  3. Mysensors Gateway on OrangePi (Zero) (opi)
117 Posts 11 Posters 66.1k Views 11 Watching
  • T
    Tag
    wrote on last edited by Tag
    Hi All!,
    I am currently trying to build the mysensors gateway on the OrangePI Zero, However it seems that tahe NRF24L01 radio is not supported. and the SPI.h is missing on the OPI.
    Everything works like a charm on the RaspberryPI.
    Has anyone already managed to use the mysgw on the orange PI?
    The OS i use is ARMBIAN. and MySensors 2.1.0
    Erorrs:
    In file included from examples_linux/mysgw.cpp:74:0:
    ./MySensors.h:258:2: error: #error No support for nRF24 radio on this platform
    In file included from ./drivers/RF24/RF24.cpp:23:0,
    from ./MySensors.h:294,
    ./drivers/RF24/RF24.h:52:17: fatal error: SPI.h: No such file or directory
    Really like MySensors, great piece of software!!
    Thanks in advance for any response!
    Kind regards,
    Tag
    jirmJ 1 Reply Last reply
    • pansenP
      pansenP
      pansen
      I just ordered a Opi Plus 2e for usage as a controller + nRF24 PCB. Since you have a zero and my device is not here yet I can only give you some theoretical thoughts:
      First error: this should be easily fixable, but it involves modifiying code.
      Second error: needs a bit more work, because SPI.h is specifically written for RPi, which has different hardware than OPi. I will develop something for my Plus 2e and this could work for you too :)
      Without coding experience it will be very difficult to achieve anything here...
      Orange Pi Plus 2e connected to nrf24 PA via SPI running git-development MySensors gateway, OpenHAB2, mosquitto and MySQL persistence.
      T jirmJ 2 Replies Last reply
      • T Tag
        Hi All!,
        Erorrs:
        Kind regards,
        Tag
        jirmJ
        jirmJ
        jirm
        @Tag
        I agree to open a new thread specifically to try to run Mysensor on Orange PI.
        With some help here from Mysensors coders I belive is possible to make it work soon.
        As a summary I think that you can already make several tests that yesterday were suggested by @marceloaqno and @aanden @hausinger and in the general all OPI users for post of support to the installation of mysgw to see the result of the same and evaluate if these produce some progress in the solution.
        I have some rage at not being able to do them test myself and help much bettter, but I am away from home during these days and I have no possibility.
        In any case try to summarize what would be convenient to try on first place if can detect nrf24 module with RF24 driver, as suggested yesterday by @marceloaqno:
        The configure script from MySensor repo is based on the https://github.com/TMRh20/RF24/blob/master/configure.
        Could you try with theTMRh20 master branch and post the result?
        Git clone https://github.com/TMRh20/RF24.git
        Cd RF24
        ./configure
        Make
        As reference that maybe can help too below post about install NRF24 module on OPI and Armbian, that they finally make work the board:
        https://forum.armbian.com/index.php/topic/3161-orange-pi-one-with-nrf24l01/
        Regards
        T 1 Reply Last reply
        • jirmJ jirm
          @Tag
          Cd RF24
          ./configure
          Make
          Regards
          Tag
          Hi!,
          I can confirm that i can build the RF24 from TMRh20 without any errors..
          root@orangepizero:~# git clone https://github.com/TMRh20/RF24.git
          Cloning into 'RF24'...
          remote: Counting objects: 3041, done.
          remote: Compressing objects: 100% (8/8), done.
          remote: Total 3041 (delta 2), reused 0 (delta 0), pack-reused 3033
          Receiving objects: 100% (3041/3041), 1.32 MiB | 835.00 KiB/s, done.
          Resolving deltas: 100% (1795/1795), done.
          Checking connectivity... done.
          root@orangepizero:~# cd RF24/
          root@orangepizero:~/RF24# ./configure
          [SECTION] Detecting arm compilation environment.
