  2. Feature Requests
  3. RFM69 RSSI value report
Scheduled Pinned Locked Moved Feature Requests
41 Posts 11 Posters 22.4k Views 12 Watching
    Well, finally we have decided to wait for releasing the new rfm69 drivers.
    Because
    • there was already so much changes/improvements in Mysensors to release.
    • to keep a better history, and the new rfm69 driver has lot of improvements.
    That said, for w5100 users, we have tested the new driver (not the one on my repo) and it works ok with w5100 and rfm69 in hardware spi mode, on same bus, without changing the w5100 lib.
    So Mysensors 2.1 still use the old driver. The new rfm69 driver is planned for 2.2. No eta as far as i know, but with luck, let's see when it will release.
    • rmtuckerR
      rmtuckerR
      rmtucker
      I am totally confused now?
      So Rssi data is not available?
        @rmtucker no it is not available in 2.1. this will be for 2.2
        • scalzS scalz
          mihai.aldea
          @scalz Just to make it clear. The RFM69 RSSI value is not available in the official MySensors 2.1.0 release but it is available in your GitHub fork here: https://github.com/scalz/Mysensors/tree/rfm69_update2. Is that correct?
            Yes RSSI is a work in progress available in @scalz fork. We didn't have time to test it enough to include it in the 2.1 release.
              mihai.aldea
              @hek I confirm that the RSSI support works perfect in scalz's fork.
              • M mihai.aldea
                @mihai.aldea it is not just about verifying RSSI. It is about verifying that the changes don't break anything else for existing users. Unfortunately, the new driver does break things and most users would dislike an upgrade that breaks their existing system.
                  mihai.aldea
                  This is perfectly understandable but I merely wanted to give a raw input on the feature status.
                  I consider the RSSI values to be paramount when testing MySensors along with new hardware (antennas, wall penetration, registry tweaks etc.) as the simple online/offline node status would not help very much with these scenarios. That's why for the time being I will stick to scalz's rfm69_update2.
                  • rmtuckerR rmtucker
                    Has Rssi been added to mysensors 2.1 ?
                    J
                    J
                    jpaulin
                    wrote on last edited by jpaulin
                    @rmtucker In my RFM69 sensors using ver2.1 I'm doing as follows to check RSSI and, as well, how to check the background noise level. I have them implemented as two sensor values being reported every 5 minutes in the loop() to the gateway and controller.
                      float humidity = dht.readHumidity();       // get dht22 humidity
                      if (isnan(humidity)) {
                        send(msgHum.set(humidity, 1));           // send dht22 humidity
                      float temperature = dht.readTemperature(); // get dht22 temperature
                      if (isnan(temperature)) {
                        send(msgTemp.set(temperature, 1));       // send dht22 temperature
                      digitalWrite(DHT22_PWR,LOW);               // save some power. Turn off dht22 module.
                      rssi = _radio.readRSSI();                  // read RSSI in RFM69. Measure reception signal level from gw
                      send(msgRSSI1.set(rssi));                  // send RSSI, signal level to gateway
                      wait(500);                                 // wait to get idle
                      rssi = _radio.readRSSI();                  // read RSSI in RFM69. Measure background noise
                      send(msgRSSI2.set(rssi));                  // send RSSI, noise level to gateway
                      sleep(SLEEP_TIME);                         // sleep a bit
                      digitalWrite(DHT22_PWR,HIGH);              // wake up dht22 module
                      wait(2000);                                // warm up dht22 module
                    To get the RSSI value it's read in the sketch ( int rssi = _radio.readRSSI(); ) immediately after sending something, in this case the dht22 temperature. To check the background noise the RSSI level is read again 500ms after being kept idle (probably a shorter waiting period would work as well, but haven't studied it as it's not a critical issue for me). Normally the background noise-floor should be something around -95dBm and -115dBm. If you have some external interference, it could be easily detected with this method.
                    rmtuckerR 1 Reply Last reply
                    • J jpaulin
                      rmtuckerR
                      rmtuckerR
                      rmtucker
                      @jpaulin
                      Thank you so much for the info that rssi can be extracted in V2.1.0.
