  2. Announcements
  • luizrrochaL luizrrocha
    @Oli: sorry, correct syntax is ps -ef | grep my
    OliO
    OliO
    Oli
    @luizrrocha
    pi@raspberrypi ~ $ ls /dev
    autofs mmcblk0p1 stderr tty36 ttyAMA0
    block mmcblk0p2 stdin tty37 ttyMySensorsGateway
    btrfs-control net stdout tty38 ttyprintk
    bus network_latency tty tty39 ttyUSB0
    cachefiles network_throughput tty0 tty4 ttyUSB20
    char null tty1 tty40 uhid
    console ppp tty10 tty41 uinput
    cpu_dma_latency ptmx tty11 tty42 urandom
    cuse pts tty12 tty43 vc-cma
    disk ram0 tty13 tty44 vchiq
    fb0 ram1 tty14 tty45 vcio
    fd ram10 tty15 tty46 vc-mem
    full ram11 tty16 tty47 vcs
    fuse ram12 tty17 tty48 vcs1
    gpiomem ram13 tty18 tty49 vcs2
    hwrng ram14 tty19 tty5 vcs3
    i2c-1 ram15 tty2 tty50 vcs4
    input ram2 tty20 tty51 vcs5
    kmsg ram3 tty21 tty52 vcs6
    log ram4 tty22 tty53 vcsa
    loop0 ram5 tty23 tty54 vcsa1
    loop1 ram6 tty24 tty55 vcsa2
    loop2 ram7 tty25 tty56 vcsa3
    loop3 ram8 tty26 tty57 vcsa4
    loop4 ram9 tty27 tty58 vcsa5
    loop5 random tty28 tty59 vcsa6
    loop6 raw tty29 tty6 vhci
    loop7 root tty3 tty60 watchdog
    loop-control serial tty30 tty61 watchdog0
    MAKEDEV shm tty31 tty62 xconsole
    mapper snd tty32 tty63 zero
    mem sndstat tty33 tty7
    memory_bandwidth spidev0.0 tty34 tty8
    mmcblk0 spidev0.1 tty35 tty9
    pi@raspberrypi ~ $ ps -ef | grep my
    root 2079 1 1 18:40 ? 00:02:49 /usr/local/bin/mysgw -b
    pi 4214 4181 0 21:25 pts/2 00:00:00 grep --color=auto my
    luizrrochaL 1 Reply Last reply
    • OliO Oli
      @luizrrocha
      luizrrochaL
      luizrrochaL
      luizrrocha
      @Oli : the port name is actually ttyMySensorsGateway, you have to correct the definition of the gateway on Domoticz to use it....
      Luiz
      OliO 1 Reply Last reply
      • J jacikaas
        Could someone answer: if i have RPi NRF24 GW, how I could connect MYSController from other computer (for example from Windows computer)?
        1. Is it possible to make that type connection with RPi NRF24 GW?
        2. May I use some integrated web server for this type of connection in RPi to make it work? Is there are easier solutions?
        EDIT: no matter, already answered it by myself :)
        Its easy becose it's like Ethernet GW.
        luizrrochaL
        luizrrochaL
        luizrrocha
        @jacikaas : on MYSController go to Settings -> Gateway -> TCP/IP and add the IP address of the Gateway and use port 5003. It works even if the gateway is feeding data to Domoticz, so you can monitor your sensors in "raw" mode.
        Cheers,
        Luiz
          Luiz
          OliO
          OliO
          Oli
          wrote on last edited by Oli
          #241
          @luizrrocha as You can see, on the picture above, I've wrote that ttyUSBMySensors.... is from my previous backup copy. On the same pictures You can also see that I can choose only from three serial ports: USB0, USB20 and AMA0. Thera are no ttyMySensorsGateway despite that it is present after ls /dev.
          And that's the problem, I dont know how to make it present in the serial ports popup menu.
          • OliO Oli
            luizrrochaL
            luizrrochaL
            luizrrocha
            @Oli : why not remove the old definition to avoid any trash information and restarting Domoticz to make shure it rereads the port info before creating the new entry ?
            And I do not understand why if you are running domoticz and the gateway on the same Pi, why not use a ethernet gateway and set 127.0.0.1 and port 5003 on the Domoticz gateway entry. I did that and never had to worry about USB ports at all.
              OliO
              OliO
              Oli
              @luizrrocha
              Of course I did that, I started from the scratch... but when it did not work I try to restore my backup... but it did not work also...
              simple... I have no free LAN on my rotuer... there is more, I also have raZberry daughter board (Z-Wave) connected to same Raspberry Pi GPIO port. And till today everything works perfect until... "Better is the enemy of the good" ;-)
              • OliO
                OliO
                Oli
                #244
                OK I found the solution (thanks to @luizrrocha). I change
                ./configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyMySensorsGateway
                to
                ./configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyUSBMySensorsGateway and now its working.
                Question is, It's only workaround (in my case) or there is bug in the installation guide?
                • OliO Oli
                  to
                  luizrrochaL
                  luizrrochaL
                  luizrrocha
                  @Oli : if both the gateway and Domoticz run on the same Raspi, there is no physical network involved, hence the 127.0.0.1 dummy local address is used by Domoticz to talk to the gateway on the same machine, just using port 5003... and since you use localhost (127.0.0.1, a virtual network) there is no need to create a virtual USB port which is what you did...