          [OK] arm-linux-gnueabihf-gcc detected.
          [OK] arm-linux-gnueabihf-g++ detected.
          [SECTION] Detecting target machine.
          [OK] machine detected: SoC=H3, Type=unknown, CPU=armv7l.
          [SECTION] Detecting DRIVER
          [OK] DRIVER detected:SPIDEV.
          [SECTION] Detecting OS.
          [INFO] OS detected:LINUX.
          [SECTION] Preparing configuration.
          [SECTION] Saving configuration.
          [SECTION] Cleaning previous builds.
          [OK] Finished.
          root@orangepizero:~/RF24# make
          arm-linux-gnueabihf-g++ -fPIC -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -Ofast -Wall -pthread -c RF24.cpp
          /tmp/ccMd5F0g.s: Assembler messages:
          /tmp/ccMd5F0g.s:3924: Warning: IT blocks containing 32-bit Thumb instructions are deprecated in ARMv8
          arm-linux-gnueabihf-g++ -fPIC -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -Ofast -Wall -pthread -c utility/SPIDEV/spi.cpp
          arm-linux-gnueabihf-g++ -fPIC -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -Ofast -Wall -pthread -c utility/SPIDEV/gpio.cpp
          arm-linux-gnueabihf-gcc -fPIC -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -Ofast -Wall -pthread -c utility/SPIDEV/compatibility.c
          arm-linux-gnueabihf-g++ -fPIC -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -Ofast -Wall -pthread -c utility/SPIDEV/interrupt.c
          [Linking]
          arm-linux-gnueabihf-gcc -pthread -shared -Wl,-soname,librf24.so.1 -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -Ofast -Wall -pthread -o librf24.so.1.2.0 RF24.o spi.o gpio.o compatibility.o interrupt.o
          Unfortunately i do not have that much experience with coding... but i can try to help as much as possible by testing.....
          Anyway many thanks for all your help!!
          kind regards,
          Tag
          • pansenP pansen
            Tag
            Thanks!!
            • pansenP pansen
              jirmJ
              jirmJ
              jirm
              wrote on last edited by jirm
              Hi @pansen
              Totally agree that is needed modify mysensors code (at least some files of mysgw installation process) to make work it on OPI board. But I'm little more optimistic with that because some coder here ( @marceloaqno ??? ) sure would help mostly if only is needed include the changes on code but we can offer he all the workaround about issues we found and tested all the code that can avoid the problems.
              About SPI.h , of course we need provide tested the proper all OPI librarys that differ from Raspi.
              Regard this I´m figure that the SPI library is included in the driver for NRF24 (Tmr20h) that @aand some days ago feedback is working fine on OPI.
              If so then only will be need changed this library to de mysgw installation process when a OPI board is detected.
              See you
              pansenP 1 Reply Last reply
              • T Tag
                Hi!,
                [OK] Finished.
                [Linking]
                kind regards,
                Tag
                jirmJ
                jirmJ
                jirm
                @Tag
                I see... Then we have a driver installed properly on OPI from where Mysensors gateway are derived that they use. So agree this issue seems easily fixable on mysensors code.
                Can you now that have a NRF24 driver installed try follow the step by step mysgw installation process ( https://www.mysensors.org/build/raspberry ) and post here what happens ?
                I figure that SPI library (for OPI) is needed too for the master driver TMR20h, so seems is only needed adapt the mysgw code to use this when the OPI board are detected.
                I belive this next too lines extracted from your test say SPI is well detected and ready:
                I think banana boards are in the exact same situation than OPI (yesterday someone run the same tests in Banana board and have the same result) and maybe is easy can include both at same time on Mysensors.