                      Would you be able to post your full sketch as it would be easier for me to extract the bits i need.?
                      I just can not understand why before your answer i was being told it is not possible in V2.1.0 to do this?
                      Or does this need another version of the Rfm69 library?
                      J 2 Replies Last reply
                        @jpaulin
                        J
                        J
                        jpaulin
                        #21
                        @rmtucker Here's the complete sketch. It's a DHT22 temp/humidity battery powered sensor node with an RFM69 radio.
                         * Version 1.0 - Henrik EKblad
                         * This sketch provides an example how to implement a humidity/temperature
                         * sensor using DHT11/DHT-22
                        // Enable debug prints
                        //#define MY_RADIO_NRF24
                        #define MY_RADIO_RFM69
                        #define MY_RFM69_FREQUENCY   RF69_433MHZ
                        #define MY_NODE_ID 13                        // Identity for temp/hum sensor
                        // Set blinking period
                        #define MY_DEFAULT_LED_BLINK_PERIOD 50
                        // Flash leds on rx/tx/err
                        //#define MY_DEFAULT_ERR_LED_PIN 7           // Error led pin  red
                        //#define MY_DEFAULT_RX_LED_PIN  6           // Receive led pin  yellow
                        #define MY_DEFAULT_TX_LED_PIN  9             // Transmit led pin  green
                        const byte BATT_ADC = 1;                     // ADC Pin to measure battery level
                        unsigned long SLEEP_TIME = 300000;           // Sleep time between reads (in milliseconds)
                        #define CHILD_ID_HUM 0
                        #define CHILD_ID_TEMP 1
                        #define DHTPIN 18                            // Input pin from DHT22
                        #define DHT22_PWR 6                          // Vdc pin DHT22 to get it to sleep
                        #define DHTTYPE DHT22
                        DHT dht(DHTPIN, DHTTYPE);
                        #define CHILD_ID_RSSI_HIGH  7                // RSSI received signal level
                        #define CHILD_ID_RSSI_LOW   8                // RSSI background noise level
                        #define CHILD_ID_TEMP2      9                // internal temperature RFM69 chip
                        int rssi;                                    // RSSI RFM69 chip
                        int temp2;                                   // Internal temperature RFM69 chip
                        int batteryLevel;                            // measured battery level
                        int batteryPcnt;                             // measured battery level in percentage
                        MyMessage msgRSSI1(CHILD_ID_RSSI_HIGH, V_VAR1);
                        MyMessage msgRSSI2(CHILD_ID_RSSI_LOW, V_VAR1);
                        MyMessage msgTemp2(CHILD_ID_TEMP2, V_TEMP);
                          pinMode(DHT22_PWR,OUTPUT);
                          digitalWrite(DHT22_PWR,HIGH);              // power-on dht22
                          wait(2000);
                          dht.begin();                               // Start-up DHT22 sensor Temperature/Humidity
                          sendSketchInfo("Temp_Hum", "1.0");
                          present(CHILD_ID_HUM, S_HUM);
                          present(CHILD_ID_RSSI_HIGH, S_CUSTOM);
                          present(CHILD_ID_RSSI_LOW, S_CUSTOM);
                          present(CHILD_ID_TEMP2, S_TEMP);
                            wait(200);
                          rssi = _radio.readRSSI();                  // read RSSI in RFM69. Measure reception signal from gw
                          send(msgRSSI1.set(rssi));                  // send RSSI level
                          rssi = _radio.readRSSI();                  // read RSSI in RFM69. Wait and measure background noise
                          send(msgRSSI2.set(rssi));                  // send RSSI level
                          wait(200);                                 // wait for next send
                          temp2 = _radio.readTemperature(1);         // read temperature in RFM69
                          send(msgTemp2.set(temp2));                 // send temperature
                          batteryLevel = analogRead(BATT_ADC);       //  (* 0.0032225806)
                          batteryPcnt = batteryLevel / 10;           // battery percentage
                          sendBatteryLevel(batteryPcnt);             // send battery level in percentage to controller
                          // if (oldBatteryPcnt != batteryPcnt) {    // use if not to send every cycle
                          //     sendBatteryLevel(batteryPcnt);
                          //     oldBatteryPcnt = batteryPcnt;
                          digitalWrite(DHT22_PWR,HIGH);              // wake up DHT sensor
                          wait(2000);                                // warm up DHT sensor
                          Serial.println("something came in");
                          if (message.type==V_VAR1) {                // reception to change SLEEP_TIME.
