  3. MYSBootloader 1.3.0-beta.3
182 Posts 44 Posters 94.5k Views 42 Watching
  • C
    C
    cdr
    Hi Tekka,
    Happy 2017! Thanks for the update, can you upload a 8Mhz precompiled bootloader? (and update boards.txt) :)
    I'm curious is there a changelog since last version?
    • TetnobicT
      TetnobicT
      Tetnobic
      @tekka Hi Happy new year 2017 !!!
      Many thanks for release source of MYSBootloader!!! A very good news !!!
      Can you explain how to compile ?
      Makefile in Master Branch failed with :
      make: *** No rule to make target 'MYSBootloader.c', needed by 'MYSBootloader.o'.
      I would like to compile an ATMega328 1Mhz version
      • MiKaM
        MiKaM
        MiKa
        To tekka:
        +1 to "Can you explain how to compile ?"
        OTA with MYSBootloader is possible also with gateway based on ESP8266 ? I cant do it, node is just rebooting after firmware update request and thats all.
        tekkaT 1 Reply Last reply
        • MiKaM MiKa
          To tekka:
          tekkaT
          tekkaT
          tekka
          @MiKa @Tetnobic:
          Issue created, please feel free to add any comments: https://github.com/mysensors/MySensorsBootloaderRF24/issues/3
          • FejiF
            FejiF
            Feji
            Hi Tekka,
            First, thx for all your hard work.
            +1 for the How-to cause I'm on a try to compile since two hours, :(. There is an include missing : RF24_registers.h.
            While I'm here, is there a timout if the node can't reach the gateway in order to boot anyway in this version ?
            Thx again.
            • FejiF Feji
              Hi Tekka,
              Thx again.
              tekkaT
              tekkaT
              tekka
              wrote on last edited by tekka
              @Tetnobic, @Feji
              Dev branch updated: https://github.com/mysensors/MySensorsBootloaderRF24/tree/development
              • updated Makefile, added include files to same dir
              • To compile (under win): install make (I'm using mingw32-make from MinGW)
              • clone dev repo
              • update paths to avr tools and includes in Makefile (BINPATH, INLCUDES)
              • run Makefile to obtain .hex file
              • Flash .hex file using ISP
              • MiKaM
                MiKaM
                MiKa
                Hi Tekka,
                can You compile for ATMega328P 8MHz pls?
                THX,
                MiKa
                • FejiF
                  FejiF
                  Feji
                  There is a 8 MHz version.
                  I can't get the serial uploading working, don't know why.
                  MYSBootloader_8MHZ.hex
                  MiKaM 1 Reply Last reply
                  • FejiF Feji
                    MiKaM
                    MiKaM
                    MiKa
                    I already have it ;) finnaly I compile it after one hour :)
                    • MiKaM MiKa
                      MiKaM
                      MiKaM
                      MiKa
                      wrote on last edited by MiKa
                      To Feji: You have speed 38400 Bd?
                      FejiF 1 Reply Last reply
                      • MiKaM MiKa
                        FejiF
                        FejiF
                        Feji
                        @MiKa
                        It's a 56K version, I haven't try 38k yet.
                        • FejiF Feji
                          @MiKa
                          MiKaM
                          MiKaM
                          MiKa
                          @Feji
                          try 38400Bd it should work
                          HW.h
                          #ifndef BAUD_RATE
                          #if F_CPU >= 16000000L
                          #define BAUD_RATE 115200
                          #elif F_CPU >= 8000000L
                          #define BAUD_RATE 38400L
                          #elif F_CPU >= 1000000L
                          #define BAUD_RATE 9600L
                          #elif F_CPU >= 128000L
                          #define BAUD_RATE 4800L
                          #define BAUD_RATE 1200L
                          • MiKaM MiKa
                            @Feji
                            HW.h
                            #ifndef BAUD_RATE
                            FejiF
                            FejiF
                            Feji
                            @MiKa
                            My bad, it's a 38k version but I was trying to upload the sketch at 56k...
                            • FejiF Feji
                              @MiKa
                              FejiF
                              FejiF
                              Feji
                              @Feji
                              After modifying the HW.h, it's work much better :). Obviously...