                    OliO
                    OliO
                    Oli
                    @luizrrocha interesting... step by step instruction?
                    • OliO Oli
                      luizrrochaL
                      luizrrochaL
                      luizrrocha
                      @Oli: delete the Makefile.inc file on mysensors folder
                      make
                      sudo ./bin/mysgw -b
                      go to domoticz and create a new MySensors Gateway with LAN, inform 127.0.0.1 as the address and 5003 as the port...
                      that should do the trick.
                      • ysinhY ysinh
                        A tiny hint for the users of domoticz :
                        ./configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyUSB20
                        make
                        :) i hope this helps
                        then in the hardware setup
                        MySensors Gateway USB
                        serial port: /dev/ttyUSB20
                        carlylerC
                        carlylerC
                        carlyler
                        @Oli luizrocha's configuration seems interesting, but just in case your still wanting the serial, from above, has worked for me in the past, but I have since switched to OH2:
                        make
                        • W
                          W
                          Wackid
                          I am also not get it to work in Domoticz tried the USB serial and ethernet way.
                          It's a testing pi. Where i didn't connected the radio. Because it's still in the Nano. Could that be the issue? I guess not.
                          • M marceloaqno
                            @aand @Tag @jirm MySensors uses its own nrf24 drivers, and OrangePi is not currently supported. It will be in the future.
                            Tag
                            wrote on last edited by Tag
                            #250
                            @marceloaqno, @jirm, @aand
                            Hi!,
                            I started a new topic for Mysensors Gateway on OrangePI (OPI), Here
                            Hope this is okay,
                            Kind regards,
                            Tag
                              Mihai
                              wrote on last edited by Mihai
                              #251
                              The Pi MQTT Gateway with IRQ connected may handle better the messages into a loaded network than Ethernet MQTT Gateway where IRQ is not used? (with NRF24)
                              Also I would like to know if I can use the other pins of RPi to connect some digital sensors directly there.
                              • W
                                W
                                Wackid
                                @Oli
                                Stupid question... Did you mount the radio? Because I thought I would like to test if it works. (without radio) but that doesn't work.
                                Mounted a radio and ethernet gateway is working.
                                • eyesoftE
                                  eyesoftE
                                  eyesoft
                                  @Mihai
                                  Maybe i'm wrong but IRQ is used on all gateways if you read above :
                                  Improving throughput for nrf24
                                  There is another method were the interrupt pin from the nrf24 modules is used to inform when a new message arrives and it's immediately added to a queue for further processing
                                  for the second part yes you can use other pins on RPi ... i have RF module NRF24L01 for gateway and DHT11 on RPi.
                                    Ditto, @Robinek70 !
                                    'nuff said.
                                    Luiz Roberto
                                    musthafa
                                    @luizrrocha said:
                                    Ditto, @Robinek70 !
                                    'nuff said.
                                    Luiz Roberto
                                    Can you please give me the instructions for Domoticz setup?
                                    I have a node with DHT11 sensor and I can see mygsw service is getting messages. How do I connect Domoticz with mysensors ?
                                    I have been following openhab until today and I'm switching to Domoticz now.
                                    • M musthafa
                                      @luizrrocha said:
                                      Ditto, @Robinek70 !
                                      'nuff said.
                                      Luiz Roberto
                                      luizrrochaL
                                      luizrrochaL
                                      luizrrocha
                                      Hello, @musthafa .
                                      For installation I used the tutorial at http://www.domoticz.com/wiki/Installing_and_running_Domoticz_on_a_Raspberry_PI. It looks like they changed the tutorial that I used to just a single curl command to install it, although there are complaints about it not working alright. You'll have to try it as I cannot reinstall mine.
                                      Setting up MySensors Gateway is also covered in the wiki : http://www.domoticz.com/wiki/MySensors, very easy. I recommend you go thru the wiki pages as I did, they are a treasure of information, as the manual on www.domoticz.com is outdated though useful.
                                      Good luck.
                                      Luiz
                                        Hello, @musthafa .
                                        Good luck.
                                        Luiz
                                        musthafa
                                        @luizrrocha said:
                                        Thank you!
                                        Hello, @musthafa .
                                        Domoticz Installation was straight forward as per their wiki.
                                        Good luck.
                                        Luiz
                                        MySensors I tried Ethernet didn't work. Virtual Serial Port worked for me. However I have 1 light (LED Test at PIN 4 of Node) & a DHT sensor. Domoticz only lists the DHT sensor. It doesn't show me the light child.
                                        • M musthafa
                                          @luizrrocha said:
                                          Thank you!
                                          Hello, @musthafa .
                                          Good luck.
                                          Luiz
                                          luizrrochaL
                                          luizrrochaL
                                          luizrrocha
                                          @musthafa : look on the MySensors forum for the MYSController, install it and you can monitor the messages going to the gateway.
                                          Most likely your declaration of the LED output pin on the MySensors arduino is not correct. I still did not use arduinos as actuators with MySensors so I will probably not be of much help here.
                                          Cheers,
                                          Luiz
