:FPAR
      26401 TSM:FAIL:PDT
      3 TSM:INIT
      4 TSF:WUR:MS=0
      11 TSM:INIT:TSP OK
      15 TSF:SID:OK,ID=5
      17 TSM:FPAR
      2062 TSM:FPAR
      4105 TSM:FPAR:OK
      4106 TSM:ID
      4107 TSM:ID:OK
      4109 TSM:UPL
      4126 TSM:UPL:OK
      4670 MCO:REG:REQ
      4686 MCO:BGN:STP
      loop_count: 36610
      loop_count: 85099
      loop_count: 85091
      Switch A pressed
      Switch A pressed
      Switch A pressed
      loop_count: 84876
      R
      R
      Reza
      @tboha
      i use #define MY_RF24_CHANNEL 0 and all of node are #define MY_RF24_CHANNEL 0
      T 2 Replies Last reply
      • R Reza
        @tboha
        tboha
        @Reza
        Based on your answer I have to confess I didn´t read your log carefully enough - being fixed to missing ACKs I didn´t pay attention to successful transmissions.
        Difference between Node 160 log and Node 4 log is the complete absence of any messages from Node 0 (GW) in Node 160 log, whereas in Node 4 log there are answers from GW.
        So my next question would be: are these failures consistent?
        If you are not feed up already, would you please log some boot sequences from Node 4? And some button-presses too?
        I think it would be interesting if failures are the exact identical or just almost identical.
        (exact identical favors software problem, almost identical favors hardware problem).
        A parallel log from the GW would be nice too. Maybe there is a problem in the ACK system.
        If you don´t trust your OrangePi hardware - would a temporarily switch to Laptop/Windows/Linux make much effort? Just to prove integrity of GW-Arduino and radio.
        • R Reza
          @tboha
          tboha
          @Reza
          I forgot - you are completely right. Why is there any need for a repeater node in between at 1m distance?
          To get a clean solution you could isolate your GW and Node 4 by changing RF-channels and have a look at their private conversation without being disturbed by other (healthy) nodes.
          • J
            J
            Jan Gatzke
            Coul it be you are using modules with different chips? See https://forum.mysensors.org/topic/1153/we-are-mostly-using-fake-nrf24l01-s-but-worse-fakes-are-emerging
            • T tboha
              @Reza
              R
              R
              Reza
              @tboha
              sorry for english
              generally , my problem is connection.
              i have a controller (domoticz on orangepi) and one serial gateway with usb cable to controller. and some sensors in all of house (Sporadic) and some relay for test just in my room. id 4 or 160 is choose random for test. i am near controller and test some sketch, some relay , radio and etc...
              so my problem is just connection between relays and gateway. sensors is good and work well and report all of states. but relays. first can not connection and show error :
              (4143 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
              6152 TSM:FPAR
              8195 !TSM:FPAR:FAIL
              8196 TSM:FAIL:CNT=1
              8198 TSM:FAIL:PDT)
              but after some time (with some power off/on) relay can connect to gateway . but after connect this is very unstable and some command send and some command dont send and show error ( NACK...)
              i test and i change hardware and sketch but dont resolve :(
              this is a solution ?please explain more . what am i do ?
              use a repeater near gateway and use this for connect all of relays to gateway?
              • J Jan Gatzke
                R
                R
                Reza
                @Jan-Gatzke
                my radios is not fake. i use 3 type of radio nrf+ but i have problem
                J 1 Reply Last reply
                • R Reza
                  @Jan-Gatzke
                  J
                  J
                  Jan Gatzke
                  @Reza
                  Can you try to add the following line to your sketch?
                  Right at the top, along with the other defines. I had similar problems with a LED Dimmer node. This solved the problem.
                  • R Reza
                    @tboha
                    sorry for english
                    6152 TSM:FPAR
                    8195 !TSM:FPAR:FAIL
                    8196 TSM:FAIL:CNT=1
                    8198 TSM:FAIL:PDT)
                    tboha
                    @Reza No, an additional repeater was not intended (though it may be a solution).