                Now is matter that any mysensors coder can ear our call and help us to deal with mysensors code
                See you
                • jirmJ jirm
                  Hi @pansen
                  See you
                  pansenP
                  pansenP
                  pansen
                  Agreed! The way I see it too is that we just need to swap RPi SPI library with the OPi implementation (SPIDEV by the looks) or write a wrapper that looks the same to mysensors. I'm raging too because I won't get my board before a few weeks...Tmr20h's git code should be good to see if the NRF24 board actually works at all. Programmingwise I'd create a new compiler flag, identifying the host computer as an OPi and then from there...I am new to community projects, could a fork easily be merged back into the master branch? What's the procedure for mysensors?
                  • pansenP
                    pansenP
                    pansen
                    probably related: https://github.com/mysensors/MySensors/issues/719
                    • pansenP pansen
                      jirmJ
                      jirmJ
                      jirm
                      Hi @pansen, yes no seems so much tricky and will need so much effort to make the proper changes to Mysensors code for install on OPI (and Banana) , but that is only matter that main code developers here that are maintaining this code like do that but in this moment I don't know what is in the developer's "brain" about include support for other boards than RPI....so like I said before we only can ask they and purpose include their support for OPI board and see what will happen.
                      I'm too not a software coder, so can reply properly about coding and her methods and best practices but anyone can always "purpose" the changes to the responsible developers directly on through the github repository of the concrete software (similar to report issues, purpose improvements, etc...) and then if approved by developers they make the changes to the code.
                      Of course always anyone can fork the github (if is licence allowed) and make another branch/project to fits its own purposes.
                      Regards.
                      • pansenP pansen
                        jirmJ
                        jirmJ
                        jirm
                        @pansen Yes...This is a pull purpose to support Banana.
                        If you see yesterday messages on support post for Mysensors RPI Gateway, you can see some test for that guy @eyesoft and I like see this ended in that purpose on github. That's I would mean about all that before.
                        We can do the same about OPI boards because we are in exactly same situation and have the same test than Banana completed.
                        Generally speaking all this is I refer in my last post here.
                        Regards
                        • pansenP
                          pansenP
                          pansen
                          @jirm ah yes, sorry, I oversaw that. Digging more into what you wrote, git and the forum it looks liek there is some progress. See also @marceloaqno fork: https://github.com/marceloaqno/MySensors/commit/8ae05ac79b5b603754350fe0ac8b96b0ad2ab9b7?diff=split
                          • pansenP pansen
                            jirmJ
                            jirmJ
                            jirm
                            @pansen
                            Yes...the test that @eyessoft did were indicated by @marceloaqno that is a developer on mysensors...so I suppose he are over it to solve.
                            I hope @marceloaqno (that knows about OPI issue and yesterday he too try help us with OPI) don't forget us and help to make work OPI too.
                            But we need some guy with OPI board ( @Tag ?? ) that in short time can follow the developer indications and run the test he purpose for debug and test when he are modifying the code .
                            So that's where we are for now...
                            Regards
                            • jirmJ jirm
                              @pansen
                              Regards
                              jirmJ
                              jirmJ
                              jirm
                              @Tag, @pansen
                              I insist that I think that it would be very good if whatever ( @Tag ?? ) that has an OPI in place tried to run the mysgw install again and see what errors appear just after compile NRF24 driver, now that we know the TRM20h driver is working.
                              With this test we could try to transfer the result to @marceloqano (or any developer available here) to try to also modify the mysensors code for OPI.
                              Regards
                              • T
                                Tag
                                Hi Guys,
                                Sure, just let me know what to test.... The OPI is up and running :)
                                Sofar this is what i did:
                                Install the NRF24 driver:
                                [OK] Finished.
                                [Linking]
                                root@orangepizero:~/RF24# make install
                                [Installing Libs to /usr/local/lib]
                                [Installing Headers to /usr/local/include/RF24]
                                MySensors:
                                root@orangepizero:~# git clone https://github.com/mysensors/MySensors.git
                                Cloning into 'MySensors'...
                                remote: Counting objects: 13768, done.
                                remote: Compressing objects: 100% (12/12), done.