                             SLEEP_TIME = message.getULong();        // send topic: eg. my_RFM69_gw1-in/3/1/1/0/24 30000 (payload in ms)
                           }                                         // MQTT_publish_topic_prefix/Node_Id/Sensor_Id/Cmd_Type/Ack_flag/type(V_VAR1=24) payload
                        readRSSI(); is an internal function in the RFM69.h / RFM69.cpp library that I'm calling in the sketch to get the RSSI and background noise level.
                        rmtuckerR zboblamontZ 2 Replies Last reply
                          @jpaulin
                          J
                          J
                          jpaulin
                          #22
                          @rmtucker Another feature I'm using in the sketch, by calling directly the RFM69 library, is reading the temperature sensor in the RFM69.
                          The value (1) sent in the call above to the RFM69 library is a calibration in Centigrades (e.g. 1 = +1 °C). Added here to show the possibility to adjust the measured temperature. The temperature sensor on the chip is not as accurate as for example a dht22 and needs sometimes some manual adjustment.
                            mihai.aldea
                            The onboard temperature sensor is not a cool freebie. It's meant to be a way to check the approximate environmental temperature for the outdoor or industrial devices (not only sensor nodes) using RFM69.
                            • J jpaulin
                                wait(2000);
                                  wait(200);
                              rmtuckerR
                              rmtuckerR
                              rmtucker
                              @jpaulin
                              Just wanted to thank you for taking the time to post your example for rssi.
                              I have just finished putting my new rfm69 gateway together and about to start assembling a new node to try everything out.
                              I will let you know how i get on.
                              • G
                                G
                                gieemek
                                wrote on last edited by gieemek
                                #25
                                In the 2.2 version of MySensors (development branch) the new driver for RFM69 is built. It has new command for reading RSSI value: RFM69_getSendingRSSI() and RFM69_getReceivingRSSI(), so now is very easy to get RSSI value.
                                You can get some more information from ATC Signal Report which are useful - look at RFM69_RFM95_ATC_SignalReport example.
                                G gohanG 2 Replies Last reply
                                • G gieemek
                                  G
                                  G
                                  gieemek
                                  • G gieemek
                                    @gieemek
                                    what kind of variable and type are better for reporting RSSI?
                                    G 1 Reply Last reply
                                      @gieemek
                                      G
                                      G
                                      gieemek
                                      @gohan I use V_VAR1 type of variable.
                                      gohanG 1 Reply Last reply
                                      • G gieemek
                                        @gieemek ok, but how about when you present the child? S_CUSTOM is not accepted by Domoticz S_SOUND could be an option
                                        • N
                                          N
                                          napo7
                                          wrote on last edited by napo7
                                          #30
                                          I see in the domoticz code that there are some fields to record Signal Level for other sensors types.
                                          Making domoticz handle the signal level would then be possible.
                                          There is 2 enhancements to do so :
                                          • Handle a standard variable or subtype in MySensors to carry the signal or RSSI level (github issue 581 : https://github.com/mysensors/MySensors/issues/581)
                                          • Modify the domoticz code to show somewhere the Signal Level for MySensors devices. (no github issue yet)
                                          That would be interresting, since it would also allow to trigger some custom scripts if a device falls in a poor level...