                              Serial upload confirmed work at 57600.
                              • W
                                W
                                Werwolfx
                                wrote on last edited by Werwolfx
                                Hello everybody.
                                I have a problem with the update over the air.
                                Version 2.1.0 mysensors
                                Gateway on ESP8266 default sketh
                                I downloaded the loader in atmega328p Arduino pro mini
                                in MYSController choose firmware
                                in logs
                                [12.01.2017 20: 32: 50.118 Info] INFO BL version = 768
                                 [12.01.2017 20: 32: 50.118 Info] INFO Send FW info to node 4: type = A, version = 1, blocks = 0x0050, CRC = 0x46D4
                                 [12/01/2017 20: 32: 50.120 Info] TX 4, 0, 4, 0, 1; 0A0001005000D446
                                 [12/01/2017 20: 32: 52.205 Info] RX 0, 255, 3, 0, 2, 2.1.0
                                 [12.01.2017 20: 32: 53.724 Info] RX 10, 3, 1, 0, 0, 21.2
                                 [12/01/2017 20: 32: 53.736 Info] RX 4; 255; 3, 0, 6, 0
                                 [12/01/2017 20: 32: 53.737 Info] TX 4; 255; 3, 0; 6; M
                                in arduino serial
                                0 MCO: BGN: INIT NODE, CP = RNONA -, VER = 2.1.0
                                3 TSM: INIT
                                4 TSF: WUR: MS = 0
                                11 TSM: INIT: TSP OK
                                13 TSM: INIT: STATID = 4
                                15 TSF: SID: OK, ID = 4
                                16 TSM: FPAR
                                53 TSF: MSG: SEND, 4-4-255-255, s = 255, c = 3, t = 7, pt = 0, l = 0, sg = 0, ft = 0, st = OK:
                                592 TSF: MSG: READ, 0-0-4, s = 255, c = 3, t = 8, pt = 1, l = 1, sg = 0: 0
                                598 TSF: MSG: FPAR OK, ID = 0, D = 1
                                2060 TSM: FPAR: OK
                                2061 TSM: ID
                                2062 TSM: ID: OK
                                2064 TSM: UPL
                                2069 TSF: MSG: SEND, 4-4-0-0, s = 255, c = 3, t = 24, pt = 1, l = 1, sg = 0, ft = 0, st = OK: 1
                                2083 TSF: MSG: READ, 0-0-4, s = 255, c = 3, t = 25, pt = 1, l = 1, sg = 0: 1
                                2088 TSF: MSG: PONG RECV, HP = 1
                                2092 TSM: UPL: OK
                                2093 TSM: READY: ID = 4, PAR = 0, DIS = 1
                                2113 TSF: MSG: SEND, 4-4-0-0, s = 255, c = 4, t = 0, pt = 6, l = 10, sg = 0, ft = 0, st = OK: FFFFFFFFD0033C3E0300
                                2131 TSF: MSG: SEND, 4-4-0-0, s = 255, c = 3, t = 15, pt = 6, l = 2, sg = 0, ft = 0, st = OK: 0100
                                2138 TSF: MSG: READ, 0-0-4, s = 0, c = 4, t = 1, pt = 6, l = 8, sg = 0: 0A0001005000D446
                                2144 OTA: FWP: UPDATE
                                ! 2146 OTA: FWP: FLASH INIT FAIL
                                2151 TSF: MSG: READ, 0-0-4, s = 255, c = 3, t = 15, pt = 6, l = 2, sg = 0: 0100
                                4074 TSF:! MSG: SEND, 4-4-0-0, s = 255, c = 0, t = 17, pt = 0, l = 5, sg = 0, ft = 0, st = NACK: 2.1. 0
                                5727 TSF: MSG: SEND, 4-4-0-0, s = 255, c = 3, t = 6, pt = 1, l = 1, sg = 0, ft = 1, st = OK: 0
                                5734 TSF: MSG: READ, 10-10-0, s = 3, c = 1, t = 0, pt = 7, l = 5, sg = 0: 21.2
                                ! 5739 TSF: MSG: REL MSG, NREP
                                5817 TSF: MSG: READ, 0-0-4, s = 255, c = 3, t = 6, pt = 0, l = 1, sg = 0: M
                                ! 7739 TSF: MSG: SEND, 4-4-0-0, s = 1, c = 0, t = 23, pt = 0, l = 0, sg = 0, ft = 0, st = NACK:
                                8436 TSF: MSG: SEND, 4-4-0-0, s = 255, c = 3, t = 11, pt = 0, l = 9, sg = 0, ft = 1, st = OK: Yang Node
                                8462 TSF: MSG: SEND, 4-4-0-0, s = 255, c = 3, t = 12, pt = 0, l = 4, sg = 0, ft = 0, st = OK: v1.0
                                confuse line
                                what could be the problem?
