  2. Announcements
  • OliO Oli
    OK, I did it, I f....g did it, and guess what...
    s...t happened again.
    Everything went as it should, no errors at all, but no ttyUSBMySensorsGateway...
    log error message:
    2017-01-03 19:56:38.784 MySensors: Using serial port: /dev/ttyUSBMySensorsGateway
    2017-01-03 19:56:38.785 Error: MySensors: Error opening serial port!
    2017-01-03 19:56:39.785 MySensors: retrying in 30 seconds...
    and again...
    and again...
    any help would be appreciated.
    luizrrochaL
    luizrrochaL
    luizrrocha
    @Oli: when you do a "ls /dev" is ttyUSBMySensorsGateway shown ?
    luizrrochaL 1 Reply Last reply
    • luizrrochaL luizrrocha
      luizrrochaL
      luizrrochaL
      luizrrocha
      @Oli: by the way, the name of the port you used is ttyMySensorsGateway, not ttyUSBMySensorsGateway:
      @mfalkvidd I could not find ttyMySensorsGateway on Domoticz. Only ttyUSB0, ttyUSB20 and ttyAMA0. Even after I did ./configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyMySensorsGateway
      Is the gateway running, ie, "ps -ef "grep my" shows a process there ?
      Cheers,
      Luiz
        Cheers,
        Luiz
        luizrrochaL
        luizrrochaL
        luizrrocha
        @Oli: sorry, correct syntax is ps -ef | grep my
        OliO 1 Reply Last reply
          OliO
          OliO
          Oli
          @luizrrocha
          pi@raspberrypi ~ $ ls /dev
          autofs mmcblk0p1 stderr tty36 ttyAMA0
          block mmcblk0p2 stdin tty37 ttyMySensorsGateway
          btrfs-control net stdout tty38 ttyprintk
          bus network_latency tty tty39 ttyUSB0
          cachefiles network_throughput tty0 tty4 ttyUSB20
          char null tty1 tty40 uhid
          console ppp tty10 tty41 uinput
          cpu_dma_latency ptmx tty11 tty42 urandom
          cuse pts tty12 tty43 vc-cma
          disk ram0 tty13 tty44 vchiq
          fb0 ram1 tty14 tty45 vcio
          fd ram10 tty15 tty46 vc-mem
          full ram11 tty16 tty47 vcs
          fuse ram12 tty17 tty48 vcs1
          gpiomem ram13 tty18 tty49 vcs2
          hwrng ram14 tty19 tty5 vcs3
          i2c-1 ram15 tty2 tty50 vcs4
          input ram2 tty20 tty51 vcs5
          kmsg ram3 tty21 tty52 vcs6
          log ram4 tty22 tty53 vcsa
          loop0 ram5 tty23 tty54 vcsa1
          loop1 ram6 tty24 tty55 vcsa2
          loop2 ram7 tty25 tty56 vcsa3
          loop3 ram8 tty26 tty57 vcsa4
          loop4 ram9 tty27 tty58 vcsa5
          loop5 random tty28 tty59 vcsa6
          loop6 raw tty29 tty6 vhci
          loop7 root tty3 tty60 watchdog
          loop-control serial tty30 tty61 watchdog0
          MAKEDEV shm tty31 tty62 xconsole
          mapper snd tty32 tty63 zero
          mem sndstat tty33 tty7
          memory_bandwidth spidev0.0 tty34 tty8
          mmcblk0 spidev0.1 tty35 tty9
          pi@raspberrypi ~ $ ps -ef | grep my
          root 2079 1 1 18:40 ? 00:02:49 /usr/local/bin/mysgw -b
          pi 4214 4181 0 21:25 pts/2 00:00:00 grep --color=auto my
          • OliO Oli
            @luizrrocha
            luizrrochaL
            luizrrochaL
            luizrrocha
            @Oli : the port name is actually ttyMySensorsGateway, you have to correct the definition of the gateway on Domoticz to use it....
            Luiz
            • J jacikaas
              Could someone answer: if i have RPi NRF24 GW, how I could connect MYSController from other computer (for example from Windows computer)?
              1. Is it possible to make that type connection with RPi NRF24 GW?
              2. May I use some integrated web server for this type of connection in RPi to make it work? Is there are easier solutions?
              EDIT: no matter, already answered it by myself :)
              Its easy becose it's like Ethernet GW.
              luizrrochaL
              luizrrochaL
              luizrrocha
              @jacikaas : on MYSController go to Settings -> Gateway -> TCP/IP and add the IP address of the Gateway and use port 5003. It works even if the gateway is feeding data to Domoticz, so you can monitor your sensors in "raw" mode.
              Cheers,
              Luiz
                Luiz
                OliO
                OliO
                Oli
                wrote on last edited by Oli
                #241
                @luizrrocha as You can see, on the picture above, I've wrote that ttyUSBMySensors.... is from my previous backup copy. On the same pictures You can also see that I can choose only from three serial ports: USB0, USB20 and AMA0. Thera are no ttyMySensorsGateway despite that it is present after ls /dev.
