  2. Announcements
  • OliO Oli
    @mfalkvidd hah... thats a good question, don't know. After dozen or more reinstallations, spending hours on Google I finally make it work. Got some notes but frankly I am worrying it will happen again. Hahaha
    @Oli ah, ok. Then I'd recommend backing up everything before doing git pull, configure, make, etc so you can restore if it stops working.
    • jirmJ jirm
      @Oli I´m thinking is hard to "only" update (changing from develop to master branch) directly from github if the repository is not been previously prepared to do this kind of updates... but maybe I´m wrong.
      Will be good you give feedback if you get it.
      jirmJ
      jirmJ
      jirm
      wrote on last edited by jirm
      #232
      @Oli :-) :-)
      Good !
      I like when people can make something work that nobody even knows what it is :-)
      For me it usually happens just the opposite I am not able to make work even the things I know perfectly well ... maybe it will be a matter of "bad karma" :-)
      • OliO
        OliO
        Oli
        OK, I did it, I f....g did it, and guess what...
        s...t happened again.
        Everything went as it should, no errors at all, but no ttyUSBMySensorsGateway...
        log error message:
        2017-01-03 19:56:38.784 MySensors: Using serial port: /dev/ttyUSBMySensorsGateway
        2017-01-03 19:56:38.785 Error: MySensors: Error opening serial port!
        2017-01-03 19:56:39.785 MySensors: retrying in 30 seconds...
        and again...
        and again...
        any help would be appreciated.
        luizrrochaL 1 Reply Last reply
        • J
          J
          jacikaas
          wrote on last edited by jacikaas
          #234
          Could someone answer: if i have RPi NRF24 GW, how I could connect MYSController from other computer (for example from Windows computer)?
          1. Is it possible to make that type connection with RPi NRF24 GW?
          2. May I use some integrated web server for this type of connection in RPi to make it work? Is there are easier solutions?
          EDIT: no matter, already answered it by myself :)
          Its easy becose it's like Ethernet GW.
          • OliO Oli
            log error message:
            and again...
            and again...
            luizrrochaL
            luizrrochaL
            luizrrocha
            @Oli: when you do a "ls /dev" is ttyUSBMySensorsGateway shown ?
            • luizrrochaL luizrrocha
              luizrrochaL
              luizrrochaL
              luizrrocha
              @Oli: by the way, the name of the port you used is ttyMySensorsGateway, not ttyUSBMySensorsGateway:
              @mfalkvidd I could not find ttyMySensorsGateway on Domoticz. Only ttyUSB0, ttyUSB20 and ttyAMA0. Even after I did ./configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyMySensorsGateway
              Is the gateway running, ie, "ps -ef "grep my" shows a process there ?
              Cheers,
              Luiz
                Cheers,
                Luiz
                luizrrochaL
                luizrrochaL
                luizrrocha
                @Oli: sorry, correct syntax is ps -ef | grep my
                OliO 1 Reply Last reply
                  OliO
                  OliO
                  Oli
                  @luizrrocha
                  pi@raspberrypi ~ $ ls /dev
                  autofs mmcblk0p1 stderr tty36 ttyAMA0
                  block mmcblk0p2 stdin tty37 ttyMySensorsGateway
                  btrfs-control net stdout tty38 ttyprintk
                  bus network_latency tty tty39 ttyUSB0
                  cachefiles network_throughput tty0 tty4 ttyUSB20
                  char null tty1 tty40 uhid
                  console ppp tty10 tty41 uinput
                  cpu_dma_latency ptmx tty11 tty42 urandom
                  cuse pts tty12 tty43 vc-cma
                  disk ram0 tty13 tty44 vchiq
                  fb0 ram1 tty14 tty45 vcio
                  fd ram10 tty15 tty46 vc-mem
                  full ram11 tty16 tty47 vcs
                  fuse ram12 tty17 tty48 vcs1
                  gpiomem ram13 tty18 tty49 vcs2
                  hwrng ram14 tty19 tty5 vcs3
                  i2c-1 ram15 tty2 tty50 vcs4
                  input ram2 tty20 tty51 vcs5
                  kmsg ram3 tty21 tty52 vcs6
                  log ram4 tty22 tty53 vcsa
                  loop0 ram5 tty23 tty54 vcsa1
                  loop1 ram6 tty24 tty55 vcsa2
                  loop2 ram7 tty25 tty56 vcsa3
                  loop3 ram8 tty26 tty57 vcsa4
                  loop4 ram9 tty27 tty58 vcsa5
                  loop5 random tty28 tty59 vcsa6
                  loop6 raw tty29 tty6 vhci
                  loop7 root tty3 tty60 watchdog
                  loop-control serial tty30 tty61 watchdog0
                  MAKEDEV shm tty31 tty62 xconsole
                  mapper snd tty32 tty63 zero
                  mem sndstat tty33 tty7
                  memory_bandwidth spidev0.0 tty34 tty8
                  mmcblk0 spidev0.1 tty35 tty9
                  pi@raspberrypi ~ $ ps -ef | grep my
                  root 2079 1 1 18:40 ? 00:02:49 /usr/local/bin/mysgw -b
                  pi 4214 4181 0 21:25 pts/2 00:00:00 grep --color=auto my
                  • OliO Oli
                    @luizrrocha
                    luizrrochaL
                    luizrrochaL
                    luizrrocha
                    @Oli : the port name is actually ttyMySensorsGateway, you have to correct the definition of the gateway on Domoticz to use it....