                                • W Werwolfx
                                  Hello everybody.
                                  in logs
                                  in arduino serial
                                  3 TSM: INIT
                                  4 TSF: WUR: MS = 0
                                  16 TSM: FPAR
                                  2060 TSM: FPAR: OK
                                  2061 TSM: ID
                                  2062 TSM: ID: OK
                                  2064 TSM: UPL
                                  2092 TSM: UPL: OK
                                  confuse line
                                  tekkaT
                                  tekkaT
                                  tekka
                                  @Werwolfx
                                  Disable MY_OTA_FIRMWARE_FEATURE, this is only required for the external flash/dualoptiboot OTA method, MYSBootloader handles OTA updates offline.
                                  W 1 Reply Last reply
                                  • tekkaT tekka
                                    @Werwolfx
                                    W
                                    W
                                    Werwolfx
                                    @tekka oh, my mistake, thank you very much for your work.
                                    • W
                                      W
                                      Werwolfx
                                      I try to disable MY_OTA_FIRMWARE_FEATURE in arduino/
                                      but no effect =(
                                      In arduino load example code PingpongSensor and add in sketch
                                      #define MY_NODE_ID 4
                                      MYSController log
                                      14.01.2017 8:43:45	CLICK	Board with MYSBootloader=TRUE
                                      14.01.2017 8:43:46	RX	10;5;1;0;17;841
                                      14.01.2017 8:43:46	RX	10;6;1;0;39;3.66
                                      14.01.2017 8:43:52	RX	0;255;3;0;2;2.1.0
                                      14.01.2017 8:43:54	TX	4;0;3;0;13;0
                                      14.01.2017 8:43:54	INFO	FW "TimeReporter" assigned to node 4
                                      14.01.2017 8:43:57	RX	6;3;1;0;16;0
                                      14.01.2017 8:43:57	RX	6;6;1;0;3;0
                                      14.01.2017 8:43:57	RX	5;3;1;0;16;0
                                      14.01.2017 8:43:57	RX	5;6;1;0;3;0
                                      14.01.2017 8:43:57	RX	6;5;1;0;0;20.25
                                      14.01.2017 8:44:00	RX	4;255;0;0;17;2.1.0
                                      14.01.2017 8:44:00	CHILD	New child discovered, node id=4, child id=internal
                                      14.01.2017 8:44:00	DEBUG	Update child id=255, type=S_ARDUINO_NODE
                                      14.01.2017 8:44:00	RX	4;255;3;0;6;0
                                      14.01.2017 8:44:00	TX	4;255;3;0;6;M
                                      14.01.2017 8:44:00	RX	4;1;0;0;23;
                                      14.01.2017 8:44:00	CHILD	New child discovered, node id=4, child id=1
                                      14.01.2017 8:44:00	DEBUG	Update child id=1, type=S_CUSTOM
                                      14.01.2017 8:44:00	RX	4;255;3;0;12;v1.0
                                      Arduino serial
                                      38602 TSF:MSG:READ,0-0-4,s=0,c=3,t=13,pt=0,l=1,sg=0:0
                                      0 MCO:BGN:INIT NODE,CP=RNNNA--,VER=2.1.0
                                      3 TSM:INIT
                                      4 TSF:WUR:MS=0
                                      11 TSM:INIT:TSP OK
                                      12 TSM:INIT:STATID=4
                                      14 TSF:SID:OK,ID=4
                                      16 TSM:FPAR
                                      52 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                      153 TSF:MSG:READ,0-0-4,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                                      157 TSF:MSG:FPAR OK,ID=0,D=1
                                      2060 TSM:FPAR:OK
                                      2061 TSM:ID
                                      2062 TSM:ID:OK
                                      2064 TSM:UPL
                                      2067 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                                      2081 TSF:MSG:READ,0-0-4,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                                      2086 TSF:MSG:PONG RECV,HP=1
                                      2088 TSM:UPL:OK
                                      2091 TSM:READY:ID=4,PAR=0,DIS=1
                                      2122 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                                      2128 TSF:MSG:READ,0-0-4,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                      2139 TSF:MSG:SEND,4-4-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.1.0