                And that's the problem, I dont know how to make it present in the serial ports popup menu.
                • OliO Oli
                  luizrrochaL
                  luizrrochaL
                  luizrrocha
                  @Oli : why not remove the old definition to avoid any trash information and restarting Domoticz to make shure it rereads the port info before creating the new entry ?
                  And I do not understand why if you are running domoticz and the gateway on the same Pi, why not use a ethernet gateway and set 127.0.0.1 and port 5003 on the Domoticz gateway entry. I did that and never had to worry about USB ports at all.
                    OliO
                    OliO
                    Oli
                    @luizrrocha
                    Of course I did that, I started from the scratch... but when it did not work I try to restore my backup... but it did not work also...
                    simple... I have no free LAN on my rotuer... there is more, I also have raZberry daughter board (Z-Wave) connected to same Raspberry Pi GPIO port. And till today everything works perfect until... "Better is the enemy of the good" ;-)
                    • OliO
                      OliO
                      Oli
                      #244
                      OK I found the solution (thanks to @luizrrocha). I change
                      to
                      ./configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyUSBMySensorsGateway and now its working.
                      Question is, It's only workaround (in my case) or there is bug in the installation guide?
                      • OliO Oli
                        to
                        luizrrochaL
                        luizrrochaL
                        luizrrocha
                        @Oli : if both the gateway and Domoticz run on the same Raspi, there is no physical network involved, hence the 127.0.0.1 dummy local address is used by Domoticz to talk to the gateway on the same machine, just using port 5003... and since you use localhost (127.0.0.1, a virtual network) there is no need to create a virtual USB port which is what you did...
                          OliO
                          OliO
                          Oli
                          @luizrrocha interesting... step by step instruction?
                          • OliO Oli
                            luizrrochaL
                            luizrrochaL
                            luizrrocha
                            @Oli: delete the Makefile.inc file on mysensors folder
                            make
                            sudo ./bin/mysgw -b
                            go to domoticz and create a new MySensors Gateway with LAN, inform 127.0.0.1 as the address and 5003 as the port...
                            that should do the trick.
                            • ysinhY ysinh
                              A tiny hint for the users of domoticz :
                              ./configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyUSB20
                              make
                              :) i hope this helps
                              then in the hardware setup
                              MySensors Gateway USB
                              serial port: /dev/ttyUSB20
                              carlylerC
                              carlylerC
                              carlyler
                              @Oli luizrocha's configuration seems interesting, but just in case your still wanting the serial, from above, has worked for me in the past, but I have since switched to OH2:
                              make
                              • W
                                W
                                Wackid
                                I am also not get it to work in Domoticz tried the USB serial and ethernet way.
                                It's a testing pi. Where i didn't connected the radio. Because it's still in the Nano. Could that be the issue? I guess not.
                                • M marceloaqno
                                  @aand @Tag @jirm MySensors uses its own nrf24 drivers, and OrangePi is not currently supported. It will be in the future.
                                  Tag
                                  wrote on last edited by Tag
                                  #250
                                  @marceloaqno, @jirm, @aand
                                  Hi!,
                                  I started a new topic for Mysensors Gateway on OrangePI (OPI), Here
                                  Hope this is okay,
                                  Kind regards,
                                  Tag
                                    Mihai
                                    wrote on last edited by Mihai
                                    #251
                                    The Pi MQTT Gateway with IRQ connected may handle better the messages into a loaded network than Ethernet MQTT Gateway where IRQ is not used? (with NRF24)
                                    Also I would like to know if I can use the other pins of RPi to connect some digital sensors directly there.
                                    • W
                                      W
                                      Wackid
                                      @Oli
                                      Stupid question... Did you mount the radio? Because I thought I would like to test if it works. (without radio) but that doesn't work.
                                      Mounted a radio and ethernet gateway is working.
                                      • eyesoftE
                                        eyesoftE
                                        eyesoft
                                        @Mihai
                                        Maybe i'm wrong but IRQ is used on all gateways if you read above :
                                        Improving throughput for nrf24
                                        There is another method were the interrupt pin from the nrf24 modules is used to inform when a new message arrives and it's immediately added to a queue for further processing
                                        for the second part yes you can use other pins on RPi ... i have RF module NRF24L01 for gateway and DHT11 on RPi.
                                          Ditto, @Robinek70 !
                                          'nuff said.
                                          Luiz Roberto
                                          musthafa
                                          @luizrrocha said:
                                          Ditto, @Robinek70 !
                                          'nuff said.
                                          Luiz Roberto
                                          Can you please give me the instructions for Domoticz setup?
                                          I have a node with DHT11 sensor and I can see mygsw service is getting messages. How do I connect Domoticz with mysensors ?
                                          I have been following openhab until today and I'm switching to Domoticz now.