                    From your "Node 4" log I conclude:
                    • you got at least 3 fully functional nodes (node 2,3,4). These nodes talk to each other in the environment of MySensors in an expected way.
                    • so hardware (radio and power) is ok. Software is ok too.
                    • GW functionality is partially ok - maybe hard- or software issues.
                    Now there is a decision to make: go on testing potentially defective hardware or start over with known intact hardware.
                    Go on testing means: are this failures reproducible? So I asked for logs of repeated boot sequences.
                    Until now we don´t know the exact failure. The parallel log from Gateway would show if there are really missing transmissions (and the extent of missing messages) or only missing ACKs.
                    I used ACKs last time in MySensors 1.4 and those days it made more trouble than profit. At last is showed up transmissions were ok (enough) the ACK system was not ok.
                    For my purposes MySensors keeps up with transmission difficulties so I have not to care about (15m Distance, in house, reinforced concrete). So I decided not to use ACKs anymore and this did not reduce performance.
                    If there are not to many missing transmissions (compare node messages vs. GW messages) I would skip the whole ACK thing.
                    I would test potentially defective hardware first because it is easy to get some logs an costs not much time.
                    Jan Gatzkes proposal is done quickly too.
                    An additional repeater would only obscure severe GW-problems. For the GW is the heart of MySensors system - you should not tolerate any problems (hard- or software) because it will come on top again in the very near future.
                    Starting over with known hardware takes more effort but should be doable in a manageable amount of time.
                    • J Jan Gatzke
                      @Reza
                      R
                      R
                      Reza
                      @Jan-Gatzke
                      use this just for nrf +pa+lna? now i use just usual nrf+
                      • T tboha
                        R
                        R
                        Reza
                        @tboha
                        i test my hardware, change these and test again with some radio and wire and arduino ....
                        now about parallel log .what am i do ? this is means i build 2 gateway?
                        • R Reza
                          @tboha
                          tboha
                          @Reza No.
                          Parallel may not be the exact description, I meant simultaneous recording of GW and node.
                          I don`t know about Domoticz - maybe there is a raw log function - then you are done.
                          Or if you installed arduino ide on your OrangePi just use the serial monitor.
                          Otherwise just hook up a terminal to your gateway.
                          I.e. on your OrangePi look for the device GW is bound to and start some terminal program linked hereto (e.g. putty, minicom, kermit).
                          R 2 Replies Last reply
                          • T tboha
                            @Reza No.
                            R
                            R
                            Reza
                            @tboha
                            i understand . ok thank you . i will test it
                            • R Reza
                              @tboha
                              tboha
                              @Reza
                              Sometimes it is better to step back and have a look from the distance.
                              A receipe for a clean restart.
                              you need:
                              2 working Arduinos with radio (node 4 and node 3 from your log)
                              1 working Computer/Laptop with 2 free USB interfaces
                              preferably Windows with Arduino IDE installed. (Linux might work too.)
                              connect both arduinos to your USB ports.
                              if Arduinos are different - write down which Arduino is on which port (eg. com34: or similar)
                              1. start Arduino IDE
                              2. from examples/Mysensors load "Gateway serial"
                                2a. choose one USB/COM-port.
                              3. don´t change anything and load it to the Arduino No.1
                              4. from examples/Mysensors load "MockMySensors"
                                4a. choose the other USB/COM-Port
                              5. don`t change anything and load it to Arduino No.2
                              You are done. Watch Arduinos communicating via serial monitor.
                              Ok- you are right - it is not truely simultaneaus - but close enough.
                              If this is ok you should try to upload the relay-sketch and watch what is happening.
                              This should not take to long, and as a result you will hopefully know:
                              • my hardware is ok or not
                              • my software (MySensors) is ok or not
                              • my sketch is ok or not.
                              • T tboha
                                @Reza No.
                                R
                                R
                                Reza
                                @tboha
                                hi friend , i test it and when i have NACK serial monitor is :
                                • T tboha
                                  @Reza
                                  you need:
                                  R
                                  R
                                  Reza
                                  @tboha
                                  i think found problem . i was careless about parent, relay is bad working when use a parent device for connect to gateway.but when connect directly , work better . more better . but now there is 2 questions ! first i am near gateway (1meter) and relay for test is near gateway.but after start or reset , some time relay choose a node (10 m far) for parent, while gateway is near that ! why ?
