  3. ESP-8266 gateway with sensor can't communicate with controller
5 Posts 3 Posters 1.7k Views 3 Watching
  • Senne Vande SompeleS Offline
    Senne Vande Sompele
    hi everybody,
    I've read a lot of topics but can't seem to find out what i'm doing wrong.
    I've a wemos D1 mini with a switch connected to it and i want to send the state of this switch to Home Assistant
    The following code is running on my d1:
    #include <EEPROM.h>
    #define MY_BAUD_RATE 9600
    #define MY_GATEWAY_ESP8266
    #define MY_ESP8266_SSID "xxxxxxx"
    #define MY_ESP8266_PASSWORD "xxxxxxx"
    #define MY_IP_ADDRESS 192,168,0,9
    #define MY_PORT 5003
    #define CHILD_ID 1
    #define BUTTON_PIN  0  // Arduino Digital I/O pin for button/reed switch
    #include <ESP8266WiFi.h>
    Bounce debouncer = Bounce();
    int oldValue=-1;
    bool initialValueSent = false;
    MyMessage msg(CHILD_ID,V_STATUS);
      pinMode(BUTTON_PIN,INPUT_PULLUP);
      // Activate internal pull-up
      //digitalWrite(BUTTON_PIN,HIGH);
      debouncer.attach(BUTTON_PIN);
      debouncer.interval(5);
      Serial.println("Presentation:");
      sendSketchInfo("Switch", "1.1");
      present(CHILD_ID, S_BINARY);
      debouncer.update();
      // Get the update value
       int value = debouncer.read();
      if (value != oldValue) {
         // Send in the new value
         Serial.println(value);
         send(msg.set(value==HIGH ? 1 : 0));
         oldValue = value;
      if (message.isAck()) {
      Serial.println("something was received: "+ message.type);
    and got follwing output
    0;255;3;0;9;Starting gateway (R-NGE-, 2.0.0)
    scandone
    f 0, scandone
    state: 0 -> 2 (b0)
    state: 2 -> 3 (0)
    state: 3 -> 5 (10)
    add 0
    aid 3
    cnt
    connected with telenet-CED24D5, channel 11
    ip:192.168.0.9,mask:255.255.255.0,gw:192.168.0.1
    .IP: 192.168.0.9
    pm open,type:2 0
    and in home assistant i get following in the debug:
    16-12-31 11:45:08 mysensors.mysensors: Trying to connect to ('192.168.0.9', 5003)
    16-12-31 11:45:08 mysensors.mysensors: Connected to ('192.168.0.9', 5003)
    16-12-31 11:45:09 netdisco.service: Scanning
    16-12-31 11:45:09 mysensors.mysensors: Received 0;255;3;0;14;Gateway startup complete.
    0;255;3;0;11;Switch
    0;255;3;0;12;1.1
    0;1;0;0;3;
    16-12-31 11:45:09 mysensors.mysensors: Node 0 is unknown
    16-12-31 11:45:09 mysensors.mysensors: Requesting new presentation for node 0
    16-12-31 11:45:09 mysensors.mysensors: Node 0 is unknown, will not add child 1.
    16-12-31 11:45:09 mysensors.mysensors: Sending 0;255;3;0;19;
    can someone help me getting this working
    mfalkviddM martinhjelmareM 2 Replies Last reply
    • Senne Vande SompeleS Senne Vande Sompele
      hi everybody,
      #include <EEPROM.h>
      #define CHILD_ID 1
      int oldValue=-1;
        debouncer.update();
           oldValue = value;
      scandone
      f 0, scandone
      state: 0 -> 2 (b0)
      state: 2 -> 3 (0)
      state: 3 -> 5 (10)
      add 0
      aid 3
      cnt
      .IP: 192.168.0.9
      pm open,type:2 0
      0;255;3;0;11;Switch
      0;255;3;0;12;1.1
      0;1;0;0;3;
      @Senne-Vande-Sompele try upgrading to MySensors 2.1 (which was relesed yesterday). 2.0 has a problem that causes the receive function to not be called on nodes that are gateways.
        hi everybody,
        #include <EEPROM.h>
        #define CHILD_ID 1
        int oldValue=-1;
          debouncer.update();
             oldValue = value;
        scandone
        f 0, scandone
        state: 0 -> 2 (b0)
        state: 2 -> 3 (0)
        state: 3 -> 5 (10)
        add 0
        aid 3
        cnt
        .IP: 192.168.0.9
        pm open,type:2 0
        0;255;3;0;11;Switch
        0;255;3;0;12;1.1
        0;1;0;0;3;
        martinhjelmareM Offline
        martinhjelmare
        Mysensors 2.0 has a bug that leads to gateways without radio to not present themselves, which is why node 0 (gateway) is unknown in your log. This is fixed in mysensors 2.1.
        Senne Vande SompeleS 1 Reply Last reply
          Senne Vande Sompele
          I've upgraded and everything works now thank you very much
            Great work @Senne-Vande-Sompele, thanks for reporting back!
            12.1k