                                remote: Total 13768 (delta 1), reused 0 (delta 0), pack-reused 13754
                                Receiving objects: 100% (13768/13768), 9.61 MiB | 3.08 MiB/s, done.
                                Resolving deltas: 100% (8248/8248), done.
                                root@orangepizero:~# cd MySensors/
                                root@orangepizero:~/MySensors# ./configure
                                [OK] init system detected: systemd
                                [OK] Finished.
                                root@orangepizero:~/MySensors# make
                                gcc -MT build/drivers/Linux/log.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -c drivers/Linux/log.c -o build/drivers/Linux/log.o
                                g++ -MT build/drivers/Linux/noniso.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -c drivers/Linux/noniso.cpp -o build/drivers/Linux/noniso.o
                                g++ -MT build/drivers/Linux/Print.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -c drivers/Linux/Print.cpp -o build/drivers/Linux/Print.o
                                g++ -MT build/drivers/Linux/EthernetClient.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -c drivers/Linux/EthernetClient.cpp -o build/drivers/Linux/EthernetClient.o
                                g++ -MT build/drivers/Linux/SerialPort.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -c drivers/Linux/SerialPort.cpp -o build/drivers/Linux/SerialPort.o
                                g++ -MT build/drivers/Linux/Stream.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -c drivers/Linux/Stream.cpp -o build/drivers/Linux/Stream.o
                                g++ -MT build/drivers/Linux/IPAddress.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -c drivers/Linux/IPAddress.cpp -o build/drivers/Linux/IPAddress.o
                                g++ -MT build/drivers/Linux/compatibility.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -c drivers/Linux/compatibility.cpp -o build/drivers/Linux/compatibility.o
                                g++ -MT build/drivers/Linux/SoftEeprom.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -c drivers/Linux/SoftEeprom.cpp -o build/drivers/Linux/SoftEeprom.o
                                g++ -MT build/drivers/Linux/EthernetServer.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -c drivers/Linux/EthernetServer.cpp -o build/drivers/Linux/EthernetServer.o
                                g++ -MT build/examples_linux/mysgw.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -c examples_linux/mysgw.cpp -o build/examples_linux/mysgw.o
                                compilation terminated.
                                Makefile:98: recipe for target 'build/examples_linux/mysgw.o' failed
                                make: *** [build/examples_linux/mysgw.o] Error 1
                                Followed the manual you pointed out to install for RPI
                                Seems i use the beta software:
                                root@orangepizero:~/MySensors# more README.md
                                MySensors Library v2.2.0-beta
                                Armbian:
                                root@orangepizero:~# uname -a
                                Linux orangepizero 3.4.113-sun8i #50 SMP PREEMPT Mon Nov 14 08:41:55 CET 2016 armv7l GNU/Linux
                                ARMBIAN Debian GNU/Linux 8 (jessie) 3.4.113-sun8i
                                Hope it helps!
                                • T
                                  Tag
                                  @pansen,
                                  Not sure if this is useful but, checked this one:https://github.com/mysensors/MySensors/issues/719
                                  root@orangepizero:~/test# git clone https://github.com/marceloaqno/MySensors.git marceloaqno-spidev
                                  Cloning into 'marceloaqno-spidev'...
                                  remote: Counting objects: 13825, done.
                                  remote: Compressing objects: 100% (26/26), done.
                                  remote: Total 13825 (delta 4), reused 0 (delta 0), pack-reused 13799
                                  Receiving objects: 100% (13825/13825), 9.65 MiB | 3.27 MiB/s, done.
                                  Resolving deltas: 100% (8284/8284), done.
                                  root@orangepizero:~/test# cd marceloaqno-spidev/
                                  root@orangepizero:~/test/marceloaqno-spidev# git checkout spidev
                                  Branch spidev set up to track remote branch spidev from origin.