                                      2151 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                                      2170 TSF:MSG:READ,0-0-4,s=255,c=3,t=6,pt=0,l=1,sg=0:M
                                      2184 TSF:MSG:SEND,4-4-0-0,s=1,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=OK:
                                      2192 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=11,pt=0,l=9,sg=0,ft=0,st=OK:Yang Node
                                      2236 !TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=12,pt=0,l=4,sg=0,ft=0,st=NACK:v1.0
                                      Yang NodeReady.
                                      2243 MCO:REG:REQ
                                      2249 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=1,st=OK:2
                                      2265 TSF:MSG:READ,0-0-4,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                                      2269 MCO:PIM:NODE REG=1
                                      2272 MCO:BGN:STP
                                      2273 MCO:BGN:INIT OK,TSP=1
                                      2315 TSF:MSG:READ,0-0-4,s=255,c=3,t=6,pt=0,l=6,sg=0:Metric
                                      0_1484381990012_upload-678581ea-b243-4cea-8b4b-12fd2faf9c9b
                                      • W Werwolfx
                                        but no effect =(
                                        MYSController log
                                        Arduino serial
                                        3 TSM:INIT
                                        4 TSF:WUR:MS=0
                                        11 TSM:INIT:TSP OK
                                        14 TSF:SID:OK,ID=4
                                        16 TSM:FPAR
                                        2060 TSM:FPAR:OK
                                        2061 TSM:ID
                                        2062 TSM:ID:OK
                                        2064 TSM:UPL
                                        2088 TSM:UPL:OK
                                        Yang NodeReady.
                                        2243 MCO:REG:REQ
                                        2272 MCO:BGN:STP
                                        tekkaT
                                        tekkaT
                                        tekka
                                        @Werwolfx I don't see any MYSBootloader startup message in your log. Please re-download the .hex from the github repo to ensure you are on the most recent version and flash it following these instructions: https://www.mysensors.org/about/ota
                                        • tekkaT tekka
                                          W
                                          W
                                          Werwolfx
                                          @tekka
                                          i tryed it
                                          My little instructions for Arduino Atmega328p 5v ext
                                          1)download from https://github.com/mysensors/MySensorsBootloaderRF24
                                          2)copy to arduino folder arduino-1.8.0/hardware/arduino/avr/bootloaders/MySensors and paste boards.txt
                                          proMYSBL.name=ATmega328 16Mhz MYSBootloader
                                          proMYSBL.upload.tool=avrdude
                                          proMYSBL.upload.speed=115200
                                          proMYSBL.build.mcu=atmega328p
                                          proMYSBL.build.board=AVR_UNO
                                          proMYSBL.build.core=arduino
                                          3)In Arduino IDE select downloadex bootloader and burn it to Atmega
                                          avrdude log
                                          /home/werwolfx/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino8/bin/avrdude -C/home/werwolfx/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino8/etc/avrdude.conf -v -patmega328p -cusbasp -Pusb -e -Ulock:w:0x3F:m -Uefuse:w:0x06:m -Uhfuse:w:0xDA:m -Ulfuse:w:0xF7:m
                                          avrdude: Version 6.3, compiled on Dec 16 2016 at 12:32:01
                                                   System wide configuration file is "/home/werwolfx/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino8/etc/avrdude.conf"
                                                   User configuration file is "/home/werwolfx/.avrduderc"
                                                   Using Programmer              : usbasp
                                                   Programmer Type : usbasp
                                                   Description     : USBasp, http://www.fischl.de/usbasp/
                                          avrdude: auto set sck period (because given equals null)
                                          avrdude: warning: cannot set sck period. please check for usbasp firmware update.
