  3. No forward link or gateway feature activated, but I did.
sonoffesp8266library
7 Posts 3 Posters 3.7k Views 4 Watching
  • nicomediaN Offline
    nicomediaN Offline
    nicomedia
    I made some code for a Sonoff relay, which has an esp8266 chipset. I defined MY_GATEWAY_ESP8266, but when I compile it gives me this error: No forward link or gateway feature activated.
    How can I solve it? I did define my gateway.
    • F Offline
      F Offline
      Fabien
      did you define the radio ?
      nicomediaN 1 Reply Last reply
      • H Offline
        H Offline
        Did you define that before or after including MySensors.h?
        • H hek
          nicomediaN Offline
          nicomediaN Offline
          nicomedia
          @hek Tried both, doesn't make a difference. I'll include my sketch below.
          #include <MyConfig.h>
          // Modalità debug
          // Baud rate seriale mod. debug
          #define MY_BAUD_RATE 9600
          //#define MY_RADIO_NRF24
          #define MY_GATEWAY_ESP8266
          #define MY_ESP8266_SSID "SSID"
          #define MY_ESP8266_PASSWORD "Password"
          //#define MY_USE_UDP
          #define MY_ESP8266_HOSTNAME "Sonoff1"
          //Porta in ascolto
          #define MY_PORT 5003
          // Numero massimo di client
          // Enable inclusion mode
          // #define MY_INCLUSION_BUTTON_FEATURE
          #define MY_REPEATER_FEATURE
          #define RELAY_1  12  // Pin del relè
          #define NUMBER_OF_RELAYS 1 // Numero di relè
          #define RELAY_ON 1  // Stato del pin per relè attivo
          #define RELAY_OFF 0 // Stato del pin per relè inattivo
          #if defined(MY_USE_UDP)
          #include <WiFiUdp.h>
          #include <ESP8266WiFi.h>
          void before()
              // Imposta il quale pin è quello del relè
              pinMode(pin, OUTPUT);
              // Imposta il relè allo stato precedente (in caso salti la luce)
          	  // Invia informazioni versione al gateway
            sendSketchInfo("Relay", "1.0");
              // Presenta i sensori locali al gateway
              present(sensor, S_BINARY);
            // Controllo il messaggio inviato
            if (message.type==V_STATUS) {
              // Cambia stato relè
              // Memorizza stato relè
              // Informazioni debug
              Serial.print("Cambiamento relè:");
              Serial.print(", Nuovo Stato:");
          • F Fabien
            nicomediaN Offline
            nicomediaN Offline
            nicomedia
            @Fabien I did but I got the same error
            • H Offline
              H Offline
              Always put the include after the defines. The sketch posted above is wrong and will fail at compile time. And remove the MyConfig.h include.
              • H hek
                nicomediaN Offline
                nicomediaN Offline
                nicomedia
                @hek That did it! I included the library with the Arduino IDE and it put it on the top. Didn't know that, thanks!
                12.1k