                                  Switched to a new branch 'spidev'
                                  root@orangepizero:~/test/marceloaqno-spidev# ;s
                                  -bash: syntax error near unexpected token `;'
                                  root@orangepizero:~/test/marceloaqno-spidev# ls
                                  configure Doxyfile initscripts Makefile README.md
                                  CONTRIBUTING.md drivers keywords.txt MyConfig.h tests
                                  core examples library.json MySensors.h
                                  Documentation examples_linux library.properties projects
                                  root@orangepizero:~/test/marceloaqno-spidev# ./configure
                                  [SECTION] Detecting GPIO driver.
                                  [OK] GPIO driver detected:SPIDEV.
                                  [SECTION] Detecting init system.
                                  [OK] init system detected: systemd.
                                  [OK] Finished.
                                  root@orangepizero:~/test/marceloaqno-spidev# make
                                  gcc -MT build/drivers/Linux/log.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_DRIVER_SPIDEV -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/log.c -o build/drivers/Linux/log.o
                                  g++ -MT build/drivers/Linux/noniso.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_DRIVER_SPIDEV -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/noniso.cpp -o build/drivers/Linux/noniso.o
                                  g++ -MT build/drivers/Linux/Print.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_DRIVER_SPIDEV -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/Print.cpp -o build/drivers/Linux/Print.o
                                  g++ -MT build/drivers/Linux/EthernetClient.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_DRIVER_SPIDEV -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/EthernetClient.cpp -o build/drivers/Linux/EthernetClient.o
                                  g++ -MT build/drivers/Linux/SerialPort.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_DRIVER_SPIDEV -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/SerialPort.cpp -o build/drivers/Linux/SerialPort.o
                                  g++ -MT build/drivers/Linux/Stream.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_DRIVER_SPIDEV -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/Stream.cpp -o build/drivers/Linux/Stream.o
                                  In file included from drivers/Linux/Stream.cpp:24:0:
                                  ./drivers/Linux/Arduino.h:17:18: fatal error: GPIO.h: No such file or directory
                                  #include "GPIO.h"
                                  Makefile:114: recipe for target 'build/drivers/Linux/Stream.o' failed
                                  make: *** [build/drivers/Linux/Stream.o] Error 1
                                  • T Tag
                                    @pansen,
                                    [OK] Finished.
                                    #include "GPIO.h"
                                    jirmJ
                                    jirmJ
                                    jirm
                                    Hi @Tag
                                    We ( I and @pansen ) talked about that fork over mysensors github that @marceloaqno are doing to support Bananapi.
                                    Banana have same soc than OPI, so the issues are the same on both boards for compile mysensors at least at that point. Maybe own OPI GPIO library (If I remeber Wiringpi or similar name or so) will be needed added to the mysensors software, but hope this can be easily do it like one last point.
                                    Can you give a try on your OPI board and post results doing same commands than @eyesoft are doing for Banana on the forked github?
                                    Then we can see if the same solution than @marceloaqno are building for Banana can be directly applied to our OPI.
                                    I mean do this steps:
                                    git checkout spidev
                                    then...
                                    ./configure --my-gateway=ethernet --my-transport=nrf24 --my-rf24-irq-pin=15 --my-rf24-channel=119
                                    and last
                                    make
                                    • jirmJ jirm
                                      Hi @Tag
                                      git checkout spidev
                                      then...
                                      and last
                                      make
                                      Tag
                                      @jirm
                                      Sure!, here you go:
                                      root@orangepizero:~# rm -r MySensors/
                                      root@orangepizero:~# git clone https://github.com/marceloaqno/MySensors.git marceloaqno-spidev
                                      Receiving objects: 100% (13825/13825), 9.65 MiB | 3.01 MiB/s, done.
                                      root@orangepizero:~# cd marceloaqno-spidev/
                                      root@orangepizero:~/marceloaqno-spidev# git checkout spidev
                                      root@orangepizero:~/marceloaqno-spidev# ./configure --my-gateway=ethernet --my-transport=nrf24 --my-rf24-irq-pin=15 --my-rf24-channel=119
                                      [OK] Finished.