                                  i know that i can use static parent for nodes but i want know why node choose a node 10m far for parent while gateway is in near (1m)
                                  and second question. why with a parent relay work very bad and more command dont send and there is error!? this is related to power of radio of parent ?
                                  thank you
                                  • R Reza
                                    @tboha
                                    tboha
                                    @Reza this is weird - i have to think about.
                                    Just for clarification:
                                    it seems you issued a command at your controller which results in sending
                                    60;2;1;0;2;1
                                    dissected:
                                    60; = to node 60,
                                    2; = sensor 2
                                    1; = set value
                                    0; = unacknowledged message (?)
                                    2; = subtype is V_LIGHT
                                    1; = payload is "1"
                                    I think you hit button "Relais 2 ON" .
                                    The weird thing is - you haven`t asked for acknowledge - but system is trying to get acknowledge ---- strange.
                                    I just got your next question, I have to think about this too.
                                    • R Reza
                                      @tboha
                                      thank you
                                      tboha
                                      @Reza I think we are getting close to solution.
                                      This seems to be the crucial question.
                                      I never dived into the core functions how MySensors decides about choosing parent.
                                      Maybe it depends upon speed of answer?
                                      a little excerpt from an earlier log (which i didn´t read close enough, I told you).
                                      16 TSM:FPAR
                                      2061 TSM:FPAR
                                      2165 TSF:MSG:READ,2-2-4,s=255,c=3,t=8,pt=1,l=1,sg=0:1
                                      2170 TSF:MSG:FPAR OK,ID=2,D=2
                                      2340 TSF:MSG:READ,3-3-4,s=255,c=3,t=8,pt=1,l=1,sg=0:3
                                      4105 TSM:FPAR:OK
                                      4106 TSM:ID
                                      at 2097 Node 4 broadcasts for parent and gets accepted for parenting from Node 2.
                                      at 2340 Node 3 offers parenting too - upon which request?
                                      and why doesn`t GW offer parenting ?? GW shows up at 8240 with response to PING, so it is alive and connection was ok.
                                      at least at the moment - unexpected behavior.
                                      So reading logs give us some hints.
                                      Could you provide a little more from the simultaneous logs? And don´t stick to the NACK logs - the other messages are interesting as well.
                                      tekkaT R 2 Replies Last reply
                                      • T tboha
                                        16 TSM:FPAR
                                        2061 TSM:FPAR
                                        4105 TSM:FPAR:OK
                                        4106 TSM:ID
                                        tekkaT
                                        tekkaT
                                        tekka
                                        @tboha
                                        Thanks for your time and effort, you're doing an excellent analysis. Please find below some answers to your questions:
                                        The find parent step is initiated by a local I_FIND_PARENT_REQUEST broadcast, i.e. all repeaters/GW will reply with I_FIND_PARENT_RESPONSE if their uplink connections are operational (this prevents circular referencing). Node 3 (@2340) is replying to the same request, but ignored due to a greater distance to the GW (D=3+1=4 vs D=1+1=2 from node 4). The GW does not offer parenting, because it's either too close (radio interference) or too far from the requesting node. After a timeout (default 2000ms) the node uses the closest repeater/GW that replied to the request unless a static/preferred parent is defined.
                                        • T tboha
                                          16 TSM:FPAR
                                          2061 TSM:FPAR
                                          4105 TSM:FPAR:OK
                                          4106 TSM:ID
                                          R
                                          R
                                          Reza
                                          @tboha
                                          my friend . i am so sorry , i am weak in english and i can not know what am i do and you told to me what am i do!!
                                          very very thank you for time and tried for me and my problem. i can not get your time more i am sorry . i am very thank you for tried for me but i think , i am failure.
                                          this is very complicate for me because i am beginner.
                                          problems is many. this serial monitor is some problem. every time in serial monitor there is new problem and new error.
                                          i am Ashamed for your time and thank you . i can not understand your guidance.