                    Luiz
                    • J jacikaas
                      luizrrochaL
                      luizrrochaL
                      luizrrocha
                      @jacikaas : on MYSController go to Settings -> Gateway -> TCP/IP and add the IP address of the Gateway and use port 5003. It works even if the gateway is feeding data to Domoticz, so you can monitor your sensors in "raw" mode.
                      Cheers,
                      Luiz
                        Luiz
                        OliO
                        OliO
                        Oli
                        wrote on last edited by Oli
                        #241
                        @luizrrocha as You can see, on the picture above, I've wrote that ttyUSBMySensors.... is from my previous backup copy. On the same pictures You can also see that I can choose only from three serial ports: USB0, USB20 and AMA0. Thera are no ttyMySensorsGateway despite that it is present after ls /dev.
                        And that's the problem, I dont know how to make it present in the serial ports popup menu.
                        • OliO Oli
                          luizrrochaL
                          luizrrochaL
                          luizrrocha
                          @Oli : why not remove the old definition to avoid any trash information and restarting Domoticz to make shure it rereads the port info before creating the new entry ?
                          And I do not understand why if you are running domoticz and the gateway on the same Pi, why not use a ethernet gateway and set 127.0.0.1 and port 5003 on the Domoticz gateway entry. I did that and never had to worry about USB ports at all.
                            OliO
                            OliO
                            Oli
                            @luizrrocha
                            Of course I did that, I started from the scratch... but when it did not work I try to restore my backup... but it did not work also...
                            simple... I have no free LAN on my rotuer... there is more, I also have raZberry daughter board (Z-Wave) connected to same Raspberry Pi GPIO port. And till today everything works perfect until... "Better is the enemy of the good" ;-)
                            • OliO
                              OliO
                              Oli
                              #244
                              OK I found the solution (thanks to @luizrrocha). I change
                              to
                              ./configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyUSBMySensorsGateway and now its working.
                              Question is, It's only workaround (in my case) or there is bug in the installation guide?
                              • OliO Oli
                                to
                                luizrrochaL
                                luizrrochaL
                                luizrrocha
                                @Oli : if both the gateway and Domoticz run on the same Raspi, there is no physical network involved, hence the 127.0.0.1 dummy local address is used by Domoticz to talk to the gateway on the same machine, just using port 5003... and since you use localhost (127.0.0.1, a virtual network) there is no need to create a virtual USB port which is what you did...
                                  OliO
                                  OliO
                                  Oli
                                  @luizrrocha interesting... step by step instruction?
                                  • OliO Oli
                                    luizrrochaL
                                    luizrrochaL
                                    luizrrocha
                                    @Oli: delete the Makefile.inc file on mysensors folder
                                    make
                                    sudo ./bin/mysgw -b
                                    go to domoticz and create a new MySensors Gateway with LAN, inform 127.0.0.1 as the address and 5003 as the port...
                                    that should do the trick.
                                    • ysinhY ysinh
                                      A tiny hint for the users of domoticz :
                                      ./configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyUSB20
                                      make
                                      :) i hope this helps
                                      then in the hardware setup
                                      MySensors Gateway USB
                                      serial port: /dev/ttyUSB20
                                      carlylerC
                                      carlylerC
                                      carlyler
                                      @Oli luizrocha's configuration seems interesting, but just in case your still wanting the serial, from above, has worked for me in the past, but I have since switched to OH2:
                                      make
                                      • W
                                        W
                                        Wackid
                                        I am also not get it to work in Domoticz tried the USB serial and ethernet way.
                                        It's a testing pi. Where i didn't connected the radio. Because it's still in the Nano. Could that be the issue? I guess not.
                                        • M marceloaqno
                                          @aand @Tag @jirm MySensors uses its own nrf24 drivers, and OrangePi is not currently supported. It will be in the future.
                                          Tag
                                          wrote on last edited by Tag
                                          #250
                                          @marceloaqno, @jirm, @aand
                                          Hi!,
                                          I started a new topic for Mysensors Gateway on OrangePI (OPI), Here
                                          Hope this is okay,
                                          Kind regards,
                                          Tag