                                      root@orangepizero:~/marceloaqno-spidev# make
                                      gcc -MT build/drivers/Linux/log.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_DRIVER_SPIDEV -DMY_RF24_CHANNEL=119 -DMY_RX_MESSAGE_BUFFER_FEATURE -DMY_RF24_IRQ_PIN=15 -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/log.c -o build/drivers/Linux/log.o
                                      g++ -MT build/drivers/Linux/noniso.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_DRIVER_SPIDEV -DMY_RF24_CHANNEL=119 -DMY_RX_MESSAGE_BUFFER_FEATURE -DMY_RF24_IRQ_PIN=15 -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/noniso.cpp -o build/drivers/Linux/noniso.o
                                      g++ -MT build/drivers/Linux/Print.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_DRIVER_SPIDEV -DMY_RF24_CHANNEL=119 -DMY_RX_MESSAGE_BUFFER_FEATURE -DMY_RF24_IRQ_PIN=15 -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/Print.cpp -o build/drivers/Linux/Print.o
                                      g++ -MT build/drivers/Linux/EthernetClient.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_DRIVER_SPIDEV -DMY_RF24_CHANNEL=119 -DMY_RX_MESSAGE_BUFFER_FEATURE -DMY_RF24_IRQ_PIN=15 -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/EthernetClient.cpp -o build/drivers/Linux/EthernetClient.o
                                      g++ -MT build/drivers/Linux/SerialPort.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_DRIVER_SPIDEV -DMY_RF24_CHANNEL=119 -DMY_RX_MESSAGE_BUFFER_FEATURE -DMY_RF24_IRQ_PIN=15 -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/SerialPort.cpp -o build/drivers/Linux/SerialPort.o
                                      g++ -MT build/drivers/Linux/Stream.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_DRIVER_SPIDEV -DMY_RF24_CHANNEL=119 -DMY_RX_MESSAGE_BUFFER_FEATURE -DMY_RF24_IRQ_PIN=15 -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/Stream.cpp -o build/drivers/Linux/Stream.o
                                      g++ -MT build/drivers/Linux/IPAddress.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_DRIVER_SPIDEV -DMY_RF24_CHANNEL=119 -DMY_RX_MESSAGE_BUFFER_FEATURE -DMY_RF24_IRQ_PIN=15 -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/IPAddress.cpp -o build/drivers/Linux/IPAddress.o
                                      g++ -MT build/drivers/Linux/compatibility.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_DRIVER_SPIDEV -DMY_RF24_CHANNEL=119 -DMY_RX_MESSAGE_BUFFER_FEATURE -DMY_RF24_IRQ_PIN=15 -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/compatibility.cpp -o build/drivers/Linux/compatibility.o
                                      g++ -MT build/drivers/Linux/SoftEeprom.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_DRIVER_SPIDEV -DMY_RF24_CHANNEL=119 -DMY_RX_MESSAGE_BUFFER_FEATURE -DMY_RF24_IRQ_PIN=15 -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/SoftEeprom.cpp -o build/drivers/Linux/SoftEeprom.o
                                      g++ -MT build/drivers/Linux/EthernetServer.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_DRIVER_SPIDEV -DMY_RF24_CHANNEL=119 -DMY_RX_MESSAGE_BUFFER_FEATURE -DMY_RF24_IRQ_PIN=15 -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c drivers/Linux/EthernetServer.cpp -o build/drivers/Linux/EthernetServer.o
                                      g++ -MT build/examples_linux/mysgw.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_DRIVER_SPIDEV -DMY_RF24_CHANNEL=119 -DMY_RX_MESSAGE_BUFFER_FEATURE -DMY_RF24_IRQ_PIN=15 -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/SPIDEV -c examples_linux/mysgw.cpp -o build/examples_linux/mysgw.o
                                      ./drivers/RF24/RF24.h:76:2: error: #error RF24 IRQ usage requires transactional SPI support
                                      In file included from ./MySensors.h:294:0,
                                      ./drivers/RF24/RF24.cpp:39:11: error: Not supported on linux-generic
                                      hwDigitalWrite(MY_RF24_CS_PIN, level);
                                      ./drivers/RF24/RF24.cpp:44:11: error: Not supported on linux-generic
                                      hwDigitalWrite(MY_RF24_CE_PIN, level);
                                      ./drivers/RF24/RF24.cpp:388:11: error: Not supported on linux-generic
                                      hwPinMode(MY_RF24_CE_PIN,OUTPUT);