                                          avrdude: erasing chip
                                          /home/werwolfx/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino8/bin/avrdude -C/home/werwolfx/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino8/etc/avrdude.conf -v -patmega328p -cusbasp -Pusb -Uflash:w:/media/werwolfx/SSDData/arduino-1.8.0/hardware/arduino/avr/bootloaders/MySensors/MYSBootloader.hex:i -Ulock:w:0x0F:m
                                          avrdude: verifying ...
                                          Writing |  ***failed;
                                          ################################################## | 100% 0.03s
                                          avrdude: WARNING: invalid value for unused bits in fuse "efuse", should be set to 1 according to datasheet
                                          This behaviour is deprecated and will result in an error in future version
                                          You probably want to use 0xfe instead of 0x06 (double check with your datasheet first).
                                          avrdude: reading input file "0xF7"
                                          avrdude: verifying lfuse memory against 0xF7:
                                          avrdude: load data lfuse data from input file 0xF7:
                                          avrdude: input file 0xF7 contains 1 bytes
                                          avrdude done.  Thank you.
                                          avrdude: reading input file "/media/werwolfx/SSDData/arduino-1.8.0/hardware/arduino/avr/bootloaders/MySensors/MYSBootloader.hex"
                                          avrdude: writing flash (32762 bytes):
                                          avrdude: 32762 bytes of flash written
                                          avrdude: verifying flash memory against /media/werwolfx/SSDData/arduino-1.8.0/hardware/arduino/avr/bootloaders/MySensors/MYSBootloader.hex:
                                          avrdude: load data flash data from input file /media/werwolfx/SSDData/arduino-1.8.0/hardware/arduino/avr/bootloaders/MySensors/MYSBootloader.hex:
                                          avrdude: input file /media/werwolfx/SSDData/arduino-1.8.0/hardware/arduino/avr/bootloaders/MySensors/MYSBootloader.hex contains 32762 bytes
                                          avrdude: 32762 bytes of flash verified
                                          avrdude: reading input file "0x0F"
                                          avrdude: verifying lock memory against 0x0F:
                                          avrdude: load data lock data from input file 0x0F:
                                          avrdude: input file 0x0F contains 1 bytes
                                          1. I loaded test sketh WaterMeterPulssensor (from Mysensors example) to arduino
                                            wait if the module is start and see to MYSController
                                            in MYSController
                                          14.01.2017 11:34:49	RX	5;6;1;0;3;0
                                          14.01.2017 11:34:52	RX	10;5;1;0;17;5519
                                          14.01.2017 11:34:52	RX	10;6;1;0;39;23.99
                                          14.01.2017 11:34:57	RX	6;3;1;0;16;0
                                          14.01.2017 11:34:58	RX	6;4;1;0;37;170
                                          14.01.2017 11:34:58	RX	6;6;1;0;3;0
                                          14.01.2017 11:34:58	RX	6;5;1;0;0;20.50
                                          14.01.2017 11:35:01	RX	4;255;0;0;17;2.1.0
                                          14.01.2017 11:35:01	DEBUG	Update child id=255, type=S_ARDUINO_NODE
                                          14.01.2017 11:35:01	RX	4;255;3;0;6;0
                                          14.01.2017 11:35:01	TX	4;255;3;0;6;M
                                          14.01.2017 11:35:02	RX	4;255;3;0;11;Water Meter
                                          14.01.2017 11:35:02	RX	4;255;3;0;12;1.1
                                          14.01.2017 11:35:02	RX	4;1;0;0;21;
                                          14.01.2017 11:35:02	DEBUG	Update child id=1, type=S_WATER
                                          14.01.2017 11:35:02	RX	4;1;2;0;24;
                                          14.01.2017 11:35:08	RX	10;5;1;0;17;5462
                                          14.01.2017 11:35:08	RX	10;6;1;0;39;23.75
                                          14.01.2017 11:35:18	RX	7;3;1;0;16;0