                                      ./drivers/RF24/RF24.cpp:389:11: error: Not supported on linux-generic
                                      hwPinMode(MY_RF24_CS_PIN,OUTPUT);
                                      ./drivers/RF24/RF24.cpp:391:11: error: Not supported on linux-generic
                                      hwPinMode(MY_RF24_IRQ_PIN,INPUT);
                                      ./drivers/RF24/RF24.cpp:37:32: warning: unused parameter ‘level’ [-Wunused-parameter]
                                      LOCAL void RF24_csn(const bool level)
                                      ./drivers/RF24/RF24.cpp:42:31: warning: unused parameter ‘level’ [-Wunused-parameter]
                                      LOCAL void RF24_ce(const bool level)
                                      ./drivers/RF24/RF24.cpp: In function ‘bool RF24_initialize()’:
                                      ./drivers/RF24/RF24.cpp:403:75: error: ‘FALLING’ was not declared in this scope
                                      attachInterrupt(digitalPinToInterrupt(MY_RF24_IRQ_PIN), RF24_irqHandler, FALLING);
                                      ./drivers/RF24/RF24.cpp:403:82: error: ‘attachInterrupt’ was not declared in this scope
                                      In file included from ./MySensors.h:346:0,
                                      ./core/MyMainLinux.cpp: In function ‘void handle_sigint(int)’:
                                      ./core/MyMainLinux.cpp:44:33: error: ‘detachInterrupt’ was not declared in this scope
                                      detachInterrupt(MY_RF24_IRQ_PIN);
                                      Makefile:114: recipe for target 'build/examples_linux/mysgw.o' failed
                                      Thanks for all the time you guys put into this!! really appreciate it!!
                                      • T Tag
                                        @jirm
                                        Sure!, here you go:
                                        [OK] Finished.
                                        jirmJ
                                        jirmJ
                                        jirm
                                        @Tag
                                        Thanks to you to make the effort to try our "suppositions" ...
                                        Mmmm...I see some interesting things on your results.
                                        First all your results on OPI really differ from @eyesoft posted on the github. That can mean that Banana are much different (on drivers aspect) than OPI and then same solution cannot be applied to both...bad thing for us.
                                        Then I see on make that the soc (and cpu) are bad seleected (I said this issue yesterday to @marceloaqno on general support post for mysensors gateway) because seems in the configure file have a bad selection about that specs when soc are a H3, and select a bad A53 type of cpu when is Armv7.
                                        Then I don't know if all subsequent errors raised are significant or simply derived from that initially bad cpu selection.
                                        Last I see that have issues on GPIO pins, but this is something we hoped would happen.
                                        Anyway, I'm not coder so maybe are totally grong on all my observations and we need some coder (preferible @marceloaqno ) help us to deal with all that.
                                        Regards and thanks to you !
                                        • jirmJ jirm
                                          @Tag
                                          jirmJ
                                          jirmJ
                                          jirm
                                          @Tag
                                          I just see than on your previous compilation for NRF24 build from Tmr24h that you confirm is working OK, the compilation have same "bad" cpu type A53 that I figure that is a bad selection for H3 and seems that is not any problem...so now I'dont understand nothing..
                                          Well mean only understand that we need a mysensor coder for help an guidance and if available make to it all the changes needed for OPI on mysenros.
                                          So we need help for all.
                                          Regards