                                          14.01.2017 11:35:18	RX	7;4;1;0;37;192
                                          14.01.2017 11:35:18	RX	7;6;1;0;3;0
                                          14.01.2017 11:35:19	RX	5;3;1;0;16;0
                                          14.01.2017 11:35:19	RX	5;4;1;0;37;34
                                          14.01.2017 11:35:19	RX	5;6;1;0;3;0
                                          5)in MYSController Assign FW Blink and Reboot
                                          MYSController
                                          14.01.2017 11:38:03	TX	4;0;3;0;13;0
                                          14.01.2017 11:38:09	RX	4;255;0;0;17;2.1.0
                                          14.01.2017 11:38:09	CHILD	New child discovered, node id=4, child id=internal
                                          14.01.2017 11:38:09	DEBUG	Update child id=255, type=S_ARDUINO_NODE
                                          14.01.2017 11:38:09	RX	4;255;3;0;6;0
                                          14.01.2017 11:38:09	TX	4;255;3;0;6;M
                                          14.01.2017 11:38:09	RX	4;255;3;0;11;Water Meter
                                          14.01.2017 11:38:09	RX	4;255;3;0;12;1.1
                                          14.01.2017 11:38:09	RX	4;1;0;0;21;
                                          14.01.2017 11:38:09	CHILD	New child discovered, node id=4, child id=1
                                          14.01.2017 11:38:09	DEBUG	Update child id=1, type=S_WATER
                                          14.01.2017 11:38:10	RX	4;1;2;0;24;
                                          14.01.2017 11:38:14	RX	4;255;3;0;21;0
                                          Serial
                                          101794 TSF:MSG:READ,0-0-4,s=0,c=3,t=13,pt=0,l=1,sg=0:0
                                          3 TSM:INIT
                                          4 TSF:WUR:MS=0
                                          11 TSM:INIT:TSP OK
                                          13 TSM:INIT:STATID=4
                                          14 TSF:SID:OK,ID=4
                                          16 TSM:FPAR
                                          345 TSF:MSG:READ,0-0-4,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                                          350 TSF:MSG:FPAR OK,ID=0,D=1
                                          2060 TSM:FPAR:OK
                                          2061 TSM:ID
                                          2062 TSM:ID:OK
                                          2064 TSM:UPL
                                          2089 TSM:UPL:OK
                                          2098 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                                          2104 TSF:MSG:READ,0-0-4,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                          2114 TSF:MSG:SEND,4-4-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.1.0
                                          2126 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                                          2157 TSF:MSG:READ,0-0-4,s=255,c=3,t=6,pt=0,l=1,sg=0:M
                                          2164 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=11,pt=0,l=11,sg=0,ft=0,st=OK:Water Meter
                                          2176 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.1
                                          2183 TSF:MSG:SEND,4-4-0-0,s=1,c=0,t=21,pt=0,l=0,sg=0,ft=0,st=OK:
                                          2189 MCO:REG:REQ
                                          2193 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                                          2245 TSF:MSG:READ,0-0-4,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                                          2250 MCO:PIM:NODE REG=1
                                          2252 MCO:BGN:STP
                                          2255 TSF:MSG:SEND,4-4-0-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
                                          2262 MCO:BGN:INIT OK,TSP=1
                                          2335 TSF:MSG:READ,0-0-4,s=255,c=3,t=6,pt=0,l=6,sg=0:Metric
                                          2866 TSF:MSG:READ,0-0-4,s=1,c=1,t=24,pt=0,l=6,sg=0:400100
                                          Received last pulse count from gw:400100
                                          6381 TSF:MSG:READ,0-0-255,s=255,c=3,t=20,pt=0,l=0,sg=0:
                                          6386 TSF:MSG:BC
                                          6637 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=21,pt=1,l=1,sg=0,ft=0,st=OK:0```
